Текущее время: Вт ноя 03, 2026 10:00
 Заголовок сообщения: Модем DSL-2650
СообщениеДобавлено: Вс авг 22, 2010 17:17
Проблема в том что стабильно раз в 20 минут (примерно) пропадает интрнет, хотя все лампочки горят. DSL горит,internet мигает, вот лог
Date/Time Facility Severity Message
Jan 1 00:00:24 user emerg kernel: gpio_fasync
Jan 1 00:00:29 user crit kernel: ADSL G.992 message exchange
Jan 1 00:00:29 user crit kernel: ADSL link up, interleaved, us=1018, ds=2044
Jan 1 00:00:34 daemon crit pppd[658]: Connect: ppp_0_8_35_1 <--> nas_0_8_35
Jan 1 00:00:36 daemon err user: No server certificate found. Skip checking on certificate.
Jan 1 00:00:36 user alert kernel: Intrusion -> IN=ppp_0_8_35_1 OUT= MAC= SRC=213.108.21.181 DST=212.96.110.43 LEN=48 TOS=0x00 PREC=0x00 TTL=120 ID=64884 DF PROTO=TCP SPT=4240 DPT=19408 WINDOW=65535 RES=0x00 SYN URGP=0
Jan 1 00:00:39 daemon err user: tr69c: Unable to retrieve attributes in scratch PAD
Jan 1 00:00:39 daemon err user: Stored Parameter Attribute data is corrupt or missing
Jan 1 00:00:39 user alert kernel: Intrusion -> IN=ppp_0_8_35_1 OUT= MAC= SRC=82.137.160.3 DST=212.96.110.43 LEN=48 TOS=0x00 PREC=0x00 TTL=119 ID=2541 DF PROTO=TCP SPT=3015 DPT=19408 WINDOW=65535 RES=0x00 SYN URGP=0
Jan 1 00:00:43 user alert kernel: Intrusion -> IN=ppp_0_8_35_1 OUT= MAC= SRC=82.193.140.165 DST=212.96.110.43 LEN=48 TOS=0x00 PREC=0x00 TTL=115 ID=17792 DF PROTO=TCP SPT=56004 DPT=19408 WINDOW=8192 RES=0x00 SYN URGP=0
Jan 1 00:00:46 user alert kernel: Intrusion -> IN=ppp_0_8_35_1 OUT= MAC= SRC=82.193.140.165 DST=212.96.110.43 LEN=48 TOS=0x00 PREC=0x00 TTL=115 ID=25420 DF PROTO=TCP SPT=56004 DPT=19408 WINDOW=8192 RES=0x00 SYN URGP=0
Jan 1 00:00:46 user alert kernel: Intrusion -> IN=ppp_0_8_35_1 OUT= MAC= SRC=195.191.146.134 DST=212.96.110.43 LEN=52 TOS=0x00 PREC=0x00 TTL=117 ID=15231 DF PROTO=TCP SPT=57841 DPT=19408 WINDOW=8192 RES=0x00 SYN URGP=0
Jan 1 00:10:37 user alert kernel: Intrusion -> IN=ppp_0_8_35_1 OUT= MAC= SRC=213.171.57.162 DST=212.96.110.43 LEN=48 TOS=0x00 PREC=0x00 TTL=116 ID=15229 DF PROTO=TCP SPT=60759 DPT=19408 WINDOW=8192 RES=0x00 SYN URGP=0
Jan 1 00:13:40 daemon crit pppd[658]: Connection terminated....
Jan 1 00:13:48 daemon crit pppd[658]: Connect: ppp_0_8_35_1 <--> nas_0_8_35
Jan 1 00:13:51 user alert kernel: Intrusion -> IN=ppp_0_8_35_1 OUT= MAC= SRC=87.228.82.107 DST=212.96.110.43 LEN=52 TOS=0x00 PREC=0x00 TTL=119 ID=21430 DF PROTO=TCP SPT=62142 DPT=19408 WINDOW=8192 RES=0x00 SYN URGP=0
Jan 1 00:13:52 user alert kernel: Intrusion -> IN=ppp_0_8_35_1 OUT= MAC= SRC=188.19.173.205 DST=212.96.110.43 LEN=48 TOS=0x00 PREC=0x00 TTL=117 ID=18693 DF PROTO=TCP SPT=56982 DPT=19408 WINDOW=8192 RES=0x00 SYN URGP=0
Jan 1 00:13:53 user alert kernel: Intrusion -> IN=ppp_0_8_35_1 OUT= MAC= SRC=93.100.237.120 DST=212.96.110.43 LEN=48 TOS=0x00 PREC=0x00 TTL=118 ID=3224 DF PROTO=TCP SPT=62884 DPT=19408 WINDOW=8192 RES=0x00 SYN URGP=0
Jan 1 00:13:56 user alert kernel: Intrusion -> IN=ppp_0_8_35_1 OUT= MAC= SRC=93.100.237.120 DST=212.96.110.43 LEN=48 TOS=0x00 PREC=0x00 TTL=118 ID=3582 DF PROTO=TCP SPT=62884 DPT=19408 WINDOW=8192 RES=0x00 SYN URGP=0
Jan 1 00:13:58 user alert kernel: Intrusion -> IN=ppp_0_8_35_1 OUT= MAC= SRC=87.228.82.107 DST=212.96.110.43 LEN=48 TOS=0x00 PREC=0x00 TTL=119 ID=22571 DF PROTO=TCP SPT=62142 DPT=19408 WINDOW=8192 RES=0x00 SYN URGP=0
СообщениеДобавлено: Пн авг 23, 2010 09:57
Сделайте так: В закладке Advanced setup->PPP Username and Password, поставьте "птичку" напротив Bridge PPPoE Frames Between WAN and Local Ports (в самом низу).
СообщениеДобавлено: Пн авг 23, 2010 21:48
Сделал, посмотрим что будет. Потом напишу
Сейчас этот форум просматривают: Google [Bot] и гости: 38
