Текущее время: Ср сен 30, 2026 03:35
 Заголовок сообщения: Постоянный реконект на 504T
СообщениеДобавлено: Сб фев 10, 2007 18:20
Началось дня два назад, постоянные потери связи, могут и через минуту,а могут через несколько часов происходить. Причем иногда соединение происходит очень долго, а иногда почти сразу. В логах написано что вроде теряет несущую
Feb 10 13:37:00> secondary DNS address 195.34.32.116
Feb 10 13:37:30> DSL Carrier is down
Feb 10 13:38:00> DSL Carrier is training
Feb 10 13:38:10> DSL Carrier is up
Feb 10 13:38:17> Modem hangup
Feb 10 13:38:17> Connection terminated.
Feb 10 13:38:17> Doing disconnect
Feb 10 13:38:23> pppd 2.4.1 started by root, uid 0
Feb 10 13:38:23> Connecting PPPoE socket: 00:30:88:01:15:7f df12 nas0 0x1000d3b8
Feb 10 13:38:23> Connect: ppp0 {--} nas0
Feb 10 13:38:24> WAN IP address 85.141.77.89
Feb 10 13:38:24> WAN gateway 85.141.76.1
Feb 10 13:38:24> PPPoE Connect with IP Address 85.141.77.89
Feb 10 13:38:24> primary DNS address 212.188.4.10
Feb 10 13:38:24> PPPoE Connection Successfully Established
Feb 10 13:38:24> PPPoE Connect with Gateway IP Address: 85.141.76.1
Feb 10 13:38:24> secondary DNS address 195.34.32.116
Feb 10 14:11:20> DSL Carrier is down
Feb 10 14:11:30> DSL Carrier is up
Feb 10 14:11:36> Connection terminated.
Feb 10 14:11:36> Doing disconnect
Feb 10 14:11:41> pppd 2.4.1 started by root, uid 0
Feb 10 14:11:47> Connecting PPPoE socket: 00:30:88:01:15:7f d011 nas0 0x1000d3b8
Feb 10 14:11:47> Connect: ppp0 {--} nas0
Feb 10 14:11:48> WAN IP address 85.140.155.52
Feb 10 14:11:48> PPPoE Connect with IP Address 85.140.155.52
Feb 10 14:11:48> WAN gateway 85.140.152.1
Feb 10 14:11:48> PPPoE Connection Successfully Established
Feb 10 14:11:48> PPPoE Connect with Gateway IP Address: 85.140.152.1
Feb 10 14:11:48> primary DNS address 212.188.4.10
Feb 10 14:11:48> secondary DNS address 195.34.32.116
Feb 10 14:30:29> DSL Carrier is training
Feb 10 14:30:39> DSL Carrier is training
Feb 10 14:30:49> DSL Carrier is up
Feb 10 14:30:59> DSL Carrier is down
Feb 10 14:31:00> Connection terminated.
Feb 10 14:31:00> Doing disconnect
и так далее
Пробовал менять модуляции, но в итоге все тоже самое с различными вариациями. Версия прошивки V1.00B02T02.RU.20041014
Помогите советом.
СообщениеДобавлено: Пн фев 12, 2007 11:31
Стрим.... АТС какая? У меня на 941 такая же беда с 7-го февраля. Модем у меня DSL-500T. За 5 дней удалось установить всего 7 соединений по несколько секунд каждое. Прошивка модема от февраля 2005 года.
DSL-500T+3Com 905TX NIC, Splitter Dlink ~6$ Stream Neo+
Если тебе дадут линованую бумагу, пиши на ней поперек.
СообщениеДобавлено: Пн фев 12, 2007 14:34
To All
Нужно чтобы техническая служба Вашего оператора посмотрела статистику ошибок на Ваших DSL портах на DSLAM. Изходя из полученной информации, специалисты должны сделать вывод о качестве линии и предпринять комплекс мер по тонкой настройке параметров порта. Со своей стороны Вы ничего сделать не сможете.
С уважением, Давыдов Денис.
СообщениеДобавлено: Пн фев 12, 2007 15:26
to Davydov Denis: Да они мне в первый день моего обращения сразу сказали что проблема у них. Зарегистрировали заявку и вот уже 4 дня пытаются решить проблему. Проблема массовая, но на сайте стрима ни слова об этом. В чём проблема - непонятно. Есть мнение что бОльшей частью эта проблема затронула владельцев модемов Dlink на определённых АТС в СЗАО.
СообщениеДобавлено: Пн фев 12, 2007 20:23
МТУ, АТС 378
Я вообщем и думал что надо в техподдержку звонить, но связыватся лишний раз с ней не хочется, решил сюда написать.
Спасибо за ответы, буду звонить.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 51
