Текущее время: Ср сен 23, 2026 04:36
 Заголовок сообщения: Проблема подключения wifi на DSL-G604T
СообщениеДобавлено: Вс фев 01, 2009 16:00
Прошивка: V2.01B01T01.RU.20060109
Проблема следующая:
Модем запускается и нормально связывается с провайдером (status - мигает). Как только подключаю wifi (через 2-3 мин.) модем входит в ступор и лампочка status либо потухает, либо горит постоянно.
Скачал log с модема (при вкл. wifi)
Feb 1 16:07:44> Default Asymmetric MTU for wlan0 1500
Feb 1 16:07:44> AP Driver configuration successful
Feb 1 16:07:48> AP IS UP
Feb 1 16:07:48>
Feb 1 16:07:48> disabled.
Feb 1 16:07:48> 802.11h is 1137: disabled.
Feb 1 16:07:48> Configuration succeeded !!!
Feb 1 16:07:48> WLAN driver database is up
Feb 1 16:07:48> Resetting the remote device.
Feb 1 16:07:48> Un-resetting the remote device.
Feb 1 16:07:48> About to re-init the VLYNQ.
Feb 1 16:07:48> Re-initialized the VLYNQ.
Feb 1 16:07:48> AcxRegAddr = 0xA4040000, AcxMemAddr = 0xA4000000
Feb 1 16:07:48> whal_acxProcInitiate: found DEVICE_VENDOR ID = 0x9066104c
Feb 1 16:07:48> whal_acxProcInitiate: Cpu halt -} download code
Feb 1 16:07:48> whal_acxProcLoadFwImage: 0xa4000000, 0x0
Feb 1 16:07:48> whal_acxProcLoadFwImage() -- Loading FW image1137: Compiled for RADIA (bg) radio
Feb 1 16:07:48> whal_acxProcLoadFwImage: 1, pBuf=0xc00a8000, len=0x15564. Extra pBuf=0x0, len=0x3
Feb 1 16:07:48> whal_acxProcLoadFwImage: 2, pBuf=0xc00a8000, len=0x15564. Extra pBuf=0x0, len=0x3
Feb 1 16:07:48> whal_acxProcLoadFwImage: 3, pBuf=0xc00a8000, len=0x15564, DataLen=0x1555c
Feb 1 16:07:48> whal_acxProcLoadFwImage: 4, pBuf=0xc00a8000, len=0x15564
Feb 1 16:07:48> whal_acxProcLoadFwImage: Checksum, calc=0x71e76f, file=0x71e76f
Feb 1 16:07:48> BssBridge is up
Feb 1 16:07:48> Mgmt is up
Feb 1 16:07:48> Rx is up
Feb 1 16:07:48> Tx is up
Feb 1 16:07:48> MemMngr is up
Feb 1 16:07:48> main state machine is up
Feb 1 16:07:48> WDRV_MAINSM: WLAN Driver initialized successfully
Feb 1 16:07:48>
Feb 1 16:07:48> WDRV_4X: 4x Disabled
Feb 1 16:07:48> WDRV_4X: Concatenation Disabled
Feb 1 16:07:48> WDRV_4X: Ack Emulation Disabled
Feb 1 16:07:48> whal_apiStartBss: Enable Tx, Rx and Start the Bss
Feb 1 16:07:48> ----------------------------------------------------------------
Feb 1 16:07:48> START BSS, SSID=DLINK_WIRELESS, BSSID=**-**-**-**-**-**
Feb 1 16:07:48> AP Power Level = 1
Feb 1 16:07:48> Regulatory Domain = ETSI
Feb 1 16:07:48> Net[0] : Channel=6
Feb 1 16:07:48> FW Watchdog is Enabled
Feb 1 16:07:48> No Module Description from Interface Below
Feb 1 16:07:48> Bridge Interface Added: wlan0
Очень смущает строчка "Feb 1 16:07:48> No Module Description from Interface Below"!!!
P.S. проблема началась на родной прошивке.
Думал проблема в прошивке. Менял на следующие:
1. DLinkEU_DSL-G604T_V2.00B01T01.EU.20050930_upgradeB10
2. DLinkRU_DSL-G604T_ V2.01.B01T01RU.20051205
3. DSL-G604T_V2.01.B01T01RU.20060109
4. DSL-G604T_V3.02B01T01.RU.20070322
Ситуация (и log) остаются прежними! Посоветуйте, что сделать?
