Текущее время: Вт сен 29, 2026 06:06
 Заголовок сообщения: Проблема G604T и AnnexM (
СообщениеДобавлено: Вт авг 14, 2007 14:47
Никак не подключается на AnnexM. Прошивка V3.02B01T01.RU.20070322, работает как роутер, провайдер Домолинк Воронеж.
Лог:
Jan 1 12:00:11> AP Acquiring Lock
Jan 1 12:00:12> NTP Polling Timer for DHCP Started succesfully.
Jan 1 12:00:12> DSL Polling Timer Started succesfully.
Jan 1 12:00:12> Firewall NAT service started
Jan 1 12:00:12> AP REPORT LOCK ACQUIRED
Jan 1 12:00:12> wlan_handle_load_event - Acquired Lock
Jan 1 12:00:13> MAC address is : 00:19:5b:1d:f9:ea
Jan 1 12:00:14> starting on port 80
Jan 1 12:00:14> ip_nat_pptp version 1.5 loaded
Jan 1 12:00:14> (c)2000 Netfilter core team
Jan 1 12:00:14> netfilter PSD loaded - (c) astaro AG
Jan 1 12:00:14> Initializing the WAN Bridge.
Jan 1 12:00:14> Please set the MAC Address for the WAN Bridge.
Jan 1 12:00:14> Set the Environment variable 'wan_br_mac'.
Jan 1 12:00:14> xx.xx.xx.xx.xx.xx
Jan 1 12:00:14> Mounted root (squashfs filesystem) readonly.
Jan 1 12:00:14> Mounted devfs on /dev
Jan 1 12:00:14> 64k freed
Jan 1 12:00:14> Algorithmics/MIPS FPU Emulator v1.5
Jan 1 12:00:14> registered device TI Avalanche SAR
Jan 1 12:00:14> Sangam detected
Jan 1 12:00:14> DSP binary filesize = 356930 bytes
Jan 1 12:00:14> Setting mode to 0x2000
Jan 1 12:00:14> version:[5.00.04.00]
Jan 1 12:00:14> Default Asymmetric MTU for nas0 1500
Jan 1 12:00:14> Registering protocol inspector: 0x94172dd8 for VCC:0x94258a00
Jan 1 12:00:14> Default Asymmetric MTU for br0 1500
Jan 1 12:00:14> Bridge Created: br0
Jan 1 12:00:15> Bridge Created: br1
Jan 1 12:00:16> Bridge Interface Added: eth0
Jan 1 12:00:16> WPA Authenticator Started
Jan 1 12:00:16> 2
Jan 1 12:00:16> Default Asymmetric MTU for br1 1500
Jan 1 12:00:16> 2
Jan 1 12:00:20> Default Asymmetric MTU for wlan0 1500
Jan 1 12:00:20> Default Asymmetric MTU for wdsup0 1500
Jan 1 12:00:20> Default Asymmetric MTU for wdsdw0 1500
Jan 1 12:00:20> Default Asymmetric MTU for wdsdw1 1500
Jan 1 12:00:20> Default Asymmetric MTU for wdsdw2 1500
Jan 1 12:00:20> Default Asymmetric MTU for wdsdw3 1500
Jan 1 12:00:21> AP Driver configuration successful
Jan 1 12:00:26> AP IS UP
Jan 1 12:00:26>
Jan 1 12:00:26> disabled.
Jan 1 12:00:26> For SSID 0 vlan tag received is 0
Jan 1 12:00:26> wdrv_dbMainInit : WME disabled
Jan 1 12:00:26> wdrv_dbMainInit: wdsEnabled=0
Jan 1 12:00:26> Configuration succeeded !!!
Jan 1 12:00:26> WLAN driver database is up
Jan 1 12:00:26> ACX Hard reset!!!
Jan 1 12:00:26> Preparing for vlynq tearing down....
Jan 1 12:00:26> Resetting the remote device.
Jan 1 12:00:26> Un-resetting the remote device.
Jan 1 12:00:26> Preparing the VLYNQ, now the Link is up.
Jan 1 12:00:26> MemAddr=0xa4000000, RegAddr=0xa4040000
Jan 1 12:00:26> AcxRegAddr = 0xA4040000, AcxMemAddr = 0xA4000000
Jan 1 12:00:26> whal_ParamsInitDmaParams:303 wone = 0 queues = 2
Jan 1 12:00:26> whal_acxProcInitiate: found DEVICE_VENDOR ID(0x1000) = 0x9066104c, 0x9066104c
Jan 1 12:00:26> whal_acxProcInitiate: Cpu halt -} download code
Jan 1 12:00:26> whal_acxProcLoadFwImage: 0xa4000000, 0x0
Jan 1 12:00:26> AP Releasing Lock
Jan 1 12:00:26> whal_acxProcLoadFwImage() -- Loading FW image
Jan 1 12:00:26> ERROR - WAN Bridge Creation: wbr0
Jan 1 12:00:26> Compiled for RADIA (bg) radio
Jan 1 12:00:26> whal_acxProcLoadFwImage: 1, pBuf=0xc00af650, len=0x13884. Extra pBuf=0x0, len=0x0
Jan 1 12:00:26> whal_acxProcLoadFwImage: 2, pBuf=0xc00af650, len=0x13884. Extra pBuf=0x0, len=0x0
Jan 1 12:00:26> whal_acxProcLoadFwImage: 3, pBuf=0xc00af650, len=0x13884, DataLen=0x1387c
Jan 1 12:00:26> whal_acxProcLoadFwImage: 4, pBuf=0xc00af650, len=0x13884
Jan 1 12:00:26> whal_acxProcLoadFwImage: Checksum, calc=0x6a9ea3, file=0x6a9ea3
Jan 1 12:00:26> wdrv_txInit: AC = 3 size = 192
Jan 1 12:00:26> Tx is up
Jan 1 12:00:26> MemMngr is up
Jan 1 12:00:26> main state machine is up
Jan 1 12:00:26> Bridge Interface Added: wlan0
Jan 1 12:00:27> QoS module is up is up
Jan 1 12:00:27> WDRV_MAINSM: WLAN Driver initialized successfully
Jan 1 12:00:27>
Jan 1 12:00:27> WDRV_4X: 4x Disabled
Jan 1 12:00:27> WDRV_4X: Concatenation Disabled
Jan 1 12:00:27> WDRV_4X: Ack Emulation Disabled
Jan 1 12:00:27> whal_apiStartBss: Enable Tx, Rx and Start the Bss
Jan 1 12:00:27> ----------------------------------------------------------------
Jan 1 12:00:27> START BSS, SSID=DLINK_WIRELESS, BSSID=00-19-5B-1D-F9-EA
Jan 1 12:00:27> DSL Carrier is down
Jan 1 12:00:27> AP Power Level = 1
Jan 1 12:00:27> Regulatory Domain = ETSI
Jan 1 12:00:27> Net[0] : Channel=6
Jan 1 12:00:27> FW Watchdog is Enabled
Jan 1 12:00:35> DSL in Sync
Jan 1 12:00:36> closing 0.10.40.5
Jan 1 12:00:36> tn7sar_teardown_complete called for channel 0
Jan 1 12:00:36> ChannelTeardown returned rc = 0
Jan 1 12:00:37> DSL Carrier is up
Jan 1 12:00:37> sar read trained mode (16)(ADSL_2plus_AnxM)
Jan 1 12:00:38> pingStat 2, oamHdr 230 result 0
Jan 1 12:00:38> pingStat 2, oamHdr 200 result 0
Jan 1 12:00:38> pingStat 2, oamHdr 280 result 0
Jan 1 12:00:38> pingStat 2, oamHdr 240 result 0
Jan 1 12:00:38> pingStat 2, oamHdr 260 result 0
Jan 1 12:00:38> pingStat 2, oamHdr 600 result 0
Jan 1 12:00:38> pingStat 2, oamHdr 800230 result 0
Jan 1 12:00:38> pingStat 2, oamHdr 2B0 result 0
Jan 1 12:00:38> pingStat 2, oamHdr 330 result 0
Jan 1 12:00:38> pingStat 2, oamHdr 3B0 result 0
Jan 1 12:00:38> pingStat 2, oamHdr 8002B0 result 0
Jan 1 12:00:38> pingStat 2, oamHdr 800330 result 0
Jan 1 12:00:38> pingStat 2, oamHdr 8003B0 result 0
Jan 1 12:00:38> Default Asymmetric MTU for nas0 1500
Jan 1 12:00:38> Registering protocol inspector: 0x94172dd8 for VCC:0x94258800
Jan 1 12:00:39> pppd 2.4.3 started by root, uid 0
Jan 1 12:00:39> Connect: ppp0 {--} nas0
Jan 1 12:00:41> Connection terminated.
Jan 1 12:00:41> pppd 2.4.3 started by root, uid 0
Jan 1 12:00:41> Connect: ppp0 {--} nas0
Jan 1 12:00:43> Connection terminated.
Jan 1 12:00:44> pppd 2.4.3 started by root, uid 0
Jan 1 12:00:44> Connect: ppp0 {--} nas0
Jan 1 12:00:46> Connection terminated.
Jan 1 12:00:46> pppd 2.4.3 started by root, uid 0
Jan 1 12:00:46> Connect: ppp0 {--} nas0
Jan 1 12:00:48> Connection terminated.
Jan 1 12:00:52> pppd 2.4.3 started by root, uid 0
Jan 1 12:00:52> Connect: ppp0 {--} nas0
Jan 1 12:00:54> Connection terminated.
Последний раз редактировалось MyBot Ср авг 15, 2007 12:09, всего редактировалось 1 раз.
СообщениеДобавлено: Ср авг 15, 2007 10:47
Ну подскажите что делать, а то труба без интернета :(
СообщениеДобавлено: Ср авг 15, 2007 15:40
Ну подскажите уже кто-нибудь в чём проблема :?:
СообщениеДобавлено: Чт авг 16, 2007 16:05
Тему можно удалять. Проблема решилась путём замены модема на Zyxel.
