Текущее время: Пн авг 31, 2026 10:53
 Заголовок сообщения: DSL-2600 link down
СообщениеДобавлено: Вс июл 26, 2009 17:26
происходит прерывание соединения по неизвестной мне причине. иногда все работает сутками, а иногда просто безбожно часто!
Инфа о девайсе и лог прилагаются.
Device Info
BoardID: DSL-2600U
Software Version: RU_1.02
Bootloader (CFE) Version: 1.0.37-8.7
Wireless Driver Version: 3.131.35.6.cpe1.0a.s
Date/Time Facility Severity Message
Jan 1 00:00:23 user warn kernel: 96338WS prom init
Jan 1 00:00:23 user warn kernel: CPU revision is: 00029010
Jan 1 00:00:23 user warn kernel: Determined physical RAM map:
Jan 1 00:00:23 user warn kernel: memory: 00fa0000 @ 00000000 (usable)
Jan 1 00:00:23 user warn kernel: Built 1 zonelists
Jan 1 00:00:23 user warn kernel: Kernel command line: root=31:0 ro noinitrd console=ttyS0,115200
Jan 1 00:00:23 user warn kernel: brcm mips: enabling icache and dcache...
Jan 1 00:00:23 user warn kernel: Primary instruction cache 16kB, physically tagged, 2-way, linesize 16 bytes.
Jan 1 00:00:23 user warn kernel: Primary data cache 8kB 2-way, linesize 16 bytes.
Jan 1 00:00:23 user warn kernel: PID hash table entries: 64 (order 6: 512 bytes)
Jan 1 00:00:23 user warn kernel: Using 120.000 MHz high precision timer.
Jan 1 00:00:23 user warn kernel: Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Jan 1 00:00:23 user warn kernel: Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Jan 1 00:00:23 user warn kernel: KLOB Pool 1 Initialized: 1048576 bytes <0x80e00000 ... 0x80f00000>
Jan 1 00:00:23 user warn kernel: Calibrating delay loop... 239.20 BogoMIPS
Jan 1 00:00:23 user warn kernel: Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Jan 1 00:00:23 user warn kernel: Checking for 'wait' instruction... unavailable.
Jan 1 00:00:23 user warn kernel: Total Flash size: 4096K with 71 sectors
Jan 1 00:00:23 user warn kernel: File system address: 0xbfc10100
Jan 1 00:00:23 user warn kernel: Blk# BlkOff Blks MemLen Partition Name
Jan 1 00:00:23 user warn kernel: 0 1408 1 1024 NVRAM
Jan 1 00:00:23 user warn kernel: 69 40960 1 24576 Config 2
Jan 1 00:00:23 user warn kernel: 70 32768 1 8192 Scratch PAD
Jan 1 00:00:23 user warn kernel: 70 40960 1 24576 Config 1
Jan 1 00:00:23 user warn kernel: Can't analyze prologue code at 8017ebd4
Jan 1 00:00:23 user warn kernel: Using noop io scheduler
Jan 1 00:00:23 user warn kernel: bcm963xx_mtd driver v1.0
Jan 1 00:00:23 user warn kernel: brcmboard: brcm_board_init entry
Jan 1 00:00:23 user warn kernel: SES: Button Interrupt 0x0 is enabled
Jan 1 00:00:23 user warn kernel: SES: LED GPIO 0x8005 is enabled
Jan 1 00:00:23 user warn kernel: ttyS0 at MMIO 0xfffe0300 (irq = 10) is a BCM63XX
Jan 1 00:00:23 user notice kernel: Ebtables v2.0 registered
Jan 1 00:00:23 user warn kernel: VFS: Mounted root (squashfs filesystem) readonly.
Jan 1 00:00:23 user warn kernel: Algorithmics/MIPS FPU Emulator v1.5
Jan 1 00:00:23 user warn kernel: atmapi: module license 'Proprietary' taints kernel.
Jan 1 00:00:23 user warn kernel: adsl: adsl_init entry
Jan 1 00:00:23 user warn kernel: blaadd: blaa_detect entry
Jan 1 00:00:23 user warn kernel: SDIOH mode switch from 1 to 2
Jan 1 00:00:23 user warn kernel: available commands: sdio sdioh
Jan 1 00:00:23 user warn kernel: ---SDIO init SUCCEEDED--- sromless
Jan 1 00:00:23 user warn kernel: chipid 0x4024318
Jan 1 00:00:23 user warn kernel: bcmsdh_attach, sdioh_attach successful, bcmsdh->sdioh 0x80e58b80
Jan 1 00:00:23 user warn kernel: wl0: wlc_attach: use mac addr from the system pool by id: 0x776c0000
Jan 1 00:00:23 user warn kernel: wl0: MAC Address: 00:1E:58:E5:4D:0D
Jan 1 00:00:23 user warn kernel: wl0: Broadcom BCM4318 802.11 Wireless Controller 3.131.35.6.cpe1.0a.sd-e1
Jan 1 00:00:23 user warn kernel: dgasp: kerSysRegisterDyingGaspHandler: wl0 registered
Jan 1 00:00:23 user warn kernel: Trying to free free IRQ25
Jan 1 00:00:23 user warn kernel: Broadcom BCM6338A2 Ethernet Network Device v0.3 Jan 14 2009 13:30:25
Jan 1 00:00:23 user warn kernel: Config Internal PHY Through MDIO
Jan 1 00:00:23 user warn kernel: eth0: MAC Address: 00:1E:58:E5:4D:0E
Jan 1 00:00:23 user crit kernel: eth0 Link UP.
Jan 1 00:00:23 user warn kernel: BcmAdsl_Initialize=0xC00663E8, g_pFnNotifyCallback=0xC0080FE4
Jan 1 00:00:23 user warn kernel: AnnexCParam=0x7FFF7EB8 AnnexAParam=0x00000981 adsl2=0x00000000
Jan 1 00:00:23 user warn kernel: pSdramPHY=0xA0FFFFF8, 0xCEC6CFCD 0xE5EDE4DC
Jan 1 00:00:23 user warn kernel: AdslCoreHwReset: AdslOemDataAddr = 0xA0FEF96C
Jan 1 00:00:23 user warn kernel: dgasp: kerSysRegisterDyingGaspHandler: dsl0 registered
Jan 1 00:00:23 user warn kernel: ATM proc init !!!
Jan 1 00:00:23 user warn kernel: ip_tables: (C) 2000-2002 Netfilter core team
Jan 1 00:00:23 user warn kernel: ip_conntrack version 2.1 (125 buckets, 0 max) - 384 bytes per conntrack
Jan 1 00:00:23 user warn kernel: ip_ct_h323: init success
Jan 1 00:00:23 user warn kernel: >ip_nat_h323: init success
Jan 1 00:00:23 user warn kernel: BRCM NAT Caching v1.0 Nov 20 2007 10:22:27
Jan 1 00:00:23 user warn kernel: BRCM NAT Cache: Hooking hit function @ c005f088
Jan 1 00:00:23 user crit kernel: ADSL G.994 training
Jan 1 00:00:23 user warn kernel: ip_conntrack_rtsp v0.01 loading
Jan 1 00:00:23 user warn kernel: ip_nat_rtsp v0.01 loading
Jan 1 00:00:23 user crit kernel: ADSL G.992 started
Jan 1 00:00:23 user crit kernel: ADSL G.992 channel analysis
Jan 1 00:00:23 user crit kernel: ADSL link down
Jan 1 00:00:24 daemon notice pppd[415]: pppd 2.4.1 started by admin, uid 0
Jan 1 00:00:25 user crit kernel: ADSL G.994 training
Jan 1 00:00:28 user crit kernel: ADSL G.992 started
Jan 1 00:00:31 user crit kernel: ADSL G.992 channel analysis
Jan 1 00:00:35 user crit kernel: ADSL G.992 message exchange
Jan 1 00:00:36 user crit kernel: ADSL link up, interleaved, us=623, ds=2492
Jan 1 00:00:36 user warn kernel: ATM Soft SAR: ATM link connected.
Jan 1 00:00:38 daemon notice pppd[415]: PPP: Start to connect ...
Jan 1 00:00:38 daemon crit pppd[415]: PPP server detected.
Jan 1 00:00:38 daemon crit pppd[415]: PPP session established.
Jan 1 00:00:39 daemon crit pppd[415]: PPP LCP UP.
Jan 1 00:00:51 daemon crit pppd[415]: Received valid IP address from server. Connection UP.
Jan 1 00:00:53 user notice dnsprobe[826]: dnsprobe started!
Jan 1 00:00:55 user notice syslog: siproxd.c:192 INFO:siproxd-0.5.10-2847 i686-redhat-linux-gnu starting up
Jan 1 00:00:55 user notice syslog: siproxd.c:218 INFO:daemonized, pid=874
Jan 1 00:00:55 user notice syslog: sock.c:65 INFO:bound to port 5060
Jan 1 00:00:55 user notice syslog: register.c:65 WARNING:registration file not found, starting with empty table
Jan 1 00:00:55 user notice syslog: siproxd.c:265 INFO:siproxd-0.5.10-2847 i686-redhat-linux-gnu started
Jan 1 00:00:55 user warn dnsprobe[826]: dns query failed
Jan 1 00:00:58 daemon err user: No server certificate found. Skip checking on certificate.
Jan 1 00:01:00 daemon err user: tr69c: Unable to retrieve attributes in scratch PAD
Jan 1 00:01:00 daemon err user: Stored Parameter Attribute data is corrupt or missing
Jan 1 00:02:05 user alert kernel: Intrusion -> IN=ppp_0_1_32_1 OUT= MAC= SRC=188.134.1.131 DST=92.113.212.185 LEN=48 TOS=0x00 PREC=0x00 TTL=114 ID=49494 DF PROTO=TCP SPT=1276 DPT=41030 WINDOW=65535 RES=0x00 SYN URGP=0
Jan 1 00:02:24 user crit kernel: ADSL link down
Jan 1 00:02:25 daemon crit pppd[415]: Clear IP addresses. Connection DOWN.
Jan 1 00:02:25 daemon crit pppd[415]: Clear IP addresses. PPP connection DOWN.
Jan 1 00:02:26 user crit kernel: ADSL G.994 training
Jan 1 00:02:29 user crit kernel: ADSL G.992 started
Jan 1 00:02:32 user crit kernel: ADSL G.992 channel analysis
Jan 1 00:02:36 user crit kernel: ADSL link down
Jan 1 00:02:38 user crit kernel: ADSL G.994 training
Jan 1 00:02:41 user crit kernel: ADSL G.992 started
Jan 1 00:02:44 user crit kernel: ADSL G.992 channel analysis
Jan 1 00:02:48 user crit kernel: ADSL link down
Jan 1 00:02:51 user crit kernel: ADSL G.994 training
Jan 1 00:02:54 user crit kernel: ADSL G.992 started
Jan 1 00:02:57 user crit kernel: ADSL G.992 channel analysis
Jan 1 00:03:02 user crit kernel: ADSL link down
Jan 1 00:03:03 user crit kernel: ADSL G.994 training
Jan 1 00:03:06 user crit kernel: ADSL G.992 started
Jan 1 00:03:09 user crit kernel: ADSL G.992 channel analysis
Jan 1 00:03:13 user crit kernel: ADSL link down
Jan 1 00:03:16 user crit kernel: ADSL G.994 training
Jan 1 00:03:19 user crit kernel: ADSL G.992 started
Jan 1 00:03:22 user crit kernel: ADSL G.992 channel analysis
Jan 1 00:03:27 user crit kernel: ADSL link down
Jan 1 00:03:29 user crit kernel: ADSL G.994 training
Jan 1 00:03:33 user crit kernel: ADSL G.992 started
Jan 1 00:03:35 user crit kernel: ADSL G.992 channel analysis
Jan 1 00:03:40 user crit kernel: ADSL link down
Jan 1 00:03:42 user crit kernel: ADSL G.994 training
Jan 1 00:03:46 user crit kernel: ADSL G.992 started
Jan 1 00:03:49 user crit kernel: ADSL G.992 channel analysis
Jan 1 00:03:53 user crit kernel: ADSL link down
Jan 1 00:03:56 user crit kernel: ADSL G.994 training
Jan 1 00:03:59 user crit kernel: ADSL G.992 started
Jan 1 00:04:02 user crit kernel: ADSL G.992 channel analysis
Jan 1 00:04:06 user crit kernel: ADSL G.992 message exchange
Jan 1 00:04:07 user crit kernel: ADSL link up, interleaved, us=623, ds=2492
Jan 1 00:04:08 daemon notice pppd[415]: PPP: Start to connect ...
Jan 1 00:04:09 daemon crit pppd[415]: PPP server detected.
Jan 1 00:04:21 daemon notice pppd[415]: PPP: Start to connect ...
Jan 1 00:04:22 daemon crit pppd[415]: PPP server detected.
Jan 1 00:04:24 daemon crit pppd[415]: PPP session established.
Jan 1 00:04:24 daemon crit pppd[415]: PPP LCP UP.
Jan 1 00:04:25 daemon crit pppd[415]: Received valid IP address from server. Connection UP.
Jan 1 00:04:27 user notice syslog: siproxd.c:192 INFO:siproxd-0.5.10-2847 i686-redhat-linux-gnu starting up
Jan 1 00:04:27 user notice syslog: siproxd.c:218 INFO:daemonized, pid=2727
Jan 1 00:04:27 user notice syslog: sock.c:65 INFO:bound to port 5060
Jan 1 00:04:27 user notice syslog: register.c:65 WARNING:registration file not found, starting with empty table
Jan 1 00:04:27 user notice syslog: siproxd.c:265 INFO:siproxd-0.5.10-2847 i686-redhat-linux-gnu started
может кто поможет или посоветует что-нить?
 Заголовок сообщения: Re: DSL-2600 link down
СообщениеДобавлено: Пн июл 27, 2009 15:22
Device Info
BoardID: DSL-2600U
1. Обновите прошивку модема до текущей версии RU_1.20.
ftp://ftp.dlink.ru/pub/ADSL/DSL-2600U_B ... 090514.zip
2. Если не поможет, приведите вывод страницы Device Info > Statistics > ADSL.
СообщениеДобавлено: Вт июл 28, 2009 01:50
поменял прошивку. не помогло. работает с все также с перерывами.
вот то, что просили:
1 вариант
Statistics -- ADSL
Mode: G.DMT
Type: Interleave
Line Coding: Trellis On
Status: No Defect
Link Power State: L0
Downstream Upstream
SNR Margin (dB): 32.9 15.0
Attenuation (dB): 27.0 13.5
Output Power (dBm): 12.1 16.6
Attainable Rate (Kbps): 11283 1055
Rate (Kbps): 2492 623
K (number of bytes in DMT frame): 73 19
R (number of check bytes in RS code word): 14 16
S (RS code word size in DMT frame): 2 8
D (interleaver depth): 32 2
Delay (msec): 16 4
Super Frames: 5780 5721
Super Frame Errors: 0 0
RS Words: 196550 48628
RS Correctable Errors: 0 0
RS Uncorrectable Errors: 0 N/A
HEC Errors: 0 0
OCD Errors: 0 0
LCD Errors: 0 0
Total Cells: 577632 0
Data Cells: 4289 0
Bit Errors: 0 0
Total ES: 0 0
Total SES: 0 0
Total UAS: 35 0
2 вариант
Statistics -- ADSL
Mode: G.DMT
Type: Interleave
Status:
Downstream Upstream
SNR Margin (dB): 2.4 15.0
Attenuation (dB): 28.0 13.5
Output Power (dBm): 12.1 16.1
Attainable Rate (Kbps): 11214 1068
Delay (msec): 16 4
Super Frames: 1827 1823
Super Frame Errors: 938 32
RS Words: 62148 15495
RS Correctable Errors: 10628 6
RS Uncorrectable Errors: 31454 N/A
HEC Errors: 940 11
OCD Errors: 0 1
LCD Errors: 0 0
Total Cells: 150728 0
Data Cells: 5406 0
Bit Errors: 0 0
Total ES: 15 0
Total SES: 12 0
Total UAS: 20 0
СообщениеДобавлено: Вт июл 28, 2009 08:05
И у меня такая же петрушка. прошивку еще с самого начала обновил. настроено в режиме роутера.
СообщениеДобавлено: Ср июл 29, 2009 11:23
AtomX
Возможно барахлит входной канал. Звоните в поддержку, пусть проверяют.
 Заголовок сообщения: d-link вобще работает?
СообщениеДобавлено: Ср июл 29, 2009 22:06
Я как дурак купил аж 3 оборудования d-link, теперь жалею. У меня модем 2500U и 2600U оба нормально не работают. Единственно что у меня работает - это свич, но и тот начал выделываться (пропадает сеть и сразу востанавлюется).
Модем 2500U в режиме роутера работает пару минут, а то и меньше и вылитает, в режиме бриджинг - все норм.(по крайней мере сдесь можно спрыгнуть на провайдера или линию), знакомы принес 2 таких модема, у обоих та же проблема.
У 2600U немного иная проблемка, этот работает, а потом виснит, помагает ребут. (уже достало) при этом выбивает не систематично, вот пока я написал это сообщение - выбило 3 раза. Ну, раз в час - это как минимум.
Пожалуйста подскажите что делать!
Все оборудование у меня работает без выключения и должно работать по принцепу - включил и забыл!))
Сервис-центр не предлагать!!! :!:
Всем большое спасибо))
 Заголовок сообщения: Re: d-link вобще работает?
СообщениеДобавлено: Пт июл 31, 2009 14:02
Обратитесь в ближайший сервисный центр D-Link для тестирования.
СообщениеДобавлено: Сб авг 01, 2009 09:45
Модем 2600U.
Самопроизвольно (вне зависимости от меня и моих действий (компьютер скажем был вообще выключен)) пропадает интернет.
Моедм при этом показывает, что есть связь по DSL, работает WiFi и Ethernet.
Но, лампочка internet - светится постоянно и раз в секунду не на долго тухнет и снова загорается.
Перезагрузка модема помогает, но не на долго. Иногда такие пропажи случаются раз в два дня, а иногда (как сегодня) 4 раза за час! :(
Если в течении следующей недели решение проблемы не будет найдено, то это был мой первый и последний D-Link. Пойду и поменяю его на Зухель :(
Товарищи админы, выручайте свою компанию.
p.s. При этом сам модем не висит, а при попытке выйти на любой адрес в инете - получаю "ошибку DNS" и всё.
Прошивка самая свежая (20090731, 1.21). Только что залил и улучшений не заметил :(
СообщениеДобавлено: Сб авг 01, 2009 16:52
Залил новую прошивку, все как работало, так и работает нормально...
DjG
1. Логи
2. Настройки WAN
3. Проверить живы ли DNS-сервера
СообщениеДобавлено: Вс авг 02, 2009 19:35
а я вот на модеме пишу примари днс провайдера а второй какой нибудь из крупных типа 192.58.128.30.так можно делать?
СообщениеДобавлено: Вт авг 11, 2009 18:33
DjG
1. Логи
2. Настройки WAN
Проблема решена, покупкой ZyXEL. 2 суток - полёт нормальный. Прощай D-Link.
СообщениеДобавлено: Чт авг 27, 2009 22:29
Та же петрушка. Господа из тех.поддержки, надо что-то делать. Или всем переходить на Зухели?
СообщениеДобавлено: Вс авг 30, 2009 20:05
Переходи на зухель и забудешь о разрывах, у меня аптайм уже перевалил за 460 часов и не одного разрыва ;)
Делаем выводы господа админы.
СообщениеДобавлено: Вс авг 30, 2009 22:57
Пиар зухелей? Тут от этого никому ни холодно, ни жарко))). Поверьте.
СообщениеДобавлено: Вт сен 01, 2009 14:27
Мне всё равно как это выглядит, мне за пиар ни кто не платит, просто ебля с Длинками достала. Если вам нравится (то холодно, то жарко ;)), то удачи!
