Текущее время: Вт окт 13, 2026 19:18
СообщениеДобавлено: Ср сен 22, 2010 21:54
Периодически отпадает PPPOE сессия на DSL-2650U Укртелеком
и мне кажется что такое началось после перехода на Windows 7, и ещё параллельно перешился на последнюю прошивку.
Вот лог
Jan 1 00:00:19 user info kernel: TCP: Hash tables configured (established 2048 bind 4096)
Jan 1 00:00:19 user info kernel: Initializing IPsec netlink socket
Jan 1 00:00:19 user info kernel: NET: Registered protocol family 1
Jan 1 00:00:19 user info kernel: NET: Registered protocol family 17
Jan 1 00:00:19 user info kernel: NET: Registered protocol family 15
Jan 1 00:00:19 user notice kernel: Ebtables v2.0 registered
Jan 1 00:00:19 user info kernel: NET: Registered protocol family 8
Jan 1 00:00:19 user info kernel: NET: Registered protocol family 20
Jan 1 00:00:19 user info kernel: 802.1Q VLAN Support v1.8 Ben Greear
Jan 1 00:00:19 user info kernel: All bugs added by David S. Miller
Jan 1 00:00:19 user warn kernel: VFS: Mounted root (squashfs filesystem) readonly.
Jan 1 00:00:19 user info kernel: unused kernel memory: 76k freed
Jan 1 00:00:19 user warn kernel: Algorithmics/MIPS FPU Emulator v1.5
Jan 1 00:00:19 user warn kernel: atmapi: module license 'Proprietary' taints kernel.
Jan 1 00:00:19 user warn kernel: adsl: adsl_init entry
Jan 1 00:00:19 user warn kernel: blaadd: blaa_detect entry
Jan 1 00:00:19 user warn kernel: fuse init (API version 7.8)
Jan 1 00:00:19 user warn kernel: fuse distribution version: 2.7.3
Jan 1 00:00:19 user info kernel: Broadcom BCMPROCFS v1.0 initialized
Jan 1 00:00:19 user warn kernel: Broadcom BCM6358A1 Ethernet Network Device v0.3 Aug 16 2010 15:16:56
Jan 1 00:00:19 user warn kernel: Config Ethernet Switch Through MDIO Pseudo PHY Interface
Jan 1 00:00:19 user warn kernel: dgasp: kerSysRegisterDyingGaspHandler: eth0 registered
Jan 1 00:00:19 user warn kernel: eth0: MAC Address: 00:22:B0:62:D0:4C
Jan 1 00:00:19 user warn kernel: Broadcom BCM6358A1 USB Network Device v0.4 Aug 16 2010 15:16:57
Jan 1 00:00:19 user warn kernel: usb0: MAC Address: 00 22 B0 62 D0 4D
Jan 1 00:00:19 user warn kernel: usb0: Host MAC Address: 00 22 B0 62 D0 4E
Jan 1 00:00:19 user debug kernel: PCI: Setting latency timer of device 0000:00:01.0 to 64
Jan 1 00:00:19 user warn kernel: PCI: Enabling device 0000:00:01.0 (0004 -> 0006)
Jan 1 00:00:19 user warn kernel: wl: srom not detected, using main memory mapped srom info (wombo board)
Jan 1 00:00:19 user warn kernel: wl0: wlc_attach: use mac addr from the system pool by id: 0x776c0000
Jan 1 00:00:19 user warn kernel: wl0: MAC Address: 00:22:B0:62:D0:4F
Jan 1 00:00:19 user warn kernel: wl0: Broadcom BCM4318 802.11 Wireless Controller 4.100.27.0.cpe2.1
Jan 1 00:00:19 user warn kernel: dgasp: kerSysRegisterDyingGaspHandler: wl0 registered
Jan 1 00:00:19 user crit kernel: eth0 Link UP.
Jan 1 00:00:19 user warn kernel: BcmAdsl_Initialize=0xC006B808, g_pFnNotifyCallback=0xC0084834
Jan 1 00:00:19 user warn kernel: AnnexCParam=0x7FFF7EA8 AnnexAParam=0x00003987 adsl2=0x00000003
Jan 1 00:00:19 user warn kernel: pSdramPHY=0xA1FFFFF8, 0x1B7808 0xDEADBEEF
Jan 1 00:00:19 user warn kernel: AdslCoreHwReset: AdslOemDataAddr = 0xA1FFD3D4
Jan 1 00:00:19 user warn kernel: dgasp: kerSysRegisterDyingGaspHandler: dsl0 registered
Jan 1 00:00:19 user warn kernel: ATM proc init !!!
Jan 1 00:00:19 user warn kernel: ip_tables: (C) 2000-2002 Netfilter core team
Jan 1 00:00:19 user warn kernel: ip_conntrack version 2.1 (253 buckets, 0 max) - 376 bytes per conntrack
Jan 1 00:00:19 user warn kernel: ip_conntrack_pptp version 2.1 loaded
Jan 1 00:00:19 user warn kernel: ip_nat_pptp version 2.0 loaded
Jan 1 00:00:19 user warn kernel: ip_ct_h323: init success
Jan 1 00:00:19 user warn kernel: ip_nat_h323: init success
Jan 1 00:00:19 user crit kernel: ADSL G.994 training
Jan 1 00:00:19 user warn kernel: ip_conntrack_rtsp v0.01 loading
Jan 1 00:00:19 user warn kernel: ip_nat_rtsp v0.01 loading
Jan 1 00:00:19 user info kernel: device usb0 entered promiscuous mode
Jan 1 00:00:19 user info kernel: br0: port 1(usb0) entering learning state
Jan 1 00:00:19 user info kernel: br0: topology change detected, propagating
Jan 1 00:00:19 user info kernel: br0: port 1(usb0) entering forwarding state
Jan 1 00:00:19 user info kernel: device eth0 entered promiscuous mode
Jan 1 00:00:19 user info kernel: br0: port 2(eth0) entering learning state
Jan 1 00:00:19 user info kernel: br0: port 2(eth0) entering forwarding state
Jan 1 00:00:19 user debug syslog: echo > /var/snmpd.conf
Jan 1 00:00:19 user debug syslog: echo > /var/hosts
Jan 1 00:00:19 user debug syslog: mount -o remount,size=1M /var
Jan 1 00:00:19 user debug syslog: mkdir -p /var/samba/var/locks
Jan 1 00:00:19 user warn kernel: ioctl, p_name=diapd
Jan 1 00:00:19 user emerg kernel: gpio_fasync
Jan 1 00:00:19 user warn kernel: Pasync_queue->magic = 0x4601
Jan 1 00:00:19 user debug syslog: mkdir -p /var/samba/private
Jan 1 00:00:19 user debug syslog: mkdir -p /var/samba/lib/vfs
Jan 1 00:00:19 user debug syslog: mkdir -p /var/samba/lib/pdb
Jan 1 00:00:19 user debug syslog: mkdir -p /var/samba/lib/rpc
Jan 1 00:00:19 user debug syslog: mkdir -p /var/samba/lib/atuh
Jan 1 00:00:19 user debug syslog: mkdir -p /var/samba/lib/config
Jan 1 00:00:19 user debug syslog: smbd -s /var/smb.conf
Jan 1 00:00:21 user crit kernel: ADSL G.992 started
Jan 1 00:00:22 user debug syslog: nmbd -s /var/smb.conf
Jan 1 00:00:23 user debug syslog: pppd plugin pppoe oldsession 00901a422143/3838 nas_0_1_32 nodetach user 'spawn_lmg@dsl.ukrtel.net' password *********** interface_name 0_1_32_1 usepeerdns refuse-eap persist lcp-echo-interval 30 holdoff 3
Jan 1 00:00:24 daemon info pppd[450]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.3
Jan 1 00:00:24 daemon info pppd[450]: Plugin pppoe called.
Jan 1 00:00:24 daemon notice pppd[450]: pppd 2.4.3 started by admin, uid 0
Jan 1 00:00:24 user info kernel: br0: port 1(usb0) entering disabled state
Jan 1 00:00:25 user crit kernel: ADSL G.992 channel analysis
Jan 1 00:00:31 user crit kernel: ADSL G.992 message exchange
Jan 1 00:00:32 user crit kernel: ADSL link up, interleaved, us=613, ds=4415
Jan 1 00:00:32 user warn kernel: ADSL2/ADSL2+ connection
Jan 1 00:00:33 user debug syslog: iptables -t nat -D PREROUTING -i br0 -d 192.168.1.223 -p udp --dport 53 -j DNAT --to 128.9.0.107
Jan 1 00:00:33 user debug syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.1.223 -p udp --dport 53 -j DNAT --to 128.9.0.107
Jan 1 00:00:33 daemon info pppd[450]: Sent PADT
Jan 1 00:00:36 daemon info pppd[450]: PPP session is 3244
Jan 1 00:00:36 daemon info pppd[450]: Using interface ppp0_1_32_1
Jan 1 00:00:36 daemon crit pppd[450]: Connect: ppp_0_1_32_1 <--> nas_0_1_32
Jan 1 00:00:36 daemon warn pppd[450]: Couldn't increase MRU to 1500
Jan 1 00:00:37 daemon notice pppd[450]: PAP authentication succeeded
Jan 1 00:00:37 daemon notice pppd[450]: peer from calling number 00:90:1A:42:31:02 authorized
Jan 1 00:00:37 daemon notice pppd[450]: local IP address 178.94.145.166
Jan 1 00:00:37 daemon notice pppd[450]: remote IP address 195.5.5.204
Jan 1 00:00:37 daemon notice pppd[450]: primary DNS address 213.179.249.137
Jan 1 00:00:37 daemon notice pppd[450]: secondary DNS address 213.179.249.138
Jan 1 00:00:37 user debug syslog: kill -9 424
Jan 1 00:00:37 user debug syslog: echo > /var/hosts
Jan 1 00:00:37 user debug syslog: cp /proc/var/fyi/wan/ppp_0_1_32_1/dns /var/fyi/sys/dns
Jan 1 00:00:37 user debug syslog: cp /proc/var/fyi/wan/ppp_0_1_32_1/gateway /var/fyi/sys/gateway
Jan 1 00:00:37 user debug syslog: route add default gw 195.5.5.204 2>/dev/null
Jan 1 00:00:37 user debug syslog: iptables -A FORWARD -o ppp_0_1_32_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Jan 1 00:00:37 user debug syslog: iptables -A FORWARD -i ppp_0_1_32_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Jan 1 00:00:37 user debug syslog: echo > /proc/net/ip_conntrack
Jan 1 00:00:37 user debug syslog: echo "1000" > /proc/sys/net/ipv4/ip_conntrack_max
Jan 1 00:00:38 user debug syslog: echo 2000 > /proc/sys/net/ipv4/ip_conntrack_max
Jan 1 00:00:38 user debug syslog: echo 2000 > /proc/sys/net/ipv4/netfilter/ip_conntrack_generic_timeout
Jan 1 00:00:38 user debug syslog: echo 1400 > /proc/sys/net/ipv4/netfilter/ip_conntrack_tcp_timeout_established
Jan 1 00:00:38 user debug syslog: echo 1400 > /proc/sys/net/ipv4/netfilter/ip_conntrack_tcp_timeout_fin_wait
Jan 1 00:00:38 user debug syslog: echo 120 > /proc/sys/net/ipv4/netfilter/ip_conntrack_tcp_timeout_time_wait
Jan 1 00:00:38 user debug syslog: echo 4096 > /proc/sys/net/ipv4/ipfrag_high_thresh
Jan 1 00:00:38 user debug syslog: echo 1024 > /proc/sys/net/ipv4/ipfrag_low_thresh
Jan 1 00:00:38 user debug syslog: echo 5 > /proc/sys/net/ipv4/ipfrag_time
Jan 1 00:00:38 user debug syslog: iptables -t nat -D PREROUTING -i br0 -d 192.168.1.223 -p udp --dport 53 -j DNAT --to 128.9.0.107 2>/dev/null
Jan 1 00:00:38 user debug syslog: iptables -t nat -D POSTROUTING -o ppp_0_1_32_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE 2>/dev/null
Jan 1 00:00:38 user debug syslog: iptables -t nat -A POSTROUTING -o ppp_0_1_32_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE
Jan 1 00:00:38 user debug syslog: kill -9 712
Jan 1 00:00:38 user debug syslog: echo > /var/hosts
Jan 1 00:00:38 daemon err user: No server certificate found. Skip checking on certificate.
Jan 1 00:00:39 user debug syslog: echo 1024 > /proc/sys/net/ipv4/ipfrag_low_thresh
Jan 1 00:00:39 user debug syslog: echo 5 > /proc/sys/net/ipv4/ipfrag_time
Jan 1 00:00:39 daemon debug user: wlctl -i wl0 authe_sta_list > /var/wl_authe
Jan 1 00:00:39 daemon debug user: wlctl -i wl0 assoclist > /var/wl_assoc
Jan 1 00:00:39 daemon debug user: wlctl -i wl0 autho_sta_list > /var/wl_autho
Jan 1 00:00:40 daemon err user: tr69c: Unable to retrieve attributes in scratch PAD
Jan 1 00:00:40 daemon err user: Stored Parameter Attribute data is corrupt or missing
Sep 22 21:38:15 user debug kernel: UDP: bad checksum. From 195.242.179.188:58208 to 178.94.145.166:61337 ulen 60
Sep 22 21:38:16 user debug kernel: UDP: bad checksum. From 85.196.225.82:57044 to 178.94.145.166:61337 ulen 60
Sep 22 21:38:18 user debug kernel: UDP: bad checksum. From 195.222.127.71:55338 to 178.94.145.166:61337 ulen 60
Sep 22 21:38:20 user debug kernel: UDP: bad checksum. From 83.114.28.134:62952 to 178.94.145.166:61337 ulen 86
Sep 22 21:38:21 user debug kernel: UDP: bad checksum. From 79.132.67.52:56149 to 178.94.145.166:61337 ulen 60
Sep 22 21:38:24 user debug kernel: UDP: bad checksum. From 195.114.6.10:61325 to 178.94.145.166:61337 ulen 64
Sep 22 21:38:25 user debug kernel: UDP: bad checksum. From 195.242.179.188:58208 to 178.94.145.166:61337 ulen 60
Sep 22 21:38:30 user debug kernel: UDP: bad checksum. From 82.193.155.233:59792 to 178.94.145.166:61337 ulen 60
Sep 22 21:38:33 user debug kernel: UDP: bad checksum. From 85.202.113.34:52375 to 178.94.145.166:61337 ulen 64
Sep 22 21:38:33 user debug kernel: UDP: bad checksum. From 79.132.67.52:56149 to 178.94.145.166:61337 ulen 60
Sep 22 21:38:43 user debug kernel: UDP: bad checksum. From 195.149.90.72:51998 to 178.94.145.166:61337 ulen 60
Sep 22 21:38:47 user debug kernel: UDP: bad checksum. From 79.132.67.52:56149 to 178.94.145.166:61337 ulen 60
Sep 22 21:38:50 user debug kernel: UDP: bad checksum. From 109.205.250.61:53946 to 178.94.145.166:61337 ulen 86
Sep 22 21:38:55 user debug kernel: UDP: bad checksum. From 80.249.83.45:61211 to 178.94.145.166:61337 ulen 60
Sep 22 21:38:59 user debug kernel: UDP: bad checksum. From 83.114.28.134:62952 to 178.94.145.166:61337 ulen 60
Sep 22 21:39:00 user debug kernel: UDP: bad checksum. From 195.114.6.10:51176 to 178.94.145.166:61337 ulen 60
Sep 22 21:39:02 user debug kernel: UDP: bad checksum. From 195.149.90.72:51998 to 178.94.145.166:61337 ulen 60
Sep 22 21:39:09 user debug kernel: UDP: bad checksum. From 188.16.207.98:54833 to 178.94.145.166:61337 ulen 60
Sep 22 21:39:10 user debug kernel: UDP: bad checksum. From 195.149.90.72:51998 to 178.94.145.166:61337 ulen 60
Sep 22 21:39:12 user debug kernel: UDP: bad checksum. From 195.149.90.72:51998 to 178.94.145.166:61337 ulen 60
Sep 22 21:39:14 user debug kernel: UDP: bad checksum. From 195.114.6.10:61325 to 178.94.145.166:61337 ulen 64
Sep 22 21:39:21 user warn kernel: printk: 3 messages suppressed.
Sep 22 21:39:21 user debug kernel: UDP: bad checksum. From 77.47.192.208:53966 to 178.94.145.166:61337 ulen 60
Sep 22 21:39:24 user debug kernel: UDP: bad checksum. From 94.73.247.161:19601 to 178.94.145.166:61337 ulen 60
Sep 22 21:39:25 user debug kernel: UDP: bad checksum. From 94.73.247.161:19601 to 178.94.145.166:61337 ulen 60
Sep 22 21:39:33 user warn kernel: printk: 4 messages suppressed.
Sep 22 21:39:33 user debug kernel: UDP: bad checksum. From 188.16.207.98:54833 to 178.94.145.166:61337 ulen 60
Sep 22 21:39:38 user warn kernel: printk: 3 messages suppressed.
Sep 22 21:39:38 user debug kernel: UDP: bad checksum. From 94.73.247.161:19601 to 178.94.145.166:61337 ulen 60
Sep 22 21:39:41 user warn kernel: printk: 1 messages suppressed.
Sep 22 21:39:41 user debug kernel: UDP: bad checksum. From 83.99.163.50:55338 to 178.94.145.166:61337 ulen 60
Sep 22 21:42:41 daemon info pppd[450]: No response to 5 echo-requests
Sep 22 21:42:41 daemon notice pppd[450]: Serial link appears to be disconnected.
Sep 22 21:42:41 daemon info pppd[450]: Connect time 5641782.1 minutes.
Sep 22 21:42:41 daemon info pppd[450]: Sent 28793126 bytes, received 4226953 bytes.
Sep 22 21:42:41 daemon warn pppd[450]: Couldn't increase MRU to 1500
Sep 22 21:42:47 daemon crit pppd[450]: Connection terminated....
Sep 22 21:42:47 daemon notice pppd[450]: Modem hangup
Sep 22 21:42:50 daemon info pppd[450]: Sent PADT
Sep 22 21:43:23 daemon info pppd[450]: Sent PADT
Sep 22 21:43:56 daemon info pppd[450]: Sent PADT
Sep 22 21:44:29 daemon info pppd[450]: Sent PADT
Sep 22 21:45:02 daemon info pppd[450]: Sent PADT
СообщениеДобавлено: Ср сен 22, 2010 22:14
Это значит что проблема с DNS , которую озвучивал Magnitudo, так и не решена, ибо кривая трансляция DNS всеже добавляется. Ну и настройте таки правильно своего торрент клиента, отключите в нем dht хотя бы( UDP: bad checksum пропадет из лога).
