Текущее время: Чт окт 01, 2026 04:23
 Заголовок сообщения: Как настроить DSL504T
СообщениеДобавлено: Вс фев 19, 2006 15:52
1) 4 компа (IP соответственно 192.168.0.102 -- 192.168.0.105).
2) Роутер DSL504T (IP 192.168.1.1), одним концом смотрящий в WebPlus
Firmware Version : V2.00B01T01.EU.20050630
параметры Pvc0:
VPI 1
VCI 32
Virtual Circuit Enabled
WAN Setting PPPoE/PPPoA
PPPoE/PPPoA
Connection Type PPPoE LLC
Default Route Enabled
NAT Enabled
Firewall Enabled
Захожу в Tools->Test
Результаты теста:
Testing Ethernet LAN connection PASS
Testing ADSL Synchronization PASS
Testing ATM OAM segment ping FAIL
Testing ATM OAM end to end ping FAIL
Ping Primary Domain Names Server FAIL
Захожу в Status->Log
Jan 1 12:04:43> PPPoE Connect with Gateway IP Address: 1.1.3.1
Jan 1 12:04:43> WAN gateway 1.1.3.1
Jan 1 12:05:00> DSL Carrier is down
Jan 1 12:05:10> DSL Carrier is up
Jan 1 12:05:11> PPPD Terminated Through Signal
Jan 1 12:05:11> Connection terminated.
Jan 1 12:05:11> Doing disconnect
Jan 1 12:05:11> pppd 2.4.1 started by root, uid 0
Jan 1 12:05:11> Got connection: 519
Jan 1 12:05:11> Saved Session ID: 0
Jan 1 12:05:11> Connecting PPPoE socket: 00:16:47:cc:0b:30 0519 nas0 0x1000d378
Jan 1 12:05:11> Connect: ppp0 {--} nas0
Jan 1 12:05:14> WAN IP address 192.168.108.153
Jan 1 12:05:14> PPPoE Connect with IP Address 192.168.108.153
Jan 1 12:05:14> PPPoE Connection Successfully Established
Jan 1 12:05:14> PPPoE Connect with Gateway IP Address: 1.1.3.1
Jan 1 12:05:14> WAN gateway 1.1.3.1
Jan 1 12:05:20> DSL Carrier is down
Jan 1 12:05:40> DSL Carrier is up
Jan 1 12:05:41> PPPD Terminated Through Signal
Jan 1 12:05:41> Connection terminated.
Jan 1 12:05:41> Doing disconnect
Jan 1 12:05:41> pppd 2.4.1 started by root, uid 0
Jan 1 12:05:41> Got connection: 619
Jan 1 12:05:41> Saved Session ID: 0
Jan 1 12:05:41> Connecting PPPoE socket: 00:16:47:cc:0b:30 0619 nas0 0x1000d378
Jan 1 12:05:41> Connect: ppp0 {--} nas0
Jan 1 12:05:50> DSL Carrier is down
Jan 1 12:06:00> DSL Carrier is up
Jan 1 12:06:00> pppd 2.4.1 started by root, uid 0
Jan 1 12:06:20> DSL Carrier is down
Jan 1 12:06:30> DSL Carrier is training
Особенно меня заинтересовала строка
"PPPoE Connect with Gateway IP Address: 1.1.3.1"
Откуда взялся шлюз 1.1.3.1? Я такого не вводил!!!
Как мне заменить этот шлюз на тот, который использует WebPlus?
Захожу в DSL504T посредством TELNET и делаю route:
# route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
192.168.1.0 * 255.255.255.0 U 0 0 0 br0
239.0.0.0 * 255.0.0.0 U 1 0 0 br0
Делаю попытку добавить шлюз по умолчанию:
route add default gateway 192.168.108.1 nas0
SIOCADDRT: Network is unreachable
Вопрос: как с этим бороться?
С Уважением
http://www.webprogrammer.spb.ru
СообщениеДобавлено: Вс фев 19, 2006 16:07
Этот шлюз, как я понимаю, стандартный для РРРоЕ
ВебПлас (195.131.х.х) DSL-500T(ADSL2)
СообщениеДобавлено: Вс фев 19, 2006 16:10
Почему же тогда в службе поддержки WebPlus мне рекоммендовали прописать их шлюз 192.168.108.1 ?
С Уважением
СообщениеДобавлено: Вс фев 19, 2006 16:27
У меня ощущение, что в тех.поддержке ВебПласа плохо разбираются в РРРоЕ. Вся сеть у них на статик построена, а люди там работают, на мой взгляд, не совсем квалифицированые!
Если у Вас фиксированый IP адрес принадлежщий подсети 192.168.108.х, тогда шлюз должен быть 192.168.108.1. А на РРРоЕ адрес все время меняется.
Последний раз редактировалось pindos Вс фев 19, 2006 16:45, всего редактировалось 1 раз.
СообщениеДобавлено: Вс фев 19, 2006 16:43
К тому же строки:
говорят о том, что связь просто рвется. Может быть плохое качество линии.
СообщениеДобавлено: Пн фев 20, 2006 17:23
1.1.3.1 - я так понимаю - это гейт для nas0... Посмотрите, что говорит ifconfig...
А уж поверх nas0 появится ppp0 с теми адресами, что говорил ВебПлюс. И, видимо, именно для ppp0 должен быть указан дефолтовый гейт...
В любом случае, ifconfig должен дать ответ...
СообщениеДобавлено: Ср фев 22, 2006 15:18
У меня тесты так же как у вас, только последний проходит.
Перешил ведь на ту же прошивку адсл+.
На старой, пппое поднимался, на новой сначала при таких же настройках не стал. Помогло выставив модуляцию G.dmt.
Правда после пошло и с мультимодом.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 105
