Текущее время: Сб сен 26, 2026 19:01
 Заголовок сообщения: 2540U bad csum
СообщениеДобавлено: Пт фев 15, 2008 16:56
Прихожу с работы инет лежит весь лог забит этим
Jan 4 01:43:09 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 01:43:10 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 01:43:11 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 01:43:14 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 01:43:15 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 01:43:17 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 01:43:18 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 01:43:19 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 01:43:20 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 01:43:22 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 01:43:27 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 01:43:28 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 01:43:29 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 01:43:36 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 01:43:37 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 01:43:38 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 02:04:46 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 02:04:47 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 02:04:48 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 02:04:50 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 02:04:51 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 02:04:52 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 02:04:53 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 02:04:54 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 02:04:55 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 02:04:56 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 02:04:57 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 02:04:58 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 02:04:59 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 02:05:00 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 02:05:01 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 02:05:02 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 02:05:03 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 02:05:04 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 02:05:05 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 02:05:06 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 02:05:07 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 02:05:08 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 02:05:09 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 02:05:10 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 02:05:11 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 02:05:12 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 02:05:13 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 02:05:14 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Jan 4 02:05:15 user notice kernel: net/ipv4/netfilter/ip_conntrack_pptp.c: bad csum
Пустил в ребут, после него вроде все норма заработало.
СообщениеДобавлено: Пт фев 15, 2008 17:02
5 минут после ребута снова весь лог в этом сообщении
никаких настроек не менял модем пахал дней 5 подряд все ок было
ппц...
СообщениеДобавлено: Пт фев 15, 2008 17:57
Версия прошивки на модеме?
Какой тип подключения ?
PPTP соединения с модема или из-за него с PC не устнавливалось ?
С уважением, Гакало Алексей
СообщениеДобавлено: Пт фев 15, 2008 18:03
Board ID: D-4P
Software Version: RU_DSL-2540U_3-06-04-3B00.A2pB023g2.d19b
Bootloader (CFE) Version: 1.0.37-6.5
PPP over Ethernet (PPPoE)
PPTP в модеме (подключение весит инет просто пропадает, ребут помогает но ненадолго).
После любова ребута через пару минут лог постоянно забевается этим сообщением. Перешол в краш режим на всякий случай залил прошивку занаво, все занаво настроил также как и было пока все пашет проблемы нет. Собственно она и появилась внезавно.
СообщениеДобавлено: Сб фев 16, 2008 12:47
Даже после перепрошивки пару раз проскочила эта ерунда, но уже не так масштабно.
СообщениеДобавлено: Пт мар 14, 2008 15:33
В логе проскачило это
user err kernel: ipt_tcpmss_target: bad length (40 bytes)
