Текущее время: Чт ноя 05, 2026 09:04
СообщениеДобавлено: Сб янв 15, 2011 19:48
После обновления прошивки перестала видна флешка по wi fi. по ethernet проверить нет возможности.
LOG модема
Jan 1 00:00:23 user notice kernel: SCSI device sda: 4067328 512-byte hdwr sectors (2082 MB)
Jan 1 00:00:23 user notice kernel: sda: assuming Write Enabled
Jan 1 00:00:23 user err kernel: sda: assuming drive cache: write through
Jan 1 00:00:23 user info kernel: sda:<6>Broadcom BCMPROCFS v1.0 initialized
Jan 1 00:00:23 user warn kernel: Broadcom BCM6358A1 Ethernet Network Device v0.3 Dec 3 2010 17:45:26
Jan 1 00:00:23 user warn kernel: Config Ethernet Switch Through MDIO Pseudo PHY Interface
Jan 1 00:00:23 user warn kernel: dgasp: kerSysRegisterDyingGaspHandler: eth0 registered
Jan 1 00:00:23 user warn kernel: eth0: MAC Address: 00:22:B0:62:E1:98
Jan 1 00:00:23 user warn kernel: sda1
Jan 1 00:00:23 user notice kernel: Attached scsi removable disk sda at scsi0, channel 0, id 0, lun 0
Jan 1 00:00:23 user debug kernel: USB Mass Storage device found at 2
Jan 1 00:00:23 user warn kernel: Broadcom BCM6358A1 USB Network Device v0.4 Dec 3 2010 17:45:27
Jan 1 00:00:23 user warn kernel: usb0: MAC Address: 00 22 B0 62 E1 99
Jan 1 00:00:23 user warn kernel: usb0: Host MAC Address: 00 22 B0 62 E1 9A
Jan 1 00:00:23 user err kernel: FAT: utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
Jan 1 00:00:23 user debug kernel: PCI: Setting latency timer of device 0000:00:01.0 to 64
Jan 1 00:00:23 user warn kernel: PCI: Enabling device 0000:00:01.0 (0004 -> 0006)
Jan 1 00:00:23 user warn kernel: wl: srom not detected, using main memory mapped srom info (wombo board)
Jan 1 00:00:23 user warn kernel: wl0: wlc_attach: use mac addr from the system pool by id: 0x776c0000
Jan 1 00:00:23 user warn kernel: wl0: MAC Address: 00:22:B0:62:E1:9B
Jan 1 00:00:23 user warn kernel: wl0: Broadcom BCM4318 802.11 Wireless Controller 4.100.27.0.cpe2.1
Jan 1 00:00:23 user warn kernel: dgasp: kerSysRegisterDyingGaspHandler: wl0 registered
Jan 1 00:00:23 user crit kernel: eth0 Link UP.
Jan 1 00:00:23 user warn kernel: BcmAdsl_Initialize=0xC006B808, g_pFnNotifyCallback=0xC0084834
Jan 1 00:00:23 user warn kernel: AnnexCParam=0x7FFF7EB8 AnnexAParam=0x00000980 adsl2=0x00000000
Jan 1 00:00:23 user warn kernel: pSdramPHY=0xA1FFFFF8, 0x0 0x0
Jan 1 00:00:23 user warn kernel: AdslCoreHwReset: AdslOemDataAddr = 0xA1FFD3D4
Jan 1 00:00:23 user warn kernel: dgasp: kerSysRegisterDyingGaspHandler: dsl0 registered
Jan 1 00:00:23 user warn kernel: ATM proc init !!!
Jan 1 00:00:23 user warn kernel: ip_tables: (C) 2000-2002 Netfilter core team
Jan 1 00:00:23 user warn kernel: ip_conntrack version 2.1 (253 buckets, 0 max) - 376 bytes per conntrack
Jan 1 00:00:23 user warn kernel: ip_conntrack_pptp version 2.1 loaded
Jan 1 00:00:23 user warn kernel: ip_nat_pptp version 2.0 loaded
Jan 1 00:00:23 user warn kernel: ip_ct_h323: init success
Jan 1 00:00:23 user warn kernel: ip_nat_h323: init success
Jan 1 00:00:23 user debug syslog: echo > /var/snmpd.conf
Jan 1 00:00:23 user warn kernel: ip_conntrack_rtsp v0.01 loading
Jan 1 00:00:23 user warn kernel: ip_nat_rtsp v0.01 loading
Jan 1 00:00:23 user info kernel: device usb0 entered promiscuous mode
Jan 1 00:00:23 user info kernel: br0: port 1(usb0) entering learning state
Jan 1 00:00:23 user info kernel: br0: topology change detected, propagating
Jan 1 00:00:23 user info kernel: br0: port 1(usb0) entering forwarding state
Jan 1 00:00:23 user info kernel: device eth0 entered promiscuous mode
Jan 1 00:00:23 user info kernel: br0: port 2(eth0) entering learning state
Jan 1 00:00:23 user info kernel: br0: port 2(eth0) entering forwarding state
Jan 1 00:00:23 user crit kernel: ADSL G.994 training
Jan 1 00:00:23 user info kernel: device wl0 entered promiscuous mode
Jan 1 00:00:23 user info kernel: br0: port 3(wl0) entering learning state
Jan 1 00:00:23 user info kernel: br0: port 3(wl0) entering forwarding state
Jan 1 00:00:23 user info kernel: device usb0 left promiscuous mode
Jan 1 00:00:23 user info kernel: br0: port 1(usb0) entering disabled state
Jan 1 00:00:23 user info kernel: device eth0 left promiscuous mode
Jan 1 00:00:23 user info kernel: br0: port 2(eth0) entering disabled state
Jan 1 00:00:23 user info kernel: device wl0 left promiscuous mode
Jan 1 00:00:23 user info kernel: br0: port 3(wl0) entering disabled state
Jan 1 00:00:23 user debug syslog: echo > /var/hosts
Jan 1 00:00:24 user warn kernel:
Jan 1 00:00:24 user warn kernel: ioctl, p_name=diapd
Jan 1 00:00:24 user emerg kernel: gpio_fasync
Jan 1 00:00:24 user warn kernel: Pasync_queue->magic = 0x4601
Jan 1 00:00:24 user debug syslog: mount -o remount,size=1M /var
Jan 1 00:00:24 user debug syslog: mkdir -p /var/samba/var/locks
Jan 1 00:00:24 user debug syslog: mkdir -p /var/samba/private
Jan 1 00:00:24 user debug syslog: mkdir -p /var/samba/lib/vfs
Jan 1 00:00:24 user debug syslog: mkdir -p /var/samba/lib/pdb
Jan 1 00:00:24 user debug syslog: mkdir -p /var/samba/lib/rpc
Jan 1 00:00:24 user debug syslog: mkdir -p /var/samba/lib/atuh
Jan 1 00:00:24 user debug syslog: mkdir -p /var/samba/lib/config
Jan 1 00:00:24 user debug syslog: smbd -s /var/smb.conf
Jan 1 00:00:26 user debug syslog: nmbd -s /var/smb.conf
Jan 1 00:00:29 user debug syslog: pppd plugin pppoe oldsession 003088189006/373f nas_0_0_33 nodetach user '' password ************ interface_name 0_0_33_1 usepeerdns refuse-eap persist lcp-echo-interval 30 holdoff 3 lcp-
Jan 1 00:00:30 daemon info pppd[693]: Plugin pppoe loaded.
Jan 1 00:00:30 daemon info pppd[693]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.3
Jan 1 00:00:30 daemon info pppd[693]: Plugin pppoe called.
Jan 1 00:00:30 daemon notice pppd[693]: pppd 2.4.3 started by admin, uid 0
Jan 1 00:00:30 user info kernel: br0: port 1(usb0) entering disabled state
Jan 1 00:00:32 user crit kernel: ADSL G.992 started
Jan 1 00:00:33 user crit kernel: ADSL link down
Jan 1 00:00:34 user crit kernel: ADSL G.994 training
Jan 1 00:00:43 user crit kernel: ADSL G.992 started
Jan 1 00:00:47 user crit kernel: ADSL G.992 channel analysis
Jan 1 00:00:53 user crit kernel: ADSL link up, interleaved, us=700, ds=10236
Jan 1 00:00:53 user warn kernel: ADSL2/ADSL2+ connection
Jan 1 00:00:55 user debug syslog: iptables -t nat -D PREROUTING -i br0 -d 10.2.54.13 -p udp --dport 53 -j DNAT --to 128.9.0.107
Jan 1 00:00:55 user debug syslog: iptables -t nat -A PREROUTING -i br0 -d 10.2.54.13 -p udp --dport 53 -j DNAT --to 128.9.0.107
Jan 1 00:00:55 daemon info pppd[693]: Sent PADT
Jan 1 00:00:58 daemon info pppd[693]: PPP session is 1476
Jan 1 00:00:58 daemon info pppd[693]: Using interface ppp0_0_33_1
Jan 1 00:00:58 daemon crit pppd[693]: Connect: ppp_0_0_33_1 <--> nas_0_0_33
Jan 1 00:00:58 daemon warn pppd[693]: Couldn't increase MRU to 1500
Jan 1 00:00:58 daemon info pppd[693]: CHAP authentication succeeded: CHAP authentication success, unit 3607
Jan 1 00:00:58 daemon notice pppd[693]: peer from calling number 00:30:88:17:67:BA authorized
Jan 1 00:00:59 daemon notice pppd[693]: local IP address 1.8.157.166
Jan 1 00:00:59 daemon notice pppd[693]: remote IP address 1.8.128.1
Jan 1 00:00:59 daemon notice pppd[693]: primary DNS address 82.209.240.241
Jan 1 00:00:59 daemon notice pppd[693]: secondary DNS address 82.209.243.241
Jan 1 00:00:59 user debug syslog: kill -9 660
Jan 1 00:00:59 user debug syslog: echo > /var/hosts
Jan 1 00:00:59 user debug syslog: cp /proc/var/fyi/wan/ppp_0_0_33_1/dns /var/fyi/sys/dns
Jan 1 00:00:59 user debug syslog: cp /proc/var/fyi/wan/ppp_0_0_33_1/gateway /var/fyi/sys/gateway
Jan 1 00:00:59 user debug syslog: route add default gw 1.8.128.1 2>/dev/null
Jan 1 00:00:59 user debug syslog: iptables -A FORWARD -o ppp_0_0_33_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Jan 1 00:00:59 user debug syslog: iptables -A FORWARD -i ppp_0_0_33_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Jan 1 00:00:59 user debug syslog: echo > /proc/net/ip_conntrack
Jan 1 00:00:59 user debug syslog: echo "1000" > /proc/sys/net/ipv4/ip_conntrack_max
Jan 1 00:00:59 user debug syslog: echo 2000 > /proc/sys/net/ipv4/ip_conntrack_max
Jan 1 00:00:59 user debug syslog: echo 2000 > /proc/sys/net/ipv4/netfilter/ip_conntrack_generic_timeout
Jan 1 00:00:59 user debug syslog: echo 1400 > /proc/sys/net/ipv4/netfilter/ip_conntrack_tcp_timeout_established
Jan 1 00:00:59 user debug syslog: echo 1400 > /proc/sys/net/ipv4/netfilter/ip_conntrack_tcp_timeout_fin_wait
Jan 1 00:00:59 user debug syslog: echo 120 > /proc/sys/net/ipv4/netfilter/ip_conntrack_tcp_timeout_time_wait
Jan 1 00:00:59 user debug syslog: echo 4096 > /proc/sys/net/ipv4/ipfrag_high_thresh
Jan 1 00:00:59 user debug syslog: echo 1024 > /proc/sys/net/ipv4/ipfrag_low_thresh
Jan 1 00:00:59 user debug syslog: echo 5 > /proc/sys/net/ipv4/ipfrag_time
Jan 1 00:00:59 user debug syslog: iptables -t nat -D PREROUTING -i br0 -d 10.2.54.13 -p udp --dport 53 -j DNAT --to 128.9.0.107 2>/dev/null
Jan 1 00:00:59 user debug syslog: iptables -t nat -D POSTROUTING -o ppp_0_0_33_1 -s 10.2.54.0/255.255.255.0 -j MASQUERADE 2>/dev/null
Jan 1 00:01:00 user debug syslog: iptables -t nat -A POSTROUTING -o ppp_0_0_33_1 -s 10.2.54.0/255.255.255.0 -j MASQUERADE
Jan 1 00:01:00 user debug syslog: kill -9 1102
Jan 1 00:01:00 user debug syslog: echo > /var/hosts
Jan 1 00:01:00 user debug syslog: upnp -L br0 -W ppp_0_0_33_1 -D
Jan 1 00:01:00 user debug syslog: iptables -t filter -I OUTPUT -o ppp_0_0_33_1 -d 239.255.255.250 -j DROP 2>/dev/null
Jan 1 00:01:00 user debug syslog: route add -host dev ppp_0_0_33_1
Jan 1 00:01:00 user debug syslog: echo "#!/bin/sh" > /var/ppp/ip-up.local
Jan 1 00:01:00 user debug syslog: echo "#!/bin/sh" > /var/ppp/ip-down.local
Jan 1 00:01:00 user debug syslog: echo "route add default dev \$1" >> /var/ppp/ip-up.local
Jan 1 00:01:01 user debug syslog: echo "route del default dev \$1" >> /var/ppp/ip-down.local
Jan 1 00:01:01 user debug syslog: echo "iptables -t nat -A POSTROUTING -o \$1 -j MASQUERADE" >> /var/ppp/ip-up.local
Jan 1 00:01:01 user debug syslog: echo "iptables -A FORWARD -o \$1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu" >> /var/ppp/ip-up.local
Jan 1 00:01:01 user debug syslog: echo "iptables -A FORWARD -i \$1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu" >> /var/ppp/ip-up.local
Jan 1 00:01:01 user debug syslog: chmod +rx /var/ppp/ip-up.local
Jan 1 00:01:01 user debug syslog: echo "iptables -t nat -D POSTROUTING -o \$1 -j MASQUERADE" >> /var/ppp/ip-down.local
Jan 1 00:01:01 user debug syslog: echo "iptables -D FORWARD -o \$1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu" >> /var/ppp/ip-down.local
Jan 1 00:01:01 user debug syslog: echo "iptables -D FORWARD -i \$1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu" >> /var/ppp/ip-down.local
Jan 1 00:01:01 user debug syslog: chmod +rx /var/ppp/ip-down.local
Jan 1 00:01:01 user debug syslog: kill -9 659
Jan 1 00:01:01 user emerg kernel: gpio_release
Jan 1 00:01:01 user debug syslog: pppd call vpnuser
Jan 1 00:01:01 user debug syslog: iptables -I INPUT 1 -j ACCEPT -i ppp_0_0_33_1 -p tcp --dport 30005
Jan 1 00:01:01 daemon notice pppd[1200]: pppd 2.4.3 started by admin, uid 0
Jan 1 00:01:01 user debug syslog: iptables -I FORWARD 1 -j ACCEPT -i ppp_0_0_33_1 -p tcp --dport 30005
Jan 1 00:01:01 user debug syslog: iptables -I INPUT 1 -j ACCEPT -i ppp_0_0_33_1 -p udp -s 10.2.54.13/24 --dport 30006
Jan 1 00:01:01 daemon info pppd[1200]: Using interface ppp0
Jan 1 00:01:01 daemon crit pppd[1200]: Connect: ppp0 <--> /dev/ttyp0
Jan 1 00:01:01 user debug syslog: iptables -I FORWARD 1 -j ACCEPT -i ppp_0_0_33_1 -p udp -s 10.2.54.13/24 --dport 30006
Jan 1 00:01:01 daemon err user: No server certificate found. Skip checking on certificate.
Jan 1 00:01:01 user debug syslog: echo 4096 > /proc/sys/net/ipv4/ipfrag_high_thresh
Jan 1 00:01:02 user debug syslog: echo 1024 > /proc/sys/net/ipv4/ipfrag_low_thresh
Jan 1 00:01:02 user debug syslog: echo 5 > /proc/sys/net/ipv4/ipfrag_time
Jan 1 00:01:02 daemon warn pppd[1200]: Warning - secret file /etc/ppp/pap-secrets has world and/or group access
Jan 1 00:01:03 daemon debug user: wlctl -i wl0 authe_sta_list > /var/wl_authe
Jan 1 00:01:03 daemon debug user: wlctl -i wl0 assoclist > /var/wl_assoc
Jan 1 00:01:03 daemon debug user: wlctl -i wl0 autho_sta_list > /var/wl_autho
Jan 1 00:01:04 daemon err user: tr69c: Unable to retrieve attributes in scratch PAD
Jan 1 00:01:04 daemon err user: Stored Parameter Attribute data is corrupt or missing
Jan 1 00:01:08 daemon warn pppd[1200]: Warning - secret file /etc/ppp/chap-secrets has world and/or group access
Jan 1 00:01:08 daemon info pppd[1200]: CHAP authentication succeeded: Access granted
Jan 1 00:01:08 daemon notice pppd[1200]: Deflate (15) transmit compression enabled
Jan 1 00:01:08 daemon notice pppd[1200]: local IP address 192.168.253.172
Jan 1 00:01:08 daemon notice pppd[1200]: remote IP address 192.168.100.1
СообщениеДобавлено: Сб янв 15, 2011 20:58
пробовали после перепрошивки сбросить модем к заводским настройкам и перенастроить заново?
СообщениеДобавлено: Вс янв 16, 2011 01:24
первым делом после прошивки сбросил и заново настроил.
А у Вас работает ?
СообщениеДобавлено: Пн янв 17, 2011 16:31
кроме того, клиент pptp теперь хоть и работает сносно, но все равно не правильно. если работаете такая связка pppoe + сверху еще pptp, то модем со временем перестает отвечать на запросы, соединения через pptp нету, остается только pppoe.
вот логи модема при падении pptp (pptp проработал часов 10)
Jan 17 15:13:37 syslog emerg BCM96345 started: BusyBox v1.00 (2010.12.03-09:49+0000)
Jan 17 15:13:37 user notice kernel: klogd started: BusyBox v1.00 (2010.12.03-09:49+0000)
Jan 17 15:13:37 user debug syslog: echo 0 > /var/isdft_cfg
Jan 17 15:13:39 daemon info pppd[1438]: Connect time 0.1 minutes.
Jan 17 15:13:39 daemon info pppd[1438]: Sent 0 bytes, received 770 bytes.
Jan 17 15:13:39 daemon crit pppd[1438]: Connection terminated....
Jan 17 15:13:39 daemon info pppd[1438]: Using interface ppp0
Jan 17 15:13:39 daemon crit pppd[1438]: Connect: ppp0 <--> /dev/ttyp0 хотелось бы узнать что за ошибка и почему она постоянно присутствует
Jan 17 15:13:40 daemon warn pppd[1438]: Warning - secret file /etc/ppp/pap-secrets has world and/or group access
Jan 17 15:13:45 daemon warn pppd[1438]: Warning - secret file /etc/ppp/chap-secrets has world and/or group access
Jan 17 15:13:45 daemon info pppd[1438]: CHAP authentication succeeded: Access granted
Jan 17 15:13:45 daemon notice pppd[1438]: local IP address 192.168.253.172
Jan 17 15:13:45 daemon notice pppd[1438]: remote IP address 192.168.100.1
Jan 17 15:13:45 daemon notice pppd[1438]: Deflate (15) transmit compression enabled
Jan 17 15:13:47 daemon notice pppd[1438]: Modem hangup
Jan 17 15:13:47 daemon info pppd[1438]: Connect time 0.1 minutes.
Jan 17 15:13:47 daemon info pppd[1438]: Sent 0 bytes, received 256 bytes.
Jan 17 15:13:47 daemon crit pppd[1438]: Connection terminated....
Jan 17 15:13:47 daemon info pppd[1438]: Using interface ppp0
Jan 17 15:13:47 daemon crit pppd[1438]: Connect: ppp0 <--> /dev/ttyp0
Jan 17 15:13:48 daemon warn pppd[1438]: Warning - secret file /etc/ppp/pap-secrets has world and/or group access
Jan 17 15:13:54 daemon warn pppd[1438]: Warning - secret file /etc/ppp/chap-secrets has world and/or group access
Jan 17 15:13:54 daemon info pppd[1438]: CHAP authentication succeeded: Access granted
Jan 17 15:13:54 daemon notice pppd[1438]: local IP address 192.168.253.172
Jan 17 15:13:54 daemon notice pppd[1438]: remote IP address 192.168.100.1
Jan 17 15:13:54 daemon notice pppd[1438]: Deflate (15) transmit compression enabled
Jan 17 15:13:54 daemon notice pppd[1438]: Modem hangup
Jan 17 15:13:54 daemon info pppd[1438]: Connect time 0.0 minutes.
Jan 17 15:13:54 daemon info pppd[1438]: Sent 1087 bytes, received 44 bytes.
Jan 17 15:13:54 daemon crit pppd[1438]: Connection terminated....
Jan 17 15:13:54 daemon info pppd[1438]: Using interface ppp0
Jan 17 15:13:54 daemon crit pppd[1438]: Connect: ppp0 <--> /dev/ttyp0
Jan 17 15:13:55 daemon warn pppd[1438]: Warning - secret file /etc/ppp/pap-secrets has world and/or group access
а вот логи модема, когда он подключился и работает нормально
Jan 1 00:00:44 daemon notice pppd[990]: pppd 2.4.3 started by admin, uid 0
Jan 1 00:00:44 user debug syslog: iptables -I FORWARD 1 -j ACCEPT -i ppp_0_0_33_1 -p tcp --dport 30005
Jan 1 00:00:44 user debug syslog: iptables -I INPUT 1 -j ACCEPT -i ppp_0_0_33_1 -p udp -s 10.2.54.13/24 --dport 30006
Jan 1 00:00:44 daemon info pppd[990]: Using interface ppp0
Jan 1 00:00:44 daemon crit pppd[990]: Connect: ppp0 <--> /dev/ttyp0 !!!!!!!!!!!!!!!!!!!!!!!
Jan 1 00:00:45 user debug syslog: iptables -I FORWARD 1 -j ACCEPT -i ppp_0_0_33_1 -p udp -s 10.2.54.13/24 --dport 30006
Jan 1 00:00:45 daemon err user: No server certificate found. Skip checking on certificate.
Jan 1 00:00:45 user debug syslog: echo 4096 > /proc/sys/net/ipv4/ipfrag_high_thresh
Jan 1 00:00:45 user debug syslog: echo 1024 > /proc/sys/net/ipv4/ipfrag_low_thresh
Jan 1 00:00:45 user debug syslog: echo 5 > /proc/sys/net/ipv4/ipfrag_time
Jan 1 00:00:45 daemon warn pppd[990]: Warning - secret file /etc/ppp/pap-secrets has world and/or group access
Jan 1 00:00:46 daemon debug user: wlctl -i wl0 authe_sta_list > /var/wl_authe
Jan 1 00:00:46 daemon debug user: wlctl -i wl0 assoclist > /var/wl_assoc
Jan 1 00:00:46 daemon debug user: wlctl -i wl0 autho_sta_list > /var/wl_autho
Jan 1 00:00:47 daemon err user: tr69c: Unable to retrieve attributes in scratch PAD
Jan 1 00:00:47 daemon err user: Stored Parameter Attribute data is corrupt or missing
Jan 1 00:00:51 daemon warn pppd[990]: Warning - secret file /etc/ppp/chap-secrets has world and/or group access
Jan 1 00:00:51 daemon info pppd[990]: CHAP authentication succeeded: Access granted
Jan 1 00:00:51 daemon notice pppd[990]: Deflate (15) transmit compression enabled
Jan 1 00:00:51 daemon notice pppd[990]: local IP address 192.168.253.172
Jan 1 00:00:51 daemon notice pppd[990]: remote IP address 192.168.100.1
Jan 17 15:15:37 daemon info pppd[990]: CCP terminated by peer (Lost compression sync)
Jan 17 15:15:37 daemon notice pppd[990]: Compression disabled by peer
со временем модем напишет Deflate (15) transmit compression enabled и все, до перезагрузки модема соединение не устанавливается. продолжительность
соединения бывает разной, то сутки, то час, то еще сколько. Такое ощущение что модем живет своей жизнью.
p.s. Перепрошил еще раз. сбросил настройки. Флешка видна, но с vpn ничего не изменилось ( все так же падает
