Текущее время: Вс авг 09, 2026 02:25
 Заголовок сообщения: No, or bad, ATMOS images.
СообщениеДобавлено: Вс фев 15, 2009 08:35
Подскажите как лечиться
DSL-504 ver A.2
NBfs3
Helium PP Boot 7.0.0.7 (C2 23 Feb 2001)
Copyright (c) 2000.
SDRAM size = 0x1000000
Flash boot failed.
Entered console ... No, or bad, ATMOS images.
Commands to the console are:
configeeprom display EEPROM configuration information
configflash display FLASH configuration information
copyimages {yes | no} copy network booted image files
flashfs {auto | emergency} use automatic FLASHFS selection or
force boot from emergency FLASHFS
initialise initialise configuration information
listenv list environment variables
mac <address> set MAC address
serialboot yes boot from EEPROM
serialboot no boot from FLASH
setenv <key> <value> set environment variable
unsetenv <key> unset environment variable
The following boot modes are supported by serial EEPROM v3.0+ only:
serialboot {yes | auto} boot via EEPROM, auto-select Ethernet or USB
serialboot ethernet boot via EEPROM from Ethernet only
serialboot usb boot via EEPROM from USB only
dw <address> [<length>] dump words (hex/ascii)
enter <address> enter an image
erw <wrdaddress> read a single word from EEPROM
eww <wrdaddress> <value> write a single word to EEPROM
fdw <address> [<length>] dump flash words (hex/ascii)
help print this text
quit leave the console
rw <address> read a single word
why reason for console entry
ww <address> <value> write a single word
