Текущее время: Ср окт 14, 2026 02:10
Начать новую тему Ответить на тему  [ Сообщений: 40 ]  На страницу Пред.  1, 2, 3  След.
СообщениеДобавлено: Ср июл 14, 2010 22:25
Jul 14 14:25:46 daemon warn pppd[673]: Couldn't increase MRU to 1500
Jul 14 14:25:52 daemon crit pppd[673]: Connection terminated....
Jul 14 14:25:52 daemon notice pppd[673]: Modem hangup
Jul 14 14:25:54 user crit kernel: ADSL G.992 started
Jul 14 14:25:58 user crit kernel: ADSL G.992 channel analysis
Jul 14 14:26:04 user crit kernel: ADSL G.992 message exchange
Jul 14 14:26:05 user crit kernel: ADSL link up, interleaved, us=963, ds=4892
Jul 14 14:26:05 user warn kernel: ADSL2/ADSL2+ connection
Jul 14 14:26:06 user debug syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107
Jul 14 14:26:06 daemon info pppd[673]: Sent PADT
Jul 14 14:26:25 user crit kernel: ADSL link down
Jul 14 14:26:27 user crit kernel: ADSL G.994 training
Jul 14 14:26:35 user crit kernel: ADSL G.992 started
Jul 14 14:26:39 user crit kernel: ADSL G.992 channel analysis
Jul 14 14:26:39 daemon info pppd[673]: Sent PADT
Jul 14 14:26:46 user crit kernel: ADSL G.992 message exchange
Jul 14 14:26:46 user crit kernel: ADSL link up, interleaved, us=780, ds=4892
Jul 14 14:26:46 user warn kernel: ADSL2/ADSL2+ connection
Jul 14 14:26:47 user debug syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107
Jul 14 14:27:12 daemon info pppd[673]: Sent PADT
Jul 14 14:27:17 user crit kernel: ADSL link down
Jul 14 14:27:19 user crit kernel: ADSL G.994 training
Jul 14 14:27:28 user crit kernel: ADSL G.992 started
Jul 14 14:27:32 user crit kernel: ADSL G.992 channel analysis
Jul 14 14:27:38 user crit kernel: ADSL G.992 message exchange
Jul 14 14:27:39 user crit kernel: ADSL link up, interleaved, us=1199, ds=4892
Jul 14 14:27:39 user warn kernel: ADSL2/ADSL2+ connection
Jul 14 14:27:40 user debug syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107
Jul 14 14:27:45 daemon info pppd[673]: Sent PADT
Jul 14 14:27:48 daemon info pppd[673]: PPP session is 9708
Jul 14 14:27:48 daemon info pppd[673]: Using interface ppp0_1_32_1
Jul 14 14:27:48 daemon crit pppd[673]: Connect: ppp_0_1_32_1 <--> nas_0_1_32
Jul 14 14:27:48 daemon warn pppd[673]: Couldn't increase MRU to 1500
Jul 14 14:27:49 daemon notice pppd[673]: PAP authentication succeeded
Jul 14 14:27:49 daemon notice pppd[673]: peer from calling number xx:xx:xx:xx:xx:xx authorized
Jul 14 14:27:49 daemon notice pppd[673]: local IP address xxx.xxx.xxx.xxx
Jul 14 14:27:49 daemon notice pppd[673]: remote IP address xxx.xxx.xxx.xxx
Jul 14 14:27:49 daemon notice pppd[673]: primary DNS address xxx.xxx.xxx.xxx
Jul 14 14:27:49 daemon notice pppd[673]: secondary DNS address xxx.xxx.xxx.xxx
Jul 14 14:27:49 user debug syslog: kill -9 24207
Jul 14 14:27:49 user debug syslog: echo > /var/hosts
Jul 14 14:27:50 user debug syslog: cp /proc/var/fyi/wan/ppp_0_1_32_1/dns /var/fyi/sys/dns
Jul 14 14:27:50 user debug syslog: cp /proc/var/fyi/wan/ppp_0_1_32_1/gateway /var/fyi/sys/gateway
Jul 14 14:27:50 user debug syslog: route add default gw xxx.xxx.xxx.xxx 2>/dev/null
Jul 14 14:27:50 user debug syslog: iptables -A FORWARD -o ppp_0_1_32_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Jul 14 14:27:50 user debug syslog: iptables -A FORWARD -i ppp_0_1_32_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Jul 14 14:27:50 user debug syslog: echo > /proc/net/ip_conntrack
Jul 14 14:27:50 user debug syslog: echo "2000" > /proc/sys/net/ipv4/ip_conntrack_max
Jul 14 14:27:50 user debug syslog: echo 2000 > /proc/sys/net/ipv4/ip_conntrack_max
Jul 14 14:27:50 user debug syslog: echo 2000 > /proc/sys/net/ipv4/netfilter/ip_conntrack_generic_timeout
Jul 14 14:27:50 user debug syslog: echo 1400 > /proc/sys/net/ipv4/netfilter/ip_conntrack_tcp_timeout_established
Jul 14 14:27:50 user debug syslog: echo 1400 > /proc/sys/net/ipv4/netfilter/ip_conntrack_tcp_timeout_fin_wait
Jul 14 14:27:50 user debug syslog: echo 120 > /proc/sys/net/ipv4/netfilter/ip_conntrack_tcp_timeout_time_wait
Jul 14 14:27:50 user debug syslog: echo 4096 > /proc/sys/net/ipv4/ipfrag_high_thresh
Jul 14 14:27:50 user debug syslog: echo 1024 > /proc/sys/net/ipv4/ipfrag_low_thresh
Jul 14 14:27:50 user debug syslog: echo 5 > /proc/sys/net/ipv4/ipfrag_time
Jul 14 14:27:50 user debug syslog: iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107 2>/dev/null
Jul 14 14:27:50 user debug syslog: iptables -t nat -D POSTROUTING -o ppp_0_1_32_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE 2>/dev/null
Jul 14 14:27:50 user debug syslog: iptables -t nat -A POSTROUTING -o ppp_0_1_32_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE
Jul 14 14:27:50 user debug syslog: kill -9 25379
Jul 14 14:27:50 user debug syslog: echo > /var/hosts
Jul 14 14:27:50 user debug syslog: iptables -I INPUT 1 -p tcp --dport 80 -i ppp_0_1_32_1 -j ACCEPT
Jul 14 14:27:50 user debug syslog: iptables -I INPUT 1 -j ACCEPT -i ppp_0_1_32_1 -p tcp --dport 30005
Jul 14 14:27:50 user debug syslog: iptables -I FORWARD 1 -j ACCEPT -i ppp_0_1_32_1 -p tcp --dport 30005
Jul 14 14:27:50 user debug syslog: iptables -I INPUT 1 -j ACCEPT -i ppp_0_1_32_1 -p udp -s 192.168.1.1/24 --dport 30006
Jul 14 14:27:50 user debug syslog: iptables -I FORWARD 1 -j ACCEPT -i ppp_0_1_32_1 -p udp -s 192.168.1.1/24 --dport 30006
Jul 14 14:27:51 user debug syslog: echo 4096 > /proc/sys/net/ipv4/ipfrag_high_thresh
Jul 14 14:27:51 user debug syslog: echo 1024 > /proc/sys/net/ipv4/ipfrag_low_thresh
Jul 14 14:27:51 user debug syslog: echo 5 > /proc/sys/net/ipv4/ipfrag_time
Итог, имеем одну (две, три, ...) записей.
СообщениеДобавлено: Ср июл 14, 2010 22:44
А потом удаляем:
Вот только не понятно, зачем это?
СообщениеДобавлено: Ср июл 14, 2010 22:53
Добавили минимум две записи а удалили то одну. В итоге получили болт. Проверено.
СообщениеДобавлено: Пт июл 16, 2010 04:02
Проверте в листинге iptables -L , у меня она не остается.
СообщениеДобавлено: Пт июл 16, 2010 06:17
Да, действительно она не остается при нормальном соединении (на моем логе записи с Jul 14 14:27:19 по Jul 14 14:27:51).
Но, ежели ADSL соединение падает до установки PPP (Jul 14 14:26:25, Jul 14 14:27:17), запись не удаляется.
А потом удаляем:
- удаляет всего ОДНУ запись.
Присмотресь к логу. Мы добавили ТРИ записи а удалили всего ОДНУ в итоге (3-1=)ДВЕ записи осталось. Таких записей может быть много, у меня бывало более 8-10.
В предыдущем же посте писал - ПРОВЕРЕНО.
СообщениеДобавлено: Сб июл 17, 2010 23:31
Я как владелец DSL-2650 подтверждаю, что проблема более чем актуальна. На плохой линии модем регулярно теряет DNS сервера при существующем линке. Несмотря на то, что сервера в роутере прописаны вручную (1 провайдера + 1 гугл), через пару минут работы ДНС отваливается. Помогает только прописывание ДНС на машинах.
Прошу администраторов обязательно решить эту проблему в следующей прошивке, тем более если всё настолько просто!
СообщениеДобавлено: Пн июл 19, 2010 13:57
Хех, прошла неделя, а решения все нет!
Всем участникам спасибо за поддержку -- давайте продолжать в том же духе, а то проблему так и не решат.
P.S. Кстати выравнивание количества добавления/удаления записей потенциально проблему не решает. Я уже писал, что у меня на модеме проблемная запись длиннной командой НЕ УДАЛЯЛАСЬ, а срабатывало только удаление записи по номеру!
DSL-2500U/BRU/D. Fw 1.58.
СообщениеДобавлено: Пн июл 19, 2010 16:33
Спасибо за информацию. В ближайшее время сообщу новости по данной проблеме.
СообщениеДобавлено: Пн июл 19, 2010 18:56
Хорошо. Ждем с нетерпением :)
СообщениеДобавлено: Вт июл 27, 2010 16:42
Странные у Вас представления о "ближайшем времени"
СообщениеДобавлено: Вт июл 27, 2010 17:16
Судя по логам у меня тоже такое
DSL-2500U/BRU/D (H/W D2) | F/W 1.58 | Укртелеком ОГО! - Лёгкий (5 мегабит)
СообщениеДобавлено: Чт июл 29, 2010 16:52
Версия 1.56 - ADSL2500
СообщениеДобавлено: Вт авг 03, 2010 10:30
Ошибка исправлена. Попробуйте новую RU_1.57
ftp://ftp.dlink.ru/pub/ADSL/DSL-2500U_B ... 022010.zip
СообщениеДобавлено: Вт авг 03, 2010 10:41
И для DSL-2650U/BRU/D сделайте пожалуйста обновление. Очень нужно.
СообщениеДобавлено: Вт авг 03, 2010 10:48
Исправлено только это или ещё что-то? Например, более важное:
viewtopic.php?t=108415&postdays=0&postorder=asc&start=285
Которое, мы от вас уже очень долго ждём
И как я понимаю, это бета-версия прошивки?
