Текущее время: Чт окт 01, 2026 11:04
СообщениеДобавлено: Пт ноя 11, 2005 22:28
Господа,
после прошивки ADSL2 на DSL-G604T и установки работы в режиме рутера возникла проблема - модем не восстанавливает связь после обрыва. Учитывая, что обрав происходит всегда 1 раз в 24 часа - то получается, что проверять работу можма надо ежедневно.
Что делать?
ЛОГ
Nov 11 20:34:27> Connection terminated.
Nov 11 20:34:27> Doing disconnect
Nov 11 20:34:28> pppd 2.4.1 started by root, uid 0
Nov 11 20:34:28> Got connection: e31c
Nov 11 20:34:28> Saved Session ID: 0
Nov 11 20:34:28> Connecting PPPoE socket: 00:30:88:00:3d:06 e31c nas0 0x1000d378
Nov 11 20:34:28> Connect: ppp0 {--} nas0
Nov 11 20:34:29> CHAP authentication failed
Nov 11 20:34:29> Connection terminated.
Nov 11 20:34:29> Doing disconnect
Nov 11 20:34:32> pppd 2.4.1 started by root, uid 0
Nov 11 20:34:33> Got connection: e41c
Nov 11 20:34:33> Saved Session ID: 0
Nov 11 20:34:33> Connecting PPPoE socket: 00:30:88:00:3d:06 e41c nas0 0x1000d378
Nov 11 20:34:33> Connect: ppp0 {--} nas0
Nov 11 20:34:33> CHAP authentication failed
Nov 11 20:34:33> Connection terminated.
Nov 11 20:34:33> Doing disconnect
Nov 11 21:52:33> Parameter Option Error
Nov 11 21:52:33> Default Asymmetric MTU for nas0 1500
Nov 11 21:52:33> Registering protocol inspector: 0x941544cc for VCC:0x94019a00
Nov 11 21:52:34> pppd 2.4.1 started by root, uid 0
Nov 11 21:52:44> Got connection: 540b
Nov 11 21:52:44> Saved Session ID: 0
Nov 11 21:52:44> Connecting PPPoE socket: 00:30:88:00:3d:06 540b nas0 0x1000d378
Nov 11 21:52:44> Connect: ppp0 {--} nas0
Nov 11 21:52:44> PPPoE Connect with IP Address 85.140.12.151
Nov 11 21:52:44> PPPoE Connection Successfully Established
Nov 11 21:52:44> PPPoE Connect with Gateway IP Address: 85.140.12.1
Nov 11 21:52:44> WAN IP address 85.140.12.151
Nov 11 21:52:44> WAN gateway 85.140.12.1
Nov 11 21:52:44> ppp0
СообщениеДобавлено: Пн ноя 14, 2005 11:19
PASHKA писал(а):
Господа,
Что делать?
ЛОГ
1. Смените прошивку.
2. По логам не заметно, что модем не восстанавливает соединение...
СообщениеДобавлено: Пн ноя 14, 2005 12:59
Приходится ВРУЧНУЮ нажимать кнопку CONNECT на вкладке Advanced\PPP
Сменить прошивку? На какую? У меня ADSL2 скачанная с Вашего сайта ftp.dlink.ru
СообщениеДобавлено: Пн ноя 14, 2005 15:29
Это проблема сервера провайдера. Он не позволяет авторизоваться DSL-G604T.
Простите, не туда посмотрел...не надо менять прошивку.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 49
