Текущее время: Сб окт 31, 2026 01:31
Начать новую тему Ответить на тему  [ Сообщений: 16 ]  На страницу Пред.  1, 2
СообщениеДобавлено: Пн июл 25, 2011 18:04
Модель: DSL_2500D
Версия прошивки: 1.0.47
Производитель: D-Link Russia
Тех. поддержка: support@dlink.ru
07/22/11 23:04:49 system Critical syslog "Clear IP addresses. Connection DOWN. "
07/22/11 23:04:49 system Critical syslog "Clear IP addresses. PPP connection DOWN. "
07/22/11 23:04:55 system Notice syslog "PPP: Start to connect ... "
07/22/11 23:04:56 system Critical syslog "PPP server detected. "
07/22/11 23:04:56 system Critical syslog "PPP session established. "
07/22/11 23:04:56 system Info syslog "Sending PADI"
07/22/11 23:04:56 system Info syslog "HOST_UNIQ successful match "
07/22/11 23:04:56 system Info syslog "Got connection: ae84"
07/22/11 23:04:57 system Critical syslog "PPP LCP UP. "
07/22/11 23:04:58 system Critical syslog "Received valid IP address from server. Connection UP. "
07/23/11 00:01:04 syslogd Info "-- MARK --"
07/23/11 23:01:02 syslogd Info "-- MARK --"
07/23/11 23:04:57 system Critical syslog "Clear IP addresses. Connection DOWN. "
07/23/11 23:04:57 system Critical syslog "Clear IP addresses. PPP connection DOWN. "
07/23/11 23:05:03 system Notice syslog "PPP: Start to connect ... "
07/23/11 23:05:04 system Critical syslog "PPP server detected. "
07/23/11 23:05:04 system Critical syslog "PPP session established. "
07/23/11 23:05:04 system Info syslog "Sending PADI"
07/23/11 23:05:04 system Info syslog "HOST_UNIQ successful match "
07/23/11 23:05:04 system Info syslog "Got connection: 77db"
07/23/11 23:05:05 system Critical syslog "PPP LCP UP. "
07/23/11 23:05:06 system Critical syslog "Received valid IP address from server. Connection UP. "
07/24/11 00:01:02 syslogd Info "-- MARK --"
07/24/11 23:01:09 syslogd Info "-- MARK --"
07/24/11 23:05:13 system Critical syslog "Clear IP addresses. Connection DOWN. "
07/24/11 23:05:13 system Critical syslog "Clear IP addresses. PPP connection DOWN. "
07/24/11 23:05:20 system Notice syslog "PPP: Start to connect ... "
07/24/11 23:05:21 system Critical syslog "PPP server detected. "
07/24/11 23:05:21 system Critical syslog "PPP session established. "
07/24/11 23:05:21 system Info syslog "Sending PADI"
07/24/11 23:05:21 system Info syslog "HOST_UNIQ successful match "
07/24/11 23:05:21 system Info syslog "Got connection: f6fb"
07/24/11 23:05:23 system Critical syslog "PPP LCP UP. "
07/24/11 23:05:23 system Critical syslog "Received valid IP address from server. Connection UP. "
07/25/11 00:01:09 syslogd Info "-- MARK --"
07/25/11 18:01:08 syslogd Info "-- MARK --"
Три дня модем не трогал. Сессия держится максимальные для Домолинк Ярославль 24 часа.
"Bridge PPPoE Frames Between WAN and Local Ports" реально помогает. В новой прошивке "Проброс PPPoE".
zau4man писал(а):
модему неделя. торрентов нет, ибо офис.
можно ссылку на тему... дабы не промахнуться... попробую...
Офис по PPPoE?
viewtopic.php?f=6&t=136938
Если не получится - viewtopic.php?p=754347#p754347
