Текущее время: Чт сен 24, 2026 20:13
СообщениеДобавлено: Пн июн 02, 2008 13:52
Работает dsl-g804 и dsl-g604 как клиент pptp с mppe ?,
спасибо
СообщениеДобавлено: Пн июн 02, 2008 14:10
Да, оба этих устройства поддерживают MPPE шифрование при использовании PPTP клиента.
С уважением, Давыдов Денис.
 Заголовок сообщения: подскажите, где грабли?
СообщениеДобавлено: Пн июн 02, 2008 20:33
не ходит в инет при влючении pptp -
настройки -
лог
Jun 2 21:07:30> PPPoE Connection Successfully Established
Jun 2 21:07:30> PPPoE Connect with Gateway IP Address: 85.140.40.1
Jun 2 21:07:34> pppd 2.4.3 started by root, uid 0
Jun 2 21:07:34> Connect: ppp10 {--} /dev/pts/17
Jun 2 21:07:35> Connection terminated.
Jun 2 21:07:35> ppp0
Jun 2 21:07:35> closing 0.1.50.5
Jun 2 21:07:35> tn7sar_teardown_complete called for channel 0
Jun 2 21:07:35> ChannelTeardown returned rc = 0
Jun 2 21:07:38> Parameter Option Error
Jun 2 21:07:38> unrecognized option 'nas0'
Jun 2 21:07:38> Default Asymmetric MTU for nas0 1500
Jun 2 21:07:38> Registering protocol inspector: 0x94172f98 for VCC:0x9400e600
Jun 2 21:07:39> pppd 2.4.3 started by root, uid 0
Jun 2 21:07:44> Connect: ppp0 {--} nas0
Jun 2 21:07:44> peer from calling number 00:30:88:00:80:9C authorized
Jun 2 21:07:44> PPPoE Connect with IP Address 91.77.96.115
Jun 2 21:07:44> PPPoE Connection Successfully Established
Jun 2 21:07:44> PPPoE Connect with Gateway IP Address: 91.77.96.1
Jun 2 21:07:44> WAN IP address 91.77.96.115
Jun 2 21:07:44> WAN gateway 91.77.96.1
Jun 2 21:07:44> primary DNS address 195.34.32.116
Jun 2 21:07:44> secondary DNS address 212.188.4.10
Jun 2 21:07:44> ppp0
Jun 2 21:08:04> LCP: timeout sending Config-Requests
Jun 2 21:08:04> Connection terminated.
Jun 2 21:08:04> Connect: ppp10 {--} /dev/pts/17
Jun 2 21:08:04> tcflush failed: Bad file descriptor
Jun 2 21:08:09> tcsetattr: Invalid argument (line 1002)
Jun 2 21:08:14> pppd 2.4.3 started by root, uid 0
Jun 2 21:08:14> Connect: ppp10 {--} /dev/pts/11
Jun 2 21:08:44> LCP: timeout sending Config-Requests
Jun 2 21:08:44> Connection terminated.
Jun 2 21:08:44> Connect: ppp10 {--} /dev/pts/11
Jun 2 21:08:44> tcflush failed: Bad file descriptor
Jun 2 21:08:48> tcsetattr: Invalid argument (line 1002)
Jun 2 21:08:53> pppd 2.4.3 started by root, uid 0
Jun 2 21:08:53> Connect: ppp10 {--} /dev/pts/11
Jun 2 21:08:56> MPPC/MPPE 128-bit stateful compression enabled
Jun 2 21:08:57> ppp10
Jun 2 21:08:57> WAN IP address 192.168.1.3
Jun 2 21:08:57> WAN gateway 192.168.1.10
или дает так и все равноне ходит в инет...
Jan 1 12:00:49> sar read trained mode (5)(ADSL_2plus)
Jan 1 12:00:49> pppd 2.4.3 started by root, uid 0
Jan 1 12:00:50> Connect: ppp0 {--} nas0
Jan 1 12:00:50> peer from calling number 00:30:88:00:80:9C authorized
Jan 1 12:00:50> ppp0
Jan 1 12:00:50> WAN IP address 91.77.96.54
Jan 1 12:00:50> WAN gateway 91.77.96.1
Jan 1 12:00:50> primary DNS address 195.34.32.116
Jan 1 12:00:50> secondary DNS address 212.188.4.10
Jan 1 12:00:51> PPPoE Connect with IP Address 91.77.96.54
Jan 1 12:00:51> PPPoE Connection Successfully Established
Jan 1 12:00:51> PPPoE Connect with Gateway IP Address: 91.77.96.1
Jan 1 12:00:55> pppd 2.4.3 started by root, uid 0
Jan 1 12:00:55> Connect: ppp10 {--} /dev/pts/14
Jan 1 12:00:58> MPPC/MPPE 128-bit stateful compression enabled
Jan 1 12:00:59> WAN IP address 192.168.1.17
Jan 1 12:00:59> WAN gateway 192.168.1.10
Jan 1 12:00:59> ppp10
СообщениеДобавлено: Вт июн 03, 2008 11:27
Если Вам нужно использовать PPTP подключение в качестве default маршрута для выхода в Интернет, выключите опцию Default Route (disable) для PPPoE соединения. После этого сохраните настройки и перезагрузите устройство. Таким образом PPTP подключение будет работать как маршрут по умолчанию и весь трафик будет уходить в туннель.
Вообще не до конца понятна данная реализация.
Для доступа к PPTP серверу провайдера Вы сначала должны инициализировать PPPoE соединение?
Абонентом какого провайдера Вы являетесь?
Или PPTP сервер находится в удаленном офисе Вашего предприятия и Вы хотите получить доступ к локальной сети этого офиса?
Опишите задачу подробнее.
СообщениеДобавлено: Вт июн 03, 2008 13:06
Спасибо за участие.
Я клиент СТРИМ с adsl через g604v (screen выше в теме)
и еще использую pptp vpn proxy server 216.x.x.x
те траффик идет туда и оттуда в инет уже
вот работающие настройки asus'a 500 (192.168.1.1):
(он не на adsl a получает dynamic ip с маршрутизатора 192.168.0.1)
При выключении опции Default Route (disable) для PPPoE соединения:
G604 очень нравится- за 3 года завис 1 раз из--за броска по питанию, и очень хотел его настроить.
Один раз получилось - но что ставил, запомнить не успел или сбил.
Спасибо за помощь,\
Вадим
СообщениеДобавлено: Вт июн 03, 2008 15:25
Где именно находится данный сервер?
Вы уже получаете доступ в Интернет посредством PPPoE соединения со "Стримом", для чего Вам "заворачивать" трафик в PPTP туннель???
СообщениеДобавлено: Вт июн 03, 2008 19:02
не все любят и пропускают русские ip/
так как настроить?
СообщениеДобавлено: Ср июн 04, 2008 11:44
Вы не ответили на мой вопрос и не описали подробно топологию. С учетом имеющейся на данный момент информации я не в состоянии помочь Вам.
