Текущее время: Чт сен 24, 2026 14:04
Начать новую тему Ответить на тему  [ Сообщений: 25 ]  На страницу Пред.  1, 2
СообщениеДобавлено: Чт мар 05, 2009 21:51
Ладно, вот расширенная информация
Device Info
Board ID: D-4P-W
Software Version: RU_DSL-2640U_3-06-04-3H00.A2pB023g2.d19b
Bootloader (CFE) Version: 1.0.37-6.5
Wireless Driver Version: 3.131.35.0.cpe2.3
This information reflects the current status of your DSL connection.
Line Rate - Upstream (Kbps): 640
Line Rate - Downstream (Kbps): 3072
LAN IP Address: 192.168.1.1
Default Gateway: 93.178.64.1
Primary DNS Server: 80.254.111.254
Secondary DNS Server: 195.161.172.254
Date/Time: Thu Mar 5 21:48:43 2009
VPI/VCI Category Service Name Interface Name Protocol State Status IP Address
0/35 UBR pppoa_0_35_1 ppp_0_35_1 PPPoA Enabled Up 93.178.80.231
0/37 UBR br_0_37 nas_0_37 MER Enabled Up 10.253.11.237
Mode: G.DMT
Type: Interleave
Line Coding: Trellis On
Status: No Defect
Link Power State: L0
Downstream Upstream
SNR Margin (dB): 30.7 19.0
Attenuation (dB): 35.0 20.0
Output Power (dBm): 12.3 18.4
Attainable Rate (Kbps): 7328 888
Rate (Kbps): 3072 640
K (number of bytes in DMT frame): 97 21
R (number of check bytes in RS code word): 2 4
S (RS code word size in DMT frame): 2 4
D (interleaver depth): 8 4
Delay (msec): 4 4
ну а лог выше
СообщениеДобавлено: Пт мар 06, 2009 19:03
вот ещё немного лога)
Mar 6 11:20:17 syslog info -- MARK --
Mar 6 11:29:42 user warn dnsprobe[557]: dns query failed
Mar 6 11:32:50 user warn dnsprobe[557]: dns query failed
Mar 6 11:34:25 user warn dnsprobe[557]: dns query failed
Mar 6 11:34:58 user warn dnsprobe[557]: dns query failed
Mar 6 11:44:49 daemon crit pppd[428]: Clear IP addresses. Connection DOWN.
Mar 6 11:44:49 daemon crit pppd[428]: Clear IP addresses. PPP connection DOWN.
Mar 6 11:44:55 daemon notice pppd[428]: PPP: Start to connect ...
Mar 6 11:44:57 daemon crit pppd[428]: PPP LCP UP.
Mar 6 11:44:57 user debug syslog: route add default gw 93.178.64.1 2>/dev/null
Mar 6 11:44:57 user debug syslog: route add -net 10.253.0.0 netmask 255.255.255.0 metric 1 gw 10.253.11.1 2>/dev/null
Mar 6 11:44:57 daemon crit pppd[428]: Received valid IP address from server. Connection UP.
Mar 6 11:44:57 user debug syslog: iptables -A FORWARD -o ppp_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Mar 6 11:44:57 user debug syslog: iptables -A FORWARD -i ppp_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Mar 6 11:44:57 user debug syslog: iptables -t nat -D POSTROUTING -o ppp_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE 2>/dev/null
Mar 6 11:44:57 user debug syslog: iptables -t nat -A POSTROUTING -o ppp_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE
Mar 6 12:02:24 user warn dnsprobe[557]: dns query failed
Mar 6 12:15:22 user warn dnsprobe[557]: dns query failed
Mar 6 12:20:16 syslog info -- MARK --
Mar 6 12:24:42 user warn dnsprobe[557]: dns query failed
Mar 6 12:44:22 user warn dnsprobe[557]: dns query failed
Mar 6 12:57:51 user warn dnsprobe[557]: dns query failed
Mar 6 13:07:41 user warn dnsprobe[557]: dns query failed
Mar 6 13:11:20 user warn dnsprobe[557]: dns query failed
Mar 6 13:12:25 user warn dnsprobe[557]: dns query failed
Mar 6 13:15:33 user warn dnsprobe[557]: dns query failed
Mar 6 13:20:17 syslog info -- MARK --
Mar 6 13:23:50 user warn dnsprobe[557]: dns query failed
Mar 6 13:25:26 user warn dnsprobe[557]: dns query failed
Mar 6 13:30:07 user warn dnsprobe[557]: dns query failed
Mar 6 13:34:17 user warn dnsprobe[557]: dns query failed
Mar 6 13:40:32 user warn dnsprobe[557]: dns query failed
Mar 6 13:40:34 user warn dnsprobe[557]: dns query failed
Mar 6 13:41:17 user debug syslog: kill 3850
Mar 6 13:41:17 user debug syslog: dhcpc -i nas_0_37 &
Mar 6 13:41:21 user debug syslog: route add -net 10.253.0.0 netmask 255.255.255.0 metric 1 gw 10.253.11.1 2>/dev/null
Mar 6 13:41:21 user debug syslog: iptables -t nat -D POSTROUTING -o nas_0_37 -s 192.168.1.0/255.255.255.0 -j MASQUERADE 2>/dev/null
Mar 6 13:41:21 user debug syslog: iptables -t nat -A POSTROUTING -o nas_0_37 -s 192.168.1.0/255.255.255.0 -j MASQUERADE
Mar 6 13:41:23 user debug syslog: iptables -D INPUT -i nas_0_37 -j DROP
Mar 6 13:41:23 user debug syslog: iptables -A INPUT -i nas_0_37 -j DROP
Mar 6 13:42:08 user warn dnsprobe[557]: dns query failed
Mar 6 13:49:25 user warn dnsprobe[557]: dns query failed
Mar 6 13:50:29 user warn dnsprobe[557]: dns query failed
Mar 6 13:58:46 user warn dnsprobe[557]: dns query failed
Mar 6 14:02:26 user warn dnsprobe[557]: dns query failed
Mar 6 14:02:28 user warn dnsprobe[557]: dns query failed
Mar 6 14:10:53 daemon crit pppd[428]: Clear IP addresses. Connection DOWN.
Mar 6 14:10:53 daemon crit pppd[428]: Clear IP addresses. PPP connection DOWN.
Mar 6 14:10:59 daemon notice pppd[428]: PPP: Start to connect ...
Mar 6 14:11:01 daemon crit pppd[428]: PPP LCP UP.
Mar 6 14:11:01 daemon crit pppd[428]: Received valid IP address from server. Connection UP.
Mar 6 14:11:01 user debug syslog: route add default gw 83.221.220.1 2>/dev/null
Mar 6 14:11:01 user debug syslog: route add -net 10.253.0.0 netmask 255.255.255.0 metric 1 gw 10.253.11.1 2>/dev/null
Mar 6 14:11:01 user debug syslog: iptables -A FORWARD -o ppp_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Mar 6 14:11:01 user debug syslog: iptables -A FORWARD -i ppp_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Mar 6 14:11:01 user debug syslog: iptables -t nat -D POSTROUTING -o ppp_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE 2>/dev/null
Mar 6 14:11:01 user debug syslog: iptables -t nat -A POSTROUTING -o ppp_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE
Mar 6 14:20:17 syslog info -- MARK --
Mar 6 14:35:35 user warn dnsprobe[557]: dns query failed
Mar 6 14:57:50 user warn dnsprobe[557]: dns query failed
Mar 6 14:59:25 user warn dnsprobe[557]: dns query failed
Mar 6 15:15:28 user warn dnsprobe[557]: dns query failed
Mar 6 15:15:30 user warn dnsprobe[557]: dns query failed
Mar 6 15:17:05 user warn dnsprobe[557]: dns query failed
Mar 6 15:20:16 syslog info -- MARK --
Mar 6 15:20:44 user warn dnsprobe[557]: dns query failed
Mar 6 15:25:56 user warn dnsprobe[557]: dns query failed
Mar 6 15:32:41 user warn dnsprobe[557]: dns query failed
Mar 6 15:47:11 user warn dnsprobe[557]: dns query failed
Mar 6 15:47:13 user warn dnsprobe[557]: dns query failed
Mar 6 15:47:46 user warn dnsprobe[557]: dns query failed
Mar 6 15:49:53 user warn dnsprobe[557]: dns query failed
Mar 6 15:56:07 user warn dnsprobe[557]: dns query failed
Mar 6 16:00:17 user warn dnsprobe[557]: dns query failed
Mar 6 16:00:19 user warn dnsprobe[557]: dns query failed
Mar 6 16:06:02 user warn dnsprobe[557]: dns query failed
Mar 6 16:06:04 user warn dnsprobe[557]: dns query failed
Mar 6 16:07:08 user warn dnsprobe[557]: dns query failed
Mar 6 16:07:18 user warn kernel: 83.254.184.1 sent an invalid ICMP type 3, code 13 error to a broadcast: 0.0.0.3 on ppp_0_35_1
Mar 6 16:11:18 user warn dnsprobe[557]: dns query failed
Mar 6 16:11:20 user warn dnsprobe[557]: dns query failed
Mar 6 16:20:09 user warn dnsprobe[557]: dns query failed
Mar 6 16:20:17 syslog info -- MARK --
Mar 6 16:22:14 daemon crit pppd[428]: Clear IP addresses. Connection DOWN.
Mar 6 16:22:14 daemon crit pppd[428]: Clear IP addresses. PPP connection DOWN.
Mar 6 16:22:15 user warn dnsprobe[557]: dns query failed
Mar 6 16:22:17 user warn dnsprobe[557]: dns query failed
Mar 6 16:22:19 user warn dnsprobe[557]: dns query failed
Mar 6 16:22:19 user notice dnsprobe[557]: Primary DNS server Is Down... Switching To Secondary DNS server
Mar 6 16:22:20 daemon notice pppd[428]: PPP: Start to connect ...
Mar 6 16:22:22 daemon crit pppd[428]: PPP LCP UP.
Mar 6 16:22:22 user debug syslog: route add default gw 87.117.48.1 2>/dev/null
Mar 6 16:22:22 daemon crit pppd[428]: Received valid IP address from server. Connection UP.
Mar 6 16:22:22 user debug syslog: route add -net 10.253.0.0 netmask 255.255.255.0 metric 1 gw 10.253.11.1 2>/dev/null
Mar 6 16:22:22 user debug syslog: iptables -A FORWARD -o ppp_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Mar 6 16:22:22 user debug syslog: iptables -A FORWARD -i ppp_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Mar 6 16:22:22 user debug syslog: iptables -t nat -D POSTROUTING -o ppp_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE 2>/dev/null
Mar 6 16:22:22 user debug syslog: iptables -t nat -A POSTROUTING -o ppp_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE
Mar 6 16:22:51 user notice dnsprobe[557]: Switching Back To Primary DNS server
Mar 6 17:01:25 user debug syslog: kill 4884
Mar 6 17:01:25 user debug syslog: dhcpc -i nas_0_37 &
Mar 6 17:01:32 user debug syslog: route add -net 10.253.0.0 netmask 255.255.255.0 metric 1 gw 10.253.11.1 2>/dev/null
Mar 6 17:01:32 user debug syslog: iptables -t nat -D POSTROUTING -o nas_0_37 -s 192.168.1.0/255.255.255.0 -j MASQUERADE 2>/dev/null
Mar 6 17:01:32 user debug syslog: iptables -t nat -A POSTROUTING -o nas_0_37 -s 192.168.1.0/255.255.255.0 -j MASQUERADE
Mar 6 17:01:33 user debug syslog: iptables -D INPUT -i nas_0_37 -j DROP
Mar 6 17:01:33 user debug syslog: iptables -A INPUT -i nas_0_37 -j DROP
Mar 6 17:20:16 syslog info -- MARK --
Mar 6 17:21:47 user warn dnsprobe[557]: dns query failed
Mar 6 17:35:46 user warn dnsprobe[557]: dns query failed
Mar 6 17:38:54 user warn dnsprobe[557]: dns query failed
Mar 6 17:38:56 user warn dnsprobe[557]: dns query failed
Mar 6 17:42:04 user warn dnsprobe[557]: dns query failed
Mar 6 17:47:47 user warn dnsprobe[557]: dns query failed
Mar 6 17:52:59 user warn dnsprobe[557]: dns query failed
Mar 6 17:58:43 user warn dnsprobe[557]: dns query failed
Mar 6 17:59:16 user warn dnsprobe[557]: dns query failed
Mar 6 18:06:32 user warn dnsprobe[557]: dns query failed
Mar 6 18:07:27 daemon crit pppd[428]: Clear IP addresses. Connection DOWN.
Mar 6 18:07:27 daemon crit pppd[428]: Clear IP addresses. PPP connection DOWN.
Mar 6 18:07:33 daemon notice pppd[428]: PPP: Start to connect ...
Mar 6 18:07:35 daemon crit pppd[428]: PPP LCP UP.
Mar 6 18:07:35 daemon crit pppd[428]: Received valid IP address from server. Connection UP.
Mar 6 18:07:35 user debug syslog: route add default gw 87.117.48.1 2>/dev/null
Mar 6 18:07:35 user debug syslog: route add -net 10.253.0.0 netmask 255.255.255.0 metric 1 gw 10.253.11.1 2>/dev/null
Mar 6 18:07:35 user debug syslog: iptables -A FORWARD -o ppp_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Mar 6 18:07:35 user debug syslog: iptables -A FORWARD -i ppp_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Mar 6 18:07:35 user debug syslog: iptables -t nat -D POSTROUTING -o ppp_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE 2>/dev/null
Mar 6 18:07:35 user debug syslog: iptables -t nat -A POSTROUTING -o ppp_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE
Mar 6 18:07:36 user warn dnsprobe[557]: dns query failed
Mar 6 18:07:38 user warn dnsprobe[557]: dns query failed
Mar 6 18:20:17 syslog info -- MARK --
Mar 6 18:42:48 user warn dnsprobe[557]: dns query failed
Mar 6 18:45:56 user warn dnsprobe[557]: dns query failed
Mar 6 18:49:05 user warn dnsprobe[557]: dns query failed
Mar 6 18:49:11 user warn kernel: 83.254.184.1 sent an invalid ICMP type 3, code 13 error to a broadcast: 0.0.0.3 on ppp_0_35_1
СообщениеДобавлено: Вс мар 08, 2009 02:29
Насчёт техподдержки не знаю, но у меня точно такая проблема была несколько недель назад:
Mar 5 20:11:23 user warn dnsprobe[563]: dns query failed
Mar 5 20:11:23 user notice dnsprobe[563]: Primary DNS server Is Down... Switching To Secondary DNS server
Mar 5 20:11:24 daemon crit pppd[434]: Received valid IP address from server. Connection UP.
Mar 5 20:11:54 user notice dnsprobe[563]: Switching Back To Primary DNS server
Mar 5 20:31:03 user warn dnsprobe[563]: dns query failed
В логах были подобные записи. При пинговании оба (ОБА!) DNS-сервера, раздаваемые мне провайдером, не отвечали. ya.ru и dlink.ru пинговались отлично.
Через два дня проблема исчезла сама собой.
DSL-2640U/BRU/C+Авангард
СообщениеДобавлено: Вс мар 08, 2009 21:51
днс сервера моего прова отлично пингуются.
СообщениеДобавлено: Чт мар 12, 2009 00:05
всё ещё актуально...
Acorp 422 - ЮТК, Asus N13U - Спарк, Asus N13U - Синтерра
СообщениеДобавлено: Пт мар 13, 2009 07:28
Каждые 30 мин разрыв. Помогает только ребут модема (on\off) Keep Alive - Включено
BoardID: DSL-2640U
Software Version: RU_1.00
Bootloader (CFE) Version: 1.0.37-12.1
Wireless Driver Version: 4.170.16.0.cpe2.1sd1
Тоже задумался о другой компании (((
СообщениеДобавлено: Ср мар 18, 2009 11:02
Та же проблема вот лог что это значит?
System Log
Date/Time Facility Severity Message
Jan 1 00:00:22 user crit kernel: eth0 Link UP.
Jan 1 00:00:22 user crit kernel: ADSL G.994 training
Jan 1 00:00:22 user crit kernel: ADSL G.992 started
Jan 1 00:00:23 user crit kernel: ADSL G.992 channel analysis
Jan 1 00:00:27 user crit kernel: ADSL G.992 message exchange
Jan 1 00:00:27 user crit kernel: ADSL link up, interleaved, us=768, ds=1024
Jan 1 00:00:29 daemon crit pppd[351]: PPP server detected.
Jan 1 00:00:29 daemon crit pppd[351]: PPP session established.
Jan 1 00:00:30 daemon crit pppd[351]: PPP LCP UP.
Jan 1 00:00:30 daemon crit pppd[351]: Received valid IP address from server. Connection UP.
Jan 1 00:00:33 user alert kernel: Intrusion -> IN=ppp_0_0_40_1 OUT= MAC= SRC=88.204.185.232 DST=92.46.143.82 LEN=48 TOS=0x00 PREC=0x00 TTL=120 ID=11637 DF PROTO=TCP SPT=3475 DPT=24961 WINDOW=65535 RES=0x00 SYN URGP=0
Jan 1 00:00:33 user alert kernel: Intrusion -> IN=ppp_0_0_40_1 OUT= MAC= SRC=92.46.241.233 DST=92.46.143.82 LEN=48 TOS=0x00 PREC=0x00 TTL=117 ID=20288 DF PROTO=TCP SPT=2369 DPT=16655 WINDOW=16384 RES=0x00 SYN URGP=0
Jan 1 00:00:33 user alert kernel: Intrusion -> IN=ppp_0_0_40_1 OUT= MAC= SRC=92.46.190.229 DST=92.46.143.82 LEN=48 TOS=0x00 PREC=0x00 TTL=119 ID=15711 DF PROTO=TCP SPT=62943 DPT=16655 WINDOW=8192 RES=0x00 SYN URGP=0
Jan 1 00:00:33 user alert kernel: Intrusion -> IN=ppp_0_0_40_1 OUT= MAC= SRC=92.46.99.222 DST=92.46.143.82 LEN=48 TOS=0x00 PREC=0x00 TTL=116 ID=19665 DF PROTO=TCP SPT=3581 DPT=24961 WINDOW=65535 RES=0x00 SYN URGP=0
Jan 1 00:00:35 daemon err user: No server certificate found. Skip checking on certificate.
Jan 1 00:00:36 user alert kernel: Intrusion -> IN=ppp_0_0_40_1 OUT= MAC= SRC=92.46.180.5 DST=92.46.143.82 LEN=48 TOS=0x00 PREC=0x00 TTL=118 ID=1716 DF PROTO=TCP SPT=3122 DPT=24961 WINDOW=65535 RES=0x00 SYN URGP=0
Jan 1 00:00:36 user alert kernel: Intrusion -> IN=ppp_0_0_40_1 OUT= MAC= SRC=89.218.233.125 DST=92.46.143.82 LEN=48 TOS=0x00 PREC=0x00 TTL=118 ID=4797 DF PROTO=TCP SPT=4010 DPT=24961 WINDOW=65535 RES=0x00 SYN URGP=0
Jan 1 00:00:36 user alert kernel: Intrusion -> IN=ppp_0_0_40_1 OUT= MAC= SRC=92.46.139.192 DST=92.46.143.82 LEN=48 TOS=0x00 PREC=0x00 TTL=126 ID=2645 DF PROTO=TCP SPT=1037 DPT=16655 WINDOW=65535 RES=0x00 SYN URGP=0
Jan 1 00:00:38 daemon err user: tr69c: Unable to retrieve attributes in scratch PAD
Jan 1 00:00:38 daemon err user: Stored Parameter Attribute data is corrupt or missing
Jan 1 00:00:38 user alert kernel: Intrusion -> IN=ppp_0_0_40_1 OUT= MAC= SRC=82.200.175.84 DST=92.46.143.82 LEN=48 TOS=0x04 PREC=0x00 TTL=120 ID=26851 DF PROTO=TCP SPT=1101 DPT=16655 WINDOW=65535 RES=0x00 SYN URGP=0
Jan 1 00:00:39 user alert kernel: Intrusion -> IN=ppp_0_0_40_1 OUT= MAC= SRC=92.46.241.233 DST=92.46.143.82 LEN=48 TOS=0x00 PREC=0x00 TTL=117 ID=21307 DF PROTO=TCP SPT=2369 DPT=16655 WINDOW=16384 RES=0x00 SYN URGP=0
Jan 1 00:06:00 daemon crit pppd[351]: Clear IP addresses. Connection DOWN.
Jan 1 00:06:00 daemon crit pppd[351]: Clear IP addresses. PPP connection DOWN.
Jan 1 00:07:06 daemon crit pppd[351]: PPP server detected.
Jan 1 00:07:09 daemon crit pppd[351]: PPP server detected.
Jan 1 00:07:13 daemon crit pppd[351]: PPP server detected.
Jan 1 00:07:17 daemon crit pppd[351]: PPP server detected.
Jan 1 00:07:21 daemon crit pppd[351]: PPP server detected.
Jan 1 00:07:25 daemon crit pppd[351]: PPP server detected.
Jan 1 00:07:28 daemon crit pppd[351]: PPP server detected.
Jan 1 00:07:32 daemon crit pppd[351]: PPP server detected.
Jan 1 00:07:36 daemon crit pppd[351]: PPP server detected.
Jan 1 00:07:40 daemon crit pppd[351]: PPP server detected.
Jan 1 00:07:43 daemon crit pppd[351]: PPP server detected.
Jan 1 00:07:47 daemon crit pppd[351]: PPP server detected.
Jan 1 00:07:51 daemon crit pppd[351]: PPP server detected.
Jan 1 00:07:55 daemon crit pppd[351]: PPP server detected.
Jan 1 00:07:55 daemon crit pppd[351]: PPP session established.
Jan 1 00:08:08 daemon crit pppd[351]: PPP server detected.
Jan 1 00:08:11 daemon crit pppd[351]: PPP server detected.
Jan 1 00:08:15 daemon crit pppd[351]: PPP server detected.
Jan 1 00:08:15 daemon crit pppd[351]: PPP session established.
Jan 1 00:08:28 daemon crit pppd[351]: PPP server detected.
Jan 1 00:08:28 daemon crit pppd[351]: PPP session established.
Jan 1 00:08:41 daemon crit pppd[351]: PPP server detected.
Jan 1 00:08:41 daemon crit pppd[351]: PPP session established.
Jan 1 00:08:54 daemon crit pppd[351]: PPP server detected.
Jan 1 00:08:54 daemon crit pppd[351]: PPP session established.
Jan 1 00:09:07 daemon crit pppd[351]: PPP server detected.
Jan 1 00:09:07 daemon crit pppd[351]: PPP session established.
Jan 1 00:09:19 daemon crit pppd[351]: PPP server detected.
Jan 1 00:09:19 daemon crit pppd[351]: PPP session established.
Jan 1 00:09:32 daemon crit pppd[351]: PPP server detected.
Jan 1 00:09:35 user crit kernel: OAM loopback response not received on PORT/VPI/VCI 0/0/40.
Jan 1 00:09:36 daemon crit pppd[351]: PPP server detected.
Jan 1 00:09:36 daemon crit pppd[351]: PPP session established.
Jan 1 00:09:49 daemon crit pppd[351]: PPP server detected.
Jan 1 00:09:49 daemon crit pppd[351]: PPP session established.
и так до бесконечности (detected established)
СообщениеДобавлено: Пт мар 20, 2009 22:54
Та же самая проблема в точности. Как следствие - приходится по нескольку раз заставлять браузер открывать сайт. Аппарат: 2640U
Board ID: D-4P-W
Mar 20 21:24:48 user notice dnsprobe[769]: Primary DNS server Is Down... Switching To Secondary DNS server
Mar 20 21:25:20 user warn dnsprobe[769]: dns query failed
Mar 20 21:25:22 user warn dnsprobe[769]: dns query failed
Mar 20 21:25:23 user notice dnsprobe[769]: Switching Back To Primary DNS server
Mar 20 21:25:55 user warn dnsprobe[769]: dns query failed
Mar 20 21:25:57 user warn dnsprobe[769]: dns query failed
Mar 20 21:25:59 user warn dnsprobe[769]: dns query failed
Mar 20 21:25:59 user notice dnsprobe[769]: Primary DNS server Is Down... Switching To Secondary DNS server
Mar 20 21:26:31 user warn dnsprobe[769]: dns query failed
Mar 20 21:26:33 user warn dnsprobe[769]: dns query failed
Mar 20 21:26:34 user notice dnsprobe[769]: Switching Back To Primary DNS server
Mar 20 21:28:39 user warn dnsprobe[769]: dns query failed
Mar 20 21:28:41 user warn dnsprobe[769]: dns query failed
Mar 20 21:29:45 user warn dnsprobe[769]: dns query failed
Mar 20 21:30:18 user warn dnsprobe[769]: dns query failed
Mar 20 21:30:51 user warn dnsprobe[769]: dns query failed
СообщениеДобавлено: Сб мар 21, 2009 12:11
Проблема есть, длинк закрывает глаза на это.
Повторю ещё раз, Acorp LAN422, работет нормально, PPPoA не рвёт, но страницы очень медленно открывает, это единственный недостаток.
Отсюда вывод, косячит 2640U.
СообщениеДобавлено: Вс мар 22, 2009 01:51
У меня второй модем 630zyxel USB тоже ничё не рвёт работает стабильно... АУ ТЕХПОДДЕРЖКА ВЫ ГДЕ???
