Текущее время: Вт ноя 10, 2026 17:31
 Заголовок сообщения: DSL-2500U пропадает сигнал
СообщениеДобавлено: Сб мар 22, 2008 17:26
Постоянно теряется сигнал dsl, лампочка dsl моргает, а в статусе device info теряется адрес шлюза а в wan info пишет что adsl link down, посдкажите куда копать?
Вот логи
Jan 1 00:02:59 user crit kernel: eth0 Link UP.
Jan 1 00:02:59 user crit kernel: ADSL G.992 started
Jan 1 00:02:59 user crit kernel: ADSL G.992 channel analysis
Jan 1 00:02:59 user crit kernel: ADSL link up, fast, us=640, ds=1024
Jan 1 00:02:59 user alert kernel: Intrusion -> IN=ppp_0_40_1 OUT= MAC= SRC=195.5.116.234 DST=89.218.135.134 LEN=48 TOS=0x00 PREC=0x00 TTL=117 ID=17390 PROTO=TCP SPT=55475 DPT=1080 WINDOW=65535 RES=0x00 SYN URGP=0
Jan 1 00:02:59 user crit kernel: ADSL link down
Jan 1 00:03:02 user crit kernel: ADSL G.992 message exchange
Jan 1 00:03:02 user crit kernel: ADSL link up, fast, us=640, ds=1024
Jan 1 00:03:04 daemon crit pppd[259]: PPP server detected.
Jan 1 00:03:04 daemon crit pppd[259]: PPP session established.
Jan 1 00:03:04 daemon crit pppd[259]: PPP LCP UP.
Jan 1 00:03:04 daemon crit pppd[259]: Received valid IP address from server. Connection UP.
Jan 1 00:03:46 user alert kernel: Intrusion -> IN=ppp_0_40_1 OUT= MAC= SRC=89.218.32.230 DST=89.218.139.67 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=32547 DF PROTO=TCP SPT=4112 DPT=1433 WINDOW=65535 RES=0x00 SYN URGP=0
Jan 1 00:03:49 user alert kernel: Intrusion -> IN=ppp_0_40_1 OUT= MAC= SRC=89.218.32.230 DST=89.218.139.67 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=33074 DF PROTO=TCP SPT=4112 DPT=1433 WINDOW=65535 RES=0x00 SYN URGP=0
Jan 1 00:06:43 user alert kernel: Intrusion -> IN=ppp_0_40_1 OUT= MAC= SRC=89.218.187.50 DST=89.218.139.67 LEN=48 TOS=0x00 PREC=0x00 TTL=122 ID=37411 DF PROTO=TCP SPT=3359 DPT=1433 WINDOW=65535 RES=0x00 SYN URGP=0
Jan 1 00:06:46 user alert kernel: Intrusion -> IN=ppp_0_40_1 OUT= MAC= SRC=89.218.187.50 DST=89.218.139.67 LEN=48 TOS=0x00 PREC=0x00 TTL=122 ID=38290 DF PROTO=TCP SPT=3359 DPT=1433 WINDOW=65535 RES=0x00 SYN URGP=0
СообщениеДобавлено: Сб мар 22, 2008 17:52
Страницу Status\Adsl покажите пожалуйста.
При потере физлинка, как вы описываете, скорее всего либо линия не впорядке, либо порты на АТС плохо изолированы.
 Заголовок сообщения: Status ADSL
СообщениеДобавлено: Сб мар 22, 2008 19:57
Status ADSL
Mode: T1.413
Type: Fast
Line Coding: Trellis On
Status: No Defect
Link Power State: L0
Downstream Upstream
SNR Margin (dB): 24.7 18.0
Attenuation (dB): 12.0 8.0
Output Power (dBm): 17.4 12.1
Attainable Rate (Kbps): 4832 1100
Rate (Kbps): 1024 640
K (number of bytes in DMT frame): 33 21
R (number of check bytes in RS code word): 0 0
S (RS code word size in DMT frame): 1 1
D (interleaver depth): 0 0
Delay (msec): 0 0
Super Frames: 522621 522619
Super Frame Errors: 0 0
RS Words: 0 0
RS Correctable Errors: 0 0
RS Uncorrectable Errors: 0 N/A
HEC Errors: 0 0
OCD Errors: 0 0
LCD Errors: 0 0
Total Cells: 21457120 0
Data Cells: 16762 0
Bit Errors: 0 0
Total ES: 3 0
Total SES: 2 0
Total UAS: 20 0
СообщениеДобавлено: Вс мар 23, 2008 20:34
Параметры линии неплохие. У меня хуже, а работает. Беспокойте провайдера - пусть свою сторону внимательно посмотрят, может профиль поменяют.
