Текущее время: Вт сен 29, 2026 13:20
Начать новую тему Ответить на тему  [ Сообщений: 19 ]  На страницу Пред.  1, 2
СообщениеДобавлено: Вс июн 03, 2007 16:14
Davydov Denis писал(а):
В то время, как модем "виснет", WEB интерфейс доступен?
Приведите вывод лога.
WEB интерфейс доступен. "Виснет" не совсем правильно.. - просто не идет траффик.
1st day 00:00:08   user   info   kernel: device eth0 entered promiscuous mode
1st day 00:00:08   user   info   kernel: br0: port 1(eth0) entering learning state
1st day 00:00:08   user   info   kernel: br0: topology change detected, propagating
1st day 00:00:08   user   info   kernel: br0: port 1(eth0) entering forwarding state
1st day 00:00:08   user   crit   kernel: ADSL G.994 training
1st day 00:00:08   user   debug   syslog: bftpd
1st day 00:00:08   user   debug   syslog: tftpd
1st day 00:00:09   user   debug   syslog: pppd
1st day 00:00:10   user   debug   syslog: ifconfig nas_0_33 mtu 1370
1st day 00:00:10   daemon   notice   pppd[193]: pppd 2.4.1 started by admin, uid 0
1st day 00:00:18   user   crit   kernel: ADSL G.992 started
1st day 00:00:20   user   crit   kernel: ADSL G.992 channel analysis
1st day 00:00:25   user   crit   kernel: ADSL G.992 message exchange
1st day 00:00:26   user   crit   kernel: ADSL link up, interleaved, us=1024, ds=7776
1st day 00:00:26   user   warn   kernel: ATM Soft SAR: ATM link connected.
1st day 00:00:27   daemon   notice   pppd[193]: PPP: Start to connect ...
1st day 00:00:35   daemon   crit   pppd[193]: PPP server detected.
1st day 00:00:35   daemon   crit   pppd[193]: PPP session established.
1st day 00:00:37   daemon   crit   pppd[193]: PPP LCP UP.
1st day 00:00:37   user   debug   syslog: kill -9 146
1st day 00:00:37   daemon   crit   pppd[193]: Received valid IP address from server. Connection UP.
1st day 00:00:37   user   debug   syslog: dhcpd &> /dev/null &
1st day 00:00:38   user   debug   syslog: route add default gw 10.1.85.1 2>/dev/null
1st day 00:00:38   user   debug   syslog: insmod /lib/modules/2.6.8.1/kernel/net/ipv4/netfilter/ip_tables.ko
1st day 00:00:38   user   warn   kernel: ip_tables: (C) 2000-2002 Netfilter core team
1st day 00:00:38   user   debug   syslog: insmod /lib/modules/2.6.8.1/kernel/net/ipv4/netfilter/iptable_filter.ko
1st day 00:00:39   user   debug   syslog: insmod /lib/modules/2.6.8.1/kernel/net/ipv4/netfilter/ip_conntrack.ko
1st day 00:00:39   user   warn   kernel: ip_conntrack version 2.1 (61 buckets, 0 max) - 368 bytes per conntrack
1st day 00:00:39   user   debug   syslog: insmod /lib/modules/2.6.8.1/kernel/net/ipv4/netfilter/ipt_TCPMSS.ko
1st day 00:00:39   user   debug   syslog: ifconfig br0 0.0.0.0
1st day 00:00:39   user   debug   syslog: ifconfig br0 192.168.0.1 netmask 255.255.255.0 broadcast 192.168.0.255
1st day 00:00:39   user   debug   syslog: ifconfig ppp_0_33_1 0.0.0.0
1st day 00:00:39   user   debug   syslog: route add -net 10.1.85.1 netmask 255.255.255.255 dev ppp_0_33_1 metric 1 2>/dev/null
1st day 00:00:39   user   debug   syslog: route add default gw 10.1.85.1 2>/dev/null
1st day 00:00:39   user   debug   syslog: route add -host 10.1.85.197 dev br0 2>/dev/null
1st day 00:00:39   user   debug   syslog: iptables -F
1st day 00:00:40   user   debug   syslog: iptables -t nat -F
1st day 00:00:40   user   debug   syslog: iptables -A FORWARD -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --set-mss 1322
1st day 00:00:40   user   debug   syslog: iptables -t nat -A PREROUTING -i ppp_0_33_1 -p tcp --dport 8080 -j DNAT --to-destination 192.168.0.1:80
1st day 00:00:40   user   debug   syslog: iptables -t nat -A PREROUTING -i ppp_0_33_1 -p tcp --dport 2323 -j DNAT --to-destination 192.168.0.1:23
1st day 00:00:40   user   debug   syslog: echo > /proc/net/ip_conntrack
1st day 00:00:40   user   debug   syslog: echo "512" > /proc/sys/net/ipv4/ip_conntrack_max
1st day 00:00:40   user   debug   syslog: echo "1" > /proc/sys/net/ipv4/conf/br0/proxy_arp
1st day 00:06:01   user   crit   kernel: eth0 Link DOWN.
1st day 00:06:01   user   info   kernel: br0: port 1(eth0) entering disabled state
1st day 00:06:02   user   crit   kernel: eth0 Link UP.
1st day 00:06:02   user   info   kernel: br0: port 1(eth0) entering learning state
1st day 00:06:02   user   info   kernel: br0: topology change detected, propagating
1st day 00:06:02   user   info   kernel: br0: port 1(eth0) entering forwarding state
1st day 00:07:37   daemon   crit   pppd[193]: Clear IP addresses. Connection DOWN.
1st day 00:07:37   daemon   crit   pppd[193]: Clear IP addresses. PPP connection DOWN.
1st day 00:07:37   user   debug   syslog: kill -9 473
1st day 00:07:37   user   debug   syslog: dhcpd &> /dev/null &
1st day 00:07:46   daemon   notice   pppd[193]: PPP: Start to connect ...
1st day 00:07:49   daemon   notice   pppd[193]: PPP: Start to connect ...
1st day 00:07:52   daemon   notice   pppd[193]: PPP: Start to connect ...
1st day 00:07:55   daemon   notice   pppd[193]: PPP: Start to connect ...
1st day 00:07:58   daemon   notice   pppd[193]: PPP: Start to connect ...
1st day 00:08:01   daemon   notice   pppd[193]: PPP: Start to connect ...
1st day 00:08:04   daemon   notice   pppd[193]: PPP: Start to connect ...
1st day 00:08:07   daemon   notice   pppd[193]: PPP: Start to connect ...
1st day 00:08:10   daemon   notice   pppd[193]: PPP: Start to connect ...
1st day 00:08:13   daemon   notice   pppd[193]: PPP: Start to connect ...
1st day 00:08:16   daemon   notice   pppd[193]: PPP: Start to connect ...
1st day 00:08:19   daemon   notice   pppd[193]: PPP: Start to connect ...
1st day 00:08:22   daemon   notice   pppd[193]: PPP: Start to connect ...
1st day 00:08:22   daemon   crit   pppd[193]: PPP server detected.
1st day 00:08:25   daemon   notice   pppd[193]: PPP: Start to connect ...
1st day 00:08:25   daemon   crit   pppd[193]: PPP server detected.
1st day 00:08:28   daemon   notice   pppd[193]: PPP: Start to connect ...
1st day 00:08:28   daemon   crit   pppd[193]: PPP server detected.
1st day 00:08:31   daemon   notice   pppd[193]: PPP: Start to connect ...
1st day 00:08:32   daemon   crit   pppd[193]: PPP server detected.
1st day 00:08:32   daemon   crit   pppd[193]: PPP session established.
1st day 00:08:32   daemon   crit   pppd[193]: PPP LCP UP.
1st day 00:08:33   daemon   crit   pppd[193]: Received valid IP address from server. Connection UP.
1st day 00:08:33   user   debug   syslog: kill -9 653
1st day 00:08:33   user   debug   syslog: dhcpd &> /dev/null &
1st day 00:08:34   user   debug   syslog: route add default gw 10.1.85.1 2>/dev/null
1st day 00:08:34   user   debug   syslog: ifconfig br0 0.0.0.0
1st day 00:08:34   user   debug   syslog: ifconfig br0 192.168.0.1 netmask 255.255.255.0 broadcast 192.168.0.255
1st day 00:08:34   user   debug   syslog: ifconfig ppp_0_33_1 0.0.0.0
1st day 00:08:34   user   debug   syslog: route add -net 10.1.85.1 netmask 255.255.255.255 dev ppp_0_33_1 metric 1 2>/dev/null
1st day 00:08:34   user   debug   syslog: route add -host 10.1.85.197 dev br0 2>/dev/null
1st day 00:08:34   user   debug   syslog: iptables -F
1st day 00:08:34   user   debug   syslog: iptables -t nat -F
1st day 00:08:34   user   debug   syslog: iptables -A FORWARD -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --set-mss 1322
1st day 00:08:34   user   debug   syslog: iptables -t nat -A PREROUTING -i ppp_0_33_1 -p tcp --dport 8080 -j DNAT --to-destination 192.168.0.1:80
1st day 00:08:34   user   debug   syslog: iptables -t nat -A PREROUTING -i ppp_0_33_1 -p tcp --dport 2323 -j DNAT --to-destination 192.168.0.1:23
1st day 00:08:34   user   debug   syslog: echo > /proc/net/ip_conntrack
1st day 00:08:34   user   debug   syslog: echo "512" > /proc/sys/net/ipv4/ip_conntrack_max
1st day 00:08:34   user   debug   syslog: echo "1" > /proc/sys/net/ipv4/conf/br0/proxy_arp
СообщениеДобавлено: Пн июн 04, 2007 11:20
To Звер
По поводу лога Вашего устройства: в логе видно, что PPP соединение успешно устанавливается, после этого Ваш компьютер по DHCP протоколу должен получить те настройки IP, которые получил модем в результате PPPoE соединения. После этого доступ к WEB интерфейсу устройства будет невозможен по той причине, что компьютер и модем находятся в разных подсетях.
С уважением, Давыдов Денис.
СообщениеДобавлено: Чт июн 07, 2007 21:48
To Звер
Меня не интересует, что делает мой комп и модем, чем они там обмениваются. Меня интересует почему пропадает интернет (проблема именно в модеме) и что сделать чтобы устранить данную проблему.
Читаю форум - вижу что у многих данная модель (dsl-2300u) работает нестабильно. Скажите, что эта модель действительно работает нестабильно и вы не собираетесь в ближайшее время эту проблему устранять - я обменяю на модем другого производителя или просто сдам модем в магазин.
СообщениеДобавлено: Пт июн 08, 2007 09:57
To Звер
В данный момент мы работаем над выяснением обстоятельств данной проблемы. До конца не ясно, проблема в устройстве либо в настройках оборудования провайдера, так как в тестовом окружении модем работает стабильно.
После выяснения всех деталей я напишу об этом на форуме.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 48
