Текущее время: Ср сен 23, 2026 01:52
 Заголовок сообщения: DSL-360T debricking
СообщениеДобавлено: Ср янв 30, 2008 01:19
Hello...
First I wanna appologise for my writting in english, but i dont know russian.
This is my problem...
I was flashing the DSL-360T and i got it bricked. Only led which is burning is power led. I readed the post http://www.dlink.ru/phorum/viewtopic.php?t=6143 but no help with that.
When is modem connected on network port on WXP i got 2-3 seconds connection and 2-3 seconds cable disconected. Tryed to connect both with WXP and Linux (Slackware 12) but no way i can get into the modem.
Last resort is to make a serial cable with MAX3232. I have to wait for IC's. I only have MAX232, but i dont wanna experiment with it, cos from my knowledge MAX3232 works with 3.3V and MAX232 with 5V.
Question is did i forgot something to do so i can reflash the modem without usage of a Com cable? If is not possible to do it without a cable, is there any option to use MAX232 and where i can find schematics for souch of interface? I would like to have a fully developed interface, cos i'm not very skillful with electronic...
Any oppinion in this subject is welcomed. Thank you.
Vladimir Ilioski
Republic of Macedonia
 Заголовок сообщения: solved problem :-)
СообщениеДобавлено: Вс фев 03, 2008 04:59
First hello...
I solved the problem considering DSL-360T.
Mainly, ftp adress was not any of ADAM2 widely posted adresses, but it was 192.168.0.199.
I managed to convert a Prolific PL-2303 mobile phone cable to a USB to RS-232 3.3v cable. I used a old cell phone cable with a bump in middle of it.
There are lot of drivers for that cable including starting from Win98-XP64, MacOSX and Linux RedHat. On a net there is a kernel module for that chip...
link for drivers for Prolific is http://www.prolific.com.tw/eng/downloads.asp?ID=31
printenv command from serial connection states this
Adam2_AR7DB > printenv
memsize               0x00800000
flashsize             0x00200000
modetty0              38400,n,8,1,hw
modetty1              38400,n,8,1,hw
bootserport           tty0
cpufrequency          150000000
sysfrequency          125000000
bootloaderVersion     0.22.02
ProductID             AR7DB
HWRevision            Unknown
SerialNumber          XX:XX:XX:XX:XX:XX (removed)
my_ipaddress          192.168.0.199
maca                  XX:XX:XX:XX:XX:XX (removed)
prompt                Adam2_AR7DB
firstfreeaddress      0x9401d888
req_fullrate_freq     125000000
mtd0                  0x90091000,0x901f0000
mtd1                  0x90010090,0x90091000
mtd2                  0x90000000,0x90010000
mtd3                  0x901f0000,0x90200000
autoload              1
usb_vid               0x0
usb_pid               0x0
usb_man               N/A
usb_prod              N/A
eoc_vendor_id         0x444C696E6B
enable_margin_retrain  1
eoc_vendor_serialnum  XX:XX:XX:XX:XX:XX (removed also)
eoc_vendor_revision   330
autoload_timeout      5
Adam2_Release         0.22.02_b03_Mar  9 2005
mtd4                  0x90010000,0x901f0000
StaticBuffer          120
vcc_encaps0           0.0
vcc_encaps1           0.0
vcc_encaps2           0.0
vcc_encaps3           0.0
vcc_encaps4           0.0
vcc_encaps5           0.0
vcc_encaps6           0.0
vcc_encaps7           0.0
modulation            0xffff
I notice that there is mtd4 partition which is non usable... (i was flashing the modem for usage with window$ vi$ta) so i erase it, fixed the other mtd partitions, reflashed it thry ftp and modem is working now....
Thank you
Vladimir Ilioski
