Текущее время: Ср сен 30, 2026 02:03
 Заголовок сообщения: Как поднять PPTP на 500T
СообщениеДобавлено: Вс дек 23, 2007 03:24
С компьютера все работает.
Модем же ни как не хочет сам поднимать соединение.
ip сервера 10.1.254.1
Может я что не так делаю:
Jan  1 12:00:12> NTP Polling Timer for DHCP Started succesfully.
Jan  1 12:00:12> DSL Polling Timer Started succesfully.
Jan  1 12:00:12> Firewall NAT service started
Jan  1 12:00:12> The firmware build date/time:20070402150429
Jan  1 12:00:14>  starting on port 80
Jan  1 12:00:15> Bridge Created: br0
Jan  1 12:00:15> Bridge Created: br1
Jan  1 12:00:17> Bridge Interface Added: eth0
Jan  1 12:00:22> DSL Carrier is down
Jan  1 12:01:05> DSL Carrier is up
Jan  1 12:01:05> sar read trained mode (1)(ADSL_G.dmt)
Jan  1 12:01:11> pppd 2.4.3 started by root, uid 0
Jan  1 12:01:11> Connect: ppp10 {--} /dev/pts/7
Jan  1 12:01:41> LCP: timeout sending Config-Requests
Jan  1 12:01:41> Connection terminated.
Jan  1 12:01:41> Connect: ppp10 {--} /dev/pts/7
Jan  1 12:01:41> tcflush failed: Bad file descriptor
Jan  1 12:01:45> tcsetattr: Invalid argument (line 1001)
Jan  1 12:01:50> pppd 2.4.3 started by root, uid 0
Jan  1 12:01:50> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:01:51> WAN IP address 91.149.188.195
Jan  1 12:01:51> WAN gateway 91.149.188.33
Jan  1 12:02:25> DSL Carrier is down
Jan  1 12:03:05> DSL Carrier is up
Jan  1 12:03:05> sar read trained mode (1)(ADSL_G.dmt)
Jan  1 12:03:05> Modem hangup
Jan  1 12:03:05> Connection terminated.
Jan  1 12:03:13> pppd 2.4.3 started by root, uid 0
Jan  1 12:03:13> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:03:15> Connection terminated.
Jan  1 12:03:15> tcflush failed: Input/output error
Jan  1 12:03:24> pppd 2.4.3 started by root, uid 0
Jan  1 12:03:24> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:03:54> LCP: timeout sending Config-Requests
Jan  1 12:03:54> Connection terminated.
Jan  1 12:03:54> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:03:54> tcflush failed: Bad file descriptor
Jan  1 12:03:55> tcsetattr: Invalid argument (line 1001)
Jan  1 12:04:03> pppd 2.4.3 started by root, uid 0
Jan  1 12:04:03> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:04:05> Connection terminated.
Jan  1 12:04:05> tcflush failed: Input/output error
Jan  1 12:04:14> pppd 2.4.3 started by root, uid 0
Jan  1 12:04:14> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:04:16> Connection terminated.
Jan  1 12:04:24> pppd 2.4.3 started by root, uid 0
Jan  1 12:04:24> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:04:26> Connection terminated.
Jan  1 12:04:26> tcflush failed: Input/output error
Jan  1 12:04:35> pppd 2.4.3 started by root, uid 0
Jan  1 12:04:35> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:04:37> Connection terminated.
Jan  1 12:04:46> pppd 2.4.3 started by root, uid 0
Jan  1 12:04:46> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:04:48> Connection terminated.
Jan  1 12:04:56> pppd 2.4.3 started by root, uid 0
Jan  1 12:04:56> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:04:59> Connection terminated.
Jan  1 12:04:59> tcflush failed: Input/output error
Jan  1 12:05:08> pppd 2.4.3 started by root, uid 0
Jan  1 12:05:08> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:05:09> Connection terminated.
Jan  1 12:05:17> pppd 2.4.3 started by root, uid 0
Jan  1 12:05:17> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:05:19> Connection terminated.
Jan  1 12:05:27> pppd 2.4.3 started by root, uid 0
Jan  1 12:05:27> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:05:29> Connection terminated.
Jan  1 12:05:37> pppd 2.4.3 started by root, uid 0
Jan  1 12:05:37> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:05:39> Connection terminated.
Jan  1 12:05:39> tcflush failed: Input/output error
Jan  1 12:05:48> pppd 2.4.3 started by root, uid 0
Jan  1 12:05:48> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:05:49> Connection terminated.
Jan  1 12:05:57> pppd 2.4.3 started by root, uid 0
Jan  1 12:05:57> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:05:59> Connection terminated.
Jan  1 12:06:07> pppd 2.4.3 started by root, uid 0
Jan  1 12:06:07> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:06:09> Connection terminated.
Jan  1 12:06:17> pppd 2.4.3 started by root, uid 0
Jan  1 12:06:17> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:06:19> Connection terminated.
Jan  1 12:06:19> tcflush failed: Input/output error
Jan  1 12:06:28> pppd 2.4.3 started by root, uid 0
Jan  1 12:06:28> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:06:29> Connection terminated.
Jan  1 12:06:38> pppd 2.4.3 started by root, uid 0
Jan  1 12:06:38> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:06:39> Connection terminated.
Jan  1 12:06:39> tcflush failed: Input/output error
Jan  1 12:06:48> pppd 2.4.3 started by root, uid 0
Jan  1 12:06:48> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:06:50> Connection terminated.
Jan  1 12:06:50> tcflush failed: Input/output error
Jan  1 12:06:59> pppd 2.4.3 started by root, uid 0
Jan  1 12:06:59> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:07:01> Connection terminated.
Jan  1 12:07:09> pppd 2.4.3 started by root, uid 0
Jan  1 12:07:09> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:07:10> Connection terminated.
Jan  1 12:07:19> pppd 2.4.3 started by root, uid 0
Jan  1 12:07:19> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:07:20> Connection terminated.
Jan  1 12:07:20> tcflush failed: Input/output error
Jan  1 12:07:29> pppd 2.4.3 started by root, uid 0
Jan  1 12:07:29> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:07:31> Connection terminated.
Jan  1 12:07:39> pppd 2.4.3 started by root, uid 0
Jan  1 12:07:39> Connect: ppp10 {--} /dev/pts/9
Jan  1 12:07:44> Connection terminated.
Jan  1 12:07:49> pppd 2.4.3 started by root, uid 0
Jan  1 12:07:49> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:08:19> LCP: timeout sending Config-Requests
Jan  1 12:08:19> Connection terminated.
Jan  1 12:08:19> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:08:19> tcflush failed: Bad file descriptor
Jan  1 12:08:23> tcsetattr: Invalid argument (line 1001)
Jan  1 12:08:28> pppd 2.4.3 started by root, uid 0
Jan  1 12:08:28> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:08:30> Connection terminated.
Jan  1 12:08:38> pppd 2.4.3 started by root, uid 0
Jan  1 12:08:38> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:08:39> Connection terminated.
Jan  1 12:08:39> tcflush failed: Input/output error
Jan  1 12:08:49> pppd 2.4.3 started by root, uid 0
Jan  1 12:08:49> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:08:50> Connection terminated.
Jan  1 12:08:58> pppd 2.4.3 started by root, uid 0
Jan  1 12:08:58> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:09:00> Connection terminated.
Jan  1 12:09:08> pppd 2.4.3 started by root, uid 0
Jan  1 12:09:08> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:09:10> Connection terminated.
Jan  1 12:09:18> pppd 2.4.3 started by root, uid 0
Jan  1 12:09:18> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:09:20> Connection terminated.
Jan  1 12:09:20> tcflush failed: Input/output error
Jan  1 12:09:29> pppd 2.4.3 started by root, uid 0
Jan  1 12:09:29> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:09:31> Connection terminated.
Jan  1 12:09:39> pppd 2.4.3 started by root, uid 0
Jan  1 12:09:39> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:09:41> Connection terminated.
Jan  1 12:09:41> tcflush failed: Input/output error
Jan  1 12:09:50> pppd 2.4.3 started by root, uid 0
Jan  1 12:09:50> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:09:52> Connection terminated.
Jan  1 12:10:00> pppd 2.4.3 started by root, uid 0
Jan  1 12:10:00> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:10:03> Connection terminated.
Jan  1 12:10:03> tcflush failed: Input/output error
Jan  1 12:10:12> pppd 2.4.3 started by root, uid 0
Jan  1 12:10:12> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:10:14> Connection terminated.
Jan  1 12:10:22> pppd 2.4.3 started by root, uid 0
Jan  1 12:10:22> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:10:52> LCP: timeout sending Config-Requests
Jan  1 12:10:52> Connection terminated.
Jan  1 12:10:52> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:10:52> tcflush failed: Bad file descriptor
Jan  1 12:10:53> tcsetattr: Invalid argument (line 1001)
Jan  1 12:11:01> pppd 2.4.3 started by root, uid 0
Jan  1 12:11:01> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:11:03> Connection terminated.
Jan  1 12:11:03> tcflush failed: Input/output error
Jan  1 12:11:12> pppd 2.4.3 started by root, uid 0
Jan  1 12:11:12> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:11:13> Connection terminated.
Jan  1 12:11:13> tcflush failed: Input/output error
Jan  1 12:11:22> pppd 2.4.3 started by root, uid 0
Jan  1 12:11:22> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:11:24> Connection terminated.
Jan  1 12:11:32> pppd 2.4.3 started by root, uid 0
Jan  1 12:11:32> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:11:34> Connection terminated.
Jan  1 12:11:34> tcflush failed: Input/output error
Jan  1 12:11:43> pppd 2.4.3 started by root, uid 0
Jan  1 12:11:43> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:12:13> LCP: timeout sending Config-Requests
Jan  1 12:12:13> Connection terminated.
Jan  1 12:12:13> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:12:13> tcflush failed: Bad file descriptor
Jan  1 12:12:14> tcsetattr: Invalid argument (line 1001)
Jan  1 12:12:22> pppd 2.4.3 started by root, uid 0
Jan  1 12:12:22> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:12:24> Connection terminated.
Jan  1 12:12:24> tcflush failed: Input/output error
Jan  1 12:12:33> pppd 2.4.3 started by root, uid 0
Jan  1 12:12:33> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:12:35> Connection terminated.
Jan  1 12:12:43> pppd 2.4.3 started by root, uid 0
Jan  1 12:12:43> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:12:44> Connection terminated.
Jan  1 12:12:52> pppd 2.4.3 started by root, uid 0
Jan  1 12:12:52> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:12:54> Modem hangup
Jan  1 12:12:54> Connection terminated.
Jan  1 12:13:03> pppd 2.4.3 started by root, uid 0
Jan  1 12:13:03> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:13:05> Connection terminated.
Jan  1 12:13:13> pppd 2.4.3 started by root, uid 0
Jan  1 12:13:13> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:13:15> Connection terminated.
Jan  1 12:13:15> tcflush failed: Input/output error
Jan  1 12:13:24> pppd 2.4.3 started by root, uid 0
Jan  1 12:13:24> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:13:25> Connection terminated.
Jan  1 12:13:25> tcflush failed: Input/output error
Jan  1 12:13:34> pppd 2.4.3 started by root, uid 0
Jan  1 12:13:34> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:13:36> Connection terminated.
Jan  1 12:13:36> tcflush failed: Input/output error
Jan  1 12:13:45> pppd 2.4.3 started by root, uid 0
Jan  1 12:13:45> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:13:47> Connection terminated.
Jan  1 12:13:55> pppd 2.4.3 started by root, uid 0
Jan  1 12:13:55> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:13:57> Connection terminated.
Jan  1 12:14:05> pppd 2.4.3 started by root, uid 0
Jan  1 12:14:05> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:14:06> Connection terminated.
Jan  1 12:14:06> tcflush failed: Input/output error
Jan  1 12:14:15> pppd 2.4.3 started by root, uid 0
Jan  1 12:14:15> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:14:17> Connection terminated.
Jan  1 12:14:25> pppd 2.4.3 started by root, uid 0
Jan  1 12:14:25> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:14:55> LCP: timeout sending Config-Requests
Jan  1 12:14:55> Connection terminated.
Jan  1 12:14:55> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:14:55> tcflush failed: Bad file descriptor
Jan  1 12:14:56> tcsetattr: Invalid argument (line 1001)
Jan  1 12:15:04> pppd 2.4.3 started by root, uid 0
Jan  1 12:15:04> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:15:06> Connection terminated.
Jan  1 12:15:06> tcflush failed: Input/output error
Jan  1 12:15:15> pppd 2.4.3 started by root, uid 0
Jan  1 12:15:15> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:15:17> Connection terminated.
Jan  1 12:15:17> tcflush failed: Input/output error
Jan  1 12:15:26> pppd 2.4.3 started by root, uid 0
Jan  1 12:15:26> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:15:28> Connection terminated.
Jan  1 12:15:28> tcflush failed: Input/output error
Jan  1 12:15:37> pppd 2.4.3 started by root, uid 0
Jan  1 12:15:37> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:15:38> Connection terminated.
Jan  1 12:15:46> pppd 2.4.3 started by root, uid 0
Jan  1 12:15:46> Connect: ppp10 {--} /dev/pts/8
Jan  1 12:15:48> Connection terminated.
СообщениеДобавлено: Ср дек 26, 2007 13:05
Какая версия прошивки модема? Какой вид аутентификации на PPTP-сервере?
Сейчас этот форум просматривают: Google [Bot] и гости: 40
