Текущее время: Чт июн 25, 2026 04:30
 Заголовок сообщения: DSL-502T Couldn't get channel number: Transport endpoint...
СообщениеДобавлено: Чт июн 09, 2005 11:49
First of all I would like to apologize for posting in English.
I have a problem with my DSL-502T router/modem and this is one of the rare pages where I've found mentioned error I get...
I am able to connect to Internet when using routers "bridge" mode. When I switch to PPPoE I keep getting error:
Jun 9 10:22:54> pppd 2.4.1 started by root, uid 0
Jun 9 10:24:34> System Call Error
Jun 9 10:24:34> Couldn't get channel number: Transport endpoint is not connected
Jun 9 10:24:34> Doing disconnect
Jun 9 10:24:35> pppd 2.4.1 started by root, uid 0
I tried with routers DHCP server ON and with routers DHCP server OFF, with PC as DHCP client and PC with static IP.
Access data for ISP are corect (VCI and VPI 35 and 8 as supplied by ISP tech support) because I am able to connect in bridge mode... The also said that they support PPPoE
I tried with Linux and Windows with same result..
Can someone help me with this setup please,
Greetings.
Device info:
Product Information
Model Number
DSL-502T
USB PID 0x5b00
USB VID 0x2001
Ethernet MAC 00:0F:3D:8A:4D:A6
USB MAC 00:0F:3D:8A:4D:A7
USB Host MAC 00:0F:3D:8A:4D:A8
Software Versions
Gateway V1.00B02T02.EU.20040611
ATM Driver 4.01.00.00
DSL HAL 1.01.00.00
DSL Datapumps 1.01.00.00 Annex A
SAR HAL 01.06.06 s
PDSP Firmware 0.49
Boot Loader 0.22.02
СообщениеДобавлено: Чт июн 09, 2005 12:10
DSL-502T doesn't support in Russia
СообщениеДобавлено: Чт июн 09, 2005 12:22
OK, Would you be so nice and show me direction I should start to look for error reasons?
СообщениеДобавлено: Чт июн 09, 2005 12:35
Ask supporto of ISP to use G.DMT or T1.413 modulation mode on Your port from their side
СообщениеДобавлено: Чт июн 09, 2005 12:47
Thank you very much for your answer. They told me few days ago that I should set modulation type to G.DMT I and did so without success... Error was still here...
Link to ISP ADSL section...
http://web.bih.net.ba/index.php?id=104
СообщениеДобавлено: Чт июн 09, 2005 13:39
If for all of you works in a mode of the bridge, and in a mode of a router pppoe does not establish connection to solve this problem with your provider, or to search for another firmware where is modified libatm. In Russia DSL-502T officially is not on sale and it is not supported...
