Текущее время: Вс ноя 01, 2026 10:50
СообщениеДобавлено: Пт мар 02, 2012 16:55
DSL 2540U работает в режиме роутера
Периодически - иногда 4-5 раз в день, иногда каждые полчаса отваливается интернет.
Log:
Jan 1 06:41:12   user   warn   dnsprobe[501]: dns query failed
Jan 1 06:41:14   user   warn   dnsprobe[501]: dns query failed
Jan 1 06:41:16   user   warn   dnsprobe[501]: dns query failed
Jan 1 06:41:16   user   notice   dnsprobe[501]: Primary DNS server Is Down... Switching To Secondary DNS server
Jan 1 06:41:48   user   warn   dnsprobe[501]: dns query failed
Jan 1 06:41:50   user   warn   dnsprobe[501]: dns query failed
Jan 1 06:41:52   user   warn   dnsprobe[501]: dns query failed
Jan 1 06:42:24   user   warn   dnsprobe[501]: dns query failed
Jan 1 06:42:26   user   warn   dnsprobe[501]: dns query failed
Jan 1 06:42:28   user   warn   dnsprobe[501]: dns query failed
Jan 1 06:42:58   daemon   crit   pppd[273]: Clear IP addresses. Connection DOWN.
Jan 1 06:42:58   daemon   crit   pppd[273]: Clear IP addresses. PPP connection DOWN.
Jan 1 06:43:00   user   warn   dnsprobe[501]: dns query failed
Jan 1 06:43:02   user   warn   dnsprobe[501]: dns query failed
Jan 1 06:43:04   user   warn   dnsprobe[501]: dns query failed
Jan 1 06:43:07   daemon   notice   pppd[273]: PPP: Start to connect ...
Jan 1 06:43:08   daemon   crit   pppd[273]: PPP server detected.
Jan 1 06:43:08   daemon   crit   pppd[273]: PPP session established.
Jan 1 06:43:20   daemon   notice   pppd[273]: PPP: Start to connect ...
Jan 1 06:43:36   user   warn   dnsprobe[501]: dns query failed
Jan 1 06:43:38   user   warn   dnsprobe[501]: dns query failed
Jan 1 06:43:40   user   warn   dnsprobe[501]: dns query failed
Jan 1 06:44:12   user   warn   dnsprobe[501]: dns query failed
При этом модем теряет адрес шлюза (Default Gateway)
Device Info
Board ID:   D-4P
Software Version:   RU_DSL-2540U_3-06-04-3H00.A2pB023g2.d19b
Bootloader (CFE) Version:   1.0.37-6.5
Line Rate - Upstream (Kbps):   780
Line Rate - Downstream (Kbps):   4046
LAN IP Address:   192.168.1.1
Default Gateway:
Primary DNS Server:   212.96.96.38
Secondary DNS Server:   8.8.8.8
uTorrent пользуюсь, но он на результат не влияет, без него интернет также отваливается как и с ним.
Пробовал прописывать различные DNS сервера в модеме и google и альтернативные провайдера - не помогает.
СообщениеДобавлено: Пн мар 05, 2012 15:35
Пропишите на ПК вручную DNS- провайдера.
СообщениеДобавлено: Вт мар 06, 2012 09:55
Пробовал. На результат не влияет.
