Текущее время: Вс авг 09, 2026 18:58
 Заголовок сообщения: Постоянно падает ППОЕ. почему?
СообщениеДобавлено: Вт июн 19, 2007 08:12
Проблема следующая постоянно падает ППОЕ. Почему?
Физика АДСЛ по мнению провайдера беспроблем она постоянна падает постоянно соединение.
Вкладываю лог если кто объяснит проблему отпишитесь, а то задолбался искать причину.
Модем DSL - 500T
ЛОГ:
Jun 18 15:13:53> Serial link appears to be disconnected.
Jun 18 15:13:59> Connection terminated.
Jun 18 15:13:59> Modem hangup
Jun 18 15:13:59> Terminated: Modem Hang-Up
Jun 18 15:14:02> pppd 2.4.3 started by root, uid 0
Jun 18 15:14:37> Timeout waiting for PADO packets
Jun 18 15:14:37> Unable to complete PPPoE Discovery
Jun 18 15:14:37> PPPD Successfully Launched
Jun 18 15:14:37> pppd 2.4.3 started by root, uid 0
Jun 18 15:15:12> Timeout waiting for PADO packets
Jun 18 15:15:12> Unable to complete PPPoE Discovery
Jun 18 15:15:12> PPPD Successfully Launched
Jun 18 15:15:12> pppd 2.4.3 started by root, uid 0
Jun 18 15:15:17> Connect: ppp0 {--} nas0
Jun 18 15:15:17> PAP authentication succeeded
Jun 18 15:15:17> peer from calling number 00:18:BA:5E:88:01 authorized
Jun 18 15:15:17> WAN IP address 84.42.23.34
Jun 18 15:15:17> PPPoE Connect with IP Address 84.42.23.34
Jun 18 15:15:17> PPPoE Connection Successfully Established
Jun 18 15:15:17> PPPoE Connect with Gateway IP Address: 84.42.0.230
Jun 18 15:15:17> WAN gateway 84.42.0.230
Jun 18 15:15:18> primary DNS address 84.42.0.3
Jun 18 15:15:18> secondary DNS address 84.42.0.4
Jun 18 16:10:17> Serial link appears to be disconnected.
Jun 18 16:10:23> Terminated: Modem Hang-Up
Jun 18 16:10:23> Connection terminated.
Jun 18 16:10:23> Modem hangup
Jun 18 16:10:23> pppd 2.4.3 started by root, uid 0
Jun 18 16:10:58> PPPD Successfully Launched
Jun 18 16:10:58> Timeout waiting for PADO packets
Jun 18 16:10:58> Unable to complete PPPoE Discovery
Jun 18 16:10:58> pppd 2.4.3 started by root, uid 0
Jun 18 16:11:33> Timeout waiting for PADO packets
Jun 18 16:11:33> Unable to complete PPPoE Discovery
Jun 18 16:11:33> PPPD Successfully Launched
Jun 18 16:11:39> pppd 2.4.3 started by root, uid 0
Jun 18 16:12:14> Timeout waiting for PADO packets
Jun 18 16:12:14> Unable to complete PPPoE Discovery
Jun 18 16:12:14> PPPD Successfully Launched
Jun 18 16:12:14> pppd 2.4.3 started by root, uid 0
Jun 18 16:12:49> Timeout waiting for PADO packets
Jun 18 16:12:49> Unable to complete PPPoE Discovery
Jun 18 16:12:49> PPPD Successfully Launched
Jun 18 16:12:53> pppd 2.4.3 started by root, uid 0
Jun 18 16:13:28> Timeout waiting for PADO packets
Jun 18 16:13:28> Unable to complete PPPoE Discovery
Jun 18 16:13:28> PPPD Successfully Launched
Jun 18 16:13:28> pppd 2.4.3 started by root, uid 0
Jun 18 16:14:03> Timeout waiting for PADO packets
Jun 18 16:14:03> Unable to complete PPPoE Discovery
Jun 18 16:14:03> PPPD Successfully Launched
Jun 18 16:14:06> pppd 2.4.3 started by root, uid 0
Jun 18 16:14:41> Timeout waiting for PADO packets
Jun 18 16:14:41> Unable to complete PPPoE Discovery
Jun 18 16:14:41> PPPD Successfully Launched
Jun 18 16:14:41> pppd 2.4.3 started by root, uid 0
Jun 18 16:15:16> Timeout waiting for PADO packets
Jun 18 16:15:16> Unable to complete PPPoE Discovery
Jun 18 16:15:16> PPPD Successfully Launched
Jun 18 16:15:18> pppd 2.4.3 started by root, uid 0
Jun 18 16:15:18> Connect: ppp0 {--} nas0
Jun 18 16:15:33> PAP authentication succeeded
Jun 18 16:15:33> peer from calling number 00:18:BA:5E:88:01 authorized
Jun 18 16:15:48> WAN IP address 84.42.23.34
Jun 18 16:15:48> PPPoE Connect with IP Address 84.42.23.34
Jun 18 16:15:48> PPPoE Connection Successfully Established
Jun 18 16:15:48> PPPoE Connect with Gateway IP Address: 84.42.0.230
Jun 18 16:15:48> WAN gateway 84.42.0.230
Jun 18 16:15:48> primary DNS address 84.42.0.3
Jun 18 16:15:48> secondary DNS address 84.42.0.4
Человеку нужно 2 года чтобы, научиться говорить, и 60 лет, чтобы научиться держать язык за зубами.
Л. Фейхтвангер
СообщениеДобавлено: Вт июн 19, 2007 09:07
Приведите данные со страницы Status > ADSL.
С уважением, Давыдов Денис.
СообщениеДобавлено: Вт июн 19, 2007 09:18
ADSL Status
ADSL status shows the ADSL physical layer status.
ADSL Firmware Version: 4.03.03.00 - 3.02.00.03 - 3.02.06.00 Annex A - 01.07.02 - 0.49
ADSL Software Version: V2.01B01T01.RU.20060620
Line State Connected
Modulation G.dmt
Annex Mode ANNEX_A
Max Tx Power -38 dBm/Hz
Item
Downstream
Upstream
Unit
SNR Margin
31
26
dB
Line Attenuation
20
8
dB
Data Rate
160
160
kbps[/img][/url]
Л. Фейхтвангер
СообщениеДобавлено: Вт июн 19, 2007 09:19
Не могу вставить картинку не знаю как.
Л. Фейхтвангер
СообщениеДобавлено: Вт июн 19, 2007 09:20
To MikaelW
1. Обновите прошивку до последней: ftp://ftp.dlink.ru/pub/ADSL/DSL-500T/Fi ... 070402.zip
2. После обновления прошивки обязательно залейте конфигурационный файл, идущий в одном архиве с прошивкой.
3. Перенастройте устройство.
СообщениеДобавлено: Вт июн 19, 2007 09:23
А можно исправить бес перепрошивки?
Я управляю этим делом удаленно.
Оборудование находится далеко.
Л. Фейхтвангер
СообщениеДобавлено: Вт июн 19, 2007 09:28
А как правильно перепрошивать?
Есть какое-то руководство?
Л. Фейхтвангер
СообщениеДобавлено: Вт июн 19, 2007 09:29
Что можно попробовать сделать: нужно вернуть устройство к заводским настройкам и перенастроить.
Судя по приведенному в Вашем первом сообщении логу, по каким то причинам недоступен PPP сервер провайдера.
Также на странице Tools > Test проведите тесты соединения F4 и F5.
Результаты тестов приведите здесь.
СообщениеДобавлено: Вт июн 19, 2007 09:43
Diagnostic Test
The diagnostics feature executes a series of test of your system software and hardware connections. Use the feature when working with your ISP to troubleshoot problems.
Virtual Circuits :
OAM Type :
This Page is used for performing diagnostics on the system.
Testing Connectivity to modem
Testing Ethernet LAN connection PASS
Testing ADSL Connection
Testing ADSL Synchronization PASS
Testing Network Connection
Testing ATM OAM segment ping FAIL
Testing ATM OAM end to end ping FAIL
Testing Internet Connectivity
Ping Primary Domain Names Server PASS
Это тест Ф4. После его проведения модем опять прекратил свою работу. БЛИН.
Когда восстановиться пришлю данные Ф5.
Л. Фейхтвангер
СообщениеДобавлено: Вт июн 19, 2007 09:46
Diagnostic Test
Virtual Circuits :
OAM Type :
Testing ATM OAM segment ping PASS
Testing ATM OAM end to end ping PASS
Это тест Ф5.
Л. Фейхтвангер
СообщениеДобавлено: Вт июн 19, 2007 09:54
MikaelW писал(а):
Diagnostic Test
Virtual Circuits :
OAM Type :
Это тест Ф5.
Судя по результатам теста, ATM уровень работает нормально. Кроме того, пингуется DNS сервер.
Попросите провайдера включить режим Interleave на Вашем DSL порту на DSLAM, если порт работает в режиме Fast. Если же порт уже работает в режиме Interleave, попросите провайдера увеличить задержку.
Если ничего не поможет, обновите прошивку до той, что я Вам привел.
Инструкция по обновлению прошивки: http://ftp.dlink.ru/pub/ADSL/DSL-300T/F ... l_ver3.pdf
СообщениеДобавлено: Вт июн 19, 2007 10:21
Вот кое что еще.
на 30 минут выключили модем.
После этого он проработал 1 час беспрерывно.
А потом опять началось.
Будет возможность заработает вытащу лог.
А также сделаю перепрошивку. А могут быть проблемы с железом?
Л. Фейхтвангер
СообщениеДобавлено: Вт июн 19, 2007 10:22
MikaelW писал(а):
Вот кое что еще.
В каком окружении находится устройство? Возможно, оно перегревается?
СообщениеДобавлено: Вт июн 19, 2007 10:30
Модем ка в прочем и сервер и прочее находится в серверной где кондишн поддерживает температуру около 20 градусов. Все ободудование висит на Упсе(который позволяет подключать модемы и маршрутизаторы, не знаю в чем особенность(это по мненению производителя)).
Л. Фейхтвангер
СообщениеДобавлено: Вт июн 19, 2007 10:42
Перепрошейте устройство и если проблема все же будет иметь место, приведите лог устройства.
