Текущее время: Вс сен 27, 2026 05:26
 Заголовок сообщения: PPtP on 2500/BRU
СообщениеДобавлено: Пн фев 04, 2008 18:57
Software Version: RU_DSL-2500U_1.00_11162007
Создаю pptp-коннект, пытаюсь подключится.
Вижу в логах со стороны сервера (линуксовый pptpd с radius-плугином):
Feb  4 16:50:15 rt-one pppd[7642]: Plugin radius.so loaded.
Feb  4 16:50:15 rt-one pppd[7642]: RADIUS plugin initialized.
Feb  4 16:50:15 rt-one pppd[7642]: Plugin /usr/lib/pptpd/pptpd-logwtmp.so loaded.
Feb  4 16:50:15 rt-one pppd[7642]: pptpd-logwtmp: $Version$
Feb  4 16:50:15 rt-one pppd[7642]: pppd 2.4.4 started by root, uid 0
Feb  4 16:50:15 rt-one pppd[7642]: using channel 21974
Feb  4 16:50:15 rt-one pppd[7642]: Using interface ppp4
Feb  4 16:50:15 rt-one pppd[7642]: Connect: ppp4 <--> /dev/pts/5
Feb  4 16:50:15 rt-one pppd[7642]: sent [LCP ConfReq id=0x1 <asyncmap 0x0> <auth chap MD5> <magic 0x60cdbd> <pcomp
Feb  4 16:50:16 rt-one pppd[7642]: rcvd [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0x853ccf24> <pcomp> <accomp>]
Feb  4 16:50:16 rt-one pppd[7642]: sent [LCP ConfAck id=0x1 <asyncmap 0x0> <magic 0x853ccf24> <pcomp> <accomp>]
Feb  4 16:50:16 rt-one pppd[7642]: rcvd [LCP ConfAck id=0x1 <asyncmap 0x0> <auth chap MD5> <magic 0x60cdbd> <pcomp
Feb  4 16:50:16 rt-one pppd[7642]: sent [LCP EchoReq id=0x0 magic=0x60cdbd]
Feb  4 16:50:16 rt-one pppd[7642]: sent [CHAP Challenge id=0xfb <b74429d839d7687bf3521ba7c69f051ec8fe>, name = "pp
Feb  4 16:50:16 rt-one pppd[7642]: rcvd [LCP EchoRep id=0x0 magic=0x853ccf24]
Feb  4 16:50:16 rt-one pppd[7642]: rcvd [CHAP Response id=0xfb <7e44d0f7b630d9940178568a71b8f873>, name = "iga"]
Feb  4 16:50:16 rt-one pppd[7642]: rc_avpair_gen: received unknown attribute 85 of length 4: 0x0000003C
Feb  4 16:50:16 rt-one pppd[7642]: sent [CHAP Success id=0xfb ""]
Feb  4 16:50:16 rt-one pppd[7642]: sent [CCP ConfReq id=0x1 <deflate 15> <deflate(old#) 15>]
Feb  4 16:50:16 rt-one pppd[7642]: sent [IPCP ConfReq id=0x1 <compress VJ 0f 01> <addr 192.168.0.5>]
Feb  4 16:50:16 rt-one pppd[7642]: rcvd [CCP ConfReq id=0x1 <mppe -H -M -S -L -D +C> <bsd v1 15>]
Feb  4 16:50:16 rt-one pppd[7642]: sent [CCP ConfRej id=0x1 <mppe -H -M -S -L -D +C> <bsd v1 15>]
Feb  4 16:50:16 rt-one pppd[7642]: rcvd [IPCP ConfReq id=0x1 <compress VJ 0f 01> <addr 0.0.0.0>]
Feb  4 16:50:16 rt-one pppd[7642]: sent [IPCP ConfNak id=0x1 <addr 10.100.1.254>]
Feb  4 16:50:16 rt-one pppd[7642]: rcvd [CCP ConfAck id=0x1 <deflate 15> <deflate(old#) 15>]
Feb  4 16:50:16 rt-one pppd[7642]: rcvd [IPCP ConfAck id=0x1 <compress VJ 0f 01> <addr 192.168.0.5>]
Feb  4 16:50:16 rt-one pppd[7642]: rcvd [CCP ConfReq id=0x2]
Feb  4 16:50:16 rt-one pppd[7642]: sent [CCP ConfAck id=0x2]
Feb  4 16:50:16 rt-one pppd[7642]: Deflate (15) receive compression enabled
Feb  4 16:50:16 rt-one pppd[7642]: rcvd [IPCP ConfReq id=0x2 <compress VJ 0f 01> <addr 10.100.1.254>]
Feb  4 16:50:16 rt-one pppd[7642]: sent [IPCP ConfAck id=0x2 <compress VJ 0f 01> <addr 10.100.1.254>]
Feb  4 16:50:16 rt-one pppd[7642]: Cannot determine ethernet address for proxy ARP
Feb  4 16:50:16 rt-one pppd[7642]: local  IP address 192.168.0.5
Feb  4 16:50:16 rt-one pppd[7642]: remote IP address 10.100.1.254
Feb  4 16:50:16 rt-one pppd[7642]: pptpd-logwtmp.so ip-up ppp4 iga 192.168.64.185
Feb  4 16:50:16 rt-one pppd[7642]: Script /etc/ppp/ip-up started (pid 7647)
Feb  4 16:50:16 rt-one pppd[7642]: Script /etc/ppp/ip-up finished (pid 7647), status = 0x0
Feb  4 16:50:21 rt-one pppd[7642]: rcvd [CCP ConfReq id=0x2]
Feb  4 16:50:21 rt-one pppd[7642]: sent [CCP ConfReq id=0x2 <deflate 15> <deflate(old#) 15>]
Feb  4 16:50:21 rt-one pppd[7642]: sent [CCP ConfAck id=0x2]
Feb  4 16:50:21 rt-one pppd[7642]: rcvd [CCP ConfAck id=0x2 <deflate 15> <deflate(old#) 15>]
Feb  4 16:50:21 rt-one pppd[7642]: Deflate (15) receive compression enabled
Feb  4 16:50:23 rt-one pppd[7642]: rcvd [CCP ConfReq id=0x2]
Feb  4 16:50:23 rt-one pppd[7642]: sent [CCP ConfReq id=0x3 <deflate 15> <deflate(old#) 15>]
Feb  4 16:50:23 rt-one pppd[7642]: sent [CCP ConfAck id=0x2]
Feb  4 16:50:23 rt-one pppd[7642]: rcvd [CCP ConfAck id=0x3 <deflate 15> <deflate(old#) 15>]
Feb  4 16:50:23 rt-one pppd[7642]: Deflate (15) receive compression enabled
Feb  4 16:50:27 rt-one pppd[7642]: rcvd [CCP ConfReq id=0x2]
Feb  4 16:50:27 rt-one pppd[7642]: sent [CCP ConfReq id=0x4 <deflate 15> <deflate(old#) 15>]
Feb  4 16:50:27 rt-one pppd[7642]: sent [CCP ConfAck id=0x2]
Feb  4 16:50:27 rt-one pppd[7642]: rcvd [CCP ConfAck id=0x4 <deflate 15> <deflate(old#) 15>]
Feb  4 16:50:27 rt-one pppd[7642]: Deflate (15) receive compression enabled
Feb  4 16:50:30 rt-one pppd[7642]: Deflate (15) receive compression enabled
Feb  4 16:50:33 rt-one pppd[7642]: rcvd [CCP ConfReq id=0x2]
Feb  4 16:50:33 rt-one pppd[7642]: sent [CCP ConfReq id=0x6 <deflate 15> <deflate(old#) 15>]
Feb  4 16:50:33 rt-one pppd[7642]: sent [CCP ConfAck id=0x2]
Feb  4 16:50:33 rt-one pppd[7642]: rcvd [CCP ConfAck id=0x6 <deflate 15> <deflate(old#) 15>]
Feb  4 16:50:33 rt-one pppd[7642]: Deflate (15) receive compression enabled
Feb  4 16:50:37 rt-one pppd[7642]: rcvd [CCP ConfReq id=0x2]
Feb  4 16:50:37 rt-one pppd[7642]: sent [CCP ConfReq id=0x7 <deflate 15> <deflate(old#) 15>]
Feb  4 16:50:37 rt-one pppd[7642]: sent [CCP ConfAck id=0x2]
Feb  4 16:50:38 rt-one pppd[7642]: rcvd [CCP ConfAck id=0x7 <deflate 15> <deflate(old#) 15>]
Feb  4 16:50:38 rt-one pppd[7642]: Deflate (15) receive compression enabled
Feb  4 16:50:41 rt-one pppd[7642]: rcvd [CCP ConfReq id=0x2]
Feb  4 16:50:41 rt-one pppd[7642]: sent [CCP ConfReq id=0x8 <deflate 15> <deflate(old#) 15>]
Feb  4 16:50:41 rt-one pppd[7642]: sent [CCP ConfAck id=0x2]
Feb  4 16:50:41 rt-one pppd[7642]: rcvd [CCP ConfAck id=0x8 <deflate 15> <deflate(old#) 15>]
Feb  4 16:50:41 rt-one pppd[7642]: Deflate (15) receive compression enabled
Feb  4 16:50:47 rt-one pppd[7642]: rcvd [CCP ConfReq id=0x2]
Feb  4 16:50:47 rt-one pppd[7642]: sent [CCP ConfReq id=0x9 <deflate 15> <deflate(old#) 15>]
Feb  4 16:50:47 rt-one pppd[7642]: sent [CCP ConfAck id=0x2]
Feb  4 16:50:50 rt-one pppd[7642]: sent [CCP ConfReq id=0x9 <deflate 15> <deflate(old#) 15>]
Feb  4 16:50:53 rt-one pppd[7642]: sent [CCP ConfReq id=0x9 <deflate 15> <deflate(old#) 15>]
Feb  4 16:50:56 rt-one pppd[7642]: sent [CCP ConfReq id=0x9 <deflate 15> <deflate(old#) 15>]
Feb  4 16:50:59 rt-one pppd[7642]: sent [CCP ConfReq id=0x9 <deflate 15> <deflate(old#) 15>]
Feb  4 16:51:02 rt-one pppd[7642]: sent [CCP ConfReq id=0x9 <deflate 15> <deflate(old#) 15>]
Feb  4 16:51:05 rt-one pppd[7642]: sent [CCP ConfReq id=0x9 <deflate 15> <deflate(old#) 15>]
Feb  4 16:51:08 rt-one pppd[7642]: sent [CCP ConfReq id=0x9 <deflate 15> <deflate(old#) 15>]
Feb  4 16:51:11 rt-one pppd[7642]: sent [CCP ConfReq id=0x9 <deflate 15> <deflate(old#) 15>]
Feb  4 16:51:14 rt-one pppd[7642]: sent [CCP ConfReq id=0x9 <deflate 15> <deflate(old#) 15>]
Feb  4 16:51:17 rt-one pppd[7642]: CCP: timeout sending Config-Requests
Feb  4 16:52:46 rt-one pppd[7642]: No response to 4 echo-requests
Feb  4 16:52:46 rt-one pppd[7642]: Serial link appears to be disconnected.
Feb  4 16:52:46 rt-one pppd[7642]: pptpd-logwtmp.so ip-down ppp4
Feb  4 16:52:46 rt-one pppd[7642]: Connect time 2.5 minutes.
Feb  4 16:52:46 rt-one pppd[7642]: Sent 236 bytes, received 116 bytes.
Feb  4 16:52:46 rt-one pppd[7642]: Script /etc/ppp/ip-down started (pid 9721)
Feb  4 16:52:46 rt-one pppd[7642]: sent [LCP TermReq id=0x2 "Peer not responding"]
Feb  4 16:52:46 rt-one pppd[7642]: Script /etc/ppp/ip-down finished (pid 9721), status = 0x0
Feb  4 16:52:46 rt-one pptpd[7633]: CTRL: Reaping child PPP[7642]
Feb  4 16:52:46 rt-one pppd[7642]: Modem hangup
Feb  4 16:52:46 rt-one pppd[7642]: Connection terminated.
Feb  4 16:52:46 rt-one pppd[7642]: Exit.
И пытаюсь понять - почему же соединение отключилось?
В настройках PPPoE выключен NAT и Firewall - ну не нужны они мне в текущих условиях.
СообщениеДобавлено: Вт фев 05, 2008 10:59
Вызывает сомнение эта строка:
Попробуйте отключить на стороне сервера MPPC (компрессию) и MPPE (шифрование), так как DSL-2500U/BRU/D не поддерживает (и поддерживать не будет) данные протоколы.
С уважением, Давыдов Денис.
СообщениеДобавлено: Вт фев 05, 2008 21:33
Спасибо - действительно отключение компрессии и шифрования со стороны сервера помогло.
Попутно еще вопрос. При попытке доступа к модему по телнету все время получаю ошибку
iga@rt-one:~$ telnet 10.100.1.254
Trying 10.100.1.254...
Connected to 10.100.1.254.
Escape character is '^]'.
BCM96338 ADSL Router
Login: admin
Password:
Login incorrect. Try again.
Login: admin
Password:
Хотя ввожу правильные логин/пароль.
СообщениеДобавлено: Ср фев 06, 2008 00:02
попробуйте логин не админ а root
