Текущее время: Пн ноя 02, 2026 17:06
 Заголовок сообщения: ПРОБЛЕМА С 504Т
СообщениеДобавлено: Ср июл 26, 2006 12:22
V2.01B01T01.RU.20060522 вчера залил эту прошивку.
где то через час работы ситуация следующая - POWER горит, Статус не мигает, хотя он должен постояно мигать, ЛАН порт рабочей машины горит - пытаюсь зайти в настройки через WEBм - нехочет, пезагружаю 504-ку - все нормально.
Вот лог - посмотри или подскажи пожалуйста в чем беда!!!
лог до ресета ( У провайдера я пока отключен)
Jan 1 12:00:10>The firmware build date/time:20060522005529
Jan 1 12:00:10> Valid Configuration Tree
Jan 1 12:00:10> NTP Polling Timer for DHCP Started succesfully.
Jan 1 12:00:10> DSL Polling Timer Started succesfully.
Jan 1 12:00:10> doing modulation_set.
Jan 1 12:00:11> Firewall NAT service started
Jan 1 12:00:13> starting on port 80
Jan 1 12:00:13> Bridge Created: br0
Jan 1 12:00:14> Bridge Created: br1
Jan 1 12:00:14> Bridge Interface Added: eth0
Jan 1 12:00:20> DSL Carrier is down
Jan 1 12:00:30> DSL Carrier is up
Jan 1 12:00:31> pppd 2.4.3 started by root, uid 0
Jan 1 12:00:31> Connect: ppp0 {--} nas0
Jan 1 12:00:33> PAP authentication failed
Jan 1 12:00:33> Connection terminated.
Jan 1 12:00:35> pppd 2.4.3 started by root, uid 0
Jan 1 12:00:35> Connect: ppp0 {--} nas0
Jan 1 12:00:37> PAP authentication failed
Jan 1 12:00:38> Connection terminated.
Jan 1 12:00:40> pppd 2.4.3 started by root, uid 0
Jan 1 12:00:40> Connect: ppp0 {--} nas0
Jan 1 12:00:42> PAP authentication failed
Jan 1 12:00:42> Connection terminated.
Jan 1 12:00:42> pppd 2.4.3 started by root, uid 0
Jan 1 12:00:42> Connect: ppp0 {--} nas0
Jan 1 12:00:44> PAP authentication failed
Jan 1 12:00:44> Connection terminated.
Jan 1 12:00:44> pppd 2.4.3 started by root, uid 0
Jan 1 12:00:44> Connect: ppp0 {--} nas0
Jan 1 12:00:46> PAP authentication failed
Jan 1 12:00:46> Connection terminated.
Jan 1 12:00:47> pppd 2.4.3 started by root, uid 0
Jan 1 12:00:47> Connect: ppp0 {--} nas0
Jan 1 12:00:49> PAP authentication failed
Jan 1 12:00:49> Connection terminated.
Jan 1 12:00:49> pppd 2.4.3 started by root, uid 0
Jan 1 12:00:49> Connect: ppp0 {--} nas0
Jan 1 12:00:51> PAP authentication failed
Jan 1 12:00:51> Connection terminated.
Jan 1 12:00:53> pppd 2.4.3 started by root, uid 0
Jan 1 12:00:53> Connect: ppp0 {--} nas0
Jan 1 12:00:55> PAP authentication failed
Jan 1 12:00:55> Connection terminated.
Jan 1 12:00:56> pppd 2.4.3 started by root, uid 0
Jan 1 12:00:56> Connect: ppp0 {--} nas0
Jan 1 12:00:59> PAP authentication failed
Jan 1 12:00:59> Connection terminated.
Jan 1 12:01:00> pppd 2.4.3 started by root, uid 0
Jan 1 12:01:00> Connect: ppp0 {--} nas0
Jan 1 12:01:02> PAP authentication failed
Jan 1 12:01:02> Connection terminated.
Jan 1 12:01:02> pppd 2.4.3 started by root, uid 0
Jan 1 12:01:02> Connect: ppp0 {--} nas0
Jan 1 12:01:04> PAP authentication failed
Jan 1 12:01:04> Connection terminated.
Jan 1 12:01:05> pppd 2.4.3 started by root, uid 0
Jan 1 12:01:05> Connect: ppp0 {--} nas0
Jan 1 12:01:07> PAP authentication failed
Jan 1 12:01:07> Connection terminated.
Jan 1 12:01:10> pppd 2.4.3 started by root, uid 0
Jan 1 12:01:23> PAP authentication failed
Jan 1 12:01:23> Connection terminated.
Jan 1 12:01:23> pppd 2.4.3 started by root, uid 0
Jan 1 12:01:23> Connect: ppp0 {--} nas0
Jan 1 12:01:25> PAP authentication failed
Jan 1 12:01:25> Connection terminated.
Jan 1 12:01:26> pppd 2.4.3 started by root, uid 0
Jan 1 12:01:26> Connect: ppp0 {--} nas0
Jan 1 12:01:28> PAP authentication failed
Jan 1 12:01:28> Connection terminated.
Jan 1 12:01:29> pppd 2.4.3 started by root, uid 0
Jan 1 12:01:29> Connect: ppp0 {--} nas0
Jan 1 12:01:31> PAP authentication failed
Jan 1 12:01:31> Connection terminated.
Jan 1 12:01:35> pppd 2.4.3 started by root, uid 0
Jan 1 12:01:35> Connect: ppp0 {--} nas0
Jan 1 12:01:37> PAP authentication failed
Jan 1 12:01:37> Connection terminated.
Jan 1 12:01:40> pppd 2.4.3 started by root, uid 0
Jan 1 12:01:40> Connect: ppp0 {--} nas0
после ресета
Jan 1 12:00:15> Bridge Interface Added: eth0
Jan 1 12:01:00> DSL Carrier is up
Jan 1 12:01:01> pppd 2.4.3 started by root, uid 0
Jan 1 12:01:36> Timeout waiting for PADO packets
Jan 1 12:01:36> Unable to complete PPPoE Discovery
Jan 1 12:01:36> PPPD Successfully Launched
Jan 1 12:02:15> Timeout waiting for PADO packets
Jan 1 12:02:15> Unable to complete PPPoE Discovery
Jan 1 12:02:15> PPPD Successfully Launched
Jan 1 12:02:16> pppd 2.4.3 started by root, uid 0
Jan 1 12:02:51> Timeout waiting for PADO packets
Jan 1 12:02:51> Unable to complete PPPoE Discovery
Jan 1 12:02:51> PPPD Successfully Launched
Jan 1 12:02:56> pppd 2.4.3 started by root, uid 0
Jan 1 12:03:31> PPPD Successfully Launched
Jan 1 12:03:31> Timeout waiting for PADO packets
Jan 1 12:03:31> Unable to complete PPPoE Discovery
Jan 1 12:03:31> pppd 2.4.3 started by root, uid 0
Jan 1 12:04:07> Timeout waiting for PADO packets
Jan 1 12:04:07> Unable to complete PPPoE Discovery
Jan 1 12:04:07> PPPD Successfully Launched
Jan 1 12:04:11> pppd 2.4.3 started by root, uid 0
Или как один из вариантов перешить ее в краш моде??????????
СообщениеДобавлено: Ср июл 26, 2006 13:01
Судя по логу, все нормально. В первом варианте не проходит аутентификация, во втором - не устанавливается PPPoE сессия. Вы же сами сказали, что провайдер вас не подключил...
С уважением, Давыдов Денис.
СообщениеДобавлено: Чт июл 27, 2006 15:20
Вопрос не в этом заключался, лог я привел, что показать что все правильно. во почему с этой версии прошивки 504-ка вешается через час работы?
СообщениеДобавлено: Чт июл 27, 2006 16:41
Config после перепрошивки вливали? Верните устройство к заводским установкам и перенастройте.
