Текущее время: Вт окт 13, 2026 10:21
 Заголовок сообщения: Проблемы с dsl -2650u
СообщениеДобавлено: Сб сен 24, 2011 17:02
Модем dsl 2650u D2
Прошивка RU_2.08
Sep 24 17:00:32 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=88.135.92.194 DST=46.61.33.180 LEN=48 TOS=0x00 PREC=0x00 TTL=119 ID=44340 DF PROTO=TCP SPT=1995 DPT=25238 WINDOW=65535 RES=0x00 SYN URGP=0
Sep 24 17:22:40 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=95.28.194.22 DST=46.61.33.180 LEN=60 TOS=0x00 PREC=0x00 TTL=53 ID=43126 PROTO=TCP SPT=52788 DPT=55184 WINDOW=5840 RES=0x00 SYN URGP=0
Sep 24 17:22:43 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=95.28.194.22 DST=46.61.33.180 LEN=60 TOS=0x00 PREC=0x00 TTL=53 ID=43127 PROTO=TCP SPT=52788 DPT=55184 WINDOW=5840 RES=0x00 SYN URGP=0
Sep 24 17:36:30 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=46.146.210.156 DST=46.61.33.180 LEN=40 TOS=0x00 PREC=0x00 TTL=111 ID=256 PROTO=TCP SPT=6000 DPT=1433 WINDOW=16384 RES=0x00 SYN URGP=0
Sep 24 17:38:10 user crit kernel: OAM loopback response not received on PORT/VPI/VCI 0/0/35.
Sep 24 17:38:11 user crit kernel: OAM loopback response not received on PORT/VPI/VCI 0/0/35.
Sep 24 17:38:25 user crit kernel: OAM loopback response not received on PORT/VPI/VCI 0/0/35.
Sep 24 17:38:26 user crit kernel: OAM loopback response not received on PORT/VPI/VCI 0/0/35.
Sep 24 17:38:53 user crit kernel: OAM loopback response not received on PORT/VPI/VCI 0/0/35.
Sep 24 17:38:55 user crit kernel: OAM loopback response not received on PORT/VPI/VCI 0/0/35.
Sep 24 17:39:30 user crit kernel: OAM loopback response not received on PORT/VPI/VCI 0/0/35.
Sep 24 17:39:32 user crit kernel: OAM loopback response not received on PORT/VPI/VCI 0/0/35.
Sep 24 17:40:13 daemon crit pppd[667]: Connection terminated....
Sep 24 17:40:54 daemon err pppd[667]: Unable to complete PPPoE Discovery
Sep 24 17:41:14 daemon crit pppd[667]: Connect: ppp_0_0_35_1 <--> nas_0_0_35
Sep 24 17:41:18 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=109.172.15.1 DST=109.165.18.129 LEN=52 TOS=0x00 PREC=0x00 TTL=115 ID=10957 DF PROTO=TCP SPT=56921 DPT=62522 WINDOW=8192 RES=0x00 SYN URGP=0
Sep 24 17:41:18 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=109.172.15.17 DST=109.165.18.129 LEN=48 TOS=0x00 PREC=0x00 TTL=114 ID=8945 DF PROTO=TCP SPT=49705 DPT=62522 WINDOW=8192 RES=0x00 SYN URGP=0
Sep 24 17:41:21 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=109.172.15.1 DST=109.165.18.129 LEN=52 TOS=0x00 PREC=0x00 TTL=115 ID=14284 DF PROTO=TCP SPT=56921 DPT=62522 WINDOW=8192 RES=0x00 SYN URGP=0
Sep 24 17:41:26 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=95.82.248.59 DST=109.165.18.129 LEN=52 TOS=0x00 PREC=0x00 TTL=121 ID=1792 DF PROTO=TCP SPT=54915 DPT=62522 WINDOW=8192 RES=0x00 SYN URGP=0
Когда начинается "kernel: OAM loopback response not received on PORT/VPI/VCI 0/0/35." пропадает интернет ,причем очень хитро ,просто падает скорость до 45-450кбит\сек ,но в "Line Rate - Upstream
Line Rate - Downstream" не чего не падает, интернет,,нормальный, не восстанавливается пока не перезагружу модем ,подскажите как либо это можно исправить?
З.Ы.Бывает прирывается 1 раз на день а иногда 10 раз в час
