Текущее время: Сб ноя 07, 2026 09:46
Начать новую тему Ответить на тему  [ Сообщений: 384 ]  На страницу Пред.  1 ... 5, 6, 7, 8, 9, 10, 11 ... 26  След.
СообщениеДобавлено: Чт окт 22, 2009 11:34
хороший вариант в принципе
СообщениеДобавлено: Чт окт 22, 2009 12:43
на 1.53 поигравшись со всеми вышеуказанными настройками все равно имею
Wed Oct 21 13:27:17 2009: <40> BCM96345  started: BusyBox v1.00 (2009.10.14-01:52+0000)
Wed Oct 21 13:27:17 2009: <15> syslog: echo > /var/snmpd.conf
Wed Oct 21 13:27:19 2009: <15> syslog: pppd  plugin pppoe  nas_0_0_100 nodetach user 'ps1729784' password ****** interface_name 0_0_100_1 usepeerdns refuse-eap persist lcp-echo-interval 100 holdoff 3 lcp-echo-failure 3 maxfail 0 nomppc nomppe  mtu 1492 mru 1492 &
Wed Oct 21 13:27:19 2009: <10> kernel: ADSL G.992 started
Wed Oct 21 13:27:21 2009: <30> pppd[276]: Plugin pppoe loaded.
Wed Oct 21 13:27:22 2009: <10> kernel: ADSL G.992 channel analysis
Wed Oct 21 13:27:22 2009: <30> pppd[276]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.3
Wed Oct 21 13:27:22 2009: <30> pppd[276]: Plugin pppoe called.
Wed Oct 21 13:27:22 2009: <29> pppd[276]: pppd 2.4.3 started by admin, uid 0
Wed Oct 21 13:27:26 2009: <10> kernel: ADSL G.992 message exchange
Wed Oct 21 13:27:26 2009: <10> kernel: ADSL link up, interleaved, us=512, ds=4096
Wed Oct 21 13:27:26 2009: <12> kernel: ADSL1 connection
Wed Oct 21 13:27:26 2009: <12> kernel: ATM Soft SAR: ATM link connected.
Wed Oct 21 13:27:28 2009: <15> syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107
Wed Oct 21 13:27:29 2009: <30> pppd[276]: PPP session is 31196
Wed Oct 21 13:27:29 2009: <30> pppd[276]: Using interface ppp0_0_100_1
Wed Oct 21 13:27:29 2009: <29> pppd[276]: Connect: ppp_0_0_100_1 <--> nas_0_0_100
Wed Oct 21 13:27:29 2009: <28> pppd[276]: Couldn't increase MRU to 1500
Wed Oct 21 13:27:29 2009: <30> pppd[276]: Remote message: Exceeded sessions limit.
Wed Oct 21 13:27:29 2009: <27> pppd[276]: PAP authentication failed
Wed Oct 21 13:27:29 2009: <29> pppd[276]: Connection terminated....
Wed Oct 21 13:27:33 2009: <30> pppd[276]: Sent PADT
Wed Oct 21 13:27:36 2009: <30> pppd[276]: PPP session is 24385
Wed Oct 21 13:27:36 2009: <30> pppd[276]: Using interface ppp0_0_100_1
Wed Oct 21 13:27:36 2009: <29> pppd[276]: Connect: ppp_0_0_100_1 <--> nas_0_0_100
Wed Oct 21 13:27:36 2009: <28> pppd[276]: Couldn't increase MRU to 1500
Wed Oct 21 13:27:36 2009: <29> pppd[276]: PAP authentication succeeded
Wed Oct 21 13:27:36 2009: <29> pppd[276]: peer from calling number 00:22:91:99:04:1B authorized
Wed Oct 21 13:27:36 2009: <29> pppd[276]: local  IP address 84.204.1.10
Wed Oct 21 13:27:36 2009: <29> pppd[276]: remote IP address 84.204.111.1
Wed Oct 21 13:27:36 2009: <29> pppd[276]: primary   DNS address 217.195.65.9
Wed Oct 21 13:27:36 2009: <29> pppd[276]: secondary DNS address 217.195.66.253
Wed Oct 21 13:27:37 2009: <15> syslog: route add default gw 84.204.111.1 2>/dev/null
Wed Oct 21 13:27:38 2009: <15> syslog: iptables -A FORWARD -o ppp_0_0_100_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Wed Oct 21 13:27:38 2009: <15> syslog: iptables -A FORWARD -i ppp_0_0_100_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Wed Oct 21 13:27:38 2009: <15> syslog: echo > /proc/net/ip_conntrack
Wed Oct 21 13:27:38 2009: <15> syslog: echo "600" > /proc/sys/net/ipv4/ip_conntrack_max
Wed Oct 21 13:27:38 2009: <15> syslog: echo 2000 > /proc/sys/net/ipv4/netfilter/ip_conntrack_generic_timeout
Wed Oct 21 13:27:38 2009: <15> syslog: echo 600 > /proc/sys/net/ipv4/netfilter/ip_conntrack_tcp_timeout_established
Wed Oct 21 13:27:38 2009: <15> syslog: echo 1400 > /proc/sys/net/ipv4/netfilter/ip_conntrack_tcp_timeout_fin_wait
Wed Oct 21 13:27:38 2009: <15> syslog: echo 2000 > /proc/sys/net/ipv4/netfilter/ip_conntrack_tcp_timeout_time_wait
Wed Oct 21 13:27:38 2009: <15> syslog: echo 4096 > /proc/sys/net/ipv4/ipfrag_high_thresh
Wed Oct 21 13:27:38 2009: <15> syslog: echo 1024 > /proc/sys/net/ipv4/ipfrag_low_thresh
Wed Oct 21 13:27:38 2009: <15> syslog: echo 5 > /proc/sys/net/ipv4/ipfrag_time
Wed Oct 21 13:27:38 2009: <15> syslog: iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107 2>/dev/null
Wed Oct 21 13:27:38 2009: <15> syslog: iptables -t nat -D POSTROUTING -o ppp_0_0_100_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE 2>/dev/null
Wed Oct 21 13:27:38 2009: <15> syslog: iptables -t nat -A POSTROUTING -o ppp_0_0_100_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE
Wed Oct 21 13:27:38 2009: <15> syslog: iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 217.195.65.9 2>/dev/null
Wed Oct 21 13:27:38 2009: <15> syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 217.195.65.9
Wed Oct 21 13:27:38 2009: <15> syslog: /bin/dnsprobe &
Wed Oct 21 13:27:39 2009: <15> syslog: echo 1024 > /proc/sys/net/ipv4/ipfrag_high_thresh
Wed Oct 21 13:27:39 2009: <13> dnsprobe[465]: dnsprobe started!
Wed Oct 21 13:27:39 2009: <15> syslog: echo 512 > /proc/sys/net/ipv4/ipfrag_low_thresh
Wed Oct 21 13:27:39 2009: <15> syslog: echo 5 > /proc/sys/net/ipv4/ipfrag_time
Wed Oct 21 13:29:26 2009: <10> kernel: ADSL link down
Wed Oct 21 13:29:28 2009: <29> pppd[276]: Terminating connection due to link down.
Wed Oct 21 13:29:28 2009: <30> pppd[276]: Connect time 5157448.4 minutes.
Wed Oct 21 13:29:28 2009: <30> pppd[276]: Sent 166024 bytes, received 1484805 bytes.
Wed Oct 21 13:29:28 2009: <28> pppd[276]: Couldn't increase MRU to 1500
Wed Oct 21 13:29:29 2009: <10> kernel: ADSL G.994 training
Wed Oct 21 13:29:31 2009: <10> kernel: ADSL G.992 started
Wed Oct 21 13:29:34 2009: <10> kernel: ADSL G.992 channel analysis
Wed Oct 21 13:29:34 2009: <29> pppd[276]: Connection terminated....
Wed Oct 21 13:29:38 2009: <10> kernel: ADSL link down
Wed Oct 21 13:29:39 2009: <10> kernel: ADSL G.994 training
Wed Oct 21 13:29:42 2009: <10> kernel: ADSL G.992 started
Wed Oct 21 13:29:44 2009: <10> kernel: ADSL G.992 channel analysis
Wed Oct 21 13:29:49 2009: <10> kernel: ADSL link up, interleaved, us=512, ds=4096
продолжать мучать модем или мозги провайдеру? :) жаль, нет возможности попробовать не-д-линк, что бы разрешить все сомнения =\
СообщениеДобавлено: Чт окт 22, 2009 17:27
доброго времени суток, имеется 2500 bru/d (RU_DSL-2500U_1.10_11162007) на ого 1+ рвет соединение каждые 23:59, т.е. не подымает сессию, прошивка заводская, звонил в ТП, сказали меняйте модем, у этого модема сессия будет рваться постоянно и перепрошивка не поможет.
сейчас, дабы не умер в самый неподходящий момент, перегружаю его вручную 2 раза в сутки утром и вечером.
Вопрос, можно ли как-то это побороть? или все таки продолжать геммороиться, ведь судя по всему у народа с более свежими прошивками соединение рвется еще чаще.
СообщениеДобавлено: Пт окт 23, 2009 06:23
А что с реализацией этих опций viewtopic.php?p=530877#530877 (галка в админке) или с последними прошивками они включены по умолчанию?
Технология PhyR, продвигаемая Broadcom, поддерживается частью DSLAM и её реализация путём обновления составных компонентов DSL-драйвера и выноса соответствующего пунка в админку модема, либо включением по умолчанию была бы весьма полезной.
DSL-2540U
DIR-655 A3
СообщениеДобавлено: Пт окт 23, 2009 09:55
to Ситар
я думаю имеет место подумать над этой строчкой Wed Oct 21 13:27:29 2009: <28> pppd[276]: Couldn't increase MRU to 1500 :P
СообщениеДобавлено: Пт окт 23, 2009 22:51
madvovik писал(а):
to Ситар
игра со значениями MTU тоже пользы не приносит... или может где в реестре есть ключи имеющие больший приоритет чем значения выставляемые в web-интерфейсе модема? О_о
СообщениеДобавлено: Сб окт 24, 2009 21:33
трабла с дисконнектами так и висит.. хочу новую прошу или чем ещё потестить... логов здесь и так вагон..
СообщениеДобавлено: Вс окт 25, 2009 11:33
madvovik писал(а):
to Ситар
Уже вроде выясняли, что на это сообщение не надо обращать внимания. Не в нем причина.
СообщениеДобавлено: Чт окт 29, 2009 14:21
если кому интересно проблема лично у меня решена покупкой linksys ag241
СообщениеДобавлено: Чт окт 29, 2009 21:53
в связи с тем, что так и нет вменяемой проши без шаманств, может быть DLINK начнет отзывать эти аппараты\менять на более старую\новую модель? у меня лежит 15 штук под боком в коробках в пленке... с понедельника я дома имею только кабельный инет.. и вот и ппц
купил се блин подарок на НГ
СообщениеДобавлено: Пт окт 30, 2009 12:35
:lol:
СообщениеДобавлено: Сб ноя 07, 2009 17:26
madvovik писал(а):
:lol:
И чего два раза один и тот скрин постить?
Да и какое он к теме имеет отношение?
Спасибо за бетку 1.53, пока вроде норм, вот только странность в том, что до этого пол года просидел на заводской прошиве 1.20 и разрыв был раз в сутки, обычно ночью, а тут позавчера начались стабильные разрывы через 1-2 часа. Ставил прошиву 1.52 - бестолку, надеюсь с новой прошивой будет ок (рекомендации по выбору параметров выполнил).
Не мог же модем сам по себе испортится? Я так понимаю это больше похоже на проблему с провайдером и его настройками? Разве не так?
И чем чревато установить параметр LCP echo interval в несколько минут?
Ведь в конечном итоге нужно автоматическое восстановление сессии несмотря ни на что?
СообщениеДобавлено: Вс ноя 08, 2009 12:27
ну во-первых я 2 скрина не постил... ч их вообще не постил... ты наверное ошибся... во-вторых я не советовал прошу 1.53 а лишь когда то говорил о том что она есть и тестицца, если хочешь чтобы все равботало я чуть выше отписал как сам исправил проблему читай!
 Заголовок сообщения: 2 madvovik
СообщениеДобавлено: Вс ноя 08, 2009 13:56
Ага, ошибся, не каждый результаты с Speedtest.net себе в подпись ставит, да еще за 24 октября... :?
Что касательно прошивы 1.53 бета, то со времени вчерашнего поста интернет НЕ ВЫКЛЮЧАЛСЯ, так что на данный момент могу утверждать что лично мне помогло и очень, даже так называемое билинговое отключение пережил. :D
Выставил только LCP echo interval в 5 минут и IP fragmentation high в 3072.
Так же установил галочки SRA Enable и Bridge PPPoE Frames Between WAN and Local Ports.
Подключен мостом на один комп.
Провайдер Укртелеком с его ОГО.
СПАСИБО техподдержке D-Link! Модем конечно не супер, но всё за свои ДЕНЬГИ, да и по большей части я считаю, что проблема не столько в модеме, сколько в провайдере, ибо в как я уже говорил, модем проработал больше полугода с выключением раз в сутки по вине провайдера.
Я могу только предположить, что у тех, кому не помогает вероятно есть и другие проблемы, такие как шум в линии (атс), неисправный (некачественный) сплитер, проблемы с электронной частью модема, плохие контакты в соединительных проводах и разъемах.
На данный момент уже больше суток интернет без выключений работает.
 Заголовок сообщения: Re: 2 madvovik
СообщениеДобавлено: Пн ноя 09, 2009 13:54
что бы понять есть дисконекты или нет, послушай радио через интернет и ты поймешь, что падения по несколько раз в час на прошивке 1.53. так что благодарить тех поддержку не за что, они решают одни проблемы за счет других, а уж про аську молчу вылетает постоянно, пока самая стабильная 1.40 с кипалив, просто модем сам собой перезагружался раз в день, а с прошивой 1.53 смотреть шару на нтв+ просто огорчительно.
