Текущее время: Ср сен 23, 2026 22:51
 Заголовок сообщения: Проблемы с DSL-500Т
СообщениеДобавлено: Вт сен 09, 2008 14:12
Вообщем есть 2 роутера d-link DSL-500Т, подключение к Инфолайну
Проблема такова, настроил вроде бы все как написанно в инструкции, но инет не пашет ни в первом, ни во втором случаях(
1й роут
Firmware Version : V3.02B01T01.RU.20071212
в логе выдает вот это:
Jan 1 12:00:12> NTP Polling Timer for DHCP Started succesfully.
Jan 1 12:00:12> DSL Polling Timer Started succesfully.
Jan 1 12:00:12> Firewall NAT service started
Jan 1 12:00:13> The firmware build date/time:20071212154455
Jan 1 12:00:14> starting on port 80
Jan 1 12:00:14> Bridge Created: br0
Jan 1 12:00:15> Bridge Created: br1
Jan 1 12:00:15> Bridge Interface Added: eth0
Jan 1 12:00:22> DSL Carrier is down
Jan 1 12:00:42> DSL Carrier is up
Jan 1 12:00:42> sar read trained mode (16)(ADSL_2plus_AnxM)
Jan 1 12:00:43> pppd 2.4.3 started by root, uid 0
Jan 1 12:01:18> PPPD Successfully Launched
Jan 1 12:01:18> Timeout waiting for PADO packets
Jan 1 12:01:18> Unable to complete PPPoE Discovery
Jan 1 12:01:18> pppd 2.4.3 started by root, uid 0
Jan 1 12:01:53> PPPD Successfully Launched
Jan 1 12:01:53> Timeout waiting for PADO packets
Jan 1 12:01:53> Unable to complete PPPoE Discovery
Jan 1 12:01:53> pppd 2.4.3 started by root, uid 0
Jan 1 12:02:28> PPPD Successfully Launched
Jan 1 12:02:28> Timeout waiting for PADO packets
Jan 1 12:02:29> Unable to complete PPPoE Discovery
Jan 1 12:02:29> pppd 2.4.3 started by root, uid 0
ну и т.д...
2й роут
Firmware Version : V1.00B02T02.RU.20050223
Sep 8 12:00:06> Valid Configuration Tree
Sep 8 12:00:11> Firewall NAT service started
Sep 8 12:00:12> Bridge Created: br0
Sep 8 12:00:13> Bridge Interface Added: eth0
Sep 8 12:00:13> pppd 2.4.1 started by root, uid 0
Sep 8 12:00:15> DSL Carrier is up
Sep 8 12:01:53> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Sep 8 12:01:53> Couldn't get channel number: Transport endpoint is not connected
Sep 8 12:01:53> Doing disconnect
Sep 8 12:01:53> System Call Error
Sep 8 12:01:59> pppd 2.4.1 started by root, uid 0
Sep 8 12:03:39> System Call Error
Sep 8 12:03:39> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Sep 8 12:03:39> Couldn't get channel number: Transport endpoint is not connected
Sep 8 12:03:39> Doing disconnect
Sep 8 12:03:39> pppd 2.4.1 started by root, uid 0
Sep 8 12:05:19> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Sep 8 12:05:19> Couldn't get channel number: Transport endpoint is not connected
Sep 8 12:05:19> Doing disconnect
Sep 8 12:05:19> System Call Error
Sep 8 12:05:24> pppd 2.4.1 started by root, uid 0
Sep 8 12:07:04> System Call Error
Sep 8 12:07:04> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Sep 8 12:07:04> Couldn't get channel number: Transport endpoint is not connected
Sep 8 12:07:04> Doing disconnect
Sep 8 12:07:04> pppd 2.4.1 started by root, uid 0
Sep 8 12:08:14> Unexpected packet: Ether addr: 00:12:44:d4:50:1b (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x0026 (PADO) PPPoE tag: type=0101 length=0000 (Service name) PPPoE tag: type=0103 length=0004 (Host Uniq) data
Sep 8 12:08:15> Unexpected packet: Ether addr: 00:12:44:c2:d0:1b (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x0026 (PADO) PPPoE tag: type=0101 length=0000 (Service name) PPPoE tag: type=0103 length=0004 (Host Uniq) data
Sep 8 12:08:15> Unexpected packet: Ether addr: 00:14:f1:f7:80:1b (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x002a (PADO) PPPoE tag: type=0101 length=0000 (Service name) PPPoE tag: type=0103 length=0004 (Host Uniq) data
Sep 8 12:08:15> Unexpected packet: Ether addr: 00:15:c7:73:44:1b (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x002a (PADO) PPPoE tag: type=0101 length=0000 (Service name) PPPoE tag: type=0103 length=0004 (Host Uniq) data
Sep 8 12:08:15> Connecting PPPoE socket: 00:12:44:d4:b4:1b ee09 nas0 0x1000d3b8
Sep 8 12:08:15> Connect: ppp0 {--} nas0
Sep 8 12:08:17> WAN IP address 87.228.38.80
Sep 8 12:08:17> WAN gateway 83.217.192.144
Sep 8 12:08:17> primary DNS address 83.217.192.2
Sep 8 12:08:17> secondary DNS address 83.217.193.2
Sep 8 12:08:17> PPPoE Connect with IP Address 87.228.38.80
Sep 8 12:08:17> PPPoE Connection Successfully Established
Sep 8 12:08:17> PPPoE Connect with Gateway IP Address: 83.217.192.144
Через модем который поставили при подключении UGA-101 все работает. Так вот, подскажите пожалуйста, что не так? Почему не получается подключиться через роутер?
 Заголовок сообщения: Re: Проблемы с DSL-500Т
СообщениеДобавлено: Пт сен 12, 2008 10:59
1й роут
ну и т.д...
2й роут
Сначала логи пишут что от PPPoE-сервера нет ответа. (Это может быть связано с проблемами на стороне провайдера или с неверно указанными значениями VPI/VCI).
А вот последние строки логов показывают успешное соединение:
87.228.38.80 - это IP-адрес, который выдал Вам провайдер. 83.217.192.144 - это шлюз провайдера.
Поле Service name в настройках PPPoE-соединения оставьте пустым, если провайдер не дал других указаний.
