Текущее время: Чт сен 03, 2026 12:57
 Заголовок сообщения: Всё, ЁжЫк (500Т) умер???
СообщениеДобавлено: Ср янв 12, 2005 17:22
Не успел толком порадоваться, http://www.dlink.ru/phorum/viewtopic.php?t=7699 как индикатор ADSL без всяких причин вначале погас, а затем стал временами помаргивать. Связь прекратилась. С провайдером (Стрим) все в порядке - сейчас работаю на DSL-200 Ver.B.1
Jan 12 16:50:05> pppd 2.4.1 started by root, uid 0
Jan 12 16:50:21> DSL Carrier is down
Jan 12 16:50:31> DSL Carrier is training
Jan 12 16:50:51> DSL Carrier is down
Jan 12 16:51:21> DSL Carrier is training
Jan 12 16:51:31> DSL Carrier is down
Jan 12 16:51:41> DSL Carrier is training
Jan 12 16:51:46> System Call Error
Jan 12 16:51:46> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Jan 12 16:51:46> Couldn't get channel number: Transport endpoint is not connected
Jan 12 16:51:46> Doing disconnect
Jan 12 16:51:46> pppd 2.4.1 started by root, uid 0
Jan 12 16:51:51> DSL Carrier is down
Jan 12 16:52:31> DSL Carrier is training
Jan 12 16:52:41> DSL Carrier is down
Jan 12 16:52:51> DSL Carrier is training
Jan 12 16:53:01> DSL Carrier is up
Jan 12 16:53:21> DSL Carrier is training
Jan 12 16:53:26> System Call Error
Jan 12 16:53:26> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Jan 12 16:53:26> Couldn't get channel number: Transport endpoint is not connected
Jan 12 16:53:26> Doing disconnect
Jan 12 16:53:26> pppd 2.4.1 started by root, uid 0
Jan 12 16:53:31> DSL Carrier is training
Jan 12 16:53:41> DSL Carrier is down
Jan 12 16:54:01> DSL Carrier is training
Jan 12 16:54:11> DSL Carrier is up
Jan 12 16:54:31> DSL Carrier is training
Jan 12 16:54:41> DSL Carrier is down
Jan 12 16:54:51> DSL Carrier is training
Jan 12 16:55:07> System Call Error
Jan 12 16:55:07> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Jan 12 16:55:07> Couldn't get channel number: Transport endpoint is not connected
Jan 12 16:55:07> Doing disconnect
Jan 12 16:55:07> pppd 2.4.1 started by root, uid 0
Jan 12 16:55:11> DSL Carrier is up
Jan 12 16:55:21> DSL Carrier is down
Jan 12 16:55:31> DSL Carrier is training
Jan 12 16:55:41> DSL Carrier is training
Jan 12 16:55:51> DSL Carrier is training
Jan 12 16:56:21> DSL Carrier is down
Jan 12 16:56:41> DSL Carrier is training
Jan 12 16:56:47> System Call Error
Jan 12 16:56:47> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Jan 12 16:56:47> Couldn't get channel number: Transport endpoint is not connected
Jan 12 16:56:47> Doing disconnect
Jan 12 16:56:48> pppd 2.4.1 started by root, uid 0
Jan 12 16:56:51> DSL Carrier is down
Jan 12 16:57:11> DSL Carrier is up
Jan 12 16:57:21> DSL Carrier is down
Jan 12 16:57:31> DSL Carrier is training
Jan 12 16:57:37> Tag error: TAG_HOST_UNIQ
Jan 12 16:57:37> Failed to negotiate PPPoE connection: 25
Jan 12 16:57:37> System Call Error
Jan 12 16:57:41> DSL Carrier is up
Jan 12 16:57:41> pppd 2.4.1 started by root, uid 0
Jan 12 16:57:46> Tag error: TAG_HOST_UNIQ
Jan 12 16:57:46> Failed to negotiate PPPoE connection: 25
Jan 12 16:57:46> System Call Error
Jan 12 16:57:51> pppd 2.4.1 started by root, uid 0
Jan 12 16:58:01> DSL Carrier is training
Jan 12 16:58:11> DSL Carrier is down
Jan 12 16:58:21> DSL Carrier is training
Jan 12 16:58:31> DSL Carrier is down
Jan 12 16:59:32> System Call Error
Jan 12 16:59:32> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Jan 12 16:59:32> Couldn't get channel number: Transport endpoint is not connected
Jan 12 16:59:32> Doing disconnect
Jan 12 16:59:32> pppd 2.4.1 started by root, uid 0
Jan 12 17:01:12> System Call Error
Jan 12 17:01:12> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Jan 12 17:01:12> Couldn't get channel number: Transport endpoint is not connected
Jan 12 17:01:12> Doing disconnect
Jan 12 17:01:13> pppd 2.4.1 started by root, uid 0
Jan 12 17:02:53> System Call Error
Jan 12 17:02:53> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Jan 12 17:02:53> Couldn't get channel number: Transport endpoint is not connected
Jan 12 17:02:53> Doing disconnect
Jan 12 17:02:53> pppd 2.4.1 started by root, uid 0
Jan 12 17:04:33> System Call Error
Jan 12 17:04:33> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Jan 12 17:04:33> Couldn't get channel number: Transport endpoint is not connected
Jan 12 17:04:33> Doing disconnect
Jan 12 17:04:34> pppd 2.4.1 started by root, uid 0
Jan 12 17:05:51> DSL Carrier is training
Jan 12 17:06:11> DSL Carrier is down
Jan 12 17:06:14> System Call Error
Jan 12 17:06:14> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Jan 12 17:06:14> Couldn't get channel number: Transport endpoint is not connected
Jan 12 17:06:14> Doing disconnect
Jan 12 17:06:14> pppd 2.4.1 started by root, uid 0
Jan 12 17:06:31> DSL Carrier is training
Jan 12 17:06:41> DSL Carrier is down
Jan 12 17:07:11> DSL Carrier is training
Jan 12 17:07:21> DSL Carrier is down
Jan 12 17:07:51> DSL Carrier is training
Jan 12 17:07:54> System Call Error
Jan 12 17:07:54> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Jan 12 17:07:54> Couldn't get channel number: Transport endpoint is not connected
Jan 12 17:07:54> Doing disconnect
Jan 12 17:07:55> pppd 2.4.1 started by root, uid 0
Jan 12 17:08:01> DSL Carrier is up
Jan 12 17:08:11> DSL Carrier is down
Jan 12 17:08:20> pppd 2.4.1 started by root, uid 0
Jan 12 17:08:21> DSL Carrier is training
Jan 12 17:08:41> DSL Carrier is down
Jan 12 17:08:51> DSL Carrier is training
Jan 12 17:09:01> DSL Carrier is up
Jan 12 17:09:11> DSL Carrier is training
Jan 12 17:09:21> DSL Carrier is up
Jan 12 17:09:31> DSL Carrier is down
Jan 12 17:10:01> System Call Error
Jan 12 17:10:01> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Jan 12 17:10:01> Couldn't get channel number: Transport endpoint is not connected
Jan 12 17:10:01> Doing disconnect
Jan 12 17:10:01> pppd 2.4.1 started by root, uid 0
Jan 12 17:10:11> DSL Carrier is training
Jan 12 17:10:31> DSL Carrier is down
Jan 12 17:11:11> DSL Carrier is training
Jan 12 17:11:21> DSL Carrier is down
Jan 12 17:11:31> DSL Carrier is training
Jan 12 17:11:41> DSL Carrier is down
Jan 12 17:11:41> System Call Error
Jan 12 17:11:41> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Jan 12 17:11:41> Couldn't get channel number: Transport endpoint is not connected
Jan 12 17:11:41> Doing disconnect
Jan 12 17:11:41> pppd 2.4.1 started by root, uid 0
Jan 12 17:12:01> DSL Carrier is up
СообщениеДобавлено: Ср янв 12, 2005 18:25
Болезный выведен из комы путем отсоединения питания на 5 минут. Это, конечно, радует. Но если и дальше такое будет продолжаться - придется оставлять DSL-200 B.1
Sep 8 12:00:06> Valid Configuration Tree
Sep 8 12:00:11> Firewall NAT service started
Sep 8 12:00:12> Bridge Created: br0
Sep 8 12:00:12> Bridge Interface Added: eth0
Sep 8 12:00:13> pppd 2.4.1 started by root, uid 0
Sep 8 12:00:15> DSL Carrier is down
Sep 8 12:00:35> DSL Carrier is training
Sep 8 12:01:05> DSL Carrier is up
Sep 8 12:01:53> System Call Error
Sep 8 12:01:53> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Sep 8 12:01:53> Couldn't get channel number: Transport endpoint is not connected
Sep 8 12:01:53> Doing disconnect
Sep 8 12:01:53> pppd 2.4.1 started by root, uid 0
Sep 8 12:03:34> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Sep 8 12:03:34> Couldn't get channel number: Transport endpoint is not connected
Sep 8 12:03:34> Doing disconnect
Sep 8 12:03:34> System Call Error
Sep 8 12:03:39> pppd 2.4.1 started by root, uid 0
Sep 8 12:04:04> pppd 2.4.1 started by root, uid 0
Sep 8 12:04:15> Connecting PPPoE socket: 00:30:88:00:66:9e e438 nas0 0x1000d3b8
Sep 8 12:04:15> Connect: ppp0 {--} nas0
Sep 8 12:04:16> WAN IP address 83.237.34.215
Sep 8 12:04:16> WAN gateway 83.237.34.1
Sep 8 12:04:16> primary DNS address 212.188.4.10
Sep 8 12:04:16> secondary DNS address 195.34.32.116
Sep 8 12:04:16> PPPoE Connect with IP Address 83.237.34.215
Sep 8 12:04:16> PPPoE Connection Successfully Established
Sep 8 12:04:16> PPPoE Connect with Gateway IP Address: 83.237.34.1
СообщениеДобавлено: Чт янв 13, 2005 10:55
Попросите провайдера жестко задать G.dmt на DSLAM-е.
СообщениеДобавлено: Чт янв 13, 2005 12:08
Что удивительно, дозвонился до службы техподдержки за :!: 5 :!: секунд. Где мне было заявлено, что технической возможности сделать это у них нет.
Можно (наверное, даже лучше) конечно, продублировать им данную просьбу заказным письмом.
Но это 3 дня туда, некоторое время для рассмотрения и ответа и три дня обратно...
Сергей.
СообщениеДобавлено: Пт янв 14, 2005 12:25
Последнюю прошивку от DLINK за 24122004 зашей ... Может поможет.
Сейчас этот форум просматривают: Google [Bot] и гости: 34
