Текущее время: Ср окт 14, 2026 03:20
 Заголовок сообщения: DSL-2500u 2 wan interfaces problem
СообщениеДобавлено: Пн мар 07, 2011 01:05
Hello Dear Sirs,
I need you help very much.
Im subscribing internet and iptv services using adsl line. Was using linksys router. One port is connected to tv module, to another port pc and some laptops via wifi. But that router is shitty, have poor wifi and other problems.
So I decided to make little home server with separate access point. Bought D-link dsl-2500u/bru/d3 modem to use as bridge. I have updated firmware to latest version and created wan0 8/35 bridge for internet and wan1 8/36 bridge for iptv.
Problem is that I cant make work both interfaces at one time.
For both connections to servers are using dhcp. For example if I make connection to wan0, I have internet, but no tv. If I connect to wan1 i can see tv, but no internet connection.
Could you advice me how to make 2 connections using one ethernet interface?
And to watch tv and use internet at the same time.
Thanks in advance Sirs!
