Текущее время: Ср окт 14, 2026 16:38
СообщениеДобавлено: Пн мар 24, 2008 21:38
Такое ощущение что и я уже дурак, и вся поддержка со всеми инжененрами стрим - тоже... Помогите. Модем ни в какую не хочет видеть и логиниться на ppp сервер. Никто не понимает в чем дело.
Заранее спасибо.
Date/Time Facility Severity Message
Jan 1 00:00:11 user info kernel: TCP: Hash tables configured (established 512 bind 1024)
Jan 1 00:00:11 user info kernel: NET: Registered protocol family 1
Jan 1 00:00:11 user info kernel: NET: Registered protocol family 17
Jan 1 00:00:11 user notice kernel: Ebtables v2.0 registered
Jan 1 00:00:11 user info kernel: NET: Registered protocol family 8
Jan 1 00:00:11 user info kernel: NET: Registered protocol family 20
Jan 1 00:00:11 user info kernel: 802.1Q VLAN Support v1.8 Ben Greear
Jan 1 00:00:11 user info kernel: All bugs added by David S. Miller
Jan 1 00:00:11 user warn kernel: VFS: Mounted root (squashfs filesystem) readonly.
Jan 1 00:00:11 user info kernel: Freeing unused kernel memory: 64k freed
Jan 1 00:00:11 user warn kernel: Algorithmics/MIPS FPU Emulator v1.5
Jan 1 00:00:11 user warn kernel: atmapi: module license 'Proprietary' taints kernel.
Jan 1 00:00:11 user warn kernel: blaadd: blaa_detect entry
Jan 1 00:00:11 user warn kernel: adsl: adsl_init entry
Jan 1 00:00:11 user info kernel: Broadcom BCMPROCFS v1.0 initialized
Jan 1 00:00:11 user warn kernel: Broadcom BCM6338A2 Ethernet Network Device v0.3
Jan 1 00:00:11 user warn kernel: Config Ethernet Switch Through SPI Slave Select 0
Jan 1 00:00:11 user warn kernel: dgasp: kerSysRegisterDyingGaspHandler: eth0 registered
Jan 1 00:00:11 user warn kernel: eth0: MAC Address: 00:1B:11:76:93:2B
Jan 1 00:00:11 user warn kernel: BcmAdsl_Initialize=0xC00673B8, g_pFnNotifyCallback=0xC007E4E4
Jan 1 00:00:11 user warn kernel: pSdramPHY=0xA07FFFF8, 0xBB63E 0xDEADBEEF
Jan 1 00:00:11 user crit kernel: eth0 Link UP.
Jan 1 00:00:11 user warn kernel: AdslCoreHwReset: AdslOemDataAddr = 0xA07FA744
Jan 1 00:00:11 user warn kernel: dgasp: kerSysRegisterDyingGaspHandler: dsl0 registered
Jan 1 00:00:11 user warn kernel: ip_tables: (C) 2000-2002 Netfilter core team
Jan 1 00:00:11 user warn kernel: ip_conntrack version 2.1 (61 buckets, 0 max) - 368 bytes per conntrack
Jan 1 00:00:11 user warn kernel: ip_conntrack_pptp version 2.1 loaded
Jan 1 00:00:11 user warn kernel: ip_nat_pptp version 2.0 loaded
Jan 1 00:00:11 user warn kernel: ip_conntrack_h323: init
Jan 1 00:00:11 user warn kernel: ip_nat_h323: initialize the module!
Jan 1 00:00:11 user crit kernel: ADSL G.994 training
Jan 1 00:00:11 user info kernel: device eth0 entered promiscuous mode
Jan 1 00:00:11 user info kernel: br0: port 1(eth0) entering learning state
Jan 1 00:00:11 user info kernel: br0: topology change detected, propagating
Jan 1 00:00:11 user info kernel: br0: port 1(eth0) entering forwarding state
Jan 1 00:00:11 user crit kernel: ADSL G.992 started
Jan 1 00:00:11 user info kernel: device nas_1_50 entered promiscuous mode
Jan 1 00:00:11 user info kernel: br0: port 2(nas_1_50) entering learning state
Jan 1 00:00:11 user info kernel: br0: port 2(nas_1_50) entering forwarding state
Jan 1 00:00:11 user debug syslog: tftpd
Jan 1 00:00:12 user debug syslog: pppd
Jan 1 00:00:12 user debug syslog: ifconfig nas_1_50 mtu 1492
Jan 1 00:00:12 daemon notice pppd[264]: pppd 2.4.1 started by admin, uid 0
Jan 1 00:00:13 user crit kernel: ADSL G.992 channel analysis
Jan 1 00:00:17 user crit kernel: ADSL G.992 message exchange
Jan 1 00:00:17 user crit kernel: ADSL link up, interleaved, us=768, ds=6144
Jan 1 00:00:17 user warn kernel: ATM Soft SAR: ATM link connected.
Jan 1 00:00:18 user debug syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107
Jan 1 00:00:19 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:00:33 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:00:47 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:01:01 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:01:15 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:01:29 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:01:43 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:01:57 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:02:11 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:02:25 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:02:39 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:02:53 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:03:07 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:03:21 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:03:35 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:03:49 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:04:03 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:04:17 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:04:31 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:04:33 user debug igmp[809]: iptables -t filter -I FORWARD 1 -i br0 -d 239.255.255.250 -j DROP 2>/dev/null
Jan 1 00:04:33 user debug igmp[811]: iptables -t filter -D FORWARD -i br0 -d 239.255.255.250 -j ACCEPT 2>/dev/null
Jan 1 00:04:45 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:04:46 user debug igmp[833]: iptables -t filter -I FORWARD 1 -i br0 -d 224.0.0.22 -j DROP 2>/dev/null
Jan 1 00:04:47 user debug igmp[835]: iptables -t filter -D FORWARD -i br0 -d 224.0.0.22 -j ACCEPT 2>/dev/null
Jan 1 00:04:59 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:05:13 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:05:27 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:05:41 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:05:55 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:06:09 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:06:23 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:06:37 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:06:51 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:07:05 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:07:19 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:07:33 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:07:47 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:08:01 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:08:15 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:08:29 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:08:43 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:08:57 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:09:11 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:09:25 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:09:40 daemon notice pppd[264]: PPP: Start to connect ...
Jan 1 00:09:54 daemon notice pppd[264]: PPP: Start to connect ...
Последний раз редактировалось sciwolf Чт мар 27, 2008 11:43, всего редактировалось 1 раз.
СообщениеДобавлено: Пн мар 24, 2008 23:25
Неужели даже сами производители не могут дать ответ? :D Надеюсь, это не так...
СообщениеДобавлено: Вт мар 25, 2008 02:36
собственно модем и не видет ppp сервер
ибо в логе нету сообщения что он найден
делай модем в бридже и пробуй поднять ppp из под винды
если прокатет значет криво настроел модем под ppp
СообщениеДобавлено: Вт мар 25, 2008 15:29
Из под винды все работает. НО! Есть еще 2 модема =) Оба работают у друзей дома, у меня - нет. Более того, мой модем отлично работает у них, но не работает у меня...
Стрим и МГТС и вообще всех я уже достал так, что они не рады, что я их абонент :lol: . Даже не знаю, что делать... ppp не видит по прежнему... идут третьи сутки...
СообщениеДобавлено: Вт мар 25, 2008 18:08
Укажите версию прошивки Вашего модема.
СообщениеДобавлено: Ср мар 26, 2008 12:18
Ну, начнем с того, что пошли 4-е сутки... Теперь у меня 2 модема... 2540u и 2500u по настоянию стрима... подумываю всерьез подать на них в суд за несоблюдение условий контракта.
Теперь по модемам и прошивкам...
2540u сейчас стоит не у меня, я прошивал ему все 4 версии прошивок. Сейчас на нем последняя официальная версия прошивки. V.3-06-04-3B00
2500u как с завода была прошивка, так и есть. Версии V.3-06-04-0Z00.
Спасибо за желание помочь...
Стоит отметить что все 4 модема которые на данный момент были у меня дома (не только компании D-link), не видят ppp сервера провайдера... Также стоит отметить что все они отлично работают во всех режимах у моего соседа по slam'у ;)... иными словами мистика...
p.s. Люди, если у вас есть возможность не подключать стрим или даже просто adsl - не подключайте =).
СообщениеДобавлено: Ср мар 26, 2008 12:48
Узнай у телефонной компании стоит ли у тебя на линии уплотнитель или сигнализация.
Подключи модем через сплитер как положено к сети, потом зайди на модем Status>ADSL перепиши сюда то что в (ADSL Statistics).
И вообще лампочка ADSL у тя горит на модеме?
А насчет суда, если при проверке выяснится что проблема была с твое стороны (раз в бридже у тя пашет ппп) провайдер подаст на тебя встречный иск и будешь выплачивать неустойку и издержки.
СообщениеДобавлено: Ср мар 26, 2008 12:53
С синхронизацией с DSLAM порядок. Об этом свидетельствует запись в логе:
Остается разбираться с провайдером.
СообщениеДобавлено: Ср мар 26, 2008 17:47
Провайдеру срать... к сожалению. Просто поставил ZTE 510... все работает... уроды просто, вот и все. Жаль нет возможности от них отключиться... Крайне странно все это...
Причиной в отказе стало то, что они официально не поддерживают марку d-link... козлы... просто нет слов. Но почему ZTE конектит а d-link 2540u/2500u - нет?.. Инженер который привез ZTE сказал, что он все понимает, что проблема на стороне провайдера и все такое, но доказать им, что проблема у них - невозможно.
По поводу суда - да. Эти с**и защитились как могли от всего. Официально им пофиг что у меня не работает режим роутера. Все. Точка.
СообщениеДобавлено: Ср мар 26, 2008 18:08
Ну я не дурачок =) 4 месяца все работало как часы, потом упала adsl, заменили slam, после этого коннекта к ppp ни от какой модели d-link НА МОЕМ ТЕЛЕФОННОМ номере - нет. У остальных все в порядке. Отсюда вывод, неисправность есть, она им известна, но чтобы ее устранить, придется ради одного абонента совершать много телодвижений. Куда проще заставить его купить другой модем... с**и и все... как только перееду сразу откажусь от стрима... Там, где живу сейчас, альтернативы просто нет.
СообщениеДобавлено: Чт мар 27, 2008 10:02
Скорее всего провайдер не видит или блокирует МАС модема. имхо. В винде тоже такое бывает - заходишь в настройки сетевой и ручками прописываешь тот же самый который показывает комп, но меняешь последние 2 цифиры и всё работает. Иногда вообще с сетевой другого производителя срисовываешь мас и тоже все работает. МАС может блокироваться как на уровне DSLAM, так возможно и на самом PPoE сервере. Так же предполагаю могут быть проблемы если на одной планке DSLAM есть устройства с одинаковыми MAC. Честно говоря так сразу и не скажу как на самом модеме сменить МАС, но сделать это можно. Навряд ли он меняется при перепрошивке модема.
СообщениеДобавлено: Чт мар 27, 2008 11:35
У меня 2 устройства d-link ;). У них разные mac-адреса.
Устройства d-link в квартире работают теперь нормально...
Вердикт: Стрим - ГАВНИЩЕ. Поддержка и квалификация тех-поддержки на НУЛЕ. Ничего им нельзя доказать потому что ОБЕЗЬЯНЫ и просто следуют инструкциям... В итоге на ppp сервере просто сами штатно по расписанию обнулились мои mac-адреса, и я снова сижу с d-link'ом... Для этого им достаточно было мне сказать, чтобы я вынул модем из сети на полные сутки (я уж не говорю о том, что они могли вручную обнулить блоки маков на самом ppp-сервере, но не смогли (не захотели) ибо обезьяны!!!)... Твари крови выпили столько... и заставили купить галимый zte.... и даже отыграться не знаю теперь как...
СообщениеДобавлено: Чт мар 27, 2008 12:08
to sciwolf:
zte - глупый, но очень надёжный модем. Особенно неплохие у них были первые модельки 831 серии. А 831 (II) временами попадаются неисправные - то линк не встает, то по сети не видятся.
А можно поинтересоваться какой фирмы DSLAM у вашего провайдера?
СообщениеДобавлено: Чт мар 27, 2008 12:10
Говорят конфиденциальная информация. Но УСПД МГТС сказали что самые разные =).
СообщениеДобавлено: Чт мар 27, 2008 12:13
я имел в виду, что при некоторых условиях появлется bridge между портами уже самого DSLAM на одной плате. :) Есть там такая фича. которая это перекрывает, но провайдеры наверное её не включают (ну может не все). :) Так сказать недокументированная функция. :wink:
