Текущее время: Чт окт 01, 2026 11:13
СообщениеДобавлено: Чт ноя 03, 2005 11:39
Привествую.
Сразу хочу извиниться, если эта тема уже обсуждалась.
Я не уверен, что проблема именно в модеме, но ситуация следующая.
Мы с парнем на двоих взяли модем D-LINK DSL 500T и свич на 5 портов. Наши знакомые по нашему же совету поступили также через 3 дня после нашей покупки.
Связь рвется достаточно часто, что у них, что у нас. Приведу пример лога. :
Nov  1 21:03:46> Connect: ppp0 {--} nas0
Nov  1 21:03:47> CHAP authentication failed
Nov  1 21:03:47> Connection terminated.
Nov  1 21:03:47> Doing disconnect
Nov  1 21:03:47> Failed to Authenicate
Nov  1 21:03:53> pppd 2.4.1 started by root, uid 0
Nov  1 21:03:53> Connecting PPPoE socket: 00:30:88:00:94:63 c318 nas0 0x1000d3b8
Nov  1 21:03:53> Connect: ppp0 {--} nas0
Nov  1 21:03:54> CHAP authentication failed
Nov  1 21:03:54> Connection terminated.
Nov  1 21:03:54> Doing disconnect
Nov  1 21:03:54> Failed to Authenicate
Nov  1 21:03:59> pppd 2.4.1 started by root, uid 0
Nov  1 21:03:59> Connecting PPPoE socket: 00:30:88:00:94:63 cc06 nas0 0x1000d3b8
Nov  1 21:03:59> Connect: ppp0 {--} nas0
Nov  1 21:04:00> CHAP authentication failed
Nov  1 21:04:00> Connection terminated.
Nov  1 21:04:00> Doing disconnect
Nov  1 21:04:00> Failed to Authenicate
Nov  1 21:04:05> pppd 2.4.1 started by root, uid 0
Nov  1 21:04:05> Connecting PPPoE socket: 00:30:88:00:94:63 cc09 nas0 0x1000d3b8
Nov  1 21:04:05> Connect: ppp0 {--} nas0
Nov  1 21:04:10> WAN IP address 85.140.81.200
Nov  1 21:04:10> PPPoE Connect with IP Address 85.140.81.200
Nov  1 21:04:10> WAN gateway 85.140.80.1
Nov  1 21:04:10> primary   DNS address 212.188.4.10
Nov  1 21:04:10> secondary DNS address 195.34.32.116
Nov  1 21:04:10> PPPoE Connection Successfully Established
Nov  1 21:04:10> PPPoE Connect with Gateway IP Address: 85.140.80.1
Nov  1 21:05:33> Connection terminated.
Nov  1 21:05:35> Doing disconnect
Nov  1 21:05:36> pppd 2.4.1 started by root, uid 0
Nov  1 21:05:36> Connecting PPPoE socket: 00:30:88:00:94:63 f718 nas0 0x1000d3b8
Nov  1 21:05:36> Connect: ppp0 {--} nas0
Nov  1 21:05:37> CHAP authentication failed
Nov  1 21:05:37> Connection terminated.
Nov  1 21:05:37> Doing disconnect
Nov  1 21:05:37> Failed to Authenicate
Nov  1 21:05:42> pppd 2.4.1 started by root, uid 0
Nov  1 21:05:42> Connecting PPPoE socket: 00:30:88:00:94:63 0219 nas0 0x1000d3b8
Nov  1 21:05:42> Connect: ppp0 {--} nas0
Nov  1 21:05:43> WAN IP address 85.140.81.213
Nov  1 21:05:43> PPPoE Connect with IP Address 85.140.81.213
Nov  1 21:05:43> WAN gateway 85.140.80.1
Nov  1 21:05:43> primary   DNS address 212.188.4.10
Nov  1 21:05:43> secondary DNS address 195.34.32.116
Nov  1 21:05:43> PPPoE Connection Successfully Established
Nov  1 21:05:43> PPPoE Connect with Gateway IP Address: 85.140.80.1
Не могу понять 2 вещи:
1) Почему он НЕ принимал пароль (хотя его никто не поменял и он с ним зашел без проблем)
2) Почему он порвал соединение сразу после авторизации.
3) Как избавиться от постоянных разрывов связи?
Ну и основное - как это лечить, что делать?
Прошивку НЕ менял. Знакомые меняли. Все также.
Стрим НЕО-25, АТС 712. У других знакомых (из моего же дома) модемы зухелевские, на связь не жалуются.
Еще раз извините, если тема уже обсуждалась.
Заранее спасибо.
С уважением, Алексей.
СообщениеДобавлено: Чт ноя 03, 2005 11:40
Извините, тормознуло - случайно второй раз отправил.
СообщениеДобавлено: Чт ноя 03, 2005 12:20
1. Обращайтесь к провайдеру по ппроблемам аунтификации
2. Провайдер должен изменить модуляцию на GDMT или T1,413.
С уважением, Ежов Игорь.
Почта: iezhov@dlink.ru
Телефон: 744-00-99 +398
Адрес СЦ: г. Москва, Графский пер., д. 14, 3 этаж.
СообщениеДобавлено: Чт ноя 03, 2005 12:22
1. Обращайтесь к провайдеру по проблемам аунтификации
СообщениеДобавлено: Чт ноя 03, 2005 12:26
Спасибо за ответ.
Как я понимаю, сотрудники МТУ должны изменить модуляцию именно для моего канала, верно?
СообщениеДобавлено: Чт ноя 03, 2005 12:38
Именно так.
СообщениеДобавлено: Чт ноя 03, 2005 12:48
Большое спасибо, будем разговаривать с МТУ.
О результатах обязательно сообщу.
Сейчас этот форум просматривают: Baidu [Spider] и гости: 56
