Текущее время: Пт ноя 06, 2026 13:11
СообщениеДобавлено: Сб сен 02, 2006 14:20
Ситуация следующая:
Модем работает на прошивке V2.01B01T01.RU.20060109
WAN Setting: PPPoE/PPPoA
Connection Type: PPPoE LLC
Default Route enable
PPPoEPassThrough enable
NAT enable
Firewall enable - правила по умолчанию
IP Control Dynamic IP
Service Category UBR
Включен WiFi по нему подключен ноут. Стационар подключен к первому Ethernet
На стационарном компе инет есть на ноуте нет даже после подключения к второму ethernet.
Лог:
Jan 1 12:00:10> Valid Configuration Tree
Jan 1 12:00:10> NTP Polling Timer for DHCP Started succesfully.
Jan 1 12:00:10> DSL Polling Timer Started succesfully.
Jan 1 12:00:10> doing modulation_set.
Jan 1 12:00:11> Firewall NAT service started
Jan 1 12:00:12> starting on port 80
Jan 1 12:00:12> Init the gre conntrack!
Jan 1 12:00:12> Init the gre nat!
Jan 1 12:00:12> ip_conntrack_pptp version 1.9 loaded
Jan 1 12:00:12> ip_nat_pptp version 1.5 loaded
Jan 1 12:00:12> (c)2000 Netfilter core team
Jan 1 12:00:12> netfilter PSD loaded - (c) astaro AG
Jan 1 12:00:12> Initializing the WAN Bridge.
Jan 1 12:00:12> Please set the MAC Address for the WAN Bridge.
Jan 1 12:00:12> Set the Environment variable 'wan_br_mac'.
Jan 1 12:00:12> xx.xx.xx.xx.xx.xx
Jan 1 12:00:12> Mounted root (squashfs filesystem) readonly.
Jan 1 12:00:12> Mounted devfs on /dev
Jan 1 12:00:13> 60k freed
Jan 1 12:00:13> Algorithmics/MIPS FPU Emulator v1.5
Jan 1 12:00:13> registered device TI Avalanche SAR
Jan 1 12:00:13> version:[4.03.03.00]
Jan 1 12:00:13> Default Asymmetric MTU for nas0 1500
Jan 1 12:00:13> Registering protocol inspector: 0x94168224 for VCC:0x9401fa00
Jan 1 12:00:13> Default Asymmetric MTU for br0 1500
Jan 1 12:00:13> Bridge Created: br0
Jan 1 12:00:13> WPA Authenticator Started
Jan 1 12:00:13> Bridge Created: br1
Jan 1 12:00:14> Bridge Interface Added: eth0
Jan 1 12:00:15> Default Asymmetric MTU for br1 1500
Jan 1 12:00:15> ZIPB............
Jan 1 12:00:15> 2
Jan 1 12:00:15> 2
Jan 1 12:00:18> Default Asymmetric MTU for wlan0 1500
Jan 1 12:00:18> AP Driver configuration successful
Jan 1 12:00:23> AP IS UP
Jan 1 12:00:23>
Jan 1 12:00:23> No Module Description from Interface Below
Jan 1 12:00:23> disabled.
Jan 1 12:00:23> 802.11h is 200: disabled.
Jan 1 12:00:23> Configuration succeeded !!!
Jan 1 12:00:23> WLAN driver database is up
Jan 1 12:00:23> Resetting the remote device.
Jan 1 12:00:23> Un-resetting the remote device.
Jan 1 12:00:23> About to re-init the VLYNQ.
Jan 1 12:00:23> Re-initialized the VLYNQ.
Jan 1 12:00:23> AcxRegAddr = 0xA4040000, AcxMemAddr = 0xA4000000
Jan 1 12:00:23> whal_acxProcInitiate: found DEVICE_VENDOR ID = 0x9066104c
Jan 1 12:00:23> whal_acxProcInitiate: Cpu halt -} download code
Jan 1 12:00:23> whal_acxProcLoadFwImage: 0xa4000000, 0x0
Jan 1 12:00:23> whal_acxProcLoadFwImage() -- Loading FW image200: Compiled for RADIA (bg) radio
Jan 1 12:00:23> whal_acxProcLoadFwImage: 1, pBuf=0xc00a2000, len=0x15564. Extra pBuf=0x0, len=0x3
Jan 1 12:00:23> whal_acxProcLoadFwImage: 2, pBuf=0xc00a2000, len=0x15564. Extra pBuf=0x0, len=0x3
Jan 1 12:00:23> whal_acxProcLoadFwImage: 3, pBuf=0xc00a2000, len=0x15564, DataLen=0x1555c
Jan 1 12:00:23> whal_acxProcLoadFwImage: 4, pBuf=0xc00a2000, len=0x15564
Jan 1 12:00:23> whal_acxProcLoadFwImage: Checksum, calc=0x71e76f, file=0x71e76f
Jan 1 12:00:23> BssBridge is up
Jan 1 12:00:23> Mgmt is up
Jan 1 12:00:23> Rx is up
Jan 1 12:00:23> Tx is up
Jan 1 12:00:23> MemMngr is up
Jan 1 12:00:23> main state machine is up
Jan 1 12:00:23> WDRV_MAINSM: WLAN Driver initialized successfully
Jan 1 12:00:23>
Jan 1 12:00:23> WDRV_4X: 4x Disabled
Jan 1 12:00:23> WDRV_4X: Concatenation Disabled
Jan 1 12:00:23> WDRV_4X: Ack Emulation Disabled
Jan 1 12:00:23> whal_apiStartBss: Enable Tx, Rx and Start the Bss
Jan 1 12:00:23> ----------------------------------------------------------------
Jan 1 12:00:23> START BSS, SSID=удалил, BSSID=удалил
Jan 1 12:00:23> AP Power Level = 2
Jan 1 12:00:23> Regulatory Domain = ETSI
Jan 1 12:00:23> Net[0] : Channel=6
Jan 1 12:00:23> FW Watchdog is Enabled
Jan 1 12:00:23> DSL Carrier is down
Jan 1 12:00:23> Bridge Interface Added: wlan0
Jan 1 12:00:43> DSL in Sync
Jan 1 12:00:43> DSL Carrier is up
Jan 1 12:00:44> pppd 2.4.3 started by root, uid 0
Jan 1 12:00:44> Connect: ppp0 {--} nas0
Jan 1 12:00:46> peer from calling number удалил authorized
Jan 1 12:00:46> ppp0
Jan 1 12:00:46> WAN IP address 89.109.234.145
Jan 1 12:00:46> WAN gateway 172.16.0.225
Jan 1 12:00:46> primary DNS address 213.140.231.18
Jan 1 12:00:46> secondary DNS address 213.140.228.218
Jan 1 12:00:46> PPPoE Connect with IP Address 89.109.234.145
Jan 1 12:00:47> PPPoE Connection Successfully Established
Jan 1 12:00:47> PPPoE Connect with Gateway IP Address: 172.16.0.225
Пожалуйста помогите.
СообщениеДобавлено: Сб сен 02, 2006 14:29
Меня в основном интересует могу ли я на стороне модема отслеживать приход уход пакетов.... требуется более детальная информация чем лог... Это возможно?
СообщениеДобавлено: Вс сен 03, 2006 13:03
Может это глюк... но заработало после того как я сделал pvc0 в режим бриджа со стандартными настройками. А уже на pvc1 настроил PPPoE ...
Буду очень благодарен если прокоментируете
СообщениеДобавлено: Вс сен 03, 2006 13:17
Нет радовался рано. Открывался только сайт провайдера.... а после перевода WiFi в режим защиты WPA по строковому ключу.... опять трасировка не проходит до конца..... можно всеже поподробней принцип работы??????
СообщениеДобавлено: Вс сен 03, 2006 21:24
Блин разговор с самим собой :-( ну да ладно. Замена Home на Pro версию XP "вылечела" буду рыть почему.
