Текущее время: Вт сен 22, 2026 22:01
Начать новую тему Эта тема закрыта, Вы не можете редактировать и оставлять сообщения в ней.  [ Сообщений: 42 ]  На страницу Пред.  1, 2, 3
СообщениеДобавлено: Ср янв 21, 2009 20:53
Jan 21 22:55:27 user warn dnsprobe[686]: dns query failed
Jan 21 23:05:30 user warn dnsprobe[686]: dns query failed
Jan 21 23:05:32 user warn dnsprobe[686]: dns query failed
Jan 21 23:15:35 user warn dnsprobe[686]: dns query failed
Jan 21 23:15:37 user warn dnsprobe[686]: dns query failed
Jan 21 23:33:46 syslog info -- MARK --
Jan 21 23:42:49 user crit kernel: ADSL link down
Jan 21 23:42:50 daemon notice pppd[383]: Terminating connection due to link down.
Jan 21 23:42:50 daemon info pppd[383]: Connect time 190.4 minutes.
Jan 21 23:42:50 daemon info pppd[383]: Sent 200801424 bytes, received 438391324 bytes.
Jan 21 23:42:50 daemon warn pppd[383]: Couldn't increase MRU to 1500
Jan 21 23:42:51 user crit kernel: ADSL G.994 training
Jan 21 23:42:56 daemon notice pppd[383]: Connection terminated....
Jan 21 23:42:58 user crit kernel: ADSL G.992 started
Jan 21 23:43:03 user crit kernel: ADSL G.992 channel analysis
Jan 21 23:43:09 user crit kernel: ADSL G.992 message exchange
Jan 21 23:43:09 user crit kernel: ADSL link up, interleaved, us=765, ds=1021
Jan 21 23:43:10 user debug syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107
Jan 21 23:43:10 daemon info pppd[383]: Sent PADT
Jan 21 23:43:10 daemon info pppd[383]: PPP session is 11895
Jan 21 23:43:10 daemon info pppd[383]: Using interface ppp0_0_40_2
Jan 21 23:43:10 daemon notice pppd[383]: Connect: ppp_0_0_40_2 <--> nas_0_0_40
Jan 21 23:43:10 daemon warn pppd[383]: Couldn't increase MRU to 1500
Jan 21 23:43:11 daemon notice pppd[383]: PAP authentication succeeded
Jan 21 23:43:11 daemon notice pppd[383]: peer from calling number 00:90:1A:A1:2B:24 authorized
Jan 21 23:43:11 daemon notice pppd[383]: local IP address 92.46.146.94
Jan 21 23:43:11 daemon notice pppd[383]: remote IP address 92.46.142.1
Jan 21 23:43:11 daemon notice pppd[383]: primary DNS address 82.200.130.231
Jan 21 23:43:11 daemon notice pppd[383]: secondary DNS address 82.200.130.232
Jan 21 23:43:15 user debug syslog: route add default gw 92.46.142.1 2>/dev/null
Jan 21 23:43:15 user debug syslog: iptables -A FORWARD -o ppp_0_0_40_2 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Jan 21 23:43:15 user debug syslog: iptables -A FORWARD -i ppp_0_0_40_2 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Jan 21 23:43:15 user debug syslog: echo > /proc/net/ip_conntrack
Jan 21 23:43:15 user debug syslog: echo "1000" > /proc/sys/net/ipv4/ip_conntrack_max
Jan 21 23:43:15 user debug syslog: iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107 2>/dev/null
Jan 21 23:43:15 user debug syslog: iptables -t nat -D POSTROUTING -o ppp_0_0_40_2 -s 192.168.1.0/255.255.255.0 -j MASQUERADE 2>/dev/null
Jan 21 23:43:15 user debug syslog: iptables -t nat -A POSTROUTING -o ppp_0_0_40_2 -s 192.168.1.0/255.255.255.0 -j MASQUERADE
Jan 21 23:43:15 user debug syslog: iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 82.200.130.231 2>/dev/null
Jan 21 23:43:15 user debug syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 82.200.130.231
Jan 21 23:43:15 user debug syslog: kill -9 3067
Jan 21 23:43:15 user debug syslog: echo > /var/hosts
Jan 21 23:47:45 user crit kernel: ADSL link down
Jan 21 23:47:46 user crit kernel: ADSL G.994 training
Jan 21 23:47:47 daemon notice pppd[383]: Terminating connection due to link down.
Jan 21 23:47:47 daemon info pppd[383]: Connect time 4.6 minutes.
Jan 21 23:47:47 daemon info pppd[383]: Sent 1227089 bytes, received 6107561 bytes.
Jan 21 23:47:47 daemon warn pppd[383]: Couldn't increase MRU to 1500
Jan 21 23:47:53 daemon notice pppd[383]: Connection terminated....
Jan 21 23:47:54 user crit kernel: ADSL G.992 started
Jan 21 23:47:58 user crit kernel: ADSL G.992 channel analysis
Jan 21 23:48:04 user crit kernel: ADSL G.992 message exchange
Jan 21 23:48:05 user crit kernel: ADSL link up, interleaved, us=765, ds=1021
Jan 21 23:48:06 user debug syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107
Jan 21 23:48:07 daemon info pppd[383]: Sent PADT
Jan 21 23:48:07 daemon info pppd[383]: PPP session is 3767
Jan 21 23:48:07 daemon info pppd[383]: Using interface ppp0_0_40_2
Jan 21 23:48:07 daemon notice pppd[383]: Connect: ppp_0_0_40_2 <--> nas_0_0_40
Jan 21 23:48:07 daemon warn pppd[383]: Couldn't increase MRU to 1500
Jan 21 23:48:08 daemon notice pppd[383]: PAP authentication succeeded
Jan 21 23:48:08 daemon notice pppd[383]: peer from calling number 00:90:1A:A1:2B:08 authorized
Jan 21 23:48:08 daemon notice pppd[383]: local IP address 92.46.156.173
Jan 21 23:48:08 daemon notice pppd[383]: remote IP address 92.46.142.1
Jan 21 23:48:08 daemon notice pppd[383]: primary DNS address 82.200.130.231
Jan 21 23:48:08 daemon notice pppd[383]: secondary DNS address 82.200.130.232
Jan 21 23:48:11 user debug syslog: route add default gw 92.46.142.1 2>/dev/null
Jan 21 23:48:11 user debug syslog: iptables -A FORWARD -o ppp_0_0_40_2 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Jan 21 23:48:11 user debug syslog: iptables -A FORWARD -i ppp_0_0_40_2 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Jan 21 23:48:11 user debug syslog: echo > /proc/net/ip_conntrack
Jan 21 23:48:11 user debug syslog: echo "1000" > /proc/sys/net/ipv4/ip_conntrack_max
Jan 21 23:48:11 user debug syslog: iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107 2>/dev/null
Jan 21 23:48:11 user debug syslog: iptables -t nat -D POSTROUTING -o ppp_0_0_40_2 -s 192.168.1.0/255.255.255.0 -j MASQUERADE 2>/dev/null
Jan 21 23:48:11 user debug syslog: iptables -t nat -A POSTROUTING -o ppp_0_0_40_2 -s 192.168.1.0/255.255.255.0 -j MASQUERADE
Jan 21 23:48:11 user debug syslog: iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 82.200.130.231 2>/dev/null
Jan 21 23:48:11 user debug syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 82.200.130.231
Jan 21 23:48:11 user debug syslog: kill -9 3662
Jan 21 23:48:11 user debug syslog: echo > /var/host
ЭТИ ЛОГИ ЧТОНЕБУДЬ ГОВОРЯТ????
СообщениеДобавлено: Чт янв 22, 2009 11:57
Судя по приведенному выше логу у Вас происходит обрыв ADSL соединения. Приведите скриншот страницы Device Info > Statistics > ADSL после успешной синхронизации.
Посмотрим на параметры Вашей линии.
С уважением, Давыдов Денис.
СообщениеДобавлено: Чт янв 22, 2009 12:31
СообщениеДобавлено: Чт янв 22, 2009 12:34
Слишком много ошибок в потоке.
Попросите провайдера немного понизить скорость Upstream/Downstream потоков и увеличить значение Interleave Delay в профиле Вашего порта на DSLAM.
Количество ошибок должно снизится, увеличится значение параметра SNR Margin для Upstream/Downstream потоков, что с большой вероятностью повлияет на стабильность ADSL соединения.
СообщениеДобавлено: Чт янв 22, 2009 13:22
Нде. АГа ща позвоню к провайдеру там как всегда подымит бабуся какаета. У нас тупые специалисты. У нас инет начинает тупить к ним звониш заявку даёшь. Неделю инет ровно работает потмо через неделю опять глюки. Опять звонишь. Вроде самый крупный в Казахстане провайдер а специалисты гомно. Даже званить пабаиваюсь ещё пашлют куда падальше. Ну я папытаюся какнебудь впихареть им это сообщение.
СообщениеДобавлено: Чт янв 22, 2009 13:26
Кстати ща второй день Агент не тупит. Вроде!
СообщениеДобавлено: Чт янв 22, 2009 13:36
Возможно из за того, что в эти дни линия меньше подвержена помехам. Если снова начнутся ADSL дисконнекты, единственный выход - звонить провайдеру и оптимизировать профиль на DSLAM.
СообщениеДобавлено: Чт янв 22, 2009 19:31
Вчера была переканект. Вчера ещё много тестил!!!
Объясните мне пару вещей. Мне кажется что провайдер тут непречём так как.
Вчера опять скинулся модем нечайно отключил блок питание. При подключение я увидел-->
Проблема в том что НЕ грузяться кантакты. Написанно что идёт ЗАГРУЗКА на самом деле я ОНЛАЙН. Меня народ видет что я в сети. А кантактов нету. И через 5 минут я вижу 2 табличку.
Если вы говарите что это и за провайдера то объясните мне пару вещей.
1) Тогда почему когда я перевожу модем в режими бридж,таких глюков в поныне я невижу.
2) Вчера взял Тплинк у друга,перевёл его в режим маршрутизатара (роутер) Тестил отключал переканективал что токо с ним нетварил Агент включался на Ураа!!!!
3) Я не 1 это предумал. Первые логи довал ещё 1 чел у него такая же проблемма!
4) Почему после перегрузки модема Агент снова работает отлично!
Полюбому что-то зависает или какаета пересесия остоёца в модеме.
ПОПРОБУЙТЕ У СЕБЯ ОТКЛЮЧИТЬ НЕ ТЕЛЕФОНЫЙ ШНУР. А ВЫДЕРНКТЬ ИЗ РЕЗЕТКИ РЕЗКО А ПОТОМ ВКЛЮЧТЬ!
СообщениеДобавлено: Пт янв 23, 2009 10:48
"Выдергивал" также из розетки. Все нормально работает.
Клиент подключается и выводит сообщение о полученной почте.
Что касается контактов: если это ICQ - возможны проблемы (они сейчас у всех).
Повторюсь - в нашем окружении mail агент работает нормально.
Проблема в Вашем случае именно в дисконнектах ADSL и большом количестве ошибок в канале. Просите провайдера оптимизировать профиль на порту DSLAM. Больше здесь ничего не сделать.
То, что с другим модемом у Вас все работает, может говорить о том что данный модем построен на другом чипсете и имеет большую совместимость с конкретной моделью DSLAM в плане работы физики ADSL.
СообщениеДобавлено: Пт янв 23, 2009 11:11
ICQ Работает отлично. Тогда почему после зброса модема Агент снова работает отлично?
СообщениеДобавлено: Пт янв 23, 2009 11:19
Дальнейшая дискуссия бессмысленна.
Привозите устройство в ближайший сервисный центр D-Link - Вам его протестируют.
То что в тестовом окружении агент работает - это факт.
В Вашей ситуации я вижу:
1. Общую нестабильность ADSL соединения.
2. Большое количество ошибок в канале.
Звоните провайдеру - пусть оптимизирует работу Вашего порта на DSLAM. Иного выхода нет.
СообщениеДобавлено: Пт янв 23, 2009 11:26
ТЕМА ЗАКРЫТА!!! П. НЕ Р. :(
