Текущее время: Пн сен 21, 2026 23:12
 Заголовок сообщения: DSL-2500U/BRU/C и постоянные разрывы
СообщениеДобавлено: Вс июн 21, 2009 22:34
Имеется такой сабж. В момент разрыва захожу на модем очень долго, тормозит неймоверно. Провайдер Укртелеком. Прошивка 1.20. Включен KeepAlive.
Jun 21 20:29:27   daemon   crit   pppd[248]: PPP server detected.
Jun 21 20:29:27   daemon   crit   pppd[248]: PPP session established.
Jun 21 20:29:40   daemon   crit   pppd[248]: PPP server detected.
Jun 21 20:29:44   daemon   crit   pppd[248]: PPP server detected.
Jun 21 20:29:44   daemon   crit   pppd[248]: PPP session established.
Jun 21 20:29:57   daemon   crit   pppd[248]: PPP server detected.
Jun 21 20:30:01   daemon   crit   pppd[248]: PPP server detected.
Jun 21 20:30:01   daemon   crit   pppd[248]: PPP session established.
Jun 21 20:30:13   daemon   crit   pppd[248]: PPP server detected.
Jun 21 20:30:17   daemon   crit   pppd[248]: PPP server detected.
Jun 21 20:30:17   daemon   crit   pppd[248]: PPP session established.
Jun 21 20:30:17   daemon   crit   pppd[248]: PPP LCP UP.
Jun 21 20:30:18   daemon   crit   pppd[248]: Received valid IP address from server. Connection UP.
Jun 21 20:30:34   user   alert   kernel: Intrusion -> IN=ppp_0_1_32_1 OUT= MAC= SRC=94.51.227.14 DST=95.134.233.8 LEN=48 TOS=0x00 PREC=0x00 TTL=110 ID=14533 DF PROTO=TCP SPT=1500 DPT=31067 WINDOW=65535 RES=0x00 SYN URGP=0
Jun 21 20:30:37   user   alert   kernel: Intrusion -> IN=ppp_0_1_32_1 OUT= MAC= SRC=94.51.227.14 DST=95.134.233.8 LEN=48 TOS=0x00 PREC=0x00 TTL=110 ID=14995 DF PROTO=TCP SPT=1500 DPT=31067 WINDOW=65535 RES=0x00 SYN URGP=0
Jun 21 20:30:43   user   alert   kernel: Intrusion -> IN=ppp_0_1_32_1 OUT= MAC= SRC=94.51.227.14 DST=95.134.233.8 LEN=48 TOS=0x00 PREC=0x00 TTL=110 ID=15833 DF PROTO=TCP SPT=1500 DPT=31067 WINDOW=65535 RES=0x00 SYN URGP=0
Jun 21 20:30:43   user   alert   kernel: Intrusion -> IN=ppp_0_1_32_1 OUT= MAC= SRC=95.107.126.11 DST=95.134.233.8 LEN=48 TOS=0x00 PREC=0x00 TTL=113 ID=720 DF PROTO=TCP SPT=2621 DPT=31067 WINDOW=65535 RES=0x00 SYN URGP=0
Jun 21 20:30:45   user   alert   kernel: Intrusion -> IN=ppp_0_1_32_1 OUT= MAC= SRC=94.124.160.233 DST=95.134.233.8 LEN=52 TOS=0x00 PREC=0x00 TTL=121 ID=14329 DF PROTO=TCP SPT=49165 DPT=38292 WINDOW=8192 RES=0x00 SYN URGP=0
Jun 21 20:40:45   user   alert   kernel: Intrusion -> IN=ppp_0_1_32_1 OUT= MAC= SRC=95.135.231.138 DST=95.134.233.8 LEN=52 TOS=0x00 PREC=0x00 TTL=61 ID=36726 DF PROTO=TCP SPT=4272 DPT=31067 WINDOW=64240 RES=0x00 SYN URGP=0
Jun 21 20:50:37   user   alert   kernel: Intrusion -> IN=ppp_0_1_32_1 OUT= MAC= SRC=92.124.5.135 DST=95.134.233.8 LEN=48 TOS=0x00 PREC=0x00 TTL=112 ID=16082 DF PROTO=TCP SPT=2020 DPT=38292 WINDOW=65535 RES=0x00 SYN URGP=0
Jun 21 21:00:34   user   alert   kernel: Intrusion -> IN=ppp_0_1_32_1 OUT= MAC= SRC=93.178.112.179 DST=95.134.233.8 LEN=48 TOS=0x00 PREC=0x00 TTL=110 ID=40003 DF PROTO=TCP SPT=50720 DPT=18224 WINDOW=65535 RES=0x00 SYN URGP=0
Jun 21 21:10:35   user   alert   kernel: Intrusion -> IN=ppp_0_1_32_1 OUT= MAC= SRC=92.124.5.135 DST=95.134.233.8 LEN=48 TOS=0x00 PREC=0x00 TTL=112 ID=23963 DF PROTO=TCP SPT=3320 DPT=38292 WINDOW=65535 RES=0x00 SYN URGP=0
Jun 21 21:20:44   user   alert   kernel: Intrusion -> IN=ppp_0_1_32_1 OUT= MAC= SRC=81.200.24.20 DST=95.134.233.8 LEN=48 TOS=0x00 PREC=0x00 TTL=114 ID=62813 DF PROTO=TCP SPT=4419 DPT=18224 WINDOW=65535 RES=0x00 SYN URGP=0
Jun 21 21:22:46   user   crit   kernel: ADSL link down
Jun 21 21:22:48   user   crit   kernel: ADSL G.994 training
Jun 21 21:22:49   daemon   crit   pppd[248]: Clear IP addresses. Connection DOWN.
Jun 21 21:22:49   daemon   crit   pppd[248]: Clear IP addresses. PPP connection DOWN.
Jun 21 21:22:57   user   crit   kernel: ADSL G.992 started
Jun 21 21:23:01   user   crit   kernel: ADSL G.992 channel analysis
Jun 21 21:23:07   user   crit   kernel: ADSL G.992 message exchange
Jun 21 21:23:08   user   crit   kernel: ADSL link up, interleaved, us=605, ds=1247
Jun 21 21:23:19   daemon   crit   pppd[248]: PPP server detected.
Jun 21 21:23:34   daemon   crit   pppd[248]: PPP server detected.
Jun 21 21:23:34   daemon   crit   pppd[248]: PPP session established.
Jun 21 21:23:48   daemon   crit   pppd[248]: PPP server detected.
Jun 21 21:23:51   daemon   crit   pppd[248]: PPP server detected.
и так до бесконечности, пока не перезагружу модем:
Statistics -- ADSL
Mode:   ADSL2+
Line Coding:   Trellis On
Status:   No Defect
Link Power State:   L0
    Downstream   Upstream
SNR Margin (dB):   34.6    20.4
Attenuation (dB):   13.5    7.7
Output Power (dBm):   12.1    6.3
Attainable Rate (Kbps):   21611    1110
Rate (Kbps):   1247    605
MSGc (number of bytes in overhead channel message):   60    15
B (number of bytes in Mux Data Frame):   17    7
M (number of Mux Data Frames in FEC Data Frame):   1    8
T (Mux Data Frames over sync bytes):   2    7
R (number of check bytes in FEC Data Frame):   16    16
S (ratio of FEC over PMD Data Frame length):   0.4857    3.5955
L (number of bits in PMD Data Frame):   560    178
D (interleaver depth):   64    8
Delay (msec):   7    7
Super Frames:   219890    220315
Super Frame Errors:   0    2
RS Words:   29025574    3919850
RS Correctable Errors:   0    128
RS Uncorrectable Errors:   0    N/A
HEC Errors:   0    1
OCD Errors:   0    0
LCD Errors:   0    0
Total Cells:   10361905    4046661108
Data Cells:   1342295    196681031
Bit Errors:   0    5629055
Total ES:   0    3676
Total SES:   0    1195
Total UAS:   17    5292525
СообщениеДобавлено: Пн июн 22, 2009 22:02
а зачем ты включил ADSL2+, если у тебя максимальная скорость всего (Kbps): 1247 605
И обнови прошивку
СообщениеДобавлено: Вт июн 23, 2009 01:41
И обнови прошивку
прошивка последняя. ADSL2+ Enabled по-умолчанию. Какой будет режим лучше, при таких скоростях?
СообщениеДобавлено: Пт июн 26, 2009 16:07
И обнови прошивку
спасибо Sky-Net, что ответил. Решилось всё заменой на dsl-2540U/BRU/D. Уже 2ое суток работает на ура, незамечено ниодного разрыва. по меню бегает шустро. Интересно, что пинг уменьшился с 95 до 78.
Так что для меня эта тема закрыта.
