Текущее время: Ср сен 30, 2026 12:50
СообщениеДобавлено: Ср июн 07, 2006 21:48
При заходе в меню Advanced/Filters появляются в логе записи:
cfgmgr(fdb): Jun 7 19:26:06> Maximum Number (20) of User Rules Reached
cfgmgr(fdb): Jun 7 20:26:54> Maximum Number (20) of User Rules Reached
cfgmgr(fdb): Jun 7 22:41:25> Maximum Number (20) of User Rules Reached
cfgmgr(fdb): Jun 7 22:41:33> Maximum Number (20) of User Rules Reached
При записи правил:
webcm: Jan 1 12:09:01> set error: message= :Bad key 'settings/categoryF//description' in 'fdb':
webcm: Jan 1 12:09:01> set error: message= :Bad key 'settings/categoryF//protocolport1/in_out' in 'fdb':
webcm: Jan 1 12:09:01> set error: message= :Bad key 'settings/categoryF//protocolport1/portend' in 'fdb':
webcm: Jan 1 12:09:01> set error: message= :Bad key 'settings/categoryF//protocolport1/portmap' in 'fdb':
webcm: Jan 1 12:09:01> set error: message= :Bad key 'settings/categoryF//protocolport1/sip_range' in 'fdb':
webcm: Jan 1 12:09:01> set error: message= :Bad key 'settings/categoryF//protocolport1/dip_range' in 'fdb':
webcm: Jan 1 12:09:01> set error: message= :Bad key 'settings/categoryF//protocolport1/sport_range' in 'fdb':
webcm: Jan 1 12:09:01> set error: message= :Bad key 'settings/categoryF//protocolport1/dport_range' in 'fdb':
webcm: Jan 1 12:09:01> set error: message= :Bad key 'settings/categoryF//protocolport1/sip_start' in 'fdb':
webcm: Jan 1 12:09:01> set error: message= :Bad key 'settings/categoryF//protocolport1/sip_end' in 'fdb':
webcm: Jan 1 12:09:01> set error: message= :Bad key 'settings/categoryF//protocolport1/dip_start' in 'fdb':
webcm: Jan 1 12:09:01> set error: message= :Bad key 'settings/categoryF//protocolport1/dip_end' in 'fdb':
webcm: Jan 1 12:09:01> set error: message= :Bad key 'settings/categoryF//protocolport1/sport_start' in 'fdb':
webcm: Jan 1 12:09:01> set error: message= :Bad key 'settings/categoryF//protocolport1/sport_end' in 'fdb':
webcm: Jan 1 12:09:01> set error: message= :Bad key 'settings/categoryF//protocolport1/dport_start' in 'fdb':
webcm: Jan 1 12:09:02> set error: message= :Bad key 'settings/categoryF//protocolport1/dport_end' in 'fdb':
webcm: Jan 1 12:09:02> set error: message= :Bad key 'settings/categoryF//protocolport1/protocol' in 'fdb':
webcm: Jan 1 12:09:02> set error: message= :Bad key 'settings/categoryF//protocolport1/accept_drop' in 'fdb':
Подобное уже было в предидущих прошивках..... :cry: Только как исправили Maximum Number (20) of User Rules Reached..... И вот те новенькое : set error: message= :Bad key 'settings/categoryF//protocolport1/accept_drop' in 'fdb':..... :? Мда.... Нет слов, одни ....... :(
СообщениеДобавлено: Чт июн 08, 2006 11:21
Версия прошивки? Правила работают или нет?
С уважением, Давыдов Денис.
СообщениеДобавлено: Сб июн 10, 2006 00:16
Простите за склероз. :oops:
F/W V2.01B01T01.RU.20060522
Проблема вроде решилась перепрошивкой.
Но перепрошивка далась с трудом - пришлось с помощью V2.00B01T01.EU.20050630 перешивать. Хотя прошивка заливается очень долго по сравнению с предидущими прошивками. Пробывал несколько раз с разными F/W.
Хотя есть проблема с коннектом:
При коннекте у модема как бы зависает ВЕБ интерфейс и нет выхода в интернет, но в логах пишет что соединение установленно. Через некоторое время, от 10 до 40 минут, все нормализуется, т.е. работает ВЕБ интерфейс и интернет. Пока не знаю на что грешить.
З.Ы.
Простите за поднятый шум - был не прав. :oops:
СообщениеДобавлено: Пн июн 12, 2006 01:40
Sokolikov Andrey писал(а):
З.Ы.
DSL-504TRU
Нет, шум был поднят правильно. Продолжается:
cfgmgr(fdb): Jun 12 02:18:03> Maximum Number (20) of User Rules Reached
cfgmgr(fdb): Jun 12 02:18:04> Maximum Number (20) of User Rules Reached
cfgmgr(fdb): Jun 12 02:18:05> Maximum Number (20) of User Rules Reached
cfgmgr(fdb): Jun 12 02:18:30> Maximum Number (20) of User Rules Reached
cfgmgr(fdb): Jun 12 02:18:31> Maximum Number (20) of User Rules Reached
cfgmgr(fdb): Jun 12 02:18:32> Maximum Number (20) of User Rules Reached
cfgmgr(fdb): Jun 12 02:18:41> Maximum Number (20) of User Rules Reached
cfgmgr(fdb): Jun 12 02:21:27> Maximum Number (20) of User Rules Reached
cfgmgr(fdb): Jun 12 02:22:09> Maximum Number (20) of User Rules Reached
cfgmgr(fdb): Jun 12 02:22:10> Maximum Number (20) of User Rules Reached
cfgmgr(fdb): Jun 12 02:22:12> Maximum Number (20) of User Rules Reached
cfgmgr(fdb): Jun 12 02:22:15> Maximum Number (20) of User Rules Reached
cfgmgr(fdb): Jun 12 02:23:07> Maximum Number (20) of User Rules Reached
cfgmgr(fdb): Jun 12 02:23:08> Maximum Number (20) of User Rules Reached
cfgmgr(fdb): Jun 12 02:23:09> Maximum Number (20) of User Rules Reached
Появляется не сразу, а через некоторое время при заходе в Virtual Server или Filters. При этом нанные страницы инткрфейса начинают подтормаживать. Правила вроде работают. Проверю во вторник. Вообще-то об этом говорилось еще с прошлого года. http://www.dlink.ru/phorum/viewtopic.ph ... hed#107908 сдесь описанно и сдесь http://www.dlink.ru/phorum/viewtopic.ph ... hed#104228 и сдесь http://www.dlink.ru/phorum/viewtopic.ph ... ched#74524.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 59
