Текущее время: Вт сен 15, 2026 03:09
 Заголовок сообщения: DSL-500T проблема с подключением
СообщениеДобавлено: Чт май 12, 2005 17:08
Проблема у меня такая:
Не могу подключиться к стриму.
В службе техподдержки просил даже линию проверить. Проверили , сказали что с ней всё в порядке только вот сигнала от модема не поступает.
Модем настроен в режиме роутер.
Вот какой лог при попытке подключения:
Sep 8 12:00:06> Valid Configuration Tree
Sep 8 12:00:11> Firewall NAT service started
Sep 8 12:00:12> Bridge Created: br0
Sep 8 12:00:12> Bridge Interface Added: eth0
Sep 8 12:00:13> pppd 2.4.1 started by root, uid 0
Sep 8 12:00:15> DSL Carrier is down
Sep 8 12:00:25> DSL Carrier is training
Sep 8 12:00:55> DSL Carrier is down
Sep 8 12:01:05> DSL Carrier is training
Sep 8 12:01:25> DSL Carrier is training
Sep 8 12:01:35> DSL Carrier is down
Sep 8 12:01:45> DSL Carrier is training
Sep 8 12:01:53> System Call Error
Sep 8 12:01:53> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Sep 8 12:01:53> Couldn't get channel number: Transport endpoint is not connected
Sep 8 12:01:53> Doing disconnect
Sep 8 12:01:53> pppd 2.4.1 started by root, uid 0
Sep 8 12:03:33> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Sep 8 12:03:33> Couldn't get channel number: Transport endpoint is not connected
Sep 8 12:03:33> Doing disconnect
Sep 8 12:03:33> System Call Error
Sep 8 12:03:38> pppd 2.4.1 started by root, uid 0
Sep 8 12:04:15> DSL Carrier is down
Sep 8 12:04:25> DSL Carrier is training
Sep 8 12:04:55> DSL Carrier is training
Sep 8 12:05:05> DSL Carrier is down
Sep 8 12:05:18> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Sep 8 12:05:18> Couldn't get channel number: Transport endpoint is not connected
Sep 8 12:05:18> Doing disconnect
Sep 8 12:05:18> System Call Error
Sep 8 12:05:19> pppd 2.4.1 started by root, uid 0
Sep 8 12:05:25> DSL Carrier is training
Sep 8 12:05:45> DSL Carrier is down
Sep 8 12:05:55> DSL Carrier is training
Sep 8 12:06:59> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Sep 8 12:06:59> Couldn't get channel number: Transport endpoint is not connected
Sep 8 12:06:59> Doing disconnect
Sep 8 12:06:59> System Call Error
Sep 8 12:07:04> pppd 2.4.1 started by root, uid 0
Sep 8 12:07:25> DSL Carrier is down
Sep 8 12:07:35> DSL Carrier is training
Sep 8 12:07:55> DSL Carrier is down
Sep 8 12:08:15> DSL Carrier is training
Sep 8 12:08:44> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Sep 8 12:08:44> Couldn't get channel number: Transport endpoint is not connected
Sep 8 12:08:44> Doing disconnect
Sep 8 12:08:44> System Call Error
Sep 8 12:08:49> pppd 2.4.1 started by root, uid 0
Sep 8 12:08:55> DSL Carrier is down
Sep 8 12:09:05> DSL Carrier is training
Sep 8 12:09:45> DSL Carrier is down
Sep 8 12:09:55> DSL Carrier is training
Sep 8 12:10:29> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Sep 8 12:10:29> Couldn't get channel number: Transport endpoint is not connected
Sep 8 12:10:29> Doing disconnect
Sep 8 12:10:29> System Call Error
Sep 8 12:10:34> pppd 2.4.1 started by root, uid 0
Sep 8 12:11:35> DSL Carrier is down
Sep 8 12:11:45> DSL Carrier is training
Sep 8 12:12:14> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Sep 8 12:12:14> Couldn't get channel number: Transport endpoint is not connected
Sep 8 12:12:14> Doing disconnect
Sep 8 12:12:14> System Call Error
Sep 8 12:12:20> pppd 2.4.1 started by root, uid 0
Sep 8 12:12:25> DSL Carrier is down
Sep 8 12:13:05> DSL Carrier is training
Sep 8 12:13:35> DSL Carrier is training
Sep 8 12:13:45> DSL Carrier is training
Sep 8 12:14:00> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Sep 8 12:14:00> Couldn't get channel number: Transport endpoint is not connected
Sep 8 12:14:00> Doing disconnect
Sep 8 12:14:00> System Call Error
Sep 8 12:14:05> pppd 2.4.1 started by root, uid 0
Sep 8 12:14:35> DSL Carrier is down
Sep 8 12:14:55> DSL Carrier is up
Sep 8 12:15:05> DSL Carrier is training
Sep 8 12:15:45> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Sep 8 12:15:45> Couldn't get channel number: Transport endpoint is not connected
Sep 8 12:15:45> Doing disconnect
Sep 8 12:15:45> System Call Error
Sep 8 12:15:50> pppd 2.4.1 started by root, uid 0
Sep 8 12:15:55> DSL Carrier is down
Sep 8 12:16:05> DSL Carrier is training
Sep 8 12:16:35> DSL Carrier is training
Sep 8 12:16:45> DSL Carrier is down
Sep 8 12:17:15> DSL Carrier is training
Sep 8 12:17:30> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Sep 8 12:17:30> Couldn't get channel number: Transport endpoint is not connected
Sep 8 12:17:30> Doing disconnect
Sep 8 12:17:30> System Call Error
Sep 8 12:17:35> pppd 2.4.1 started by root, uid 0
Sep 8 12:17:55> DSL Carrier is down
Sep 8 12:18:05> DSL Carrier is training
Sep 8 12:19:15> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Sep 8 12:19:15> Couldn't get channel number: Transport endpoint is not connected
Sep 8 12:19:15> Doing disconnect
Sep 8 12:19:15> System Call Error
Sep 8 12:19:21> pppd 2.4.1 started by root, uid 0
Sep 8 12:21:01> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Sep 8 12:21:01> Couldn't get channel number: Transport endpoint is not connected
Sep 8 12:21:01> Doing disconnect
Sep 8 12:21:01> System Call Error
Sep 8 12:21:06> pppd 2.4.1 started by root, uid 0
Sep 8 12:21:15> DSL Carrier is down
Sep 8 12:21:35> DSL Carrier is training
 Заголовок сообщения: Re: DSL-500T проблема с подключением
СообщениеДобавлено: Чт май 12, 2005 17:16
Вот здесь поподробнее! плиз :D
http://ant0.ru
СообщениеДобавлено: Чт май 12, 2005 17:30
Вообщем я не особ разбираюсь в сетях и АДСЛе
но этим я имел ввиду что он сам подключается при включении независимо от компьютера.
СообщениеДобавлено: Чт май 12, 2005 18:21
Поподробнее - имел ввиду:
Значения:
VPI:
VCI:
Mode:
и т.п.
http://ant0.ru
Сейчас этот форум просматривают: Google [Bot] и гости: 18
