Текущее время: Сб окт 31, 2026 14:58
СообщениеДобавлено: Сб окт 30, 2004 00:12
Трабла похожая на много раз обсуждаемые тут, но решить ее никак не удается :((
Вот что имеем:
Status Information
System Uptime 0 hour(s) 0 minute(s)
DSL Status Connected
DSL Speed 128 Kbps Upstream,
 160 Kbps Downstream
LAN IP Address 192.168.1.1
Ethernet Connected
DHCP Server  Running
Software Version  V1.00B02T02.RU.20041006
DSL Status
  Connection Status Connected
  Upstream Rate (Kbps) 128
  Downstream Rate (Kbps) 160
  US Margin 28
  DS Margin 31
  Modulation MMODE
  LOS Errors 0
  DS Line Attenuation 37
  US Line Attenuation 41
  Path Mode Interleaved
DSL Statistics
  Near End F4 Loop Back Count 0
  Near End F5 Loop Back Count 0
Лог:
Sep  8 12:00:06> Valid Configuration Tree
Sep  8 12:00:11> Firewall NAT service started
Sep  8 12:00:12> Bridge Created: br0
Sep  8 12:00:12> Bridge Interface Added: eth0
Sep  8 12:00:13> pppd 2.4.1 started by root, uid 0
Sep  8 12:00:15> DSL Carrier is training
Sep  8 12:00:55> DSL Carrier is up
Sep  8 12:01:53> System Call Error
Sep  8 12:01:53> Connecting PPPoE socket: 00:00:00:00:00:00 0000  0x1000d3b8
Sep  8 12:01:53> Couldn't get channel number: Transport endpoint is not connected
Sep  8 12:01:53> Doing disconnect
Sep  8 12:01:53> pppd 2.4.1 started by root, uid 0
Sep  8 12:02:13> pppd 2.4.1 started by root, uid 0
Sep  8 12:03:11> pppd 2.4.1 started by root, uid 0
Sep  8 12:03:35> DSL Carrier is training
Sep  8 12:03:45> DSL Carrier is up
Sep  8 12:04:25> DSL Carrier is down
Sep  8 12:04:35> DSL Carrier is training
Sep  8 12:04:45> DSL Carrier is up
Sep  8 12:04:51> System Call Error
Sep  8 12:04:51> Connecting PPPoE socket: 00:00:00:00:00:00 0000  0x1000d3b8
Sep  8 12:04:51> Couldn't get channel number: Transport endpoint is not connected
Sep  8 12:04:51> Doing disconnect
Sep  8 12:04:51> pppd 2.4.1 started by root, uid 0
Sep  8 12:04:55> DSL Carrier is down
Sep  8 12:05:05> DSL Carrier is up
Sep  8 12:05:15> DSL Carrier is down
Перепрошил последнюю прошивку, как описано в readme, загрузил конфиг из того же архива. Все провода подключены правильно и вроде нормальные.
А коннекта как не было, так и нет.
Да, единственно - это мое первое подключение к Стриму, но на сайте в личном кабинете написано, что работы на АТС завершены и линия готова:
Статус: Заявка N: xxxxxx. Ожидание авторизации.
Ваша телефонная линия готова к подключению канала СТРИМ. Вам необходимо установить оборудование и подключиться к Интернет в течение 14 дней с момента готовности линии. [27.10.2004]
Тарифный план: СТРИМ-НЕО+
Что можно сделать чтобы заработало окромя танцев с бубном?
Спасибо!
СообщениеДобавлено: Сб окт 30, 2004 10:11
Утро вечера мудренее :)
Удалось настроить работу модема в режиме bridge, для этого пришлось отключить NAT и DNS. К сожалению, те настройки, что приведены в базе знаний применить трудно, так как никакого qiuck configuration у себя я так и не обнаружил. В общем, хорошо, что заработало :) Единственно хотелось бы настроить его работу в режиме роутера - если кто может подсказать как - был бы рад выслушать.
P.S. Вопрос вдогонку как лучше подключить пару компов к модему через свитч (любой типа D-Link <DES-1008D/E+> Fast E-net Switch 8-port (8UTP, 10/100Mbps)) или через роутер (например D-Link <DI-604> Ethernet Broadband Router 4-port (4UTP, 10/100Mbps) или SureCom <EP-4904SX> Internet Broadband Router 4port 10/100Mbps+USB Print Server (4UTP,USB))?
Спасибо!
СообщениеДобавлено: Сб окт 30, 2004 10:12
http://www.dlink.ru/phorum/viewtopic.php?t=5880
http://www.dlink.ru/phorum/viewtopic.ph ... c&start=15
http://mskvoz.ru Грузоперевозки
http://nabmos.ru Установка систем видеонаблюдения, обслуживание, модернизация.
