Текущее время: Сб окт 10, 2026 11:51
 Заголовок сообщения: PPTP в G604T
СообщениеДобавлено: Чт апр 03, 2008 14:11
При попытке установить связь на D-Link DSL-G64T с провайдером через PPTP протокол, интерфейс PPP поднимается, однако связь с вышестоящим маршрутизатором отсутствует. В логах следующее:
Jan 1 12:01:53> pppd 2.4.3 started by root, uid 0
Jan 1 12:01:53> Connect: ppp10 {--} /dev/pts/15
Jan 1 12:01:57> MPPE 128-bit stateful compression enabled
Jan 1 12:01:57> WAN IP address 85.114.185.155
Jan 1 12:01:57> WAN gateway 81.28.174.1
Jan 1 12:01:57> ppp10
Jan 1 12:02:31> Protocol-Reject for unsupported protocol 0x4d
Jan 1 12:02:32> Protocol-Reject for unsupported protocol 0x5c43
Jan 1 12:02:33> Protocol-Reject for unsupported protocol 0xe7
Jan 1 12:02:34> Protocol-Reject for unsupported protocol 0xf28a
Jan 1 12:02:35> Protocol-Reject for unsupported protocol 0xd082
anon log[main:pptp.c:279]: The synchronous pptp option is NOT activated
anon log[callmgr_name_unixsock:pptp_callmgr.c:404]: callmgr_unixsock:/var/run/pptp/255.255.255.255:192.168.0.1
anon log[callmgr_main:pptp_callmgr.c:164]: call pptp_conn_open()!
anon log[ctrlp_rep:pptp_ctrl.c:251]: Sent control packet type is 1 'Start-Control-Connection-Request'
anon log[ctrlp_disp:pptp_ctrl.c:735]: Received Start Control Connection Replyanon log[ctrlp_disp:pptp_ctrl.c:769]: Client connection established.anon log[ctrlp_rep:pptp_ctrl.c:251]: Sent control packet type is 7 'Outgoing-Call-Request'
anon log[ctrlp_disp:pptp_ctrl.c:852]: Received Outgoing Call Reply.anon log[ctrlp_disp:pptp_ctrl.c:887]: call pptp_set_link() to send set link info packageanon log[ctrlp_rep:pptp_ctrl.c:251]: Sent control packet type is 15 'Set-Link-Info'
anon log[pptp_set_link:pptp_ctrl.c:998]: success send set link infoanon log[ctrlp_disp:pptp_ctrl.c:892]: Outgoing call established (call ID 0, peer's call ID 12584).
anon log[logecho:pptp_ctrl.c:674]: Echo Reply received.anon log[logecho:pptp_ctrl.c:674]: Echo Request received.anon log[ctrlp_rep:pptp_ctrl.c:251]: Sent control packet type is 6 'Echo-Reply'
anon log[logecho:pptp_ctrl.c:674]: Echo Request received.anon log[ctrlp_rep:pptp_ctrl#
В чём может быть причина такого поведения?
СообщениеДобавлено: Пт апр 04, 2008 10:12
Причину проблемы нашёл - провайдер использует stateless MPPE 128 compression, а соединение устанавливается stateful. В Linux это решается просто - добавляются параметры nomppe-128 и mppe-stateless в options.pptp, однако в DSL-G604T каким образом создается PPTP соединение и где находятся конфигурационные параметры я не нашёл. Каким образом можно добавить/изменить опции при запуске pppd?
СообщениеДобавлено: Пт апр 04, 2008 10:20
Данное устройство не поддерживает MPPE.
СообщениеДобавлено: Пт апр 04, 2008 15:42
Да? Строка в логе и конфигурационные параметры почему-то говорят об обратном:
Если бы pppd был собран без поддержки MPPE, то соединение бы и не устанавливалось вовсе. Да и при конфигурации PPTP-клиента есть опции, отвечающие за mppe, только вот stateful в них нет:
mppe required
mppe no40
mppe no56
mppe no128
А тут необходимо всего лишь добавить одну опцию в строчку запуска pppd, которой нет в выпадающем списке (должно быть mppe required,stateless), вот только как это сделать? Ведь это ограничения лишь веб-интерфейса, я так понимаю?
Прошивка DLinkRU_DSL-G604T_V3.02B01T01.RU.20071228
Если бы были исходные тексты этой прошивки со встроенным pptp-клиентом, можно было бы самому добвить данный пункт меню в прошивку...
СообщениеДобавлено: Пн апр 07, 2008 11:48
Заявление о том, что D-Link DSL-G604T не поддерживает mschap-v2 и MPPE неверно. Устройство работает именно на таких протоколах.
http://forums.avtograd.ru/index.php?showtopic=29031
