Текущее время: Вт окт 13, 2026 16:16
Начать новую тему Ответить на тему  [ Сообщений: 16 ]  На страницу Пред.  1, 2
СообщениеДобавлено: Чт окт 01, 2009 10:11
Команда iptables называется
В 2500U/BRU/D нет такой команды, правда есть ifconfig.
Не уверен что это требуемая команда.
Вот её описание
IFCONFIG
NAME
ifconfig – configure a network interface
SYNOPSIS
ifconfig [interface] ifconfig interface [aftype] options | address ...
DESCRIPTION
Ifconfig is used to configure the kernel-resident network interfaces. It is used at boot time to set up interfaces as necessary. After that, it is usually only needed when debugging or when system tuning is needed.
If no arguments are given, ifconfig displays the status of the currently active interfaces. If a single interface argument is given, it displays the status of the given interface only; if a single -a argument is given, it displays the status of all interfaces, even those that are down. Otherwise, it configures an interface.
COMMANDS
None.
OPTIONS
interface
The name of the interface. This is usually a driver name followed by a unit number, for example eth0 for the first Ethernet interface.
address
The IP address to be assigned to this interface.
up
This flag causes the interface to be activated. It is implicitly specified if an address is assigned to the interface.
down
This flag causes the driver for this interface to be shut down.
[-]arp
Enable or disable the use of the ARP protocol on this interface.
[-]promisc
Enable or disable the promiscuous mode of the interface. If selected, all packets on the network will be received by the interface.
[-]allmulti
Enable or disable all-multicast mode. If selected, all multicast packets on the network will be received by the interface.
metric N
This parameter sets the interface metric.
mtu N
This parameter sets the Maximum Transfer Unit (MTU) of an interface.
dstaddr addr
Set the remote IP address for a point-to-point link (such as PPP). This keyword is now obsolete; use the pointopoint keyword instead.
netmask addr
Set the IP network mask for this interface. This value defaults to the usual class A, B or C network mask (as derived from the interface IP address), but it can be set to any value.
irq addr
Set the interrupt line used by this device. Not all devices can dynamically change their IRQ setting.
io_addr addr
Set the start address in I/O space for this device.
mem_start addr
Set the start address for shared memory used by this device. Only a few devices need this.
[-]broadcast [addr]
If the address argument is given, set the protocol broadcast address for this interface. Otherwise, set (or clear) the IFF_BROADCAST flag for the interface.
[-]pointopoint [addr]
This keyword enables the point-to-point mode of an interface, meaning that it is a direct link between two machines with nobody else listening on it. If the address argument is also given, set the protocol address of the other side of the link, just like the obsolete dstaddr keyword does. Otherwise, set or clear the IFF_POINTOPOINT flag for the interface.
[-]trailers
Set or clear the IFF_NOTRAILERS flag for the interface.
[-]dynamic
Set or clear the IFF_DYNAMIC flag for the interface.
hw class address
Set the hardware address of this interface, if the device driver supports this operation. The keyword must be followed by the name of the hardware class and the printable ASCII equivalent of the hardware address. Hardware classes currently supported include ether (Ethernet) only.
multicast
Set the multicast flag on the interface. This should not normally be needed as the drivers set the flag correctly themselves.
outfill N
This parameter sets the interface outfill timeout.
keepalive N
This parameter sets the interface keepalive timeout.
txqueuelen length
Set the length of the transmit queue of the device. It is useful to set this to small values for slower devices with a high latency (modem links, ISDN) to prevent fast bulk transfers from disturbing interactive traffic like telnet too much.
EXAMPLES
Display all the active interfaces
ifconfig
Set interface eth0’s IP address to be 192.168.1.1, netmask to be 255.255.255.0
ifconfig eth0 192.168.1.1 netmask 255.255.255.0
