Текущее время: Вт июл 07, 2026 14:20
 Заголовок сообщения: Подскажите по логу D-link 2640u
СообщениеДобавлено: Ср мар 28, 2012 07:26
Помогите расшифровать лог.
Jan 1 00:21:35 daemon crit pppd[368]: PPP session established.
Jan 1 00:21:47 daemon notice pppd[368]: PPP: Start to connect ...
Jan 1 00:21:48 daemon crit pppd[368]: PPP server detected.
Jan 1 00:21:48 daemon crit pppd[368]: PPP session established.
Jan 1 00:22:00 daemon notice pppd[368]: PPP: Start to connect ...
Jan 1 00:22:01 daemon crit pppd[368]: PPP server detected.
Jan 1 00:22:01 daemon crit pppd[368]: PPP session established.
Jan 1 00:22:13 daemon notice pppd[368]: PPP: Start to connect ...
Jan 1 00:22:14 daemon crit pppd[368]: PPP server detected.
Jan 1 00:22:14 daemon crit pppd[368]: PPP session established.
Jan 1 00:22:17 daemon crit pppd[368]: PPP LCP UP.
Jan 1 00:22:18 daemon crit pppd[368]: Received valid IP address from server. Connection UP.
Jan 1 00:22:18 user debug syslog: route add default gw 172.16.0.82 2>/dev/null
Jan 1 00:22:19 user debug syslog: iptables -A FORWARD -o ppp_0_0_33_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Jan 1 00:22:19 user debug syslog: iptables -A FORWARD -i ppp_0_0_33_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Jan 1 00:22:19 user debug syslog: echo > /proc/net/ip_conntrack
Jan 1 00:22:19 user debug syslog: echo "1000" > /proc/sys/net/ipv4/ip_conntrack_max
Jan 1 00:22:19 user debug syslog: iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107 2>/dev/null
Jan 1 00:22:19 user debug syslog: iptables -t nat -D POSTROUTING -o ppp_0_0_33_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE 2>/dev/null
Jan 1 00:22:19 user debug syslog: iptables -t nat -A POSTROUTING -o ppp_0_0_33_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE
Jan 1 00:22:19 user debug syslog: iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 213.135.96.250 2>/dev/null
Jan 1 00:22:19 user debug syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 213.135.96.250
Jan 1 00:22:19 user debug syslog: /bin/dnsprobe &
Jan 1 00:22:19 user debug syslog: upnp -L br0 -W ppp_0_0_33_1 -D
Mar 28 09:20:43 user notice dnsprobe[11911]: dnsprobe started!
Mar 28 09:20:43 user debug syslog: iptables -t filter -I OUTPUT -o ppp_0_0_33_1 -d 239.255.255.250 -j DROP 2>/dev/null
Mar 28 09:20:44 user debug syslog: iptables -I INPUT 1 -i ppp_0_0_33_1 -p udp --dport 5060 -j ACCEPT 2>/dev/null
Mar 28 09:20:44 user debug syslog: iptables -I INPUT 1 -i ppp_0_0_33_1 -p udp --dport 7070:7079 -j ACCEPT 2>/dev/null
Mar 28 09:20:44 user debug syslog: iptables -t nat -A PREROUTING -i br0 -p udp --dport 5060 -j REDIRECT --to-ports 5060 2>/dev/null
Mar 28 09:20:44 user debug syslog: siproxd --config /var/siproxd/siproxd.conf &
Mar 28 09:20:45 user notice syslog: siproxd.c:192 INFO:siproxd-0.5.10-2842 i686-redhat-linux-gnu starting up
Mar 28 09:20:45 user notice syslog: siproxd.c:218 INFO:daemonized, pid=11979
Mar 28 09:20:45 user notice syslog: sock.c:65 INFO:bound to port 5060
Mar 28 09:20:45 user notice syslog: register.c:65 WARNING:registration file not found, starting with empty table
Mar 28 09:20:45 user notice syslog: siproxd.c:265 INFO:siproxd-0.5.10-2842 i686-redhat-linux-gnu started
Mar 28 09:20:45 user debug syslog: setkey -f /var/setkey.conf
Mar 28 09:20:46 user debug syslog: iptables -I INPUT 1 -j ACCEPT -i ppp_0_0_33_1 -p tcp --dport 30005
Mar 28 09:20:46 user debug syslog: iptables -I FORWARD 1 -j ACCEPT -i ppp_0_0_33_1 -p tcp --dport 30005
Mar 28 09:20:46 user debug syslog: iptables -I INPUT 1 -j ACCEPT -i ppp_0_0_33_1 -p udp -s 192.168.1.1/24 --dport 30006
Mar 28 09:20:46 user debug syslog: iptables -I FORWARD 1 -j ACCEPT -i ppp_0_0_33_1 -p udp -s 192.168.1.1/24 --dport 30006
Mar 28 09:20:48 user debug syslog: ifconfig ppp_0_0_33_1 mtu 1492
Mar 28 09:20:48 daemon err user: No server certificate found. Skip checking on certificate.
Mar 28 09:20:51 daemon err user: tr69c: Unable to retrieve attributes in scratch PAD
Mar 28 09:20:51 daemon err user: Stored Parameter Attribute data is corrupt or missing
 Заголовок сообщения: Re: Подскажите по логу D-link 2640u
СообщениеДобавлено: Ср мар 28, 2012 08:06
Polzovatel56, А что собственно особого в этом логе ?
Или что-то конкретно интересует ?
knock-knock
СообщениеДобавлено: Ср мар 28, 2012 08:11
Да вобщем пропадает интернет время от времени. Хочу понять в чем дело. Толи линия плохая, толи на атс оборудование глючит, толи мой модем.
Statistics -- ADSL
Mode: ADSL2+
Line Coding: Trellis On
Status: No Defect
Link Power State: L0
Downstream Upstream
SNR Margin (dB): 5.9 8.0
Attenuation (dB): 42.0 22.3
Output Power (dBm): 12.6 0.0
Attainable Rate (Kbps): 9812 992
Rate (Kbps): 7878 892
MSGc (number of bytes in overhead channel message): 60 68
B (number of bytes in Mux Data Frame): 241 13
M (number of Mux Data Frames in FEC Data Frame): 1 16
T (Mux Data Frames over sync bytes): 1 2
R (number of check bytes in FEC Data Frame): 12 16
S (ratio of FEC over PMD Data Frame length): 0.9788 7.7419
L (number of bits in PMD Data Frame): 2076 248
D (interleaver depth): 64 4
Delay (msec): 15 7
Super Frames: 19251 18294
Super Frame Errors: 1280 0
RS Words: 1270586 160478
RS Correctable Errors: 180258 0
RS Uncorrectable Errors: 3815 N/A
HEC Errors: 1159 0
OCD Errors: 0 0
LCD Errors: 0 0
Total Cells: 5763188 687060
Data Cells: 116631 52760
Bit Errors: 0 0
Total ES: 33 1
Total SES: 25 0
Total UAS: 17 39
СообщениеДобавлено: Ср мар 28, 2012 14:38
Для сравнения вот мои параметры ADSL, жалоб на дисконнекты по причине плохой линии нет.
adsl: ADSL driver and PHY status
Status: ShowtimeRetrain Reason: 1
Channel: INTR, Upstream rate = 1023 Kbps, Downstream rate = 10079 Kbps
Mode: ADSL2+ AnnexM EU-60
Channel: Interleave
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 19.1 21.5
Attn(dB): 9.0 0.1
Pwr(dBm): 21.5 1.2
Max(Kbps): 20532 1056
Rate (Kbps): 10079 1023
G.dmt framing
K: 252(0) 32
R: 0 0
S: 1 1
D: 1 1
ADSL2 framing
MSGc: 75 68
B: 251 31
M: 1 1
T: 1 1
R: 0 0
S: 0.7968 0.9696
L: 2530 264
D: 1 1
Counters
SF: 7946751 7543015
SFErr: 0 5
RS: 0 0
RSCorr: 0 0
RSUnCorr: 0 0
HEC: 0 2
OCD: 0 0
LCD: 0 0
Total Cells: 3048382186 309367032
Data Cells: 70121959 39818824
Drop Cells: 281
Bit Errors: 0 0
ES: 2 22
SES: 2 0
UAS: 61 25
AS: 128225
INP: 0.00 0.00
PER: 16.13 17.93
delay: 0.19 0.24
OR: 40.15 33.00
Bitswap: 0 0
knock-knock
СообщениеДобавлено: Ср мар 28, 2012 14:42
Polzovatel56, вот здесь у вас не очень хорошо Attenuation (dB):
Вот почитайте http://ru.wikipedia.org/wiki/ADSL
knock-knock
Сейчас этот форум просматривают: Google [Bot] и гости: 14
