Текущее время: Чт окт 01, 2026 13:19
 Заголовок сообщения: Ошибка авторизации CHAP на 504T
СообщениеДобавлено: Ср сен 21, 2005 02:01
Подскажите, пожалуйста, как побороть проблему авторизации CHAP на D-Link 504T. На родном СТРИМовском USB модеме (AUSLynx 2006) всё работает прекрасно.
Перепрошил с родной от 20040830 на V1.00B02T02.RU.20041014, никаких изменений. WAN disconnected.
Sep 8 12:00:06> Valid Configuration Tree
Sep 8 12:00:11> Firewall NAT service started
Sep 8 12:00:12> Bridge Created: br0
Sep 8 12:00:12> Bridge Interface Added: eth0
Sep 8 12:00:13> pppd 2.4.1 started by root, uid 0
Sep 8 12:00:15> DSL Carrier is training
Sep 8 12:00:25> DSL Carrier is down
Sep 8 12:00:55> DSL Carrier is training
Sep 8 12:01:03> Connecting PPPoE socket: 00:30:88:00:87:56 9f23 nas0 0x1000d3b8
Sep 8 12:01:03> Connect: ppp0 {--} nas0
Sep 8 12:01:03> CHAP authentication failed
Sep 8 12:01:04> Connection terminated.
Sep 8 12:01:04> Doing disconnect
Sep 8 12:01:04> Failed to Authenicate
Sep 8 12:01:04> pppd 2.4.1 started by root, uid 0
Sep 8 12:01:04> Connecting PPPoE socket: 00:30:88:00:87:56 5721 nas0 0x1000d3b8
Sep 8 12:01:04> Connect: ppp0 {--} nas0
Sep 8 12:01:04> CHAP authentication failed
Sep 8 12:01:05> DSL Carrier is up
Sep 8 12:01:05> pppd 2.4.1 started by root, uid 0
Sep 8 12:01:06> Connecting PPPoE socket: 00:30:88:00:87:56 3b0d nas0 0x1000d3b8
Sep 8 12:01:06> Connect: ppp0 {--} nas0
Sep 8 12:01:06> CHAP authentication failed
Sep 8 12:01:06> Connection terminated.
Sep 8 12:01:06> Doing disconnect
Sep 8 12:01:06> Failed to Authenicate
Sep 8 12:01:10> pppd 2.4.1 started by root, uid 0
Sep 8 12:01:10> Connecting PPPoE socket: 00:30:88:00:87:56 2727 nas0 0x1000d3b8
Sep 8 12:01:10> Connect: ppp0 {--} nas0
Sep 8 12:01:11> CHAP authentication failed
Sep 8 12:01:11> Connection terminated.
Sep 8 12:01:11> Doing disconnect
Sep 8 12:01:11> Failed to Authenicate
Sep 8 12:01:12> pppd 2.4.1 started by root, uid 0
Sep 8 12:01:12> Connecting PPPoE socket: 00:30:88:00:87:56 5b27 nas0 0x1000d3b8
Sep 8 12:01:12> Connect: ppp0 {--} nas0
Sep 8 12:01:12> CHAP authentication failed
Sep 8 12:01:12> Connection terminated.
Sep 8 12:01:12> Doing disconnect
Sep 8 12:01:12> Failed to Authenicate
Sep 8 12:01:18> pppd 2.4.1 started by root, uid 0
Sep 8 12:01:18> Connecting PPPoE socket: 00:30:88:00:87:56 7009 nas0 0x1000d3b8
Sep 8 12:01:18> Connect: ppp0 {--} nas0
Sep 8 12:01:18> CHAP authentication failed
Sep 8 12:01:18> Connection terminated.
Sep 8 12:01:18> Doing disconnect
Sep 8 12:01:18> Failed to Authenicate
Sep 8 12:01:19> pppd 2.4.1 started by root, uid 0
Sep 8 12:01:20> Connecting PPPoE socket: 00:30:88:00:87:56 9523 nas0 0x1000d3b8
Sep 8 12:01:20> Connect: ppp0 {--} nas0
Sep 8 12:01:20> CHAP authentication failed
Sep 8 12:01:20> Connection terminated.
Sep 8 12:01:20> Doing disconnect
Sep 8 12:01:20> Failed to Authenicate
Sep 8 12:01:22> pppd 2.4.1 started by root, uid 0
Sep 8 12:01:22> Connecting PPPoE socket: 00:30:88:00:87:56 6927 nas0 0x1000d3b8
Sep 8 12:01:22> Connect: ppp0 {--} nas0
Sep 8 12:01:22> CHAP authentication failed
Sep 8 12:01:22> Failed to Authenicate
Sep 8 12:01:22> Connection terminated.
Sep 8 12:01:22> Doing disconnect
Sep 8 12:01:23> pppd 2.4.1 started by root, uid 0
Sep 8 12:01:23> Connecting PPPoE socket: 00:30:88:00:87:56 6e27 nas0 0x1000d3b8
Sep 8 12:01:23> Connect: ppp0 {--} nas0
Sep 8 12:01:23> CHAP authentication failed
Sep 8 12:01:23> Connection terminated.
Sep 8 12:01:23> Doing disconnect
Sep 8 12:01:23> Failed to Authenicate
Sep 8 12:01:24> Connecting PPPoE socket: 00:30:88:00:87:56 3723 nas0 0x1000d3b8
Sep 8 12:01:24> Connect: ppp0 {--} nas0
Sep 8 12:01:24> CHAP authentication failed
Sep 8 12:01:24> Connection terminated.
Sep 8 12:01:24> Doing disconnect
Sep 8 12:01:24> Failed to Authenicate
Sep 8 12:01:25> pppd 2.4.1 started by root, uid 0
Sep 8 12:01:25> Connecting PPPoE socket: 00:30:88:00:87:56 6f0c nas0 0x1000d3b8
Sep 8 12:01:25> Connect: ppp0 {--} nas0
Sep 8 12:01:26> CHAP authentication failed
Sep 8 12:01:26> Connection terminated.
Sep 8 12:01:26> Doing disconnect
Sep 8 12:01:26> Failed to Authenicate
Sep 8 12:01:31> pppd 2.4.1 started by root, uid 0
Sep 8 12:01:31> Connecting PPPoE socket: 00:30:88:00:87:56 7020 nas0 0x1000d3b8
Sep 8 12:01:31> Connect: ppp0 {--} nas0
Sep 8 12:01:31> CHAP authentication failed
Sep 8 12:01:31> Connection terminated.
Sep 8 12:01:31> Doing disconnect
Sep 8 12:01:31> Failed to Authenicate
Sep 8 12:01:36> pppd 2.4.1 started by root, uid 0
Sep 8 12:01:36> Connecting PPPoE socket: 00:30:88:00:87:56 1b26 nas0 0x1000d3b8
Sep 8 12:01:36> Connect: ppp0 {--} nas0
Sep 8 12:01:36> CHAP authentication failed
Sep 8 12:01:36> Failed to Authenicate
Sep 8 12:01:36> Connection terminated.
Sep 8 12:01:36> Doing disconnect
Sep 8 12:01:37> Connecting PPPoE socket: 00:30:88:00:87:56 8227 nas0 0x1000d3b8
Sep 8 12:01:37> Connect: ppp0 {--} nas0
Sep 8 12:01:37> CHAP authentication failed
Sep 8 12:01:37> Connection terminated.
Sep 8 12:01:37> Doing disconnect
Sep 8 12:01:37> Failed to Authenicate
Sep 8 12:01:38> pppd 2.4.1 started by root, uid 0
Sep 8 12:01:39> Connecting PPPoE socket: 00:30:88:00:87:56 5505 nas0 0x1000d3b8
Sep 8 12:01:39> Connect: ppp0 {--} nas0
Sep 8 12:01:39> CHAP authentication failed
Sep 8 12:01:39> Connection terminated.
Sep 8 12:01:39> Doing disconnect
Sep 8 12:01:39> Failed to Authenicate
СообщениеДобавлено: Ср сен 21, 2005 12:41
Это проблема провейдера. Там осталась зависшая сессия. Через полчаса она сбрасывается. Про CHAP authentication failed тут уже очень много написано, поищи.
DFL-260E A1 v.12.00.13.05-34465; DFL-210 A4 v.2.27.08.03-22678; DAP-2310 A1 v.1.16
СообщениеДобавлено: Ср сен 21, 2005 13:57
Когда срывается связь по каким-либо причинам, на провайдеровском сервере ещё висит сессия, сбрасывается она через 15-30 минут, можно быстрей: 2 программных ресета.
Бигаров Руслан.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 80
