Текущее время: Вт ноя 10, 2026 15:31
Начать новую тему Эта тема закрыта, Вы не можете редактировать и оставлять сообщения в ней.  [ Сообщений: 4 ]
 Заголовок сообщения: DSL-500T и несколько PVC
СообщениеДобавлено: Вс апр 06, 2008 11:54
В модеме созданы два интерфейса pvc0 и pvc1, и там и там PPPoE. Так же прописаны роуты на pvc1.
Firmware Version : V3.02B01T01.RU.20070402
Jan 1 12:00:12> NTP Polling Timer for DHCP Started succesfully.
Jan 1 12:00:12> DSL Polling Timer Started succesfully.
Jan 1 12:00:13> Firewall NAT service started
Jan 1 12:00:13> The firmware build date/time:20070402150429
Jan 1 12:00:15> starting on port 80
Jan 1 12:00:16> Bridge Created: br0
Jan 1 12:00:16> Bridge Created: br1
Jan 1 12:00:17> Bridge Interface Added: eth0
Jan 1 12:00:22> DSL Carrier is down
Jan 1 12:00:42> DSL Carrier is up
Jan 1 12:00:42> sar read trained mode (1)(ADSL_G.dmt)
Jan 1 12:00:42> pppd 2.4.3 started by root, uid 0
Jan 1 12:00:46> pppd 2.4.3 started by root, uid 0
Jan 1 12:00:46> Connect: ppp0 {--} nas1
Jan 1 12:00:51> Connect: ppp1 {--} nas0
Jan 1 12:01:06> peer from calling number 00:15:*:*:*:* authorized
Jan 1 12:01:06> WAN IP address 1.2.*.*
Jan 1 12:01:06> WAN gateway 194.158.202.252
Jan 1 12:01:06> primary DNS address 194.158.202.57
Jan 1 12:01:06> secondary DNS address 193.232.248.2
Jan 1 12:01:06> PPPoE Connect with IP Address 1.2.*.*
Jan 1 12:01:06> PPPoE Connection Successfully Established
Jan 1 12:01:06> PPPoE Connect with Gateway IP Address: 194.158.202.252
Jan 1 12:01:11> peer from calling number 00:15:*:*:*:* authorized
Jan 1 12:01:11> WAN IP address 93.84.*.*
Jan 1 12:01:11> PPPoE Connect with IP Address 93.84.*.*
Jan 1 12:01:11> PPPoE Connection Successfully Established
Jan 1 12:01:11> PPPoE Connect with Gateway IP Address: 194.158.202.252
Jan 1 12:01:11> WAN gateway 194.158.202.252
Jan 1 12:01:11> primary DNS address 194.158.202.57
Jan 1 12:01:11> secondary DNS address 193.232.248.2
Jan 1 12:15:15> Connection terminated.
Jan 1 12:15:18> /dev/led file could not be opened
Jan 1 12:15:18> Connection terminated.
Jan 1 12:15:24> Parameter Option Error
Jan 1 12:15:24> unrecognized option 'nas0'
Jan 1 12:15:24> pppd 2.4.3 started by root, uid 0
Jan 1 12:15:24> Connect: ppp0 {--} nas0
Jan 1 12:15:45> peer from calling number 00:15:*:*:*:* authorized
Jan 1 12:15:45> PPPoE Connect with IP Address 93.84.*.*
Jan 1 12:15:45> PPPoE Connection Successfully Established
Jan 1 12:15:45> PPPoE Connect with Gateway IP Address: 194.158.202.252
Jan 1 12:15:45> WAN IP address 93.84.*.*
Jan 1 12:15:45> WAN gateway 194.158.202.252
Jan 1 12:15:45> primary DNS address 194.158.202.57
Jan 1 12:15:45> secondary DNS address 193.232.248.2
Jan 1 12:15:55> Parameter Option Error
Jan 1 12:15:55> unrecognized option 'nas1'
Jan 1 12:15:55> pppd 2.4.3 started by root, uid 0
Jan 1 12:15:56> Connect: ppp1 {--} nas1
Jan 1 12:16:16> peer from calling number 00:15:*:*:*:* authorized
Jan 1 12:16:16> PPPoE Connect with IP Address 1.2.*.*
Jan 1 12:16:16> PPPoE Connection Successfully Established
Jan 1 12:16:16> PPPoE Connect with Gateway IP Address: 194.158.202.252
Jan 1 12:16:16> WAN IP address 1.2.*.*
Jan 1 12:16:16> WAN gateway 194.158.202.252
Jan 1 12:16:16> primary DNS address 194.158.202.57
Jan 1 12:16:16> secondary DNS address 193.232.248.2
93.84.*.* - pvc0
1.2.*.* - pvc1
1) При включении модема интерфейсы поднимаются как себе захотят: может первым подключиться pvc0, а следом за ним pvc1, может наоборот. Из логов видно, что в данном случае поднялся первым pvc1, что не есть хорошо. Приходится заходить через веб интерфейс и переподключать ручками в правильном порядке.
Как заставить модем поднимать первым pvc0?
2) Если pvc1 поднимется первым, а потом pvc0, то почему-то абсолютно всё ходит только через pvc1 независимо от роутов (в модеме на него прописано пару роутов). Как сделать, чтобы всё работало независимо от очередности pvc?
СообщениеДобавлено: Пт апр 11, 2008 23:36
Эх... :cry:
СообщениеДобавлено: Вт апр 15, 2008 16:17
Какой из PPP интерфейсов является маршрутом по умолчанию?
Для этого в настройках каждого PVC есть опция Default Route enable/disable.
С уважением, Давыдов Денис.
СообщениеДобавлено: Чт апр 17, 2008 21:55
Оба. Поставил 0 - enable, 1 - disable. Всё наладилось:)
Сейчас этот форум просматривают: Baidu [Spider] и гости: 12
