Текущее время: Вт сен 22, 2026 19:59
СообщениеДобавлено: Сб июл 07, 2007 15:22
Вот мой лог файл, помогите пожалуйста! Модем работает не дольше 2 минут, потом просто отрубается, тоесть связь есть, но просто не хочет работать инет, модем подключен в режиме роутера, прошивка:
ADSL Firmware Version: 6.00.01.00 - 6.00.01.00 - 6.00.04.00 Annex A - 01.07.2b - 0.54
ADSL Software Version: V3.02B01T01.RU.20070402
Jan 1 12:00:12> NTP Polling Timer for DHCP Started succesfully.
Jan 1 12:00:12> DSL Polling Timer Started succesfully.
Jan 1 12:00:12> Firewall NAT service started
Jan 1 12:00:14> starting on port 80
Jan 1 12:00:14> ip_nat_pptp version 1.5 loaded
Jan 1 12:00:14> (c)2000 Netfilter core team
Jan 1 12:00:14> netfilter PSD loaded - (c) astaro AG
Jan 1 12:00:14> Initializing the WAN Bridge.
Jan 1 12:00:14> Please set the MAC Address for the WAN Bridge.
Jan 1 12:00:14> Set the Environment variable 'wan_br_mac'.
Jan 1 12:00:14> xx.xx.xx.xx.xx.xx
Jan 1 12:00:14> Mounted root (squashfs filesystem) readonly.
Jan 1 12:00:14> Mounted devfs on /dev
Jan 1 12:00:14> 64k freed
Jan 1 12:00:14> Algorithmics/MIPS FPU Emulator v1.5
Jan 1 12:00:14> registered device TI Avalanche SAR
Jan 1 12:00:14> Sangam detected
Jan 1 12:00:14> DSP binary filesize = 356930 bytes
Jan 1 12:00:14> Setting mode to 0x3
Jan 1 12:00:14> version:[6.00.01.00]
Jan 1 12:00:14> Default Asymmetric MTU for nas0 1500
Jan 1 12:00:14> Registering protocol inspector: 0x941716c8 for VCC:0x9423ba00
Jan 1 12:00:14> Default Asymmetric MTU for br0 1500
Jan 1 12:00:15> Bridge Created: br0
Jan 1 12:00:15> Bridge Created: br1
Jan 1 12:00:16> Bridge Interface Added: eth0
Jan 1 12:00:17> Default Asymmetric MTU for br1 1500
Jan 1 12:00:17> 2
Jan 1 12:00:17> 2
Jan 1 12:00:22> DSL Carrier is down
Jan 1 12:01:35> DSL in Sync
Jan 1 12:01:39> closing 0.8.35.5
Jan 1 12:01:39> tn7sar_teardown_complete called for channel 0
Jan 1 12:01:39> ChannelTeardown returned rc = 0
Jan 1 12:01:42> DSL Carrier is up
Jan 1 12:01:42> sar read trained mode (1)(ADSL_G.dmt)
Jan 1 12:01:45> pingStat 2, oamHdr 230 result 0
Jan 1 12:01:45> pingStat 2, oamHdr 200 result 0
Jan 1 12:01:45> pingStat 2, oamHdr 280 result 0
Jan 1 12:01:45> pingStat 2, oamHdr 240 result 0
Jan 1 12:01:45> pingStat 2, oamHdr 260 result 0
Jan 1 12:01:45> pingStat 2, oamHdr 600 result 0
Jan 1 12:01:45> pingStat 2, oamHdr 800230 result 0
Jan 1 12:01:45> pingStat 2, oamHdr 2B0 result 0
Jan 1 12:01:45> pingStat 2, oamHdr 330 result 0
Jan 1 12:01:45> pingStat 2, oamHdr 3B0 result 0
Jan 1 12:01:45> pingStat 2, oamHdr 8002B0 result 0
Jan 1 12:01:45> pingStat 2, oamHdr 800330 result 0
Jan 1 12:01:45> pingStat 2, oamHdr 8003B0 result 0
Jan 1 12:01:45> get 0xF at Addr 0xA30085B0
Jan 1 12:01:45> Default Asymmetric MTU for nas0 1500
Jan 1 12:01:45> Registering protocol inspector: 0x941716c8 for VCC:0x9423b800
Jan 1 12:01:46> pppd 2.4.3 started by root, uid 0
Jan 1 12:01:47> Connect: ppp0 {--} nas0
Jan 1 12:01:50> PAP authentication succeeded
Jan 1 12:01:56> PPPoE Connect with IP Address 91.124.104.91
Jan 1 12:02:05> PPPoE Connection Successfully Established
Jan 1 12:02:06> PPPoE Connect with Gateway IP Address: 195.5.5.18
Jan 1 12:02:17> peer from calling number 00:0D:66:02:00:1B authorized
Jan 1 12:02:17> WAN IP address 91.124.104.91
Jan 1 12:02:17> WAN gateway 195.5.5.18
Jan 1 12:02:17> Lost SIGCHLD, process iptables(185) died
Jan 1 12:02:17> ppp0
Jan 1 12:05:27> Firewall rules flushed
СообщениеДобавлено: Пн июл 09, 2007 14:43
После перепрошивки устройства Вы заливали конфигурационный файл, идущий в одном архиве с прошивкой?
Попробуйте сбросить устройство к заводским настройкам и перенастроить.
С уважением, Давыдов Денис.
