Текущее время: Ср окт 14, 2026 01:01
 Заголовок сообщения: D-link 2650 и разрывы каждые 20 мин
СообщениеДобавлено: Чт сен 03, 2009 22:09
Здраствуйте! Приобрел роутер 2650,настроил. Все работает, но есть одна проблема - примерно каждые 20 минут рвется соединение, не важно, через wi-fi подключение или lan. Вот лог:
Sep 3 22:17:20 daemon info pppd[631]: No response to 5 echo-requests
Sep 3 22:17:20 daemon notice pppd[631]: Serial link appears to be disconnected.
Sep 3 22:17:20 daemon info pppd[631]: Connect time 22.0 minutes.
Sep 3 22:17:20 daemon info pppd[631]: Sent 614 bytes, received 904 bytes.
Sep 3 22:17:20 daemon warn pppd[631]: Couldn't increase MRU to 1500
Sep 3 22:17:26 daemon notice pppd[631]: Connection terminated....
Sep 3 22:17:26 daemon notice pppd[631]: Modem hangup
Sep 3 22:17:29 daemon info pppd[631]: Sent PADT
Sep 3 22:17:35 daemon info pppd[631]: PPP session is 6010
Sep 3 22:17:35 daemon info pppd[631]: Using interface ppp0_1_50_1
Sep 3 22:17:35 daemon notice pppd[631]: Connect: ppp_0_1_50_1 <--> nas_0_1_50
Sep 3 22:17:35 daemon warn pppd[631]: Couldn't increase MRU to 1500
Sep 3 22:17:35 daemon info pppd[631]: CHAP authentication succeeded: CHAP authentication success, unit 1875
Sep 3 22:17:35 daemon notice pppd[631]: peer from calling number 00:30:88:01:54:6E authorized
Sep 3 22:17:35 daemon notice pppd[631]: local IP address 83.237.107.250
Sep 3 22:17:35 daemon notice pppd[631]: remote IP address 83.237.104.1
Sep 3 22:17:35 daemon notice pppd[631]: primary DNS address 195.34.32.116
Sep 3 22:17:35 daemon notice pppd[631]: secondary DNS address 212.188.4.10
Sep 3 22:29:16 user err kernel: kill_fasync: bad magic number in fasync_struct!
Sep 3 22:29:16 user emerg kernel: my_timeout:Pasync_queue->magic = 0x4601
Sep 3 22:29:28 user info kernel: device wl0 entered promiscuous mode
Sep 3 22:29:28 user info kernel: br0: port 3(wl0) entering learning state
Sep 3 22:29:28 user info kernel: br0: topology change detected, propagating
Sep 3 22:29:28 user info kernel: br0: port 3(wl0) entering forwarding state
Sep 3 22:39:05 daemon info pppd[631]: No response to 5 echo-requests
Sep 3 22:39:05 daemon notice pppd[631]: Serial link appears to be disconnected.
Sep 3 22:39:05 daemon info pppd[631]: Connect time 21.5 minutes.
Sep 3 22:39:05 daemon info pppd[631]: Sent 150027 bytes, received 4355905 bytes.
Sep 3 22:39:05 daemon warn pppd[631]: Couldn't increase MRU to 1500
Sep 3 22:39:11 daemon notice pppd[631]: Connection terminated....
Sep 3 22:39:11 daemon notice pppd[631]: Modem hangup
Sep 3 22:39:14 daemon info pppd[631]: Sent PADT
Sep 3 22:39:17 daemon info pppd[631]: PPP session is 9942
Sep 3 22:39:17 daemon info pppd[631]: Using interface ppp0_1_50_1
Sep 3 22:39:17 daemon notice pppd[631]: Connect: ppp_0_1_50_1 <--> nas_0_1_50
Sep 3 22:39:17 daemon warn pppd[631]: Couldn't increase MRU to 1500
Sep 3 22:39:17 daemon info pppd[631]: CHAP authentication succeeded: CHAP authentication success, unit 6366
Sep 3 22:39:17 daemon notice pppd[631]: peer from calling number 00:30:88:01:54:6E authorized
Sep 3 22:39:17 daemon notice pppd[631]: local IP address 91.77.175.151
Sep 3 22:39:17 daemon notice pppd[631]: remote IP address 91.77.172.1
Sep 3 22:39:17 daemon notice pppd[631]: primary DNS address 195.34.32.116
Sep 3 22:39:17 daemon notice pppd[631]: secondary DNS address 212.188.4.10
Sep 3 22:39:22 user alert kernel: Intrusion -> IN=ppp_0_1_50_1 OUT= MAC= SRC=119.242.193.86 DST=91.77.175.151 LEN=52 TOS=0x00 PREC=0x20 TTL=112 ID=32157 DF PROTO=TCP SPT=62161 DPT=54641 WINDOW=8192 RES=0x00 SYN URGP=0
Помогите пожалуйста.
Версия прошивки 1.12, провайдер стрим.
До этого был 2540, работал как часы.
