Текущее время: Ср сен 23, 2026 11:13
 Заголовок сообщения: Проблема 2640 bru\c
СообщениеДобавлено: Ср авг 26, 2009 14:43
Не хочет подключаться нет. ДСЛ горит, а и-нет - не горит. Говорил с операторами - сказали по линии - всё гуд. В чем проблема не могу понять.
Вот лог
Jan 1 00:06:55 user crit kernel: ADSL link up, interleaved, us=1024, ds=7680
Jan 1 00:06:59 daemon crit pppd[346]: PPP server detected.
Jan 1 00:06:59 daemon crit pppd[346]: PPP session established.
Jan 1 00:07:01 daemon crit pppd[346]: PPP LCP UP.
Jan 1 00:07:01 daemon crit pppd[346]: Clear IP addresses. PPP connection DOWN.
Jan 1 00:07:01 daemon crit pppd[346]: Received valid IP address from server. Connection UP.
Jan 1 00:10:02 user crit kernel: ADSL link down
Jan 1 00:10:04 daemon crit pppd[346]: Clear IP addresses. Connection DOWN.
Jan 1 00:10:08 user crit kernel: ADSL G.994 training
Jan 1 00:10:12 user crit kernel: ADSL G.992 started
Jan 1 00:10:15 user crit kernel: ADSL G.992 channel analysis
Jan 1 00:10:19 user crit kernel: ADSL G.992 message exchange
Jan 1 00:10:20 user crit kernel: ADSL link up, interleaved, us=1024, ds=7808
Jan 1 00:10:24 daemon crit pppd[346]: PPP server detected.
Jan 1 00:10:24 daemon crit pppd[346]: PPP session established.
Jan 1 00:10:26 daemon crit pppd[346]: PPP LCP UP.
Jan 1 00:10:26 daemon crit pppd[346]: Clear IP addresses. PPP connection DOWN.
Jan 1 00:10:26 daemon crit pppd[346]: Received valid IP address from server. Connection UP.
Jan 1 00:11:27 user alert kernel: Intrusion -> IN=ppp_0_0_32_1 OUT= MAC= SRC=89.172.194.41 DST=89.105.246.138 LEN=48 TOS=0x04 PREC=0x80 TTL=120 ID=9094 DF PROTO=TCP SPT=55647 DPT=443 WINDOW=16384 RES=0x00 SYN URGP=0
Jan 1 00:11:27 user alert kernel: Intrusion -> IN=ppp_0_0_32_1 OUT= MAC= SRC=78.131.16.213 DST=89.105.246.138 LEN=60 TOS=0x04 PREC=0x80 TTL=113 ID=23584 DF PROTO=TCP SPT=56522 DPT=80 WINDOW=8192 RES=0x00 SYN URGP=0
Jan 1 00:11:30 user alert kernel: Intrusion -> IN=ppp_0_0_32_1 OUT= MAC= SRC=89.172.194.41 DST=89.105.246.138 LEN=48 TOS=0x04 PREC=0x80 TTL=120 ID=9097 DF PROTO=TCP SPT=55647 DPT=443 WINDOW=16384 RES=0x00 SYN URGP=0
Jan 1 00:11:30 user alert kernel: Intrusion -> IN=ppp_0_0_32_1 OUT= MAC= SRC=78.131.16.213 DST=89.105.246.138 LEN=60 TOS=0x04 PREC=0x80 TTL=113 ID=23616 DF PROTO=TCP SPT=56522 DPT=80 WINDOW=8192 RES=0x00 SYN URGP=0
Jan 1 00:11:36 user alert kernel: Intrusion -> IN=ppp_0_0_32_1 OUT= MAC= SRC=78.131.16.213 DST=89.105.246.138 LEN=56 TOS=0x04 PREC=0x80 TTL=113 ID=23693 DF PROTO=TCP SPT=56522 DPT=80 WINDOW=8192 RES=0x00 SYN URGP=0
Jan 1 00:16:48 user crit kernel: ADSL link down
Jan 1 00:16:50 user crit kernel: ADSL G.994 training
Jan 1 00:16:50 daemon crit pppd[346]: Clear IP addresses. Connection DOWN.
Jan 1 00:16:54 user crit kernel: ADSL G.992 started
Jan 1 00:16:56 user crit kernel: ADSL G.992 channel analysis
Jan 1 00:17:01 user crit kernel: ADSL G.992 message exchange
Jan 1 00:17:01 user crit kernel: ADSL link up, interleaved, us=1024, ds=7808
Jan 1 00:17:04 daemon crit pppd[346]: PPP server detected.
Jan 1 00:17:04 daemon crit pppd[346]: PPP session established.
Jan 1 00:17:06 daemon crit pppd[346]: PPP LCP UP.
Jan 1 00:17:09 daemon crit pppd[346]: Received valid IP address from server. Connection UP.
Jan 1 00:17:12 daemon crit pppd[346]: Clear IP addresses. Connection DOWN.
Jan 1 00:17:12 daemon crit pppd[346]: Received valid IP address from server. Connection UP.
Jan 1 00:20:02 user crit kernel: OAM loopback response not received on PORT/VPI/VCI 0/0/32.
Jan 1 00:20:04 user crit kernel: OAM loopback response not received on PORT/VPI/VCI 0/0/3.
Jan 1 00:20:05 user crit kernel: OAM loopback response not received on PORT/VPI/VCI 0/0/32.
Jan 1 00:20:07 user crit kernel: OAM loopback response not received on PORT/VPI/VCI 0/0/4.
 Заголовок сообщения: Re: Проблема 2640 bru\c
СообщениеДобавлено: Ср авг 26, 2009 15:31
Вот лог
Из лога видны потери ADSL-линка (рассинхронизация с DSLAM).
Приведите, пожалуйста, вывод страницы Device Info > Statistics > ADSL.
