Текущее время: Вс ноя 01, 2026 22:39
 Заголовок сообщения: Dsl 524T
СообщениеДобавлено: Вт окт 13, 2009 12:42
подскажите настройки чтобы интернет был на 2 компах
СообщениеДобавлено: Ср окт 14, 2009 15:53
включите NAT
и будет хоть на 4 ) а если свитч поставите, то и больше
СообщениеДобавлено: Чт окт 15, 2009 14:43
Jan 1 12:00:10> Valid Configuration Tree
Jan 1 12:00:11> NTP Polling Timer for DHCP Started succesfully.
Jan 1 12:00:11> DSL Polling Timer Started succesfully.
Jan 1 12:00:11> doing modulation_set.
Jan 1 12:00:11> Firewall NAT service started
Jan 1 12:00:16> starting on port 80
Jan 1 12:00:16> Bridge Created: br0
Jan 1 12:00:16> Bridge Created: br1
Jan 1 12:00:17> Bridge Interface Added: eth0
Jan 1 12:00:21> DSL Carrier is down
Jan 1 12:00:31> DSL Carrier is up
Jan 1 12:00:33> pppd 2.4.1 started by root, uid 0
Jan 1 12:01:43> Firewall rules flushed
Jan 1 12:01:45> Failed to negotiate PPPoE connection: 127
Jan 1 12:01:46> pppd 2.4.1 started by root, uid 0
Jan 1 12:01:46> Firewall rules flushed
Jan 1 12:02:02> Firewall rules flushed
Jan 1 12:02:05> Failed to negotiate PPPoE connection: 127
Jan 1 12:02:05> pppd 2.4.1 started by root, uid 0
Jan 1 12:02:06> Firewall rules flushed
an 1 12:03:45> System Call Error
Jan 1 12:03:45> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d388
Jan 1 12:03:45> Couldn't get channel number: Transport endpoint is not connected
Jan 1 12:03:45> Doing disconnect
Jan 1 12:03:45> pppd 2.4.1 started by root, uid 0
Jan 1 12:04:21> DSL Carrier is down
Jan 1 12:04:51> DSL Carrier is up
Jan 1 12:04:51> pppd 2.4.1 started by root, uid 0
Jan 1 12:06:31> System Call Error
Jan 1 12:06:31> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d388
Jan 1 12:06:32> Couldn't get channel number: Transport endpoint is not connected
Jan 1 12:06:32> Doing disconnect
Jan 1 12:06:32> pppd 2.4.1 started by root, uid 0
Jan 1 12:07:34> Failed to negotiate PPPoE connection: 127
Jan 1 12:07:35> pppd 2.4.1 started by root, uid 0
Jan 1 12:07:44> set error: message= :(null):
Jan 1 12:07:44> set error: message= :Bad value for key 'settings/mode' in 'pppoe0':
Jan 1 12:09:15> System Call Error
Jan 1 12:09:15> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d388
Jan 1 12:09:15> Couldn't get channel number: Transport endpoint is not connected
an 1 12:09:15> Doing disconnect
Jan 1 12:09:15> pppd 2.4.1 started by root, uid 0
Jan 1 12:09:41> DSL Carrier is down
Jan 1 12:09:51> DSL Carrier is up
Jan 1 12:09:51> pppd 2.4.1 started by root, uid 0
Jan 1 12:10:01> DSL Carrier is down
Jan 1 12:10:11> DSL Carrier is up
Jan 1 12:10:11> pppd 2.4.1 started by root, uid 0
Jan 1 12:11:51> System Call Error
Jan 1 12:11:51> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d388
Jan 1 12:11:52> Couldn't get channel number: Transport endpoint is not connected
Jan 1 12:11:52> Doing disconnect
Jan 1 12:11:52> pppd 2.4.1 started by root, uid 0
Что не так?пож могите :roll:
СообщениеДобавлено: Пн окт 19, 2009 12:57
Абонентом какого провайдера Вы являетесь? Приведите настройки WAN-интерфейса.
СообщениеДобавлено: Вт окт 20, 2009 21:19
провайдер веб плас,какие именно настройки?
