Текущее время: Чт окт 15, 2026 08:36
Начать новую тему Ответить на тему  [ Сообщений: 19 ]  На страницу Пред.  1, 2
СообщениеДобавлено: Ср авг 04, 2010 21:11
Alert   08/05/10 02:21:31   Intrusion -   192.168.1.1      user-level   <9> kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=202.89.190.117 DST=90.188.63.8 LEN=60 TOS=0x08 PREC=0xC0 TTL=45 ID=32405 DF PROTO=TCP SPT=2082 DPT=23 WINDOW=5808 RES=0x00 SYN URGP=0
Alert   08/05/10 02:30:05   Intrusion -   192.168.1.1      user-level   <9> kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=219.147.134.22 DST=90.188.63.8 LEN=48 TOS=0x08 PREC=0xC0 TTL=106 ID=2299 PROTO=TCP SPT=63499 DPT=22 WINDOW=65535 RES=0x00 SYN URGP=0
Critical   08/05/10 02:31:29   ADSL link down   192.168.1.1      user-level   <10> kernel: ADSL link down
Warning   08/05/10 02:31:30   Saving OEM   192.168.1.1      user-level   <12> kernel: Saving OEM data from 0xA07EF96C
Warning   08/05/10 02:31:30   pSdramPHY=0xA07FFFF8,   192.168.1.1      user-level   <12> kernel: pSdramPHY=0xA07FFFF8, 0xF07BC 0xDEADBEEF
Warning   08/05/10 02:31:31   AdslCoreHwReset:   192.168.1.1      user-level   <12> kernel: AdslCoreHwReset:  AdslOemDataAddr = 0xA07EF96C
Critical   08/05/10 02:31:33   ADSL G.994   192.168.1.1      user-level   <10> kernel: ADSL G.994 training
Critical   08/05/10 02:31:35   Clear IP addresses.   192.168.1.1      system daemons   <26> pppd[244]: Clear IP addresses.  Connection DOWN.
Critical   08/05/10 02:31:35   Clear IP addresses.   192.168.1.1      system daemons   <26> pppd[244]: Clear IP addresses.  PPP connection DOWN.
Debug   08/05/10 02:31:56   iptables -t   192.168.1.1      user-level   <15> syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107
Notice   08/05/10 02:32:08   PPP: Start   192.168.1.1      system daemons   <29> pppd[244]: PPP: Start to connect ...
Critical   08/05/10 02:32:12   PPP session   192.168.1.1      system daemons   <26> pppd[244]: PPP session established.
Critical   08/05/10 02:32:12   PPP server   192.168.1.1      system daemons   <26> pppd[244]: PPP server detected.
Critical   08/05/10 02:32:13   PPP LCP UP.   192.168.1.1      system daemons   <26> pppd[244]: PPP LCP UP.
Critical   08/05/10 02:32:18   Received valid   192.168.1.1      system daemons   <26> pppd[244]: Received valid IP address from server.  Connection UP.
Debug   08/05/10 02:33:14   route add default   192.168.1.1      user-level   <15> syslog: route add default gw 213.228.116.195 2>/dev/null
Debug   08/05/10 02:33:16   iptables -A   192.168.1.1      user-level   <15> syslog: iptables -A FORWARD -o ppp_0_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Debug   08/05/10 02:33:17   iptables -A   192.168.1.1      user-level   <15> syslog: iptables -A FORWARD -i ppp_0_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Debug   08/05/10 02:33:18   echo  /proc/net/ip_conntrack   192.168.1.1      user-level   <15> syslog: echo > /proc/net/ip_conntrack
Debug   08/05/10 02:33:19   echo "1000"   192.168.1.1      user-level   <15> syslog: echo "1000" > /proc/sys/net/ipv4/ip_conntrack_max
Debug   08/05/10 02:33:20   iptables -t   192.168.1.1      user-level   <15> syslog: iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107 2>/dev/null
Debug   08/05/10 02:33:20   iptables -t   192.168.1.1      user-level   <15> syslog: iptables -t nat -A POSTROUTING -o ppp_0_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE
Debug   08/05/10 02:33:20   iptables -t   192.168.1.1      user-level   <15> syslog: iptables -t nat -D POSTROUTING -o ppp_0_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE 2>/dev/null
Debug   08/05/10 02:33:21   iptables -t   192.168.1.1      user-level   <15> syslog: iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 90.188.32.22 2>/dev/null
Debug   08/05/10 02:33:21   iptables -t   192.168.1.1      user-level   <15> syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 90.188.32.22
Debug   08/05/10 02:33:34   iptables -I   192.168.1.1      user-level   <15> syslog: iptables -I INPUT 1 -p icmp --icmp-type echo-request -i ppp_0_0_35_1 -j ACCEPT
Debug   08/05/10 02:33:41   iptables -I   192.168.1.1      user-level   <15> syslog: iptables -I INPUT 1 -j ACCEPT -i ppp_0_0_35_1 -p tcp --dport 30005
Debug   08/05/10 02:33:47   iptables -I   192.168.1.1      user-level   <15> syslog: iptables -I FORWARD 1 -j ACCEPT -i ppp_0_0_35_1 -p tcp --dport 30005
Debug   08/05/10 02:33:52   iptables -I   192.168.1.1      user-level   <15> syslog: iptables -I INPUT 1 -j ACCEPT -i ppp_0_0_35_1 -p udp -s 192.168.1.1/24 --dport 30006
Debug   08/05/10 02:33:56   iptables -I   192.168.1.1      user-level   <15> syslog: iptables -I FORWARD 1 -j ACCEPT -i ppp_0_0_35_1 -p udp -s 192.168.1.1/24 --dport 30006
Debug   08/05/10 02:34:10   ifconfig ppp_0_0_35_1   192.168.1.1      user-level   <15> syslog: ifconfig ppp_0_0_35_1 mtu 1492
Alert   08/05/10 02:36:59   Intrusion -   192.168.1.1      user-level   <9> kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=121.243.212.146 DST=90.188.63.8 LEN=40 TOS=0x08 PREC=0xC0 TTL=98 ID=256 PROTO=TCP SPT=6000 DPT=1433 WINDOW=16384 RES=0x00 SYN URGP=0
Informational   08/05/10 02:40:47   Exit.   192.168.1.1      system daemons   <30> pppd[244]: Exit.
Warning   08/05/10 02:44:40   dns query failed   192.168.1.1      user-level   <12> dnsprobe[504]: dns query failed
Warning   08/05/10 02:44:42   dns query failed   192.168.1.1      user-level   <12> dnsprobe[504]: dns query failed
Warning   08/05/10 02:44:44   dns query failed   192.168.1.1      user-level   <12> dnsprobe[504]: dns query failed
Notice   08/05/10 02:44:44   Primary DNS   192.168.1.1      user-level   <13> dnsprobe[504]: Primary DNS server Is Down... Switching To Secondary DNS server
Emergency   08/05/10 02:46:34   BusyBox v1.00   192.168.1.1      syslogd   <40> BCM96345  started: BusyBox v1.00 (2010.04.19-13:15+0000)
Informational   08/05/10 02:46:35   Freeing unused   192.168.1.1      user-level   <14> kernel: Freeing unused kernel memory: 68k freed
Warning   08/05/10 02:46:35   Linux version   192.168.1.1      user-level   <12> kernel: Linux version 2.6.8.1 (root@localhost.localdomain) (gcc version 3.4.2) #1 Mon Apr 19 21:14:46 CST 2010
Informational   08/05/10 02:46:35   br0: topology   192.168.1.1      user-level   <14> kernel: br0: topology change detected, propagating
Warning   08/05/10 02:46:35   AnnexCParam=0x7FFF7EB8   192.168.1.1      user-level   <12> kernel: AnnexCParam=0x7FFF7EB8 AnnexAParam=0x00003981 adsl2=0x00000000
Informational   08/05/10 02:46:35   br0: port 1(eth0)   192.168.1.1      user-level   <14> kernel: br0: port 1(eth0) entering forwarding state
Warning   08/05/10 02:46:35      192.168.1.1      user-level   <12> kernel:
Informational   08/05/10 02:46:35   NET: Registered   192.168.1.1      user-level   <14> kernel: NET: Registered protocol family 16
Informational   08/05/10 02:46:35   br0: port 1(eth0)   192.168.1.1      user-level   <14> kernel: br0: port 1(eth0) entering learning state
Warning   08/05/10 02:46:35   $ 8   : 00000001   192.168.1.1      user-level   <12> kernel: $ 8   : 00000001 00000002 801c72b4 00000001
Informational   08/05/10 02:46:35   Memory: 5800k/7808k   192.168.1.1      user-level   <14> kernel: Memory: 5800k/7808k available (1441k kernel code, 1988k reserved, 210k data, 68k init, 0k highmem)
Informational   08/05/10 02:46:35   PPP generic   192.168.1.1      user-level   <14> kernel: PPP generic driver version 2.4.2
Informational   08/05/10 02:46:35   Initializing   192.168.1.1      user-level   <14> kernel: Initializing IPsec netlink socket
Informational   08/05/10 02:46:35   TCP: Hash tables   192.168.1.1      user-level   <14> kernel: TCP: Hash tables configured (established 512 bind 1024)
Informational   08/05/10 02:46:35   IP: routing   192.168.1.1      user-level   <14> kernel: IP: routing cache hash table of 512 buckets, 4Kbytes
Warning   08/05/10 02:46:35   Process exe   192.168.1.1      user-level   <12> kernel: Process exe (pid: 105, threadinfo=80344000, task=80480520)
Informational   08/05/10 02:46:35   NET: Registered   192.168.1.1      user-level   <14> kernel: NET: Registered protocol family 2
Informational   08/05/10 02:46:35   NET: Registered   192.168.1.1      user-level   <14> kernel: NET: Registered protocol family 24
Informational   08/05/10 02:46:35   PPP Deflate   192.168.1.1      user-level   <14> kernel: PPP Deflate Compression module registered
Warning   08/05/10 02:46:35   AdslCoreHwReset:   192.168.1.1      user-level   <12> kernel: AdslCoreHwReset:  AdslOemDataAddr = 0xA07EF96C
Warning   08/05/10 02:46:35   eth0: MAC Address:   192.168.1.1      user-level   <12> kernel: eth0: MAC Address: 00:24:01:54:20:50
Warning   08/05/10 02:46:35   ip_conntrack   192.168.1.1      user-level   <12> kernel: ip_conntrack version 2.1 (61 buckets, 0 max) - 376 bytes per conntrack
Warning   08/05/10 02:46:35   Config Internal   192.168.1.1      user-level   <12> kernel: Config Internal PHY Through MDIO
Warning   08/05/10 02:46:35   brcmboard:   192.168.1.1      user-level   <12> kernel: brcmboard: brcm_board_init entry
Warning   08/05/10 02:46:35   bcm963xx_mtd   192.168.1.1      user-level   <12> kernel: bcm963xx_mtd driver v1.0
Warning   08/05/10 02:46:35   Using noop   192.168.1.1      user-level   <12> kernel: Using noop io scheduler
Warning   08/05/10 02:46:35   blaadd: blaa_detect   192.168.1.1      user-level   <12> kernel: blaadd: blaa_detect entry
Warning   08/05/10 02:46:35   506      0   192.168.1.1      user-level   <12> kernel:  506      0    6   24576 Config 1
Warning   08/05/10 02:46:35   504      0   192.168.1.1      user-level   <12> kernel:  504      0    2    8192 Scratch PAD
Warning   08/05/10 02:46:35   pSdramPHY=0xA07FFFF8,   192.168.1.1      user-level   <12> kernel: pSdramPHY=0xA07FFFF8, 0x85B797A 0xFFEDBEEF
Warning   08/05/10 02:46:35   498      0   192.168.1.1      user-level   <12> kernel:  498      0    6   24576 Config 2
Debug   08/05/10 02:46:35   Normal zone:   192.168.1.1      user-level   <15> kernel:   Normal zone: 0 pages, LIFO batch:1
Warning   08/05/10 02:46:35   VFS: Mounted   192.168.1.1      user-level   <12> kernel: VFS: Mounted root (squashfs filesystem) readonly.
Warning   08/05/10 02:46:35   Determined   192.168.1.1      user-level   <12> kernel: Determined physical RAM map:
Warning   08/05/10 02:46:35   Primary data   192.168.1.1      user-level   <12> kernel: Primary data cache 8kB 2-way, linesize 16 bytes.
Warning   08/05/10 02:46:35   BRCM NAT Cache:   192.168.1.1      user-level   <12> kernel: BRCM NAT Cache: Hooking hit function @ c0061088
Critical   08/05/10 02:46:35   eth0 Link UP.   192.168.1.1      user-level   <10> kernel: eth0 Link UP.
Critical   08/05/10 02:46:35   ADSL G.994   192.168.1.1      user-level   <10> kernel: ADSL G.994 training
Critical   08/05/10 02:46:35   ADSL G.992   192.168.1.1      user-level   <10> kernel: ADSL G.992 started
Warning   08/05/10 02:46:35   File system   192.168.1.1      user-level   <12> kernel: File system address: 0xbfc10100
Warning   08/05/10 02:46:35   ATM proc init   192.168.1.1      user-level   <12> kernel: ATM proc init !!!
Warning   08/05/10 02:46:35   Total Flash   192.168.1.1      user-level   <12> kernel: Total Flash size: 2048K with 512 sectors
Warning   08/05/10 02:46:35   Algorithmics/MIPS   192.168.1.1      user-level   <12> kernel: Algorithmics/MIPS FPU Emulator v1.5
Warning   08/05/10 02:46:35   Serial flash   192.168.1.1      user-level   <12> kernel: Serial flash device: name NXW25P16, id 0xef14, size 2048KB
Notice   08/05/10 02:46:35   klogd started:   192.168.1.1      user-level   <13> kernel: klogd started: BusyBox v1.00 (2010.04.19-13:15+0000)
Informational   08/05/10 02:46:35   Broadcom BCMPROCFS   192.168.1.1      user-level   <14> kernel: Broadcom BCMPROCFS v1.0 initialized
Informational   08/05/10 02:46:35   NET: Registered   192.168.1.1      user-level   <14> kernel: NET: Registered protocol family 20
Warning   08/05/10 02:46:35   96332CG_F4W   192.168.1.1      user-level   <12> kernel: 96332CG_F4W prom init
Notice   08/05/10 02:46:35   Ebtables v2.0   192.168.1.1      user-level   <13> kernel: Ebtables v2.0 registered
Warning   08/05/10 02:46:35   atmapi: module   192.168.1.1      user-level   <12> kernel: atmapi: module license 'Proprietary' taints kernel.
Warning   08/05/10 02:46:35   Primary instruction   192.168.1.1      user-level   <12> kernel: Primary instruction cache 16kB, physically tagged, 2-way, linesize 16 bytes.
Warning   08/05/10 02:46:35   brcm mips:   192.168.1.1      user-level   <12> kernel: brcm mips: enabling icache and dcache...
Warning   08/05/10 02:46:35   PID hash table   192.168.1.1      user-level   <12> kernel: PID hash table entries: 32 (order 5: 256 bytes)
Warning   08/05/10 02:46:35   KLOB Pool 1   192.168.1.1      user-level   <12> kernel: KLOB Pool 1 Initialized: 1048576 bytes <0x80600000 ... 0x80700000>
Warning   08/05/10 02:46:35   Built 1 zonelists   192.168.1.1      user-level   <12> kernel: Built 1 zonelists
Warning   08/05/10 02:46:35   Inode-cache   192.168.1.1      user-level   <12> kernel: Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Warning   08/05/10 02:46:35   0   1408     192.168.1.1      user-level   <12> kernel:    0   1408    1    1024 NVRAM
Warning   08/05/10 02:46:35   Kernel command   192.168.1.1      user-level   <12> kernel: Kernel command line: root=31:0 ro noinitrd console=ttyS0,115200
Warning   08/05/10 02:46:35   Broadcom BCM6338A2   192.168.1.1      user-level   <12> kernel: Broadcom BCM6338A2 Ethernet Network Device v0.3 Apr 19 2010 21:13:50
Warning   08/05/10 02:46:35   Cause : 00800024   192.168.1.1      user-level   <12> kernel: Cause : 00800024
Warning   08/05/10 02:46:35   Dentry cache   192.168.1.1      user-level   <12> kernel: Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
Warning   08/05/10 02:46:35   Blk# BlkOff   192.168.1.1      user-level   <12> kernel: Blk# BlkOff Blks  MemLen Partition Name
Warning   08/05/10 02:46:35   ttyS0 at MMIO   192.168.1.1      user-level   <12> kernel: ttyS0 at MMIO 0xfffe0300 (irq = 10) is a BCM63XX
Warning   08/05/10 02:46:35   Calibrating   192.168.1.1      user-level   <12> kernel: Calibrating delay loop... 239.20 BogoMIPS
Warning   08/05/10 02:46:35   Mount-cache   192.168.1.1      user-level   <12> kernel: Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Warning   08/05/10 02:46:35   Code: 8c820010   192.168.1.1      user-level   <12> kernel: Code: 8c820010  14400002  00000000 <0200000d> ac800010  c0820000  3c01ffef  3421ffff  00411024
Warning   08/05/10 02:46:35   Checking for   192.168.1.1      user-level   <12> kernel: Checking for 'wait' instruction...  unavailable.
Warning   08/05/10 02:46:35   ip_tables:   192.168.1.1      user-level   <12> kernel: ip_tables: (C) 2000-2002 Netfilter core team
Warning   08/05/10 02:46:35   801bb420 00000000   192.168.1.1      user-level   <12> kernel:         801bb420 00000000 7fff7ed0 004039bc 7fff7ec4 00000002 10000000 800620bc
Warning   08/05/10 02:46:35   Stack : 00000000   192.168.1.1      user-level   <12> kernel: Stack : 00000000 0000540d 00001f00 00000000 00342000 0000000a 00000000 2ab55000
Warning   08/05/10 02:46:35   memory: 007a0000   192.168.1.1      user-level   <12> kernel:  memory: 007a0000 @ 00000000 (usable)
Warning   08/05/10 02:46:35   $16   : 801e4ee0   192.168.1.1      user-level   <12> kernel: $16   : 801e4ee0 00000000 80743d50 00000000
Warning   08/05/10 02:46:35   epc   : 80063d7c   192.168.1.1      user-level   <12> kernel: >epc   : 80063d7c     Tainted: P
Warning   08/05/10 02:46:35   Lo    : 00000358   192.168.1.1      user-level   <12> kernel: Lo    : 00000358
Warning   08/05/10 02:46:35   Hi    : 000000ec   192.168.1.1      user-level   <12> kernel: Hi    : 000000ec
Informational   08/05/10 02:46:35   PPP BSD Compression   192.168.1.1      user-level   <14> kernel: PPP BSD Compression module registered
Warning   08/05/10 02:46:35   ip_conntrack_pptp   192.168.1.1      user-level   <12> kernel: ip_conntrack_pptp version 2.1 loaded
Warning   08/05/10 02:46:35   adsl: adsl_init   192.168.1.1      user-level   <12> kernel: adsl: adsl_init entry
Warning   08/05/10 02:46:35   Cpu 0   192.168.1.1      user-level   <12> kernel: Cpu 0
Warning   08/05/10 02:46:35   00001000 801bfd58   192.168.1.1      user-level   <12> kernel:         00001000 801bfd58 2ab55000 803472a8 803472a8 2ab55000 ffffffff 801bb400
Warning   08/05/10 02:46:35   Modules linked   192.168.1.1      user-level   <12> kernel: Modules linked in: ipt_MASQUERADE ipt_REDIRECT ipt_FTOS ip_conntrack_tftp ip_conntrack_ftp nat_cache ip_nat_ipsec ip_conntrack_ipsec ip_nat_pptp ip_conntrack_pptp ip_nat_gre ip_conntrack_gre iptable_mangle iptable_nat ip_conntrack iptable_filter ip_tables bcm_enet bcmprocfs br2684 blaa_dd adsldd atmapi
Warning   08/05/10 02:46:35   $20   : 2ab54000   192.168.1.1      user-level   <12> kernel: $20   : 2ab54000 00001000 0037779f 803319a8
Warning   08/05/10 02:46:35   $ 4   : 801e4ee0   192.168.1.1      user-level   <12> kernel: $ 4   : 801e4ee0 801bfd58 80743d54 80743000
Warning   08/05/10 02:46:35   ...   192.168.1.1      user-level   <12> kernel:         ...
Warning   08/05/10 02:46:35   80345eac 801bb400   192.168.1.1      user-level   <12> kernel:         80345eac 801bb400 00000000 00000000 ffffffff 80345ea8 00000000 1000fc01
Warning   08/05/10 02:46:35   BcmAdsl_Initialize=0xC00643E8,   192.168.1.1      user-level   <12> kernel: BcmAdsl_Initialize=0xC00643E8, g_pFnNotifyCallback=0xC007EFE4
Debug   08/05/10 02:46:35   klogd &   192.168.1.1      user-level   <15> syslog: klogd &
Warning   08/05/10 02:46:35   PrId  : 00029010   192.168.1.1      user-level   <12> kernel: PrId  : 00029010
Warning   08/05/10 02:46:35   00000023 801bfd58   192.168.1.1      user-level   <12> kernel:         00000023 801bfd58 801bb400 80480520 80033930 00000000 8069ad70 c009c8b4
Warning   08/05/10 02:46:35   Break instruction   192.168.1.1      user-level   <12> kernel: Break instruction in kernel code in arch/mips/kernel/traps.c::do_bp, line 567[#1]:
Warning   08/05/10 02:46:35   Using 120.000   192.168.1.1      user-level   <12> kernel: Using 120.000 MHz high precision timer.
Warning   08/05/10 02:46:35   $28   : 80344000   192.168.1.1      user-level   <12> kernel: $28   : 80344000 80345e28 2ab54000 8005db08
Debug   08/05/10 02:46:35   HighMem zone:   192.168.1.1      user-level   <15> kernel:   HighMem zone: 0 pages, LIFO batch:1
Warning   08/05/10 02:46:35   $12   : 00000180   192.168.1.1      user-level   <12> kernel: $12   : 00000180 0006cf04 00000001 2aaf1d84
Warning   08/05/10 02:46:35   Can't analyze   192.168.1.1      user-level   <12> kernel: Can't analyze prologue code at 80177094
Warning   08/05/10 02:46:35   BRCM NAT Caching   192.168.1.1      user-level   <12> kernel: BRCM NAT Caching v1.0 Nov 20 2007 10:22:27
Warning   08/05/10 02:46:35   ip_nat_pptp   192.168.1.1      user-level   <12> kernel: ip_nat_pptp version 2.0 loaded
Warning   08/05/10 02:46:35   $ 0   : 00000000   192.168.1.1      user-level   <12> kernel: $ 0   : 00000000 1000fc00 00000000 801e4ee0
Warning   08/05/10 02:46:35   Call Trace:   192.168.1.1      user-level   <12> kernel: Call Trace: [<801bb400>]  [<801bb420>]  [<800620bc>]  [<801bb400>]  [<801bb400>]  [<80033930>]  [<801bb400>]  [<801bb400>]  [<800377ac>]  [<80176a04>]  [<80038228>]  [<8001a4c8>]  [<80012748>]  [<8009af70>]
Debug   08/05/10 02:46:35   On node 0 totalpages:   192.168.1.1      user-level   <15> kernel: On node 0 totalpages: 1952
Debug   08/05/10 02:46:35   DMA zone: 1952   192.168.1.1      user-level   <15> kernel:   DMA zone: 1952 pages, LIFO batch:1
Debug   08/05/10 02:46:35   brctl addbr   192.168.1.1      user-level   <15> syslog: brctl addbr pppbr
Debug   08/05/10 02:46:35   pppd keepalive   192.168.1.1      user-level   <15> syslog: pppd keepalive 0 0 -c 0.0.35.1  -i nas_0_0_35 -u "aldarcass" -p ********* -f 0  -m 00901a41ff69/1ae9 &
Warning   08/05/10 02:46:35   ra    : 8005db08   192.168.1.1      user-level   <12> kernel: ra    : 8005db08 Status: 1000fc03    KERNEL EXL IE
Warning   08/05/10 02:46:35   dgasp: kerSysRegisterDyingGaspHa   192.168.1.1      user-level   <12> kernel: dgasp: kerSysRegisterDyingGaspHandler: dsl0 registered
Warning   08/05/10 02:46:35   CPU revision   192.168.1.1      user-level   <12> kernel: CPU revision is: 00029010
Warning   08/05/10 02:46:35   $24   : 2aaef414   192.168.1.1      user-level   <12> kernel: $24   : 2aaef414 2ab068f0
Informational   08/05/10 02:46:35   NET: Registered   192.168.1.1      user-level   <14> kernel: NET: Registered protocol family 15
Informational   08/05/10 02:46:35   Initializing   192.168.1.1      user-level   <14> kernel: Initializing Cryptographic API
Informational   08/05/10 02:46:35   NET: Registered   192.168.1.1      user-level   <14> kernel: NET: Registered protocol family 17
Informational   08/05/10 02:46:35   device eth0   192.168.1.1      user-level   <14> kernel: device eth0 entered promiscuous mode
Informational   08/05/10 02:46:35   NET: Registered   192.168.1.1      user-level   <14> kernel: NET: Registered protocol family 8
Informational   08/05/10 02:46:35   BCM63xx_ENET:   192.168.1.1      user-level   <14> kernel: BCM63xx_ENET: 100 MB Full-Duplex (auto-neg)
Informational   08/05/10 02:46:35   Serial: BCM63XX   192.168.1.1      user-level   <14> kernel: Serial: BCM63XX driver $Revision: 3.00 $
Notice   08/05/10 02:46:36   pppd 2.4.1   192.168.1.1      system daemons   <29> pppd[244]: pppd 2.4.1 started by admin, uid 0
Critical   08/05/10 02:46:38   ADSL G.992   192.168.1.1      user-level   <10> kernel: ADSL G.992 channel analysis
Critical   08/05/10 02:46:44   ADSL G.992   192.168.1.1      user-level   <10> kernel: ADSL G.992 message exchange
Warning   08/05/10 02:46:45   ATM Soft SAR:   192.168.1.1      user-level   <12> kernel: ATM Soft SAR: ATM link connected.
Critical   08/05/10 02:46:45   ADSL link up,   192.168.1.1      user-level   <10> kernel: ADSL link up, interleaved, us=636, ds=6143
Debug   08/05/10 02:46:46   iptables -t   192.168.1.1      user-level   <15> syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107
Notice   08/05/10 02:46:47   PPP: Start   192.168.1.1      system daemons   <29> pppd[244]: PPP: Start to connect ...
Critical   08/05/10 02:46:48   PPP session   192.168.1.1      system daemons   <26> pppd[244]: PPP session established.
Critical   08/05/10 02:46:48   PPP server   192.168.1.1      system daemons   <26> pppd[244]: PPP server detected.
Critical   08/05/10 02:46:49   PPP LCP UP.   192.168.1.1      system daemons   <26> pppd[244]: PPP LCP UP.
Debug   08/05/10 02:46:49   route add default   192.168.1.1      user-level   <15> syslog: route add default gw 213.228.116.195 2>/dev/null
Critical   08/05/10 02:46:49   Received valid   192.168.1.1      system daemons   <26> pppd[244]: Received valid IP address from server.  Connection UP.
Debug   08/05/10 02:46:50   iptables -t   192.168.1.1      user-level   <15> syslog: iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107 2>/dev/null
Debug   08/05/10 02:46:50   echo  /proc/net/ip_conntrack   192.168.1.1      user-level   <15> syslog: echo > /proc/net/ip_conntrack
Debug   08/05/10 02:46:50   iptables -t   192.168.1.1      user-level   <15> syslog: iptables -t nat -D POSTROUTING -o ppp_0_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE 2>/dev/null
Debug   08/05/10 02:46:50   iptables -A   192.168.1.1      user-level   <15> syslog: iptables -A FORWARD -o ppp_0_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Debug   08/05/10 02:46:50   echo "1000"   192.168.1.1      user-level   <15> syslog: echo "1000" > /proc/sys/net/ipv4/ip_conntrack_max
Debug   08/05/10 02:46:50   iptables -A   192.168.1.1      user-level   <15> syslog: iptables -A FORWARD -i ppp_0_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Debug   08/05/10 02:46:50   iptables -t   192.168.1.1      user-level   <15> syslog: iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 90.188.32.22 2>/dev/null
Debug   08/05/10 02:46:50   iptables -t   192.168.1.1      user-level   <15> syslog: iptables -t nat -A POSTROUTING -o ppp_0_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE
Debug   08/05/10 02:46:51   /bin/dnsprobe   192.168.1.1      user-level   <15> syslog: /bin/dnsprobe &
Notice   08/05/10 02:46:51   dnsprobe started!   192.168.1.1      user-level   <13> dnsprobe[499]: dnsprobe started!
Debug   08/05/10 02:46:51   iptables -t   192.168.1.1      user-level   <15> syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 90.188.32.22
Warning   08/05/10 02:46:53   dns query failed   192.168.1.1      user-level   <12> dnsprobe[499]: dns query failed
Debug   08/05/10 02:46:53   iptables -I   192.168.1.1      user-level   <15> syslog: iptables -I FORWARD 1 -j ACCEPT -i ppp_0_0_35_1 -p tcp --dport 30005
Debug   08/05/10 02:46:53   iptables -I   192.168.1.1      user-level   <15> syslog: iptables -I INPUT 1 -j ACCEPT -i ppp_0_0_35_1 -p tcp --dport 30005
Debug   08/05/10 02:46:53   iptables -I   192.168.1.1      user-level   <15> syslog: iptables -I INPUT 1 -p icmp --icmp-type echo-request -i ppp_0_0_35_1 -j ACCEPT
Debug   08/05/10 02:46:54   iptables -I   192.168.1.1      user-level   <15> syslog: iptables -I INPUT 1 -j ACCEPT -i ppp_0_0_35_1 -p udp -s 192.168.1.1/24 --dport 30006
Debug   08/05/10 02:46:54   iptables -I   192.168.1.1      user-level   <15> syslog: iptables -I FORWARD 1 -j ACCEPT -i ppp_0_0_35_1 -p udp -s 192.168.1.1/24 --dport 30006
Warning   08/05/10 02:46:55   dns query failed   192.168.1.1      user-level   <12> dnsprobe[499]: dns query failed
Warning   08/05/10 02:46:57   dns query failed   192.168.1.1      user-level   <12> dnsprobe[499]: dns query failed
Notice   08/05/10 02:46:57   Primary DNS   192.168.1.1      user-level   <13> dnsprobe[499]: Primary DNS server Is Down... Switching To Secondary DNS server
Debug   08/05/10 02:47:09   ifconfig ppp_0_0_35_1   192.168.1.1      user-level   <15> syslog: ifconfig ppp_0_0_35_1 mtu 1492
Error   08/05/10 02:48:24   tr69c: Unable   192.168.1.1      system daemons   <27> user: tr69c: Unable to retrieve attributes in scratch PAD
Error   08/05/10 02:48:24   Stored Parameter   192.168.1.1      system daemons   <27> user: Stored Parameter Attribute data is corrupt or missing
Critical   08/05/10 02:53:04   ADSL link down   192.168.1.1      user-level   <10> kernel: ADSL link down
Warning   08/05/10 02:53:06   Saving OEM   192.168.1.1      user-level   <12> kernel: Saving OEM data from 0xA07EF96C
Warning   08/05/10 02:53:06   pSdramPHY=0xA07FFFF8,   192.168.1.1      user-level   <12> kernel: pSdramPHY=0xA07FFFF8, 0x53746 0xDEADBEEF
Warning   08/05/10 02:53:07   AdslCoreHwReset:   192.168.1.1      user-level   <12> kernel: AdslCoreHwReset:  AdslOemDataAddr = 0xA07EF96C
Critical   08/05/10 02:53:14   Clear IP addresses.   192.168.1.1      system daemons   <26> pppd[244]: Clear IP addresses.  Connection DOWN.
Critical   08/05/10 02:53:14   Clear IP addresses.   192.168.1.1      system daemons   <26> pppd[244]: Clear IP addresses.  PPP connection DOWN.
Critical   08/05/10 02:53:17   ADSL G.992   192.168.1.1      user-level   <10> kernel: ADSL G.992 started
Critical   08/05/10 02:53:21   ADSL G.992   192.168.1.1      user-level   <10> kernel: ADSL G.992 channel analysis
Critical   08/05/10 02:53:27   ADSL G.992   192.168.1.1      user-level   <10> kernel: ADSL G.992 message exchange
Critical   08/05/10 02:53:28   ADSL link up,   192.168.1.1      user-level   <10> kernel: ADSL link up, interleaved, us=636, ds=6143
Debug   08/05/10 02:53:31   iptables -t   192.168.1.1      user-level   <15> syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107
Notice   08/05/10 02:53:41   PPP: Start   192.168.1.1      system daemons   <29> pppd[244]: PPP: Start to connect ...
Critical   08/05/10 02:53:46   PPP LCP UP.   192.168.1.1      system daemons   <26> pppd[244]: PPP LCP UP.
Critical   08/05/10 02:53:46   PPP server   192.168.1.1      system daemons   <26> pppd[244]: PPP server detected.
Critical   08/05/10 02:53:46   PPP session   192.168.1.1      system daemons   <26> pppd[244]: PPP session established.
Critical   08/05/10 02:53:48   Received valid   192.168.1.1      system daemons   <26> pppd[244]: Received valid IP address from server.  Connection UP.
Debug   08/05/10 02:54:25   route add default   192.168.1.1      user-level   <15> syslog: route add default gw 213.228.116.195 2>/dev/null
Critical   08/05/10 02:56:52   ADSL G.992   192.168.1.1      user-level   <10> kernel: ADSL G.992 started
Warning   08/05/10 02:56:52   Linux version   192.168.1.1      user-level   <12> kernel: Linux version 2.6.8.1 (root@localhost.localdomain) (gcc version 3.4.2) #1 Mon Apr 19 21:14:46 CST 2010
Warning   08/05/10 02:56:52   Dentry cache   192.168.1.1      user-level   <12> kernel: Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
Warning   08/05/10 02:56:52   BRCM NAT Cache:   192.168.1.1      user-level   <12> kernel: BRCM NAT Cache: Hooking hit function @ c0061088
Warning   08/05/10 02:56:52   BRCM NAT Caching   192.168.1.1      user-level   <12> kernel: BRCM NAT Caching v1.0 Nov 20 2007 10:22:27
Warning   08/05/10 02:56:52   ip_conntrack   192.168.1.1      user-level   <12> kernel: ip_conntrack version 2.1 (61 buckets, 0 max) - 376 bytes per conntrack
Warning   08/05/10 02:56:52   ip_tables:   192.168.1.1      user-level   <12> kernel: ip_tables: (C) 2000-2002 Netfilter core team
Warning   08/05/10 02:56:52   Primary data   192.168.1.1      user-level   <12> kernel: Primary data cache 8kB 2-way, linesize 16 bytes.
Warning   08/05/10 02:56:52   ATM proc init   192.168.1.1      user-level   <12> kernel: ATM proc init !!!
Warning   08/05/10 02:56:52   504      0   192.168.1.1      user-level   <12> kernel:  504      0    2    8192 Scratch PAD
Warning   08/05/10 02:56:52   Kernel command   192.168.1.1      user-level   <12> kernel: Kernel command line: root=31:0 ro noinitrd console=ttyS0,115200
Informational   08/05/10 02:56:52   NET: Registered   192.168.1.1      user-level   <14> kernel: NET: Registered protocol family 16
Informational   08/05/10 02:56:52   PPP BSD Compression   192.168.1.1      user-level   <14> kernel: PPP BSD Compression module registered
Informational   08/05/10 02:56:52   NET: Registered   192.168.1.1      user-level   <14> kernel: NET: Registered protocol family 2
Debug   08/05/10 02:56:52   klogd &   192.168.1.1      user-level   <15> syslog: klogd &
Debug   08/05/10 02:56:52   HighMem zone:   192.168.1.1      user-level   <15> kernel:   HighMem zone: 0 pages, LIFO batch:1
Debug   08/05/10 02:56:52   On node 0 totalpages:   192.168.1.1      user-level   <15> kernel: On node 0 totalpages: 1952
Informational   08/05/10 02:56:52   PPP generic   192.168.1.1      user-level   <14> kernel: PPP generic driver version 2.4.2
Informational   08/05/10 02:56:52   NET: Registered   192.168.1.1      user-level   <14> kernel: NET: Registered protocol family 8
Informational   08/05/10 02:56:52   Initializing   192.168.1.1      user-level   <14> kernel: Initializing Cryptographic API
Informational   08/05/10 02:56:52   br0: port 1(eth0)   192.168.1.1      user-level   <14> kernel: br0: port 1(eth0) entering learning state
Warning   08/05/10 02:56:52   Blk# BlkOff   192.168.1.1      user-level   <12> kernel: Blk# BlkOff Blks  MemLen Partition Name
Informational   08/05/10 02:56:52   Broadcom BCMPROCFS   192.168.1.1      user-level   <14> kernel: Broadcom BCMPROCFS v1.0 initialized
Informational   08/05/10 02:56:52   Memory: 5800k/7808k   192.168.1.1      user-level   <14> kernel: Memory: 5800k/7808k available (1441k kernel code, 1988k reserved, 210k data, 68k init, 0k highmem)
Informational   08/05/10 02:56:52   NET: Registered   192.168.1.1      user-level   <14> kernel: NET: Registered protocol family 15
Debug   08/05/10 02:56:52   DMA zone: 1952   192.168.1.1      user-level   <15> kernel:   DMA zone: 1952 pages, LIFO batch:1
Informational   08/05/10 02:56:52   NET: Registered   192.168.1.1      user-level   <14> kernel: NET: Registered protocol family 17
Informational   08/05/10 02:56:52   NET: Registered   192.168.1.1      user-level   <14> kernel: NET: Registered protocol family 20
Notice   08/05/10 02:56:52   Ebtables v2.0   192.168.1.1      user-level   <13> kernel: Ebtables v2.0 registered
Notice   08/05/10 02:56:52   klogd started:   192.168.1.1      user-level   <13> kernel: klogd started: BusyBox v1.00 (2010.04.19-13:15+0000)
Informational   08/05/10 02:56:52   device eth0   192.168.1.1      user-level   <14> kernel: device eth0 entered promiscuous mode
Informational   08/05/10 02:56:52   br0: topology   192.168.1.1      user-level   <14> kernel: br0: topology change detected, propagating
Informational   08/05/10 02:56:52   Freeing unused   192.168.1.1      user-level   <14> kernel: Freeing unused kernel memory: 68k freed
Informational   08/05/10 02:56:52   BCM63xx_ENET:   192.168.1.1      user-level   <14> kernel: BCM63xx_ENET: 100 MB Full-Duplex (auto-neg)
Informational   08/05/10 02:56:52   br0: port 1(eth0)   192.168.1.1      user-level   <14> kernel: br0: port 1(eth0) entering forwarding state
Informational   08/05/10 02:56:52   IP: routing   192.168.1.1      user-level   <14> kernel: IP: routing cache hash table of 512 buckets, 4Kbytes
Debug   08/05/10 02:56:52   brctl addbr   192.168.1.1      user-level   <15> syslog: brctl addbr pppbr
Informational   08/05/10 02:56:52   Initializing   192.168.1.1      user-level   <14> kernel: Initializing IPsec netlink socket
Informational   08/05/10 02:56:52   TCP: Hash tables   192.168.1.1      user-level   <14> kernel: TCP: Hash tables configured (established 512 bind 1024)
Informational   08/05/10 02:56:52   PPP Deflate   192.168.1.1      user-level   <14> kernel: PPP Deflate Compression module registered
Informational   08/05/10 02:56:52   Serial: BCM63XX   192.168.1.1      user-level   <14> kernel: Serial: BCM63XX driver $Revision: 3.00 $
Debug   08/05/10 02:56:52   Normal zone:   192.168.1.1      user-level   <15> kernel:   Normal zone: 0 pages, LIFO batch:1
Informational   08/05/10 02:56:52   NET: Registered   192.168.1.1      user-level   <14> kernel: NET: Registered protocol family 24
Warning   08/05/10 02:56:52   Checking for   192.168.1.1      user-level   <12> kernel: Checking for 'wait' instruction...  unavailable.
Warning   08/05/10 02:56:52   Mount-cache   192.168.1.1      user-level   <12> kernel: Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Warning   08/05/10 02:56:52   Can't analyze   192.168.1.1      user-level   <12> kernel: Can't analyze prologue code at 80177094
Warning   08/05/10 02:56:52   ip_conntrack_pptp   192.168.1.1      user-level   <12> kernel: ip_conntrack_pptp version 2.1 loaded
Warning   08/05/10 02:56:52   bcm963xx_mtd   192.168.1.1      user-level   <12> kernel: bcm963xx_mtd driver v1.0
Warning   08/05/10 02:56:52   KLOB Pool 1   192.168.1.1      user-level   <12> kernel: KLOB Pool 1 Initialized: 1048576 bytes <0x80600000 ... 0x80700000>
Warning   08/05/10 02:56:52   ip_nat_pptp   192.168.1.1      user-level   <12> kernel: ip_nat_pptp version 2.0 loaded
Warning   08/05/10 02:56:52   VFS: Mounted   192.168.1.1      user-level   <12> kernel: VFS: Mounted root (squashfs filesystem) readonly.
Warning   08/05/10 02:56:52   adsl: adsl_init   192.168.1.1      user-level   <12> kernel: adsl: adsl_init entry
Warning   08/05/10 02:56:52   atmapi: module   192.168.1.1      user-level   <12> kernel: atmapi: module license 'Proprietary' taints kernel.
Warning   08/05/10 02:56:52   Inode-cache   192.168.1.1      user-level   <12> kernel: Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Warning   08/05/10 02:56:52   File system   192.168.1.1      user-level   <12> kernel: File system address: 0xbfc10100
Warning   08/05/10 02:56:52   Calibrating   192.168.1.1      user-level   <12> kernel: Calibrating delay loop... 239.20 BogoMIPS
Warning   08/05/10 02:56:52   ttyS0 at MMIO   192.168.1.1      user-level   <12> kernel: ttyS0 at MMIO 0xfffe0300 (irq = 10) is a BCM63XX
Warning   08/05/10 02:56:52   AnnexCParam=0x7FFF7EB8   192.168.1.1      user-level   <12> kernel: AnnexCParam=0x7FFF7EB8 AnnexAParam=0x00003981 adsl2=0x00000000
Warning   08/05/10 02:56:52   96332CG_F4W   192.168.1.1      user-level   <12> kernel: 96332CG_F4W prom init
Warning   08/05/10 02:56:52   Determined   192.168.1.1      user-level   <12> kernel: Determined physical RAM map:
Warning   08/05/10 02:56:52   Config Internal   192.168.1.1      user-level   <12> kernel: Config Internal PHY Through MDIO
Warning   08/05/10 02:56:52   Broadcom BCM6338A2   192.168.1.1      user-level   <12> kernel: Broadcom BCM6338A2 Ethernet Network Device v0.3 Apr 19 2010 21:13:50
Warning   08/05/10 02:56:52   Built 1 zonelists   192.168.1.1      user-level   <12> kernel: Built 1 zonelists
Warning   08/05/10 02:56:52   memory: 007a0000   192.168.1.1      user-level   <12> kernel:  memory: 007a0000 @ 00000000 (usable)
Warning   08/05/10 02:56:52   Total Flash   192.168.1.1      user-level   <12> kernel: Total Flash size: 2048K with 512 sectors
Warning   08/05/10 02:56:52   Algorithmics/MIPS   192.168.1.1      user-level   <12> kernel: Algorithmics/MIPS FPU Emulator v1.5
Warning   08/05/10 02:56:52   Primary instruction   192.168.1.1      user-level   <12> kernel: Primary instruction cache 16kB, physically tagged, 2-way, linesize 16 bytes.
Warning   08/05/10 02:56:52   Using 120.000   192.168.1.1      user-level   <12> kernel: Using 120.000 MHz high precision timer.
Warning   08/05/10 02:56:52   pSdramPHY=0xA07FFFF8,   192.168.1.1      user-level   <12> kernel: pSdramPHY=0xA07FFFF8, 0x14031DD 0xFFEDFEEF
Warning   08/05/10 02:56:52   CPU revision   192.168.1.1      user-level   <12> kernel: CPU revision is: 00029010
Warning   08/05/10 02:56:52   Using noop   192.168.1.1      user-level   <12> kernel: Using noop io scheduler
Warning   08/05/10 02:56:52   PID hash table   192.168.1.1      user-level   <12> kernel: PID hash table entries: 32 (order 5: 256 bytes)
Warning   08/05/10 02:56:52   BcmAdsl_Initialize=0xC00643E8,   192.168.1.1      user-level   <12> kernel: BcmAdsl_Initialize=0xC00643E8, g_pFnNotifyCallback=0xC007EFE4
Emergency   08/05/10 02:56:52   BusyBox v1.00   192.168.1.1      syslogd   <40> BCM96345  started: BusyBox v1.00 (2010.04.19-13:15+0000)
Warning   08/05/10 02:56:52   eth0: MAC Address:   192.168.1.1      user-level   <12> kernel: eth0: MAC Address: 00:24:01:54:20:50
Warning   08/05/10 02:56:52   dgasp: kerSysRegisterDyingGaspHa   192.168.1.1      user-level   <12> kernel: dgasp: kerSysRegisterDyingGaspHandler: dsl0 registered
Warning   08/05/10 02:56:52   brcm mips:   192.168.1.1      user-level   <12> kernel: brcm mips: enabling icache and dcache...
Warning   08/05/10 02:56:52   brcmboard:   192.168.1.1      user-level   <12> kernel: brcmboard: brcm_board_init entry
Warning   08/05/10 02:56:52   506      0   192.168.1.1      user-level   <12> kernel:  506      0    6   24576 Config 1
Warning   08/05/10 02:56:52   0   1408     192.168.1.1      user-level   <12> kernel:    0   1408    1    1024 NVRAM
Warning   08/05/10 02:56:52   498      0   192.168.1.1      user-level   <12> kernel:  498      0    6   24576 Config 2
Warning   08/05/10 02:56:52   AdslCoreHwReset:   192.168.1.1      user-level   <12> kernel: AdslCoreHwReset:  AdslOemDataAddr = 0xA07EF96C
Critical   08/05/10 02:56:52   eth0 Link UP.   192.168.1.1      user-level   <10> kernel: eth0 Link UP.
Critical   08/05/10 02:56:52   ADSL G.994   192.168.1.1      user-level   <10> kernel: ADSL G.994 training
Warning   08/05/10 02:56:52   Serial flash   192.168.1.1      user-level   <12> kernel: Serial flash device: name NXW25P16, id 0xef14, size 2048KB
Warning   08/05/10 02:56:52   blaadd: blaa_detect   192.168.1.1      user-level   <12> kernel: blaadd: blaa_detect entry
Debug   08/05/10 02:56:53   pppd keepalive   192.168.1.1      user-level   <15> syslog: pppd keepalive 0 0 -c 0.0.35.1  -i nas_0_0_35 -u "aldarcass" -p ********* -f 0  -m 00901a41ff69/1c0b &
Notice   08/05/10 02:56:54   pppd 2.4.1   192.168.1.1      system daemons   <29> pppd[244]: pppd 2.4.1 started by admin, uid 0
Critical   08/05/10 02:56:55   ADSL G.992   192.168.1.1      user-level   <10> kernel: ADSL G.992 channel analysis
Critical   08/05/10 02:57:01   ADSL G.992   192.168.1.1      user-level   <10> kernel: ADSL G.992 message exchange
Warning   08/05/10 02:57:02   ATM Soft SAR:   192.168.1.1      user-level   <12> kernel: ATM Soft SAR: ATM link connected.
Critical   08/05/10 02:57:02   ADSL link up,   192.168.1.1      user-level   <10> kernel: ADSL link up, interleaved, us=636, ds=6143
Debug   08/05/10 02:57:03   iptables -t   192.168.1.1      user-level   <15> syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107
Notice   08/05/10 02:57:05   PPP: Start   192.168.1.1      system daemons   <29> pppd[244]: PPP: Start to connect ...
Critical   08/05/10 02:57:06   PPP server   192.168.1.1      system daemons   <26> pppd[244]: PPP server detected.
Critical   08/05/10 02:57:06   PPP session   192.168.1.1      system daemons   <26> pppd[244]: PPP session established.
Critical   08/05/10 02:57:06   PPP LCP UP.   192.168.1.1      system daemons   <26> pppd[244]: PPP LCP UP.
Debug   08/05/10 02:57:07   iptables -A   192.168.1.1      user-level   <15> syslog: iptables -A FORWARD -o ppp_0_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Debug   08/05/10 02:57:07   route add default   192.168.1.1      user-level   <15> syslog: route add default gw 213.228.116.195 2>/dev/null
Debug   08/05/10 02:57:07   iptables -A   192.168.1.1      user-level   <15> syslog: iptables -A FORWARD -i ppp_0_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Critical   08/05/10 02:57:07   Received valid   192.168.1.1      system daemons   <26> pppd[244]: Received valid IP address from server.  Connection UP.
Debug   08/05/10 02:57:08   echo  /proc/net/ip_conntrack   192.168.1.1      user-level   <15> syslog: echo > /proc/net/ip_conntrack
Debug   08/05/10 02:57:08   echo "1000"   192.168.1.1      user-level   <15> syslog: echo "1000" > /proc/sys/net/ipv4/ip_conntrack_max
Debug   08/05/10 02:57:08   iptables -t   192.168.1.1      user-level   <15> syslog: iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107 2>/dev/null
Debug   08/05/10 02:57:08   iptables -t   192.168.1.1      user-level   <15> syslog: iptables -t nat -D POSTROUTING -o ppp_0_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE 2>/dev/null
Debug   08/05/10 02:57:08   iptables -t   192.168.1.1      user-level   <15> syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 90.188.32.22
Debug   08/05/10 02:57:08   /bin/dnsprobe   192.168.1.1      user-level   <15> syslog: /bin/dnsprobe &
Debug   08/05/10 02:57:08   iptables -t   192.168.1.1      user-level   <15> syslog: iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 90.188.32.22 2>/dev/null
Debug   08/05/10 02:57:08   iptables -t   192.168.1.1      user-level   <15> syslog: iptables -t nat -A POSTROUTING -o ppp_0_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE
Debug   08/05/10 02:57:09   iptables -I   192.168.1.1      user-level   <15> syslog: iptables -I INPUT 1 -p icmp --icmp-type echo-request -i ppp_0_0_35_1 -j ACCEPT
Debug   08/05/10 02:57:09   iptables -I   192.168.1.1      user-level   <15> syslog: iptables -I FORWARD 1 -j ACCEPT -i ppp_0_0_35_1 -p tcp --dport 30005
Notice   08/05/10 02:57:09   dnsprobe started!   192.168.1.1      user-level   <13> dnsprobe[502]: dnsprobe started!
Debug   08/05/10 02:57:09   iptables -I   192.168.1.1      user-level   <15> syslog: iptables -I INPUT 1 -j ACCEPT -i ppp_0_0_35_1 -p tcp --dport 30005
Debug   08/05/10 02:57:10   iptables -I   192.168.1.1      user-level   <15> syslog: iptables -I INPUT 1 -j ACCEPT -i ppp_0_0_35_1 -p udp -s 192.168.1.1/24 --dport 30006
Debug   08/05/10 02:57:10   iptables -I   192.168.1.1      user-level   <15> syslog: iptables -I FORWARD 1 -j ACCEPT -i ppp_0_0_35_1 -p udp -s 192.168.1.1/24 --dport 30006
Warning   08/05/10 02:57:11   dns query failed   192.168.1.1      user-level   <12> dnsprobe[502]: dns query failed
Warning   08/05/10 02:57:13   dns query failed   192.168.1.1      user-level   <12> dnsprobe[502]: dns query failed
Debug   08/05/10 02:57:13   ifconfig ppp_0_0_35_1   192.168.1.1      user-level   <15> syslog: ifconfig ppp_0_0_35_1 mtu 1492
Notice   08/05/10 02:57:15   Primary DNS   192.168.1.1      user-level   <13> dnsprobe[502]: Primary DNS server Is Down... Switching To Secondary DNS server
Warning   08/05/10 02:57:15   dns query failed   192.168.1.1      user-level   <12> dnsprobe[502]: dns query failed
Error   08/05/10 02:57:51   Stored Parameter   192.168.1.1      system daemons   <27> user: Stored Parameter Attribute data is corrupt or missing
Error   08/05/10 02:57:51   tr69c: Unable   192.168.1.1      system daemons   <27> user: tr69c: Unable to retrieve attributes in scratch PAD
Alert   08/05/10 02:59:51   Intrusion -   192.168.1.1      user-level   <9> kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=93.124.80.203 DST=90.188.63.8 LEN=60 TOS=0x08 PREC=0xC0 TTL=53 ID=34128 DF PROTO=TCP SPT=2539 DPT=23 WINDOW=5808 RES=0x00 SYN URGP=0
Informational   08/05/10 03:00:34   PPP Deflate   192.168.1.1      user-level   <14> kernel: PPP Deflate Compression module registered
Informational   08/05/10 03:00:34   PPP generic   192.168.1.1      user-level   <14> kernel: PPP generic driver version 2.4.2
Informational   08/05/10 03:00:34   NET: Registered   192.168.1.1      user-level   <14> kernel: NET: Registered protocol family 2
Informational   08/05/10 03:00:34   IP: routing   192.168.1.1      user-level   <14> kernel: IP: routing cache hash table of 512 buckets, 4Kbytes
Warning   08/05/10 03:00:34   506      0   192.168.1.1      user-level   <12> kernel:  506      0    6   24576 Config 1
Warning   08/05/10 03:00:34   Determined   192.168.1.1      user-level   <12> kernel: Determined physical RAM map:
Informational   08/05/10 03:00:34   TCP: Hash tables   192.168.1.1      user-level   <14> kernel: TCP: Hash tables configured (established 512 bind 1024)
Warning   08/05/10 03:00:34   VFS: Mounted   192.168.1.1      user-level   <12> kernel: VFS: Mounted root (squashfs filesystem) readonly.
Informational   08/05/10 03:00:34   BCM63xx_ENET:   192.168.1.1      user-level   <14> kernel: BCM63xx_ENET: 100 MB Full-Duplex (auto-neg)
Warning   08/05/10 03:00:34   ip_conntrack   192.168.1.1      user-level   <12> kernel: ip_conntrack version 2.1 (61 buckets, 0 max) - 376 bytes per conntrack
Warning   08/05/10 03:00:34   ip_tables:   192.168.1.1      user-level   <12> kernel: ip_tables: (C) 2000-2002 Netfilter core team
Informational   08/05/10 03:00:34   Broadcom BCMPROCFS   192.168.1.1      user-level   <14> kernel: Broadcom BCMPROCFS v1.0 initialized
Informational   08/05/10 03:00:34   Initializing   192.168.1.1      user-level   <14> kernel: Initializing Cryptographic API
Warning   08/05/10 03:00:34   BRCM NAT Cache:   192.168.1.1      user-level   <12> kernel: BRCM NAT Cache: Hooking hit function @ c0061088
Warning   08/05/10 03:00:34   BRCM NAT Caching   192.168.1.1      user-level   <12> kernel: BRCM NAT Caching v1.0 Nov 20 2007 10:22:27
Informational   08/05/10 03:00:34   NET: Registered   192.168.1.1      user-level   <14> kernel: NET: Registered protocol family 20
Informational   08/05/10 03:00:34   NET: Registered   192.168.1.1      user-level   <14> kernel: NET: Registered protocol family 16
Warning   08/05/10 03:00:34   pSdramPHY=0xA07FFFF8,   192.168.1.1      user-level   <12> kernel: pSdramPHY=0xA07FFFF8, 0x319F2 0xDEADBEEF
Informational   08/05/10 03:00:34   NET: Registered   192.168.1.1      user-level   <14> kernel: NET: Registered protocol family 24
Warning   08/05/10 03:00:34   ATM proc init   192.168.1.1      user-level   <12> kernel: ATM proc init !!!
Informational   08/05/10 03:00:34   Memory: 5800k/7808k   192.168.1.1      user-level   <14> kernel: Memory: 5800k/7808k available (1441k kernel code, 1988k reserved, 210k data, 68k init, 0k highmem)
Warning   08/05/10 03:00:34   0   1408     192.168.1.1      user-level   <12> kernel:    0   1408    1    1024 NVRAM
Debug   08/05/10 03:00:34   HighMem zone:   192.168.1.1      user-level   <15> kernel:   HighMem zone: 0 pages, LIFO batch:1
Debug   08/05/10 03:00:34   Normal zone:   192.168.1.1      user-level   <15> kernel:   Normal zone: 0 pages, LIFO batch:1
Warning   08/05/10 03:00:34   Total Flash   192.168.1.1      user-level   <12> kernel: Total Flash size: 2048K with 512 sectors
Warning   08/05/10 03:00:34   Mount-cache   192.168.1.1      user-level   <12> kernel: Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Warning   08/05/10 03:00:34   Inode-cache   192.168.1.1      user-level   <12> kernel: Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Critical   08/05/10 03:00:34   ADSL G.994   192.168.1.1      user-level   <10> kernel: ADSL G.994 training
Warning   08/05/10 03:00:34   KLOB Pool 1   192.168.1.1      user-level   <12> kernel: KLOB Pool 1 Initialized: 1048576 bytes <0x80600000 ... 0x80700000>
Warning   08/05/10 03:00:34   File system   192.168.1.1      user-level   <12> kernel: File system address: 0xbfc10100
Debug   08/05/10 03:00:34   brctl addbr   192.168.1.1      user-level   <15> syslog: brctl addbr pppbr
Error   08/05/10 03:00:34   SQUASHFS error:   192.168.1.1      user-level   <11> kernel: SQUASHFS error: Unable to read page, block 37954, size 4ed1
Warning   08/05/10 03:00:34   Primary instruction   192.168.1.1      user-level   <12> kernel: Primary instruction cache 16kB, physically tagged, 2-way, linesize 16 bytes.
Warning   08/05/10 03:00:34   Blk# BlkOff   192.168.1.1      user-level   <12> kernel: Blk# BlkOff Blks  MemLen Partition Name
Critical   08/05/10 03:00:34   ADSL G.992   192.168.1.1      user-level   <10> kernel: ADSL G.992 started
Notice   08/05/10 03:00:34   klogd started:   192.168.1.1      user-level   <13> kernel: klogd started: BusyBox v1.00 (2010.04.19-13:15+0000)
Notice   08/05/10 03:00:34   Ebtables v2.0   192.168.1.1      user-level   <13> kernel: Ebtables v2.0 registered
Informational   08/05/10 03:00:34   Initializing   192.168.1.1      user-level   <14> kernel: Initializing IPsec netlink socket
Emergency   08/05/10 03:00:34   BusyBox v1.00   192.168.1.1      syslogd   <40> BCM96345  started: BusyBox v1.00 (2010.04.19-13:15+0000)
Debug   08/05/10 03:00:34   klogd &   192.168.1.1      user-level   <15> syslog: klogd &
Debug   08/05/10 03:00:34   On node 0 totalpages:   192.168.1.1      user-level   <15> kernel: On node 0 totalpages: 1952
Debug   08/05/10 03:00:34   DMA zone: 1952   192.168.1.1      user-level   <15> kernel:   DMA zone: 1952 pages, LIFO batch:1
Warning   08/05/10 03:00:34   CodeReal: invalid   192.168.1.1      user-level   <12> kernel: CodeReal: invalid data
Warning   08/05/10 03:00:34   AnnexCParam=0x7FFF7EB8   192.168.1.1      user-level   <12> kernel: AnnexCParam=0x7FFF7EB8 AnnexAParam=0x00003981 adsl2=0x00000000
Warning   08/05/10 03:00:34   eth0: MAC Address:   192.168.1.1      user-level   <12> kernel: eth0: MAC Address: 00:24:01:54:20:50
Error   08/05/10 03:00:34   SQUASHFS error:   192.168.1.1      user-level   <11> kernel: SQUASHFS error: lzma_fs error while decompressing!
Warning   08/05/10 03:00:34   CPU revision   192.168.1.1      user-level   <12> kernel: CPU revision is: 00029010
Warning   08/05/10 03:00:34   Checking for   192.168.1.1      user-level   <12> kernel: Checking for 'wait' instruction...  unavailable.
Warning   08/05/10 03:00:34   Linux version   192.168.1.1      user-level   <12> kernel: Linux version 2.6.8.1 (root@localhost.localdomain) (gcc version 3.4.2) #1 Mon Apr 19 21:14:46 CST 2010
Warning   08/05/10 03:00:34   Serial flash   192.168.1.1      user-level   <12> kernel: Serial flash device: name NXW25P16, id 0xef14, size 2048KB
Warning   08/05/10 03:00:34   ip_nat_pptp   192.168.1.1      user-level   <12> kernel: ip_nat_pptp version 2.0 loaded
Warning   08/05/10 03:00:34   PID hash table   192.168.1.1      user-level   <12> kernel: PID hash table entries: 32 (order 5: 256 bytes)
Warning   08/05/10 03:00:34   memory: 007a0000   192.168.1.1      user-level   <12> kernel:  memory: 007a0000 @ 00000000 (usable)
Warning   08/05/10 03:00:34   ttyS0 at MMIO   192.168.1.1      user-level   <12> kernel: ttyS0 at MMIO 0xfffe0300 (irq = 10) is a BCM63XX
Warning   08/05/10 03:00:34   Kernel command   192.168.1.1      user-level   <12> kernel: Kernel command line: root=31:0 ro noinitrd console=ttyS0,115200
Warning   08/05/10 03:00:34   96332CG_F4W   192.168.1.1      user-level   <12> kernel: 96332CG_F4W prom init
Warning   08/05/10 03:00:34   Algorithmics/MIPS   192.168.1.1      user-level   <12> kernel: Algorithmics/MIPS FPU Emulator v1.5
Warning   08/05/10 03:00:34   blaadd: blaa_detect   192.168.1.1      user-level   <12> kernel: blaadd: blaa_detect entry
Warning   08/05/10 03:00:34   Using noop   192.168.1.1      user-level   <12> kernel: Using noop io scheduler
Warning   08/05/10 03:00:34   Config Internal   192.168.1.1      user-level   <12> kernel: Config Internal PHY Through MDIO
Informational   08/05/10 03:00:34   NET: Registered   192.168.1.1      user-level   <14> kernel: NET: Registered protocol family 8
Informational   08/05/10 03:00:34   NET: Registered   192.168.1.1      user-level   <14> kernel: NET: Registered protocol family 15
Informational   08/05/10 03:00:34   br0: port 1(eth0)   192.168.1.1      user-level   <14> kernel: br0: port 1(eth0) entering forwarding state
Informational   08/05/10 03:00:34   PPP BSD Compression   192.168.1.1      user-level   <14> kernel: PPP BSD Compression module registered
Warning   08/05/10 03:00:34   brcm mips:   192.168.1.1      user-level   <12> kernel: brcm mips: enabling icache and dcache...
Warning   08/05/10 03:00:34   ip_conntrack_pptp   192.168.1.1      user-level   <12> kernel: ip_conntrack_pptp version 2.1 loaded
Warning   08/05/10 03:00:34   Primary data   192.168.1.1      user-level   <12> kernel: Primary data cache 8kB 2-way, linesize 16 bytes.
Warning   08/05/10 03:00:34   AdslCoreHwReset:   192.168.1.1      user-level   <12> kernel: AdslCoreHwReset:  AdslOemDataAddr = 0xA07EF96C
Warning   08/05/10 03:00:34   adsl: adsl_init   192.168.1.1      user-level   <12> kernel: adsl: adsl_init entry
Critical   08/05/10 03:00:34   eth0 Link UP.   192.168.1.1      user-level   <10> kernel: eth0 Link UP.
Warning   08/05/10 03:00:34   brcmboard:   192.168.1.1      user-level   <12> kernel: brcmboard: brcm_board_init entry
Warning   08/05/10 03:00:34   BcmAdsl_Initialize=0xC00643E8,   192.168.1.1      user-level   <12> kernel: BcmAdsl_Initialize=0xC00643E8, g_pFnNotifyCallback=0xC007EFE4
Warning   08/05/10 03:00:34   Calibrating   192.168.1.1      user-level   <12> kernel: Calibrating delay loop... 239.20 BogoMIPS
Warning   08/05/10 03:00:34   Broadcom BCM6338A2   192.168.1.1      user-level   <12> kernel: Broadcom BCM6338A2 Ethernet Network Device v0.3 Apr 19 2010 21:13:50
Warning   08/05/10 03:00:34   atmapi: module   192.168.1.1      user-level   <12> kernel: atmapi: module license 'Proprietary' taints kernel.
Warning   08/05/10 03:00:34   Using 120.000   192.168.1.1      user-level   <12> kernel: Using 120.000 MHz high precision timer.
Warning   08/05/10 03:00:34   dgasp: kerSysRegisterDyingGaspHa   192.168.1.1      user-level   <12> kernel: dgasp: kerSysRegisterDyingGaspHandler: dsl0 registered
Informational   08/05/10 03:00:34   Freeing unused   192.168.1.1      user-level   <14> kernel: Freeing unused kernel memory: 68k freed
Informational   08/05/10 03:00:34   NET: Registered   192.168.1.1      user-level   <14> kernel: NET: Registered protocol family 17
Informational   08/05/10 03:00:34   br0: topology   192.168.1.1      user-level   <14> kernel: br0: topology change detected, propagating
Informational   08/05/10 03:00:34   br0: port 1(eth0)   192.168.1.1      user-level   <14> kernel: br0: port 1(eth0) entering learning state
Informational   08/05/10 03:00:34   device eth0   192.168.1.1      user-level   <14> kernel: device eth0 entered promiscuous mode
Warning   08/05/10 03:00:34   Dentry cache   192.168.1.1      user-level   <12> kernel: Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
Warning   08/05/10 03:00:34   498      0   192.168.1.1      user-level   <12> kernel:  498      0    6   24576 Config 2
Warning   08/05/10 03:00:34   504      0   192.168.1.1      user-level   <12> kernel:  504      0    2    8192 Scratch PAD
Warning   08/05/10 03:00:34   Can't analyze   192.168.1.1      user-level   <12> kernel: Can't analyze prologue code at 80177094
Informational   08/05/10 03:00:34   Serial: BCM63XX   192.168.1.1      user-level   <14> kernel: Serial: BCM63XX driver $Revision: 3.00 $
Warning   08/05/10 03:00:34   Built 1 zonelists   192.168.1.1      user-level   <12> kernel: Built 1 zonelists
Warning   08/05/10 03:00:34   bcm963xx_mtd   192.168.1.1      user-level   <12> kernel: bcm963xx_mtd driver v1.0
Debug   08/05/10 03:00:35   pppd keepalive   192.168.1.1      user-level   <15> syslog: pppd keepalive 0 0 -c 0.0.35.1  -i nas_0_0_35 -u "aldarcass" -p ********* -f 0  -m 00901a41ff69/1ca9 &
Notice   08/05/10 03:00:36   pppd 2.4.1   192.168.1.1      system daemons   <29> pppd[244]: pppd 2.4.1 started by admin, uid 0
Critical   08/05/10 03:00:37   ADSL G.992   192.168.1.1      user-level   <10> kernel: ADSL G.992 channel analysis
Critical   08/05/10 03:00:43   ADSL G.992   192.168.1.1      user-level   <10> kernel: ADSL G.992 message exchange
Critical   08/05/10 03:00:43   ADSL link up,   192.168.1.1      user-level   <10> kernel: ADSL link up, interleaved, us=636, ds=6143
Warning   08/05/10 03:00:43   ATM Soft SAR:   192.168.1.1      user-level   <12> kernel: ATM Soft SAR: ATM link connected.
Debug   08/05/10 03:00:44   iptables -t   192.168.1.1      user-level   <15> syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107
Notice   08/05/10 03:00:46   PPP: Start   192.168.1.1      system daemons   <29> pppd[244]: PPP: Start to connect ...
Critical   08/05/10 03:00:47   PPP session   192.168.1.1      system daemons   <26> pppd[244]: PPP session established.
Critical   08/05/10 03:00:47   PPP LCP UP.   192.168.1.1      system daemons   <26> pppd[244]: PPP LCP UP.
Critical   08/05/10 03:00:47   PPP server   192.168.1.1      system daemons   <26> pppd[244]: PPP server detected.
Critical   08/05/10 03:00:48   Received valid   192.168.1.1      system daemons   <26> pppd[244]: Received valid IP address from server.  Connection UP.
Debug   08/05/10 03:00:49   iptables -A   192.168.1.1      user-level   <15> syslog: iptables -A FORWARD -i ppp_0_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Debug   08/05/10 03:00:49   echo  /proc/net/ip_conntrack   192.168.1.1      user-level   <15> syslog: echo > /proc/net/ip_conntrack
Debug   08/05/10 03:00:49   echo "1000"   192.168.1.1      user-level   <15> syslog: echo "1000" > /proc/sys/net/ipv4/ip_conntrack_max
Debug   08/05/10 03:00:49   route add default   192.168.1.1      user-level   <15> syslog: route add default gw 213.228.116.195 2>/dev/null
Debug   08/05/10 03:00:49   iptables -A   192.168.1.1      user-level   <15> syslog: iptables -A FORWARD -o ppp_0_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Debug   08/05/10 03:00:50   iptables -t   192.168.1.1      user-level   <15> syslog: iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 90.188.32.22 2>/dev/null
Debug   08/05/10 03:00:50   iptables -t   192.168.1.1      user-level   <15> syslog: iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107 2>/dev/null
Debug   08/05/10 03:00:50   iptables -t   192.168.1.1      user-level   <15> syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 90.188.32.22
Debug   08/05/10 03:00:50   /bin/dnsprobe   192.168.1.1      user-level   <15> syslog: /bin/dnsprobe &
Debug   08/05/10 03:00:50   iptables -t   192.168.1.1      user-level   <15> syslog: iptables -t nat -D POSTROUTING -o ppp_0_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE 2>/dev/null
Debug   08/05/10 03:00:50   iptables -t   192.168.1.1      user-level   <15> syslog: iptables -t nat -A POSTROUTING -o ppp_0_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE
Notice   08/05/10 03:00:51   dnsprobe started!   192.168.1.1      user-level   <13> dnsprobe[484]: dnsprobe started!
Debug   08/05/10 03:00:51   iptables -I   192.168.1.1      user-level   <15> syslog: iptables -I FORWARD 1 -j ACCEPT -i ppp_0_0_35_1 -p tcp --dport 30005
Debug   08/05/10 03:00:51   iptables -I   192.168.1.1      user-level   <15> syslog: iptables -I INPUT 1 -j ACCEPT -i ppp_0_0_35_1 -p tcp --dport 30005
Debug   08/05/10 03:00:51   iptables -I   192.168.1.1      user-level   <15> syslog: iptables -I INPUT 1 -p icmp --icmp-type echo-request -i ppp_0_0_35_1 -j ACCEPT
Debug   08/05/10 03:00:52   iptables -I   192.168.1.1      user-level   <15> syslog: iptables -I FORWARD 1 -j ACCEPT -i ppp_0_0_35_1 -p udp -s 192.168.1.1/24 --dport 30006
Debug   08/05/10 03:00:52   iptables -I   192.168.1.1      user-level   <15> syslog: iptables -I INPUT 1 -j ACCEPT -i ppp_0_0_35_1 -p udp -s 192.168.1.1/24 --dport 30006
Debug   08/05/10 03:00:55   ifconfig ppp_0_0_35_1   192.168.1.1      user-level   <15> syslog: ifconfig ppp_0_0_35_1 mtu 1492
Error   08/05/10 03:01:02   tr69c: Unable   192.168.1.1      system daemons   <27> user: tr69c: Unable to retrieve attributes in scratch PAD
Error   08/05/10 03:01:02   Stored Parameter   192.168.1.1      system daemons   <27> user: Stored Parameter Attribute data is corrupt or missing
СообщениеДобавлено: Чт авг 05, 2010 08:13
Алдар писал(а):
     62.146.210.0    255.255.255.0      192.168.1.0     192.168.1.3     1
     62.189.194.0    255.255.255.0      192.168.1.0     192.168.1.3     1
     62.213.110.0    255.255.255.0      192.168.1.0     192.168.1.3     1
       63.85.36.0    255.255.255.0      192.168.1.0     192.168.1.3     1
      64.13.134.0    255.255.255.0      192.168.1.0     192.168.1.3     1
      64.41.142.0    255.255.255.0      192.168.1.0     192.168.1.3     1
      64.41.151.0    255.255.255.0      192.168.1.0     192.168.1.3     1
      64.66.190.0    255.255.255.0      192.168.1.0     192.168.1.3     1
      64.78.182.0    255.255.255.0      192.168.1.0     192.168.1.3     1
     64.128.133.0    255.255.255.0      192.168.1.0     192.168.1.3     1
     64.202.189.0    255.255.255.0      192.168.1.0     192.168.1.3     1
       64.246.4.0    255.255.255.0      192.168.1.0     192.168.1.3     1
для начала как минимум стоит избавиться от вирусов на компе и левых маршрутов на сервера обновлений антивирусов.
СообщениеДобавлено: Чт авг 05, 2010 11:41
Проблема в разрыве линии на уровне ADSL, провайдер судя по логам не виноват:
Пришли статистику на ADSL линию интересуют: Line Attenuation, SNR Margins. Эти параметры должны быть указаны в разделе ADSL status.
По ним будет видно где проблема.
Через неделю мне принесут подобный аппарат может у него можно будет протвикать настройки модема.
СообщениеДобавлено: Чт авг 05, 2010 20:05
Я тогда еще успею 2 компа форматнуть. А то они излечению от вирусов не подлежат, разве что через ливСиДи. Но у меня таких нету. Буду форматировать. А пока, откуда брать Line Attenuation, SNR Margins? Я их не могу найти. У меня тут нету ADSL\Status
