Текущее время: Пт окт 30, 2026 20:36
 Заголовок сообщения: D-Link 2650u розъединяет интернет
СообщениеДобавлено: Вс янв 27, 2013 12:14
Здравствуйте такая проблема модем держит интернет 2 часа и заканчивает сессию сам , аналогичная проблема с D-link 2500u там тоже интернет держит 15 минут и разъединяет лог модема 2640U Jan 1 00:00:08 (none) syslog.emerg BCM96345 started: BusyBox v1.00 (2011.04.07-13:25+0000) 98
Jan 1 00:00:08 (none) user.crit kernel: eth0 Link UP 100 mbps full duplex 80
Jan 1 00:00:14 (none) user.crit kernel: Line 0: xDSL G.994 training 74
Jan 1 00:00:19 (none) user.crit kernel: Line 0: ADSL G.992 started 73
Jan 1 00:00:20 (none) user.crit kernel: Line 0: ADSL link down 69
Jan 1 00:00:21 (none) user.crit kernel: Line 0: xDSL G.994 training 74
Jan 1 00:00:26 (none) user.crit kernel: Line 0: ADSL G.992 started 73
Jan 1 00:00:30 (none) user.crit kernel: Line 0: ADSL G.992 channel analysis 82
Jan 1 00:00:35 (none) user.crit kernel: Line 0: ADSL link up, Bearer 0, us=509, ds=10455 95
Jan 1 00:01:09 (none) daemon.crit syslog: PPP server detected. 70
Jan 1 00:01:09 (none) daemon.err syslog: Unexpected packet: Ether addr: 00:90:1a:a3:42:9f (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x002e (PADO) PPPoE tag: type=0102 length=000a (AC Name) data (UTF-8): KRD-E320-3 PPPoE tag: type=0103 length=0004 (Host Uniq) da 303
Jan 1 00:01:09 (none) daemon.err syslog: Unexpected packet: Ether addr: 00:90:1a:a4:45:43 (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x002e (PADO) PPPoE tag: type=0102 length=000a (AC Name) data (UTF-8): KRD-E320-1 PPPoE tag: type=0103 length=0004 (Host Uniq) da 303
Jan 1 00:02:48 (none) user.crit kernel: Line 0: ADSL link down 69
Jan 1 00:02:51 (none) user.crit kernel: Line 0: xDSL G.994 training 74
Jan 1 00:02:55 (none) user.crit kernel: Line 0: ADSL G.992 started 73
Jan 1 00:02:56 (none) user.crit kernel: Line 0: ADSL link down 69
Jan 1 00:02:57 (none) user.crit kernel: Line 0: xDSL G.994 training 74
Jan 1 00:03:02 (none) user.crit kernel: Line 0: ADSL G.992 started 73
Jan 1 00:03:06 (none) user.crit kernel: Line 0: ADSL G.992 channel analysis 82
Jan 1 00:03:11 (none) user.crit kernel: Line 0: ADSL link up, Bearer 0, us=509, ds=10643 95
Jan 1 00:04:20 (none) daemon.crit syslog: PPP server detected. 70
Jan 1 00:04:20 (none) daemon.err syslog: Unexpected packet: Ether addr: 00:90:1a:a3:1b:88 (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x002e (PADO) PPPoE tag: type=0102 length=000a (AC Name) data (UTF-8): KRD-E320-2 PPPoE tag: type=0103 length=0004 (Host Uniq) da 303
Jan 1 00:04:20 (none) daemon.err syslog: Unexpected packet: Ether addr: 00:90:1a:a3:42:a6 (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x002e (PADO) PPPoE tag: type=0102 length=000a (AC Name) data (UTF-8): KRD-E320-3 PPPoE tag: type=0103 length=0004 (Host Uniq) da 303
Jan 1 00:04:20 (none) daemon.err syslog: Unexpected packet: Ether addr: 00:90:1a:a4:45:43 (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x002e (PADO) PPPoE tag: type=0102 length=000a (AC Name) data (UTF-8): KRD-E320-1 PPPoE tag: type=0103 length=0004 (Host Uniq) da 303
Jan 1 00:04:20 (none) daemon.crit syslog: PPP session established. 74
Jan 1 00:04:20 (none) daemon.crit syslog: PPP LCP UP. 61
Jan 1 00:04:21 (none) daemon.crit syslog: Received valid IP address from server. Connection UP. 104
Jan 1 00:04:47 (none) user.alert kernel: Intrusion -> IN=ppp1 OUT= MAC= SRC=212.75.129.124 DST=31.181.141.78 LEN=48 TOS=0x00 PREC=0x00 TTL=117 ID=21901 DF PROTO=TCP SPT=60910 DPT=6881 WINDOW=8192 RES=0x00 SYN URGP=0 MARK=0x8000000 238
Jan 1 00:04:50 (none) user.alert kernel: Intrusion -> IN=ppp1 OUT= MAC= SRC=212.75.129.124 DST=31.181.141.78 LEN=48 TOS=0x00 PREC=0x00 TTL=117 ID=22164 DF PROTO=TCP SPT=60910 DPT=6881 WINDOW=8192 RES=0x00 SYN URGP=0 MARK=0x8000000 238
Jan 1 00:04:56 (none) user.alert kernel: Intrusion -> IN=ppp1 OUT= MAC= SRC=212.75.129.124 DST=31.181.141.78 LEN=48 TOS=0x00 PREC=0x00 TTL=117 ID=22649 DF PROTO=TCP SPT=60910 DPT=6881 WINDOW=8192 RES=0x00 SYN URGP=0 MARK=0x8000000 238
Jan 1 00:04:58 (none) user.alert kernel: Intrusion -> IN=ppp1 OUT= MAC= SRC=95.83.136.192 DST=31.181.141.78 LEN=52 TOS=0x00 PREC=0x00 TTL=115 ID=25795 DF PROTO=TCP SPT=48218 DPT=6881 WINDOW=8192 RES=0x00 SYN URGP=0 MARK=0x8000000 237
Jan 1 00:05:01 (none) user.alert kernel: Intrusion -> IN=ppp1 OUT= MAC= SRC=95.83.136.192 DST=31.181.141.78 LEN=52 TOS=0x00 PREC=0x00 TTL=115 ID=26053 DF PROTO=TCP SPT=48218 DPT=6881 WINDOW=8192 RES=0x00 SYN URGP=0 MARK=0x8000000 237
Jan 1 00:15:00 (none) user.alert kernel: Intrusion -> IN=ppp1 OUT= MAC= SRC=219.232.244.87 DST=31.181.141.78 LEN=48 TOS=0x00 PREC=0x00 TTL=114 ID=15039 PROTO=TCP SPT=799 DPT=22 WINDOW=65535 RES=0x00 SYN URGP=0 MARK=0x8000000 232
и лог модема 2500 u Jan 1 00:00:07 (none) syslog.emerg BCM96345 started: BusyBox v1.00 (2011.07.04-08:43+0000) 98
Jan 1 00:00:07 (none) user.err kernel: [truncated] m. 61
Jan 1 00:00:36 (none) daemon.crit syslog: PPP server detected. 70
Jan 1 00:00:36 (none) daemon.err syslog: Unexpected packet: Ether addr: 00:90:1a:a4:45:43 (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x002e (PADO) PPPoE tag: type=0102 length=000a (AC Name) data (UTF-8): KRD-E320-1 PPPoE tag: type=0103 length=0004 (Host Uniq) da 303
Jan 1 00:00:36 (none) daemon.err syslog: Unexpected packet: Ether addr: 00:90:1a:a3:42:9f (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x002e (PADO) PPPoE tag: type=0102 length=000a (AC Name) data (UTF-8): KRD-E320-3 PPPoE tag: type=0103 length=0004 (Host Uniq) da 303
Jan 1 00:00:36 (none) daemon.crit syslog: PPP session established. 74
Jan 1 00:00:36 (none) daemon.crit syslog: PPP LCP UP. 61
Jan 1 00:00:37 (none) daemon.crit syslog: Received valid IP address from server. Connection UP. 104
Jan 1 00:18:38 (none) daemon.crit syslog: Clear IP addresses. Connection DOWN. 87
Jan 1 00:18:38 (none) daemon.crit syslog: Clear IP addresses. PPP connection DOWN. 91
Jan 1 00:18:52 (none) daemon.crit syslog: PPP server detected. 70
Jan 1 00:18:52 (none) daemon.err syslog: Unexpected packet: Ether addr: 00:90:1a:a4:45:43 (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x002e (PADO) PPPoE tag: type=0102 length=000a (AC Name) data (UTF-8): KRD-E320-1 PPPoE tag: type=0103 length=0004 (Host Uniq) da 303
Jan 1 00:18:52 (none) daemon.err syslog: Unexpected packet: Ether addr: 00:90:1a:a3:1b:88 (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x002e (PADO) PPPoE tag: type=0102 length=000a (AC Name) data (UTF-8): KRD-E320-2 PPPoE tag: type=0103 length=0004 (Host Uniq) da 303
