Текущее время: Чт окт 01, 2026 11:13
 Заголовок сообщения: G604T: pppoe рассоединяется часто
СообщениеДобавлено: Сб окт 29, 2005 15:46
Здравствуйте!
Год модем проработал в режиме бриджа, никаких проблем не было. Но понадобилось наконец задействовать wi-fi, и теперь наблюдаются частые (раз в две минуты) кратковременные рассоединения ppp. Иногда, впрочем, может простоять без разрывов пару часов, но чаще всего лог выглядит так:
Oct 29 11:52:50> Connection terminated.
Oct 29 11:52:50> Doing disconnect
Oct 29 11:52:50> PPPD Successfully Launched
Oct 29 11:52:55> pppd 2.4.1 started by root, uid 0
Oct 29 11:52:55> Connecting PPPoE socket: 00:e0:fc:2b:3d:33 2502 nas1 0x1000d3b8
Oct 29 11:52:55> Connect: ppp0 {--} nas1
Oct 29 11:52:58> WAN IP address xx.xx.xx.xx
Oct 29 11:52:58> PPPoE Connect with IP Address xx.xx.xx.xx
Oct 29 11:52:58> WAN gateway yy.yy.yy.yy
Oct 29 11:52:58> PPPoE Connection Successfully Established
Oct 29 11:52:58> PPPoE Connect with Gateway IP Address: yy.yy.yy.yy
Oct 29 11:55:02> Connection terminated.
Oct 29 11:55:02> Doing disconnect
Oct 29 11:55:02> PPPD Successfully Launched
Oct 29 11:55:07> pppd 2.4.1 started by root, uid 0
Oct 29 11:55:07> Connecting PPPoE socket: 00:e0:fc:2b:3d:33 2502 nas1 0x1000d3b8
Oct 29 11:55:07> Connect: ppp0 {--} nas1
Oct 29 11:55:10> WAN IP address xx.xx.xx.xx
Oct 29 11:55:10> PPPoE Connect with IP Address xx.xx.xx.xx
Oct 29 11:55:10> WAN gateway yy.yy.yy.yy
Oct 29 11:55:10> PPPoE Connection Successfully Established
Oct 29 11:55:10> PPPoE Connect with Gateway IP Address: yy.yy.yy.yy
Oct 29 11:57:13> Connection terminated.
Oct 29 11:57:13> Doing disconnect
Oct 29 11:57:13> PPPD Successfully Launched
Oct 29 11:57:18> pppd 2.4.1 started by root, uid 0
Oct 29 11:57:18> Connecting PPPoE socket: 00:e0:fc:2b:3d:33 2502 nas1 0x1000d3b8
Oct 29 11:57:18> Connect: ppp0 {--} nas1
Oct 29 11:57:21> WAN IP address xx.xx.xx.xx
Oct 29 11:57:21> PPPoE Connect with IP Address xx.xx.xx.xx
Oct 29 11:57:21> WAN gateway yy.yy.yy.yy
Oct 29 11:57:22> PPPoE Connection Successfully Established
Oct 29 11:57:22> PPPoE Connect with Gateway IP Address: yy.yy.yy.yy
Oct 29 12:00:24> Connection terminated.
Oct 29 12:00:24> Doing disconnect
Oct 29 12:00:24> PPPD Successfully Launched
Oct 29 12:00:29> pppd 2.4.1 started by root, uid 0
Oct 29 12:00:29> Connecting PPPoE socket: 00:e0:fc:2b:3d:33 2502 nas1 0x1000d3b8
Oct 29 12:00:29> Connect: ppp0 {--} nas1
Oct 29 12:00:32> WAN IP address xx.xx.xx.xx
Oct 29 12:00:32> PPPoE Connect with IP Address xx.xx.xx.xx
Oct 29 12:00:32> WAN gateway yy.yy.yy.yy
Oct 29 12:00:32> PPPoE Connection Successfully Established
Oct 29 12:00:32> PPPoE Connect with Gateway IP Address: yy.yy.yy.yy
Oct 29 12:02:36> Connection terminated.
Oct 29 12:02:36> Doing disconnect
Oct 29 12:02:36> PPPD Successfully Launched
Oct 29 12:02:41> pppd 2.4.1 started by root, uid 0
Параметры соединения:
Options:  [x] NAT    [x] Firewall
Idle Timeout:  300     sec  <---- поле disabled
Keep Alive:  9999    min
MAX Fail:  100    times
MTU:  1400    bytes
MRU:  1492    bytes
Set Route: [x]    On Demand:  [ ]
Keep Alive пробовал делать 1 минуту, 10 минут - не помогает
MAX Fail был 10 - та же проблема.
Вот конфигурация:
Product Information
Model Number
   DSL-G604T
     Ethernet MAC    xxxxxxx
     DSL MAC    N/A
     AP MAC    yyyyyyyyy
Software Versions
     Gateway    V1.00B02T02.RU.20041014
     ATM Driver    4.01.00.00
     DSL HAL    1.01.00.00
     DSL Datapumps    1.01.00.00 Annex A
     SAR HAL    01.06.06 s
     PDSP Firmware    0.49
     Wireless Firmware    0.3.16.13
     Wireless APDK    5.5.4.24
     Wireless Driver    1.1.2
     Boot Loader    0.22.02
Сорри, что получилось длинно, но может это поможет? :)
Да, wi-fi еще не подключал.
Дмитрий.
СообщениеДобавлено: Вт ноя 01, 2005 11:25
Судя по всему, отключает сессию провайдер. Поинтересуйтесь, пожалуйста, у него почему?
СообщениеДобавлено: Вт ноя 01, 2005 11:54
Спасибо за ответ!
В техподдержке провайдера говорят, что с модема "приходит стоповый пакет каждые две минуты". Посоветовали поменять keep-alive, правда непонятно, разве keep-alive посылает именно стоповые пакеты? Еще посоветовали сделать "полный ресет модему и перенастроить все заново". Или попробовать с другим модемом.
Я так понимаю, что прошивка у меня последняя (из не-ADSL2)? Что посоветуете?
Дмитрий.
СообщениеДобавлено: Вт ноя 01, 2005 12:01
dmitry2005 писал(а):
Спасибо за ответ!
Дмитрий.
keep-alive - механизм обмена lcp сообщениями. Если по истечении time-out-а Keep Alive провайдерский AC не ответил на LCP echo, DSL-G604T, действительно, пошлет PADT и удалит текущую сессию на своей стороне. Настройки 9999 min явно не соответствуют этому "наблюдаются частые (раз в две минуты) кратковременные рассоединения ppp".
Мне думается, что проблема все-таки у провайдера. Чтобы быть точно уверенным, принесите Ваше устройство в офис D-Link в Ростове. Его там бесплатно протестируют.
СообщениеДобавлено: Вт ноя 01, 2005 14:49
Более детальный анализ логов у провайдера показал, что происходит регулярная потеря несущей. При этом "ADSL не разрывается" (со слов техподдержки). Видимо, придется вызвать их на дом со своим модемом и протестировать. Потеря несущей по инициативе модема должна была бы отразиться в логе на модеме?
Дмитрий.
СообщениеДобавлено: Вт ноя 01, 2005 17:16
Дмитрий.
Честно говоря, мне непонятно, что именно имела ввиду т.п. провайдера.
P.S. даже если происходит кратковременный разрыв adsl соединения (dsl is down), DSL-G604T будет ждать 2 минуты прежде чем разорвет PPPoE соединение на своей стороне.
СообщениеДобавлено: Вт ноя 01, 2005 17:25
Да, спасибо. Мне тоже не понятно, но они упираются, придется пригласить в гости чтобы сами проверили. :)
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 57
