Текущее время: Пт июн 26, 2026 03:15
 Заголовок сообщения: 504Т долго коннектится
СообщениеДобавлено: Сб окт 14, 2006 23:53
Всем привет
У меня имеется DSL-504T с прошивкой V1.00B02T02.RU.20040830. Все работает замечательно, аптаймы по 400-500 часов. Единственная претензия - модем коннектится обычно от 30 минут до часа - это нормально?
Вот лог коннекта:
Sep  8 12:00:07> Valid Configuration Tree
Sep  8 12:00:11> Firewall NAT service started
Sep  8 12:00:12> Bridge Created: br0
Sep  8 12:00:13> Bridge Interface Added: eth0
Sep  8 12:00:14> pppd 2.4.1 started by root, uid 0
Sep  8 12:00:15> DSL Carrier is training
Sep  8 12:01:54> Connecting PPPoE socket: 00:00:00:00:00:00 0000  0x1000d3b8
Sep  8 12:01:54> Couldn't get channel number: Transport endpoint is not connected
Sep  8 12:01:54> Doing disconnect
Sep  8 12:01:54> System Call Error
Sep  8 12:01:59> pppd 2.4.1 started by root, uid 0
Sep  8 12:03:39> Connecting PPPoE socket: 00:00:00:00:00:00 0000  0x1000d3b8
Sep  8 12:03:39> Couldn't get channel number: Transport endpoint is not connected
Sep  8 12:03:39> Doing disconnect
Sep  8 12:03:39> System Call Error
Sep  8 12:03:44> pppd 2.4.1 started by root, uid 0
Sep  8 12:05:24> Connecting PPPoE socket: 00:00:00:00:00:00 0000  0x1000d3b8
Sep  8 12:05:24> Couldn't get channel number: Transport endpoint is not connected
Sep  8 12:05:24> Doing disconnect
Sep  8 12:05:24> System Call Error
Sep  8 12:05:29> pppd 2.4.1 started by root, uid 0
Sep  8 12:07:09> Connecting PPPoE socket: 00:00:00:00:00:00 0000  0x1000d3b8
Sep  8 12:07:09> Couldn't get channel number: Transport endpoint is not connected
Sep  8 12:07:09> Doing disconnect
Sep  8 12:07:09> System Call Error
Sep  8 12:07:15> pppd 2.4.1 started by root, uid 0
Sep  8 12:08:55> Connecting PPPoE socket: 00:00:00:00:00:00 0000  0x1000d3b8
Sep  8 12:08:55> Couldn't get channel number: Transport endpoint is not connected
Sep  8 12:08:55> Doing disconnect
Sep  8 12:08:55> System Call Error
Sep  8 12:09:00> pppd 2.4.1 started by root, uid 0
Sep  8 12:10:40> Connecting PPPoE socket: 00:00:00:00:00:00 0000  0x1000d3b8
Ну и так далее.....
 Заголовок сообщения: Re: 504Т долго коннектится
СообщениеДобавлено: Пн окт 16, 2006 09:39
Хорошо, что ещё соединяется, обновите прошивку до версии 20041014.
Бигаров Руслан.
СообщениеДобавлено: Пн окт 16, 2006 09:40
Судя по логу, по каким то причинам недоступен PPP сервер провайдера (сервер не отвечает на PADI пакеты). Попросите провайдера посмотреть лог на своей стороне.
С уважением, Давыдов Денис.
